[geos-commits] [SCM] GEOS branch main updated. 3ae49122f47bae55819b0ab1cfb1a9d2dfa9d6e3
    git at osgeo.org
    git at osgeo.org
    Thu May 29 10:36:11 PDT 2025
the project "GEOS".
The branch, main has been updated
       via  3ae49122f47bae55819b0ab1cfb1a9d2dfa9d6e3 (commit)
      from  c66d7231d700b075d4644322de4e0b8e0612493d (commit)
revisions in full, below.
commit 3ae49122f47bae55819b0ab1cfb1a9d2dfa9d6e3
Author: Even Rouault <even.rouault at spatialys.com>
Date:   Thu May 29 18:35:45 2025 +0100
    Typo fixes in code comments (#1267)
diff --git a/include/geos/edgegraph/HalfEdge.h b/include/geos/edgegraph/HalfEdge.h
index d66d98493..20662f7be 100644
--- a/include/geos/edgegraph/HalfEdge.h
+++ b/include/geos/edgegraph/HalfEdge.h
@@ -126,7 +126,7 @@ public:
     virtual ~HalfEdge() {};
-    * Creates a HalfEge pair, using the HalfEdge type of the graph subclass.
+    * Creates a HalfEdge pair, using the HalfEdge type of the graph subclass.
     * @param p0 a vertex coordinate
     * @param p1 a vertex coordinate
diff --git a/include/geos/geom/Geometry.h b/include/geos/geom/Geometry.h
index 3d052d518..36e64f042 100644
--- a/include/geos/geom/Geometry.h
+++ b/include/geos/geom/Geometry.h
@@ -829,7 +829,7 @@ public:
     /** Returns the minimum distance between this Geometry and the Geometry g
      * @param g the Geometry to calculate distance to
-     * @return the distance in cartesian units
+     * @return the distance in Cartesian units
     virtual double distance(const Geometry* g) const;
diff --git a/include/geos/io/WKBWriter.h b/include/geos/io/WKBWriter.h
index 90b2fbc67..ebd37b04b 100644
--- a/include/geos/io/WKBWriter.h
+++ b/include/geos/io/WKBWriter.h
@@ -88,7 +88,7 @@ public:
      * for 2D geometries. Default since GEOS 3.12 is 4.
      * @param bo output byte order - default to native machine byte order.
      * Legal values include 0 (big endian/xdr) and 1 (little endian/ndr).
-     * @param incudeSRID true if SRID should be included in WKB (an
+     * @param includeSRID true if SRID should be included in WKB (an
      * extension).
     WKBWriter(
diff --git a/include/geos/operation/relate/RelateOp.h b/include/geos/operation/relate/RelateOp.h
index 86749ab5d..c72cafb3c 100644
--- a/include/geos/operation/relate/RelateOp.h
+++ b/include/geos/operation/relate/RelateOp.h
@@ -65,7 +65,7 @@ public:
      * @param a a Geometry to test. Ownership left to caller.
      * @param b a Geometry to test. Ownership left to caller.
-     * @return the IntersectonMatrix for the spatial relationship
+     * @return the IntersectionMatrix for the spatial relationship
      *         between the geometries. Ownership transferred.
     static std::unique_ptr<geom::IntersectionMatrix> relate(
@@ -81,7 +81,7 @@ public:
      * @param boundaryNodeRule the Boundary Node Rule to use.
Summary of changes:
 include/geos/edgegraph/HalfEdge.h        | 2 +-
 include/geos/geom/Geometry.h             | 2 +-
 include/geos/io/WKBWriter.h              | 2 +-
 include/geos/operation/relate/RelateOp.h | 4 ++--
 4 files changed, 5 insertions(+), 5 deletions(-)
hooks/post-receive
More information about the geos-commits
