[geos-commits] [SCM] GEOS branch main updated. 178183a7d89b823b7c166573ba3781288528fe06
git at osgeo.org
git at osgeo.org
Fri May 30 15:22:16 PDT 2025
the project "GEOS".
The branch, main has been updated
via 178183a7d89b823b7c166573ba3781288528fe06 (commit)
from cd8275eb1f6e81885cf7483ed4f5c24df6c12512 (commit)
revisions in full, below.
commit 178183a7d89b823b7c166573ba3781288528fe06
Author: Martin Davis <mtnclimb at gmail.com>
Date: Fri May 30 15:21:39 2025 -0700
Change CoverageGapFinder to return polygons
diff --git a/src/coverage/CoverageGapFinder.cpp b/src/coverage/CoverageGapFinder.cpp
index b4de0fc50..3cd6b6583 100644
--- a/src/coverage/CoverageGapFinder.cpp
+++ b/src/coverage/CoverageGapFinder.cpp
@@ -47,7 +47,6 @@ CoverageGapFinder::findGaps(std::vector<const Geometry*>& coverage, double gapWi
return finder.findGaps(gapWidth);
/* public */
std::unique_ptr<Geometry>
CoverageGapFinder::findGaps(double gapWidth)
@@ -56,21 +55,21 @@ CoverageGapFinder::findGaps(double gapWidth)
std::vector<const Polygon*> polygons;
PolygonExtracter::getPolygons(*geomUnion, polygons);
- std::vector<std::unique_ptr<LineString>> gapLines;
+ std::vector<std::unique_ptr<Geometry>> gapLines;
for (const Polygon* poly : polygons) {
for (std::size_t i = 0; i < poly->getNumInteriorRing(); i++) {
const LinearRing* hole = poly->getInteriorRingN(i);
if (isGap(hole, gapWidth)) {
- auto pts = hole->getCoordinatesRO()->clone();
- auto ls = geomUnion->getFactory()->createLineString(std::move(pts));
- gapLines.emplace_back(ls.release());
+ //auto pts = hole->getCoordinatesRO()->clone();
+ //auto ls = geomUnion->getFactory()->createLineString(std::move(pts));
+ auto polygon = geomUnion->getFactory()->createPolygon(hole->clone());
+ gapLines.emplace_back(polygon.release());
return geomUnion->getFactory()->buildGeometry(std::move(gapLines));
/* private */
bool
CoverageGapFinder::isGap(const LinearRing* hole, double gapWidth)
diff --git a/tests/unit/coverage/CoverageGapFinderTest.cpp b/tests/unit/coverage/CoverageGapFinderTest.cpp
index 5a345e18a..2c25c4c2c 100644
--- a/tests/unit/coverage/CoverageGapFinderTest.cpp
+++ b/tests/unit/coverage/CoverageGapFinderTest.cpp
@@ -69,7 +69,7 @@ void object::test<1> ()
checkGaps(
"MULTIPOLYGON (((1 5, 1 9, 5 9, 5 6, 3 5, 1 5)), ((5 9, 9 9, 9 5, 7 5, 5 6, 5 9)), ((1 1, 1 5, 3 5, 7 5, 9 5, 9 1, 1 1)))",
1,
- "LINESTRING (3 5, 7 5, 5 6, 3 5)"
+ "POLYGON ((3 5, 7 5, 5 6, 3 5))"
Summary of changes:
src/coverage/CoverageGapFinder.cpp | 11 +++++------
tests/unit/coverage/CoverageGapFinderTest.cpp | 2 +-
2 files changed, 6 insertions(+), 7 deletions(-)
hooks/post-receive
More information about the geos-commits
