[geos-commits] [SCM] GEOS branch main updated. a31dd3557f0c1b9b7365de8e665d00492833a232
Tue May 6 09:49:49 PDT 2025
the project "GEOS".
The branch, main has been updated
       via  a31dd3557f0c1b9b7365de8e665d00492833a232 (commit)
      from  4b9a5ad063a7ea31662d6cd054a123b8b32099a6 (commit)
revisions in full, below.
commit a31dd3557f0c1b9b7365de8e665d00492833a232
Author: Aurele Ferotin <aurele.ferotin at icloud.com>
Date:   Tue May 6 18:49:30 2025 +0200
    Add GEOSGeoJSONWriter_setOutputDimension and GEOSGeoJSONWriter_getOutputDimension (#1260)
diff --git a/capi/geos_c.cpp b/capi/geos_c.cpp
index 19f340be3..87b72163c 100644
--- a/capi/geos_c.cpp
+++ b/capi/geos_c.cpp
@@ -1607,6 +1607,18 @@ extern "C" {
         return GEOSGeoJSONWriter_writeGeometry_r(handle, writer, g, indent);
+    void
+    GEOSGeoJSONWriter_setOutputDimension(GeoJSONWriter* writer, int dim)
+        GEOSGeoJSONWriter_setOutputDimension_r(handle, writer, dim);
+    int
+    GEOSGeoJSONWriter_getOutputDimension(GeoJSONWriter* writer)
+        return GEOSGeoJSONWriter_getOutputDimension_r(handle, writer);
 // Prepared Geometry
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index 30e7bb960..6d32e95ba 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -2201,6 +2201,17 @@ extern char GEOS_DLL *GEOSGeoJSONWriter_writeGeometry_r(
     const GEOSGeometry* g,
     int indent);
+/** \see GEOSGeoJSONWriter_setOutputDimension */
+extern void GEOS_DLL GEOSGeoJSONWriter_setOutputDimension_r(
+    GEOSContextHandle_t handle,
+    GEOSGeoJSONWriter *writer,
+    int dim);
+/** \see GEOSGeoJSONWriter_getOutputDimension */
+extern int  GEOS_DLL GEOSGeoJSONWriter_getOutputDimension_r(
+    GEOSGeoJSONWriter *writer);
 /** \see GEOSFree */
 extern void GEOS_DLL GEOSFree_r(
@@ -6223,6 +6234,27 @@ extern char GEOS_DLL *GEOSGeoJSONWriter_writeGeometry(
     int indent);
+* Set the output dimensionality of the writer. Either
+* 2 or 3 dimensions.
+* \param writer A \ref GEOSGeoJSONWriter.
+* \param dim The dimensionality desired.
+* \since 3.14
+extern void GEOS_DLL GEOSGeoJSONWriter_setOutputDimension(
+    int dim);
+* Reads the current output dimension from a \ref GEOSGeoJSONWriter.
+* \return The current dimension.
+* \since 3.14
+extern int  GEOS_DLL GEOSGeoJSONWriter_getOutputDimension(GEOSGeoJSONWriter *writer);
 #endif /* #ifndef GEOS_USE_ONLY_R_API */
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index 75536a98d..5c2080115 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -3781,6 +3781,22 @@ extern "C" {
+    void
+    GEOSGeoJSONWriter_setOutputDimension_r(GEOSContextHandle_t extHandle, GeoJSONWriter* writer, int dim)
+        execute(extHandle, [&]() {
+            writer->setOutputDimension(static_cast<uint8_t>(dim));
+    int
+    GEOSGeoJSONWriter_getOutputDimension_r(GEOSContextHandle_t extHandle, GeoJSONWriter* writer)
+        return execute(extHandle, -1, [&]() {
+            return writer->getOutputDimension();
diff --git a/tests/unit/capi/GEOSGeoJSONWriterTest.cpp b/tests/unit/capi/GEOSGeoJSONWriterTest.cpp
new file mode 100644
index 000000000..e9bfe5281
--- /dev/null
+++ b/tests/unit/capi/GEOSGeoJSONWriterTest.cpp
@@ -0,0 +1,79 @@
+#include <tut/tut.hpp>
+// geos
+#include <geos_c.h>
+#include "capi_test_utils.h"
+namespace tut {
+// Test Group
+struct test_geosgeojsonwriter_data : public capitest::utility {
+    test_geosgeojsonwriter_data() :
+        geojsonwriter_(GEOSGeoJSONWriter_create()),
+        geojson_(nullptr)
+    ~test_geosgeojsonwriter_data() {
+        GEOSGeoJSONWriter_destroy(geojsonwriter_);
+        GEOSFree(geojson_);
+    void
+    test_writer_geojson(std::string const& geojson)
+        test_writer_geojson(geojson, geojson);
+    void
+    test_writer_geojson(std::string const& geojson, std::string const& expected)
+        GEOSGeoJSONReader* reader = GEOSGeoJSONReader_create();
+        GEOSGeometry* geom1 = GEOSGeoJSONReader_readGeometry(reader, &geojson[0]);
+        ensure(nullptr != geom1);
+        char* wkt_c = GEOSGeoJSONWriter_writeGeometry(geojsonwriter_, geom1, -1);
+        std::string out(wkt_c);
+        free(wkt_c);
+        GEOSGeom_destroy(geom1);
+        GEOSGeoJSONReader_destroy(reader);
+        ensure_equals(out, expected);
+    GEOSGeoJSONWriter* geojsonwriter_;
+    char* geojson_;
+typedef test_group<test_geosgeojsonwriter_data> group;
+typedef group::object object;
+group test_geosgeojsonwriter("capi::GEOSGeoJSONWriter");
+// Check default output dimension 3
+template<>
+template<>
+void object::test<1>()
+    ensure_equals(GEOSGeoJSONWriter_getOutputDimension(geojsonwriter_), 3);
+    test_writer_geojson("{\"type\":\"Point\",\"coordinates\":[10.0,13.0]}");
+    test_writer_geojson("{\"type\":\"Point\",\"coordinates\":[10.0,13.0,3.0]}");
+// Check writer with output dimension 2
+template<>
+template<>
+void object::test<2>()
+    GEOSGeoJSONWriter_setOutputDimension(geojsonwriter_, 2);
+    ensure_equals("getOutputDimension_2", GEOSGeoJSONWriter_getOutputDimension(geojsonwriter_), 2);
+    test_writer_geojson("{\"type\":\"Point\",\"coordinates\":[10.0,13.0,3.0]}", "{\"type\":\"Point\",\"coordinates\":[10.0,13.0]}");
+} // namespace tut
Summary of changes:
 capi/geos_c.cpp                           | 12 +++++
 capi/geos_c.h.in                          | 32 +++++++++++++
 capi/geos_ts_c.cpp                        | 16 +++++++
 tests/unit/capi/GEOSGeoJSONWriterTest.cpp | 79 +++++++++++++++++++++++++++++++
 4 files changed, 139 insertions(+)
 create mode 100644 tests/unit/capi/GEOSGeoJSONWriterTest.cpp
hooks/post-receive
More information about the geos-commits mailing list
