[geos-commits] [SCM] GEOS branch main updated. 31399d845873fa03caee5141f7c355cbd0660c83
git at osgeo.org
git at osgeo.org
Fri May 9 13:33:15 PDT 2025
the project "GEOS".
The branch, main has been updated
via 31399d845873fa03caee5141f7c355cbd0660c83 (commit)
from a31dd3557f0c1b9b7365de8e665d00492833a232 (commit)
revisions in full, below.
commit 31399d845873fa03caee5141f7c355cbd0660c83
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri May 9 13:32:24 2025 -0700
Port LineDissolver from JTS
diff --git a/include/geos/dissolve/DissolveEdgeGraph.h b/include/geos/dissolve/DissolveEdgeGraph.h
new file mode 100644
index 000000000..0283c970f
--- /dev/null
+++ b/include/geos/dissolve/DissolveEdgeGraph.h
@@ -0,0 +1,68 @@
+ * GEOS - Geometry Engine Open Source
+ * http://geos.osgeo.org
+ * Copyright (c) 2025 Martin Davis
+ * Copyright (C) 2025 Paul Ramsey <pramsey at cleverelephant.ca>
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+#pragma once
+#include <geos/edgegraph/EdgeGraph.h>
+#include <geos/export.h>
+#include <geos/dissolve/DissolveHalfEdge.h>
+#include <deque>
+// Forward declarations
+namespace geos {
+namespace geom {
+ class CoordinateXYZM;
+namespace edgegraph {
+ class HalfEdge;
+namespace dissolve {
+ // class DissolveHalfEdge;
+namespace geos { // geos.
+namespace dissolve { // geos.dissolve
+class GEOS_DLL DissolveEdgeGraph : public edgegraph::EdgeGraph {
+private:
+ std::deque<DissolveHalfEdge> dhEdges;
+public:
+ edgegraph::HalfEdge* createEdge(const geom::CoordinateXYZM& p0) override;
+ DissolveEdgeGraph() {};
+ ~DissolveEdgeGraph() {};
+ * Disable copy construction and assignment. Needed to make this
+ * class compile under MSVC, because it has a vector<unique_ptr>
+ * as a member. (See https://stackoverflow.com/q/29565299)
+ DissolveEdgeGraph(const DissolveEdgeGraph&) = delete;
+ DissolveEdgeGraph& operator=(const DissolveEdgeGraph&) = delete;
+} // namespace geos.dissolve
diff --git a/include/geos/dissolve/DissolveHalfEdge.h b/include/geos/dissolve/DissolveHalfEdge.h
index 000000000..0168c199f
--- /dev/null
+++ b/include/geos/dissolve/DissolveHalfEdge.h
@@ -0,0 +1,69 @@
+#pragma once
+#include <geos/edgegraph/MarkHalfEdge.h>
+namespace geos {
+namespace geom {
+class GEOS_DLL DissolveHalfEdge : public edgegraph::MarkHalfEdge {
+private:
+ bool m_isStart = false;
+public:
+ DissolveHalfEdge(const geom::CoordinateXYZM& orig)
+ : edgegraph::MarkHalfEdge(orig)
+ , m_isStart(false)
+ * Tests whether this edge is the starting segment
+ * in a LineString being dissolved.
+ * @return true if this edge is a start segment
+ bool isStart();
+ * Sets this edge to be the start segment of an input LineString.
+ void setStart();
diff --git a/include/geos/dissolve/LineDissolver.h b/include/geos/dissolve/LineDissolver.h
index 000000000..cfae61f80
--- /dev/null
+++ b/include/geos/dissolve/LineDissolver.h
@@ -0,0 +1,195 @@
+#pragma once
+#include <geos/dissolve/DissolveEdgeGraph.h>
+// #include <memory>
+// #include <vector>
+// #include <stack>
+#include <geos/geom/LineString.h>
+namespace geos {
+ class DissolveHalfEdge;
+ class HalfEdge;
+namespace geom {
+ class CoordinateSequence;
+ class Geometry;
+ class GeometryFactory;
+ // class LineString;
+ * Dissolves the linear components
+ * from a collection of Geometry
+ * into a set of maximal-length LineString
+ * in which every unique segment appears once only.
+ * The output linestrings run between node vertices
+ * of the input, which are vertices which have
+ * either degree 1, or degree 3 or greater.
+ * Use cases for dissolving linear components
+ * include generalization
+ * (in particular, simplifying polygonal coverages),
+ * and visualization
+ * (in particular, avoiding symbology conflicts when
+ * depicting shared polygon boundaries).
+ * This class does **not** node the input lines.
+ * If there are line segments crossing in the input,
+ * they will still cross in the output.
+ * @author Martin Davis
+class GEOS_DLL LineDissolver {
+ using CoordinateSequence = geos::geom::CoordinateSequence;
+ using Geometry = geos::geom::Geometry;
+ using GeometryFactory = geos::geom::GeometryFactory;
+ using LineString = geos::geom::LineString;
+ using HalfEdge = geos::edgegraph::HalfEdge;
+private:
+ std::unique_ptr<Geometry> result;
+ const GeometryFactory* factory = nullptr;
+ DissolveEdgeGraph graph;
+ std::vector<std::unique_ptr<LineString>> lines;
+ std::stack<HalfEdge*> nodeEdgeStack;
+ DissolveHalfEdge* ringStartEdge = nullptr;
+ void computeResult();
+ void process(HalfEdge* e);
+ * Adds edges around this node to the stack.
+ * @param node
+ void stackEdges(HalfEdge* node);
+ * For each edge in stack
+ * (which must originate at a node)
+ * extracts the line it initiates.
+ void buildLines();
+ * Updates the tracked ringStartEdge
+ * if the given edge has a lower origin
+ * (using the standard Coordinate ordering).
+ * Identifying the lowest starting node meets two goals:
+ * * It ensures that isolated input rings are created using the original node and orientation
+ * * For isolated rings formed from multiple input linestrings,
+ * it provides a canonical node and orientation for the output
+ * (rather than essentially random, and thus hard to test).
+ * @param e
+ void updateRingStartEdge(DissolveHalfEdge* e);
+ * Builds a line starting from the given edge.
+ * The start edge origin is a node (valence = 1 or >= 3),
+ * unless it is part of a pure ring.
+ * A pure ring has no other incident lines.
+ * In this case the start edge may occur anywhere on the ring.
+ * The line is built up to the next node encountered,
+ * or until the start edge is re-encountered
+ * (which happens if the edges form a ring).
+ * @param eStart
+ void buildLine(HalfEdge* eStart);
+ void buildRing(HalfEdge* eStartRing);
+ void addLine(std::unique_ptr<CoordinateSequence>& cs);
+public:
+ LineDissolver() : result(nullptr) {};
+ * Dissolves the linear components in a geometry.
+ * @param g the geometry to dissolve
+ * @return the dissolved lines
+ static std::unique_ptr<Geometry> dissolve(const Geometry* g);
+ * Adds a Geometry to be dissolved.
+ * Any number of geometries may be added by calling this method multiple times.
+ * Any type of Geometry may be added. The constituent linework will be
+ * extracted to be dissolved.
+ * @param geometry geometry to be line-merged
+ void add(const Geometry* geometry);
+ * Adds a collection of Geometries to be processed. May be called multiple times.
+ * Any dimension of Geometry may be added; the constituent linework will be
+ * extracted.
+ * @param geometries the geometries to be line-merged
+ void add(std::vector<const Geometry*> geometries);
+ void add(const LineString* lineString);
+ * Gets the dissolved result as a MultiLineString.
+ std::unique_ptr<Geometry> getResult();
+ LineDissolver(const LineDissolver&) = delete;
+ LineDissolver& operator=(const LineDissolver&) = delete;
diff --git a/include/geos/edgegraph/EdgeGraph.h b/include/geos/edgegraph/EdgeGraph.h
index 23422a646..c6705bd15 100644
--- a/include/geos/edgegraph/EdgeGraph.h
+++ b/include/geos/edgegraph/EdgeGraph.h
@@ -67,7 +67,7 @@ protected:
* @param orig the origin location
* @return a new HalfEdge with the given origin
- HalfEdge* createEdge(const geom::CoordinateXYZM& orig);
+ virtual HalfEdge* createEdge(const geom::CoordinateXYZM& orig);
* Inserts an edge not already present into the graph.
@@ -86,6 +86,7 @@ public:
* Initialized
EdgeGraph() {};
+ virtual ~EdgeGraph() = default;
* Adds an edge between the coordinates orig and dest
diff --git a/src/dissolve/DissolveEdgeGraph.cpp b/src/dissolve/DissolveEdgeGraph.cpp
index 000000000..0789e8dce
--- /dev/null
+++ b/src/dissolve/DissolveEdgeGraph.cpp
@@ -0,0 +1,41 @@
+#include <geos/edgegraph/HalfEdge.h>
+#include <geos/geom/Coordinate.h>
+using geos::edgegraph::HalfEdge;
+using geos::geom::CoordinateXYZM;
+HalfEdge*
+DissolveEdgeGraph::createEdge(const CoordinateXYZM& p0)
+ dhEdges.emplace_back(p0);
+ return &(dhEdges.back());
diff --git a/src/dissolve/DissolveHalfEdge.cpp b/src/dissolve/DissolveHalfEdge.cpp
index 000000000..0b48b5391
--- /dev/null
+++ b/src/dissolve/DissolveHalfEdge.cpp
@@ -0,0 +1,46 @@
+bool
+DissolveHalfEdge::isStart()
+ return m_isStart;
+void
+DissolveHalfEdge::setStart()
+ m_isStart = true;
diff --git a/src/dissolve/LineDissolver.cpp b/src/dissolve/LineDissolver.cpp
index 000000000..2c036cc0d
--- /dev/null
+++ b/src/dissolve/LineDissolver.cpp
@@ -0,0 +1,275 @@
+#include <geos/dissolve/LineDissolver.h>
+#include <geos/geom/CoordinateList.h>
+#include <geos/geom/CoordinateSequence.h>
+#include <geos/geom/Geometry.h>
+#include <geos/geom/GeometryComponentFilter.h>
+#include <geos/geom/GeometryFactory.h>
+using namespace geos::geom;
+using geos::edgegraph::MarkHalfEdge;
+/* public */
+std::unique_ptr<Geometry>
+LineDissolver::dissolve(const Geometry* g)
+ LineDissolver d;
+ d.add(g);
+ return d.getResult();
+/* public */
+void
+LineDissolver::add(const Geometry* geom)
+ struct LineStringFilter : public GeometryComponentFilter {
+ LineDissolver *m_ld;
+ LineStringFilter(LineDissolver* ld) : m_ld(ld) {};
+ void filter_ro(const Geometry* g) override {
+ GeometryTypeId type = g->getGeometryTypeId();
+ if (type == GEOS_LINEARRING || type == GEOS_LINESTRING) {
+ m_ld->add(static_cast<const LineString*>(g));
+ LineStringFilter filter(this);
+ geom->apply_ro(&filter);
+/* public */
+void
+LineDissolver::add(std::vector<const Geometry*> geometries)
+ for (const Geometry* geom : geometries) {
+ add(geom);
+/* private */
+void
+LineDissolver::add(const LineString* lineString)
+ if (factory == nullptr) {
+ factory = lineString->getFactory();
+ const CoordinateSequence* seq = lineString->getCoordinatesRO();
+ bool doneStart = false;
+ for (std::size_t i = 1; i < seq->size(); i++) {
+ CoordinateXYZM orig, dest;
+ seq->getAt(i-1, orig);
+ seq->getAt(i, dest);
+ DissolveHalfEdge* e = static_cast<DissolveHalfEdge*>(graph.addEdge(orig, dest));
+ // skip zero-length edges
+ if (e == nullptr) continue;
+ * Record source initial segments, so that they can be reflected in output when needed
+ * (i.e. during formation of isolated rings)
+ if (! doneStart) {
+ e->setStart();
+ doneStart = true;
+/* public */
+LineDissolver::getResult()
+ if (result == nullptr)
+ computeResult();
+ return std::move(result);
+/* private */
+void
+LineDissolver::computeResult()
+ std::vector<const HalfEdge*> edges;
+ graph.getVertexEdges(edges);
+ for (const HalfEdge* ce : edges) {
+ HalfEdge* e = const_cast<HalfEdge*>(ce);
+ if (MarkHalfEdge::isMarked(e)) continue;
+ process(e);
+ result = factory->buildGeometry(std::move(lines));
+/* private */
+void
+LineDissolver::process(HalfEdge* e)
+ HalfEdge* eNode = e->prevNode();
+ // if edge is in a ring, just process this edge
+ if (eNode == nullptr)
+ eNode = e;
+ stackEdges(eNode);
+ // extract lines from node edges in stack
+ buildLines();
+/* private */
+void
+LineDissolver::stackEdges(HalfEdge* node)
+ HalfEdge* e = node;
+ do {
+ if (! MarkHalfEdge::isMarked(e))
+ nodeEdgeStack.push(e);
+ e = e->oNext();
+ } while (e != node);
+/* private */
+void
+LineDissolver::buildLines()
+ while (! nodeEdgeStack.empty()) {
+ HalfEdge* e = nodeEdgeStack.top();
+ nodeEdgeStack.pop();
+ continue;
+ buildLine(e);
+/* private */
+void
+LineDissolver::updateRingStartEdge(DissolveHalfEdge* e)
+ if (! e->isStart()) {
+ e = static_cast<DissolveHalfEdge*>(e->sym());
+ if (! e->isStart()) return;
+ // here e is known to be a start edge
+ if (ringStartEdge == nullptr) {
+ ringStartEdge = e;
+ return;
+ if (e->orig().compareTo(ringStartEdge->orig()) < 0) {
+/* private */
+void
+LineDissolver::buildLine(HalfEdge* eStart)
+ std::unique_ptr<CoordinateSequence> line(new CoordinateSequence(0, 4));
+ DissolveHalfEdge* e = static_cast<DissolveHalfEdge*>(eStart);
+ ringStartEdge = nullptr;
+ MarkHalfEdge::markBoth(e);
+ line->add(e->orig(), false);
+ // scan along the path until a node is found (if one exists)
+ while (e->sym()->degree() == 2) {
+ updateRingStartEdge(e);
+ DissolveHalfEdge* eNext = static_cast<DissolveHalfEdge*>(e->next());
+ // check if edges form a ring - if so, we're done
+ if (eNext == eStart) {
+ buildRing(ringStartEdge);
+ return;
+ // add point to line, and move to next edge
+ line->add(eNext->orig(), false);
+ e = eNext;
+ // add final node
+ line->add(e->dest(), false);
+ // queue up the final node edges
+ stackEdges(e->sym());
+ // store the scanned line
+ addLine(line);
+/* private */
+void
+LineDissolver::buildRing(HalfEdge* eStartRing)
+ HalfEdge* e = eStartRing;
+ // add first node
+ HalfEdge* eNext = e->next();
+ if (eNext == eStartRing)
+ break;
+ e = eNext;
+ // add final node
+ addLine(line);
+/* private */
+void
+LineDissolver::addLine(std::unique_ptr<CoordinateSequence>& cs)
+ auto ls = factory->createLineString(std::move(cs));
+ lines.emplace_back(ls.release());
diff --git a/src/operation/GeometryGraphOperation.cpp b/src/operation/GeometryGraphOperation.cpp
index 65b5c298c..41249ca0a 100644
--- a/src/operation/GeometryGraphOperation.cpp
+++ b/src/operation/GeometryGraphOperation.cpp
@@ -54,9 +54,9 @@ GeometryGraphOperation::GeometryGraphOperation(const Geometry* g0,
setComputationPrecision(pm1);
- arg[0] = std::make_unique<GeometryGraph>(0, g0,
+ arg[0] = std::make_unique<GeometryGraph>((uint8_t)0, g0,
algorithm::BoundaryNodeRule::getBoundaryOGCSFS());
- arg[1] = std::make_unique<GeometryGraph>(1, g1,
+ arg[1] = std::make_unique<GeometryGraph>((uint8_t)1, g1,
diff --git a/tests/unit/dissolve/LineDissolverTest.cpp b/tests/unit/dissolve/LineDissolverTest.cpp
index 000000000..7723aad08
--- /dev/null
+++ b/tests/unit/dissolve/LineDissolverTest.cpp
@@ -0,0 +1,214 @@
+// Test Suite for geos::coverage::LineDissolver class.
+#include <tut/tut.hpp>
+#include <utility.h>
+#include <string>
+#include <memory>
+// geos
+using geos::dissolve::LineDissolver;
+namespace tut {
+// Common data used by all tests
+struct test_linedissolver_data {
+ WKTReader r;
+ WKTWriter w;
+ test_linedissolver_data() {}
+ void checkDissolve(const std::string& wkt, const std::string& wkt_expected)
+ std::vector<std::string> wkt_vec;
+ wkt_vec.push_back(wkt);
+ checkDissolve(wkt_vec, wkt_expected);
+ void checkDissolve(std::vector<std::string>& wkt_vec, const std::string& wkt_expected)
+ std::vector<std::unique_ptr<Geometry>> geom_store;
+ std::vector<const Geometry*> geoms;
+ for (const std::string& wkt : wkt_vec) {
+ std::unique_ptr<Geometry> geom = r.read(wkt);
+ geoms.push_back(geom.get());
+ geom_store.emplace_back(geom.release());
+ std::unique_ptr<Geometry> geom_expected = r.read(wkt_expected);
+ checkDissolve(geoms, geom_expected.get());
+ std::vector<const Geometry*>& geoms,
+ const Geometry* geom_expected)
+ LineDissolver d;
+ d.add(geoms);
+ std::unique_ptr<Geometry> result = d.getResult();
+ ensure_equals_geometry(geom_expected, result.get());
+typedef test_group<test_linedissolver_data> group;
+typedef group::object object;
+group test_linedissolver_data("geos::dissolve::LineDissolver");
+// testSingleSegmentLine
+template<>
+template<>
+void object::test<1> ()
+ checkDissolve(
+ "LINESTRING (0 0, 1 1)",
+ "LINESTRING (0 0, 1 1)");
+// testTwoSegmentLine
+template<>
+template<>
+void object::test<2>()
+ checkDissolve(
+ "LINESTRING (0 0, 1 1, 2 2)",
+ "LINESTRING (0 0, 1 1, 2 2)");
+// testOverlappingTwoSegmentLines
+template<>
+template<>
+void object::test<3>()
+ std::vector<std::string> wkts = {
+ "LINESTRING (1 1, 2 2, 3 3)"};
+ checkDissolve(
+ wkts,
+ "LINESTRING (0 0, 1 1, 2 2, 3 3)");
+// testOverlappingLines3
+template<>
+template<>
+void object::test<4>()
+ "LINESTRING (1 1, 2 2, 3 3)",
+ "LINESTRING (1 1, 2 2, 2 0)" };
+ checkDissolve(wkts,
+ "MULTILINESTRING ((0 0, 1 1, 2 2), (2 0, 2 2), (2 2, 3 3))");
+// testDivergingLines
+template<>
+template<>
+void object::test<5>()
+ checkDissolve(
+ "MULTILINESTRING ((0 0, 1 0, 2 1), (0 0, 1 0, 2 0), (1 0, 2 1, 2 0, 3 0))",
+ "MULTILINESTRING ((0 0, 1 0), (1 0, 2 0), (1 0, 2 1, 2 0), (2 0, 3 0))");
+// testLollipop
+template<>
+template<>
+void object::test<6>()
+ checkDissolve(
+ "LINESTRING (0 0, 1 0, 2 0, 2 1, 1 0, 0 0)",
+ "MULTILINESTRING ((0 0, 1 0), (1 0, 2 0, 2 1, 1 0))");
+// testDisjointLines
+template<>
+template<>
+void object::test<7>()
+ checkDissolve(
+ "MULTILINESTRING ((0 0, 1 0, 2 1), (10 0, 11 0, 12 0))",
+ "MULTILINESTRING ((0 0, 1 0, 2 1), (10 0, 11 0, 12 0))");
+// testSingleLine
+template<>
+template<>
+void object::test<8>()
+ checkDissolve(
+ "MULTILINESTRING ((0 0, 1 0, 2 1))",
+ "LINESTRING (0 0, 1 0, 2 1)");
+// testOneSegmentY
+template<>
+template<>
+void object::test<9>()
+ checkDissolve(
+ "MULTILINESTRING ((0 0, 1 1, 2 2), (1 1, 1 2))",
+ "MULTILINESTRING ((0 0, 1 1), (1 1, 2 2), (1 1, 1 2))");
+// testTwoSegmentY
+template<>
+template<>
+void object::test<10>()
+ checkDissolve(
+ "MULTILINESTRING ((0 0, 9 9, 10 10, 11 11, 20 20), (10 10, 10 20))",
+ "MULTILINESTRING ((10 20, 10 10), (10 10, 9 9, 0 0), (10 10, 11 11, 20 20))");
+// testIsolatedRing
+template<>
+template<>
+void object::test<11>()
+ checkDissolve(
+ "LINESTRING (0 0, 1 1, 1 0, 0 0)",
+ "LINESTRING (0 0, 1 1, 1 0, 0 0)");
+// testIsolateRingFromMultipleLineStrings
+template<>
+template<>
+void object::test<12>()
+ checkDissolve(
+ "MULTILINESTRING ((0 0, 1 0, 1 1), (0 0, 0 1, 1 1))",
+ "LINESTRING (0 0, 0 1, 1 1, 1 0, 0 0)");
+* Shows that rings with incident lines are created with the correct node point.
+// testRingWithTail
+template<>
+template<>
+void object::test<13>()
+ checkDissolve(
+ "MULTILINESTRING ((0 0, 1 0, 1 1), (0 0, 0 1, 1 1), (1 0, 2 0))",
+ "MULTILINESTRING ((1 0, 0 0, 0 1, 1 1, 1 0), (1 0, 2 0))");
+// testZeroLengthStartSegment
+template<>
+template<>
+void object::test<14>()
+ checkDissolve(
+ "MULTILINESTRING ((0 0, 0 0, 2 1))",
+ "LINESTRING (0 0, 2 1)");
+} // namespace tut
Summary of changes:
include/geos/dissolve/DissolveEdgeGraph.h | 68 +++++
include/geos/dissolve/DissolveHalfEdge.h | 69 ++++++
include/geos/dissolve/LineDissolver.h | 195 +++++++++++++++
include/geos/edgegraph/EdgeGraph.h | 3 +-
.../EdgeKey.cpp => dissolve/DissolveEdgeGraph.cpp} | 27 +-
src/dissolve/DissolveHalfEdge.cpp | 46 ++++
src/dissolve/LineDissolver.cpp | 275 +++++++++++++++++++++
src/operation/GeometryGraphOperation.cpp | 4 +-
tests/unit/dissolve/LineDissolverTest.cpp | 214 ++++++++++++++++
9 files changed, 892 insertions(+), 9 deletions(-)
create mode 100644 include/geos/dissolve/DissolveEdgeGraph.h
create mode 100644 include/geos/dissolve/DissolveHalfEdge.h
create mode 100644 include/geos/dissolve/LineDissolver.h
copy src/{operation/overlayng/EdgeKey.cpp => dissolve/DissolveEdgeGraph.cpp} (50%)
create mode 100644 src/dissolve/DissolveHalfEdge.cpp
create mode 100644 src/dissolve/LineDissolver.cpp
create mode 100644 tests/unit/dissolve/LineDissolverTest.cpp
hooks/post-receive
More information about the geos-commits
