[geos-commits] [SCM] GEOS branch main updated. cc9b437c994a0e68b4d04b233e0e10eb015e1390
    git at osgeo.org
    git at osgeo.org
    Mon May 26 13:36:30 PDT 2025
the project "GEOS".
The branch, main has been updated
       via  cc9b437c994a0e68b4d04b233e0e10eb015e1390 (commit)
      from  31399d845873fa03caee5141f7c355cbd0660c83 (commit)
revisions in full, below.
commit cc9b437c994a0e68b4d04b233e0e10eb015e1390
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Mon May 26 13:36:05 2025 -0700
    Fix DepthSegment comparison logic (#1266)
diff --git a/src/operation/buffer/SubgraphDepthLocater.cpp b/src/operation/buffer/SubgraphDepthLocater.cpp
index 4fc9d578a..2941c020a 100644
--- a/src/operation/buffer/SubgraphDepthLocater.cpp
+++ b/src/operation/buffer/SubgraphDepthLocater.cpp
@@ -70,8 +70,35 @@ public:
-     * Defines a comparison operation on DepthSegments
-     * which orders them left to right
+     * Compares a point to a segment for left/right position,
+     * as long as the point lies within the segment Y extent.
+     * Otherwise the point is not comparable.
+     * If the point is not comparable or it lies on the segment
+     * returns 0.
+    int
+    comparePointInYExtent(const Coordinate& p, const LineSegment& seg) const
+        //-- if point is comparable to segment
+        if (p.y >= seg.minY() && p.y <= seg.maxY()) {
+          //-- flip sign, since orientation and order relation are opposite
+          int orient = seg.orientationIndex(p);
+          switch (orient) {
+          case Orientation::LEFT: return -1;
+          case Orientation::RIGHT: return 1;
+          //-- collinear, so indeterminate
+        //-- not computable
+        return 0;
+     * A comparison operation which orders segments left to right
+     * along some horizontal line.
+     * If segments don't touch the same line,
+     * or touch at the same point,
+     * they are compared in their Y extent.
      * <pre>
      * DS1 < DS2   if   DS1.seg is left of DS2.seg
@@ -84,47 +111,62 @@ public:
     int
     compareTo(const DepthSegment& other) const
-         * If segment envelopes do not overlap, then
-         * can use standard segment lexicographic ordering.
+         * If segments are disjoint in X, X values provides ordering.
+         * This is the most common case.
-        if (upwardSeg.minX() >= other.upwardSeg.maxX()
-            || upwardSeg.maxX() <= other.upwardSeg.minX()
-            || upwardSeg.minY() >= other.upwardSeg.maxY()
-            || upwardSeg.maxY() <= other.upwardSeg.minY()) {
-            return upwardSeg.compareTo(other.upwardSeg);
+        if (upwardSeg.minX() > other.upwardSeg.maxX())
+            return 1;
+        if (upwardSeg.maxX() < other.upwardSeg.minX())
+            return -1;
-         * Otherwise if envelopes overlap, use relative segment orientation.
-         * Collinear segments should be evaluated by previous logic
+         * The segments Y ranges should intersect since they lie on same stabbing line.
+         * But check for this and provide a result based on Y ordering
-        int orientIndex = upwardSeg.orientationIndex(&(other.upwardSeg));
-         * If comparison between this and other is indeterminate,
-         * try the opposite call order.
-         * orientationIndex value is 1 if this is left of other,
-         * so have to flip sign to get proper comparison value of
-         * -1 if this is leftmost
+        if (upwardSeg.minY() > other.upwardSeg.maxY())
+            return 1;
+        if (upwardSeg.maxY() < other.upwardSeg.minY())
+            return -1;
+         * Check if some segment point is left or right
+         * of the other segment in its Y extent.
-        if(orientIndex == 0) {
-            orientIndex = -1 * other.upwardSeg.orientationIndex(&upwardSeg);
+        int comp00 = comparePointInYExtent(upwardSeg.p0, other.upwardSeg);
+        if (comp00 != 0) return comp00;
+        int comp01 = comparePointInYExtent(upwardSeg.p1, other.upwardSeg);
+        if (comp01 != 0) return comp01;
+        //-- negate orientation for other/this checks
+        int comp10 = -comparePointInYExtent(other.upwardSeg.p0, upwardSeg);
+        if (comp10 != 0) return comp10;
+        int comp11 = -comparePointInYExtent(other.upwardSeg.p1, upwardSeg);
+        if (comp11 != 0) return comp11;
+         * If point checks in Y range are indeterminate,
+         * segments touch at a point
+         * and lie above and below that point, or are horizontal.
+         * Order according to their Y values.
+         * (The ordering in this case doesn't matter, it just has to be consistent)
+        if (upwardSeg.maxY() > other.upwardSeg.maxY())
+            return 1;
+        if (upwardSeg.maxY() < other.upwardSeg.maxY())
+            return -1;
+         * If both are horizontal order by X
+        if (upwardSeg.isHorizontal() && other.upwardSeg.isHorizontal()) {
+            if (upwardSeg.minX() < other.upwardSeg.minX())
+                return -1;
+            if (upwardSeg.minX() > other.upwardSeg.minX())
+                return 1;
-        // if orientation is determinate, return it
-        if(orientIndex != 0) {
-            return orientIndex;
-         * If segment envelopes overlap and they are collinear,
-         * since segments do not cross they must be equal.
         // assert: segments are equal
-        return 0;
+        return 0;    }
 struct DepthSegmentLessThan {
diff --git a/tests/unit/operation/buffer/BufferOpTest.cpp b/tests/unit/operation/buffer/BufferOpTest.cpp
index 520256585..b51914ca8 100644
--- a/tests/unit/operation/buffer/BufferOpTest.cpp
+++ b/tests/unit/operation/buffer/BufferOpTest.cpp
@@ -610,4 +610,17 @@ void object::test<27>
 "POLYGON ((48267.2218198241 -49049.37231112561, 44430.1 -55696.500291383236, 44430.1 -55107.58561879013, 44506.96594366424 -54974.50014155032, 44507.05088958367 -54974.309530288774, 44507.09442572395 -54974.10543945913, 44507.09465615313 -54973.896756903174, 44507.05157083636 -54973.69257042533, 44506.96704607295 -54973.50177203271, 44430.1 -54839.73314639927, 44430.1 -51569.2, 44430.08071956347 -51569.00457958696, 44430.02362172434 -51568.81669475566, 44429.93090822513 -51568.64359050924, 44429.80615417933 -51568.49194189856, 42172.42282165639 -49317.178566110095, 48267.2218198241 -49049.37231112561))");
+// testBufferByZeroKeepsAllElements
+// Test a buffer-by-zero case which revealed a bug in the DeptSegment comparator.
+// See https://github.com/locationtech/jts/issues/1131
+template<>
+template<>
+void object::test<28>
+    std::string wkt = "MULTIPOLYGON (((24 95.239, 24 96, 24 99, 24.816 99, 24 95.239)), ((3 90, 3 93, 3 96, 3 99, 21 99, 21 96, 21 93, 21 90, 3 90)))";
+    checkBuffer(wkt, 0, 0.01,
+"MULTIPOLYGON (((24 95.239, 24 96, 24 99, 24.816 99, 24 95.239)), ((3 90, 3 93, 3 96, 3 99, 21 99, 21 96, 21 93, 21 90, 3 90)))");
 } // namespace tut
Summary of changes:
 src/operation/buffer/SubgraphDepthLocater.cpp | 112 ++++++++++++++++++--------
 tests/unit/operation/buffer/BufferOpTest.cpp  |  13 +++
 2 files changed, 90 insertions(+), 35 deletions(-)
hooks/post-receive
More information about the geos-commits
