[geos-commits] [SCM] GEOS branch main updated. cd8275eb1f6e81885cf7483ed4f5c24df6c12512
    git at osgeo.org
    git at osgeo.org
    Thu May 29 15:28:11 PDT 2025
the project "GEOS".
The branch, main has been updated
       via  cd8275eb1f6e81885cf7483ed4f5c24df6c12512 (commit)
      from  3ae49122f47bae55819b0ab1cfb1a9d2dfa9d6e3 (commit)
revisions in full, below.
commit cd8275eb1f6e81885cf7483ed4f5c24df6c12512
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu May 29 15:27:10 2025 -0700
    Add CAPI for CoverageCleaner
diff --git a/capi/geos_c.cpp b/capi/geos_c.cpp
index 87b72163c..9bd1068ba 100644
--- a/capi/geos_c.cpp
+++ b/capi/geos_c.cpp
@@ -52,12 +52,20 @@
 #define GEOSGeoJSONReader geos::io::GeoJSONReader
 #define GEOSGeoJSONWriter geos::io::GeoJSONWriter
+// Implementation struct for the GEOSCoverageCleanParams object
+typedef struct {
+    double snappingDistance;
+    int    overlapMergeStrategy;
+    double gapMaximumWidth;
+} GEOSCoverageCleanParams;
 // Implementation struct for the GEOSMakeValidParams object
 typedef struct {
     int method;
     int keepCollapsed;
 } GEOSMakeValidParams;
 #include "geos_c.h"
 /// Define this if you want operations triggering Exceptions to
@@ -1007,6 +1015,60 @@ extern "C" {
         return GEOSMakeValidWithParams_r(handle, g, params);
+    GEOSCoverageCleanParams*
+    GEOSCoverageCleanParams_create()
+        return GEOSCoverageCleanParams_create_r(handle);
+    void
+    GEOSCoverageCleanParams_destroy(
+        GEOSCoverageCleanParams* params)
+        return GEOSCoverageCleanParams_destroy_r(handle, params);
+    int
+    GEOSCoverageCleanParams_setSnappingDistance(
+        GEOSCoverageCleanParams* params, double snappingDistance)
+        return GEOSCoverageCleanParams_setSnappingDistance_r(
+            handle, params, snappingDistance);
+    int
+    GEOSCoverageCleanParams_setGapMaximumWidth(
+        GEOSCoverageCleanParams* params, double gapMaximumWidth)
+        return GEOSCoverageCleanParams_setGapMaximumWidth_r(
+            handle, params, gapMaximumWidth);
+    int
+    GEOSCoverageCleanParams_setOverlapMergeStrategy(
+        GEOSCoverageCleanParams* params, int overlapMergeStrategy)
+        return GEOSCoverageCleanParams_setOverlapMergeStrategy_r(
+            handle, params, overlapMergeStrategy);
+    GEOSGeometry *
+    GEOSCoverageCleanWithParams(
+        const GEOSGeometry* input,
+        const GEOSCoverageCleanParams* params)
+        return GEOSCoverageCleanWithParams_r(
+            handle, input, params);
+    GEOSGeometry *
+    GEOSCoverageClean(
+        const GEOSGeometry * input)
+        return GEOSCoverageClean_r(
+            handle, input);
     Geometry*
     GEOSRemoveRepeatedPoints(
         const Geometry* g,
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index 6d32e95ba..39671cc69 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -168,6 +168,13 @@ typedef struct GEOSSTRtree_t GEOSSTRtree;
 typedef struct GEOSBufParams_t GEOSBufferParams;
+* Parameter object for coverage cleaning options.
+* \see GEOSCoverageCleanParams_create()
+* \see GEOSCoverageCleanParams_destroy()
+typedef struct GEOSCoverageCleanParams_t GEOSCoverageCleanParams;
 * Parameter object for validity enforcement.
 * \see GEOSMakeValidParams_create()
@@ -879,6 +886,51 @@ GEOSCoverageSimplifyVW_r(
     double tolerance,
     int preserveBoundary);
+/** \see GEOSCoverageCleanParams_create */
+extern GEOSCoverageCleanParams GEOS_DLL *
+GEOSCoverageCleanParams_create_r(
+    GEOSContextHandle_t extHandle);
+/** \see GEOSCoverageCleanParams_destroy */
+extern void GEOS_DLL
+GEOSCoverageCleanParams_destroy_r(
+    GEOSContextHandle_t extHandle,
+    GEOSCoverageCleanParams* params);
+/** \see GEOSCoverageCleanParams_setSnappingDistance */
+extern int GEOS_DLL
+GEOSCoverageCleanParams_setSnappingDistance_r(
+    double snappingDistance);
+/** \see GEOSCoverageCleanParams_setGapMaximumWidth */
+GEOSCoverageCleanParams_setGapMaximumWidth_r(
+    double gapMaximumWidth);
+/** \see GEOSCoverageCleanParams_setOverlapMergeStrategy */
+GEOSCoverageCleanParams_setOverlapMergeStrategy_r(
+    int overlapMergeStrategy);
+/** \see GEOSCoverageCleanWithParams */
+extern GEOSGeometry GEOS_DLL *
+GEOSCoverageCleanWithParams_r(
+    const GEOSCoverageCleanParams* params);
+/** \see GEOSCoverageClean */
+GEOSCoverageClean_r(
+    const GEOSGeometry* input);
 /* ========= Topology Operations ========= */
 /** \see GEOSEnvelope */
@@ -4269,8 +4321,154 @@ extern GEOSGeometry GEOS_DLL * GEOSCoverageSimplifyVW(
     double tolerance,
+* Create a default GEOSCoverageCleanParams object for controlling
+* the way invalid polygon interactions are repaird by \ref GEOSCoverageCleanWithParams.
+* \return A newly allocated GEOSCoverageCleanParams. NULL on exception.
+* Caller is responsible for freeing with GEOSCoverageCleanParams_destroy().
+* \since 3.14
+GEOSCoverageCleanParams_create();
+* Destroy a GEOSCoverageCleanParams and free all associated memory.
+* \param params The object to destroy.
+* \since 3.14
+GEOSCoverageCleanParams_destroy(
+* Snapping to nearby vertices and line segment snapping
+* is used to improve noding robustness
+* and eliminate small errors in an efficient way,
+* By default this uses a very small snapping distance
+* based on the extent of the input data.
+* The snapping distance may be specified explicitly.
+* This can reduce the number of overlaps and gaps that need to be merged,
+* and reduce the risk of spikes formed by merging gaps.
+* However, a large snapping distance may introduce undesirable
+* data alteration.
+* A distance of zero prevents snapping from being used.
+* \see geos::coverage::CoverageCleaner::setSnappingDistance
+* \param params The GEOSCoverageCleanParams to operate on
+* \param snappingDistance Set to 0.0 for no snapping.
+* \return 0 on exception, 1 on success.
+* \since 3.14
+GEOSCoverageCleanParams_setSnappingDistance(
+    GEOSCoverageCleanParams *params,
+* Gaps which are wider than a given distance are merged with an adjacent polygon.
+* Polygon width is determined as twice the radius of the MaximumInscribedCircle
+* of the gap polygon.
+* Gaps are merged with the adjacent polygon with longest shared border.
+* Empty holes in input polygons are treated as gaps, and may be filled in.
+* Gaps which are not fully enclosed ("inlets") are not removed.
+* The width of a gap is twice the radius of the Maximum Inscribed Circle in the gap polygon,
+* A width of zero prevents gaps from being merged.
+* \see geos::coverage::CoverageCleaner::setGapMaximumWidth
+* \param gapMaximumWidth Set to 0.0 for no snapping.
+* \since 3.14
+GEOSCoverageCleanParams_setGapMaximumWidth(
+* Overlap repair strategies.
+* \see GEOSCoverageCleanParams_setOverlapMergeStrategy
+enum GEOSOverlapMerge {
+    /** Merge strategy that chooses polygon with longest common border */
+    GEOS_MERGE_LONGEST_BORDER = 0,
+    /** Merge strategy that chooses polygon with maximum area */
+    GEOS_MERGE_MAX_AREA       = 1,
+    /** Merge strategy that chooses polygon with minimum area */
+    GEOS_MERGE_MIN_AREA       = 2,
+    /** Merge strategy that chooses polygon with smallest input index */
+    GEOS_MERGE_MIN_INDEX      = 3
+* Sets the overlap merge strategy to use, using one from \ref GEOSOverlapMerge.
+* Overlaps are merged with an adjacent polygon chosen according to a specified merge strategy.
+* The supported strategies are:
+*   * **Longest Border**: (default) merge with the polygon with longest shared border (GEOS_MERGE_LONGEST_BORDER.)
+*   * **Maximum/Minimum Area**: merge with the polygon with largest or smallest area (GEOS_MERGE_MAX_AREA, GEOS_MERGE_MIN_AREA.)
+*   * **Minimum Index**: merge with the polygon with the lowest index in the input array (GEOS_MERGE_MIN_INDEX.)
+* This allows sorting the input according to some criteria to provide a priority
+* for merging gaps.
+* The default is GEOS_MERGE_LONGEST_BORDER.
+* \param overlapMergeStrategy One of \ref GEOSOverlapMerge strategies
+* \since 3.14
+GEOSCoverageCleanParams_setOverlapMergeStrategy(
+* Operates on a list of polygonal geometry with "exactly matching"
+* edge geometry, to fix cases where the geometry does not in fact
+* exactly match.
+* The input is a collection of polygons, and the output is a collection
+* with the same number of cleaned polygons, in the same order as
+* the input. Polygons that have collapsed during cleaning will be returned
+* as empties.
+* \param input The dirty polygonal coverage,
+*        stored in a geometry collection. All members must be POLYGON
+*        or MULTIPOLYGON.
+* \param params A GEOSCoverageCleanParams to control the options
+*        used in cleaning the coverage.
+* \return A collection containing the cleaned geometries, or null
+*         on error. Where cleaning has resulted in polygon collapse,
+*         an EMPTY geometry will be returned as part of the collection.
+* \since 3.14
+GEOSCoverageCleanWithParams(
+GEOSCoverageClean(
 /* ========== Construction Operations ========== */
 /** @name Geometric Constructions
 * Functions for computing geometric constructions.
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index 5c2080115..27ee5b812 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -28,9 +28,10 @@
 #include <geos/algorithm/distance/DiscreteFrechetDistance.h>
 #include <geos/algorithm/hull/ConcaveHull.h>
 #include <geos/algorithm/hull/ConcaveHullOfPolygons.h>
-#include <geos/coverage/CoverageValidator.h>
+#include <geos/coverage/CoverageCleaner.h>
 #include <geos/coverage/CoverageSimplifier.h>
 #include <geos/coverage/CoverageUnion.h>
+#include <geos/coverage/CoverageValidator.h>
 #include <geos/geom/CircularString.h>
 #include <geos/geom/CompoundCurve.h>
 #include <geos/geom/Coordinate.h>
@@ -139,8 +140,8 @@
 // violations.
 #define GEOSGeometry geos::geom::Geometry
 #define GEOSPreparedGeometry geos::geom::prep::PreparedGeometry
-#define GEOSCoordSequence geos::geom::CoordinateSequence
 #define GEOSClusterInfo geos::operation::cluster::Clusters
+#define GEOSCoordSequence geos::geom::CoordinateSequence
 #define GEOSBufferParams geos::operation::buffer::BufferParameters
 #define GEOSSTRtree geos::index::strtree::TemplateSTRtree<void*>
 #define GEOSWKTReader geos::io::WKTReader
@@ -150,6 +151,13 @@
+typedef struct {
 typedef struct {
     int method;
@@ -2331,6 +2339,10 @@ extern "C" {
+ * Make Valid
     Geometry*
     GEOSMakeValid_r(GEOSContextHandle_t extHandle, const Geometry* g)
@@ -4538,6 +4550,105 @@ extern "C" {
+ * Coverage Cleaner
+    GEOSCoverageCleanParams_create_r(GEOSContextHandle_t extHandle)
+        return execute(extHandle, [&]() {
+            GEOSCoverageCleanParams* p = new GEOSCoverageCleanParams();
+            p->overlapMergeStrategy = geos::coverage::CoverageCleaner::MERGE_LONGEST_BORDER;
+            p->snappingDistance = -1.0;
+            p->gapMaximumWidth = 0.0;
+            return p;
+    void
+    GEOSCoverageCleanParams_destroy_r(GEOSContextHandle_t extHandle,
+        (void)extHandle;
+        delete params;
+    int
+    GEOSCoverageCleanParams_setSnappingDistance_r(GEOSContextHandle_t extHandle,
+        return execute(extHandle, 0, [&]() {
+            params->snappingDistance = snappingDistance;
+            return 1;
+    int
+    GEOSCoverageCleanParams_setGapMaximumWidth_r(GEOSContextHandle_t extHandle,
+            params->gapMaximumWidth = gapMaximumWidth;
+            return 1;
+    int
+    GEOSCoverageCleanParams_setOverlapMergeStrategy_r(GEOSContextHandle_t extHandle,
+            if (   overlapMergeStrategy != geos::coverage::CoverageCleaner::MERGE_LONGEST_BORDER
+                && overlapMergeStrategy != geos::coverage::CoverageCleaner::MERGE_MAX_AREA
+                && overlapMergeStrategy != geos::coverage::CoverageCleaner::MERGE_MIN_AREA
+                && overlapMergeStrategy != geos::coverage::CoverageCleaner::MERGE_MIN_INDEX)
+                extHandle->ERROR_MESSAGE("GEOSCoverageCleanParams_setOverlapMergeStrategy: Invalid overlapMergeStrategy");
+                return 0;
+            params->overlapMergeStrategy = overlapMergeStrategy;
+            return 1;
+    GEOSGeometry *
+    GEOSCoverageCleanWithParams_r(GEOSContextHandle_t extHandle,
+        using geos::coverage::CoverageCleaner;
+        return execute(extHandle, [&]() -> Geometry* {
+            const GeometryCollection* col = dynamic_cast<const GeometryCollection*>(input);
+            if (!col)
+                return nullptr;
+            std::vector<const Geometry*> coverage;
+            for (const auto& g : *col) {
+                coverage.push_back(g.get());
+            geos::coverage::CoverageCleaner c(coverage);
+            if (params) {
+                c.setSnappingDistance(params->snappingDistance);
+                c.setGapMaximumWidth(params->gapMaximumWidth);
+                c.setOverlapMergeStrategy(params->overlapMergeStrategy);
+            c.clean();
+            auto cleanCov = c.getResult();
+            const GeometryFactory* gf = input->getFactory();
+            std::unique_ptr<Geometry> r = gf->createGeometryCollection(std::move(cleanCov));
+            return r.release();
+    GEOSGeometry *
+    GEOSCoverageClean_r(GEOSContextHandle_t extHandle,
+        return GEOSCoverageCleanWithParams_r(extHandle, input, nullptr);
 } /* extern "C" */
diff --git a/tests/unit/coverage/CoverageCleanerTest.cpp b/tests/unit/coverage/CoverageCleanerTest.cpp
index 5eb141be1..7256f5f72 100644
--- a/tests/unit/coverage/CoverageCleanerTest.cpp
+++ b/tests/unit/coverage/CoverageCleanerTest.cpp
@@ -420,6 +420,27 @@ void object::test<17>()
+// Tests that a collapsed polygon due to snapping is returned as EMPTY
+template<>
+template<>
+void object::test<18>()
+    checkCleanSnap({
+        "POLYGON ((1 1, 1 9, 6 5, 9 1, 1 1))",
+        "POLYGON ((9 1, 6 5.1, 1 9, 9 9, 9 1))",
+        "POLYGON ((9 1, 6 5, 1 9, 6 5.1, 9 1))"},
+        1,
+        "POLYGON ((6 5, 9 1, 1 1, 1 9, 6 5))",
+        "POLYGON ((9 9, 9 1, 6 5, 1 9, 9 9))",
+        "POLYGON EMPTY"
 } // namespace tut
Summary of changes:
 capi/geos_c.cpp                             |  62 +++++++++
 capi/geos_c.h.in                            | 198 ++++++++++++++++++++++++++++
 capi/geos_ts_c.cpp                          | 115 +++++++++++++++-
 tests/unit/coverage/CoverageCleanerTest.cpp |  21 +++
 4 files changed, 394 insertions(+), 2 deletions(-)
hooks/post-receive
More information about the geos-commits
