[geos-commits] [SCM] GEOS branch main updated. 640d3758eeafc859e7484ca7ab7e6d76fc48719d
Mon Nov 17 05:24:06 PST 2025
the project "GEOS".
The branch, main has been updated
       via  640d3758eeafc859e7484ca7ab7e6d76fc48719d (commit)
       via  174866213c52f91d24cda3cfdb32dea6e4a4684e (commit)
       via  b0b52d238eee1b70388404e1401f7d3d7d90bc02 (commit)
      from  afe4d0595b2203605f6cdccd7742a9665caab6e3 (commit)
revisions in full, below.
commit 640d3758eeafc859e7484ca7ab7e6d76fc48719d
Author: Daniel Baston <dbaston at gmail.com>
Date:   Wed Oct 22 10:30:37 2025 -0400
    Densifier: preserve and interpolate M values
diff --git a/src/geom/util/Densifier.cpp b/src/geom/util/Densifier.cpp
index 9f4e27967..a344757b4 100644
--- a/src/geom/util/Densifier.cpp
+++ b/src/geom/util/Densifier.cpp
@@ -108,16 +108,13 @@ Densifier::Densifier(const Geometry* geom):
 std::unique_ptr<CoordinateSequence>
 Densifier::densifyPoints(const CoordinateSequence& pts, double distanceTolerance, const PrecisionModel* precModel)
-    geom::LineSegment seg;
-    auto coordList = detail::make_unique<CoordinateSequence>();
+    auto coordList = detail::make_unique<CoordinateSequence>(0, pts.hasZ(), pts.hasM());
-    auto items = pts.items<Coordinate>();
-    for(auto it = items.cbegin(), itEnd = items.cend() - 1; it < itEnd; ++it) {
-        seg.p0 = *it;
-        seg.p1 = *(it + 1);
-        coordList->add(seg.p0, false);
-        const double len = seg.getLength();
-        const double densifiedSegCountDbl = ceil(len / distanceTolerance);
+    pts.forEachSegment([&coordList, distanceTolerance, precModel](const auto& p0, const auto& p1) {
+        coordList->add(p0, false);
+        const double len = p0.distance(p1);
+        const double densifiedSegCountDbl = std::ceil(len / distanceTolerance);
         if(densifiedSegCountDbl > std::numeric_limits<int>::max()) {
             throw geos::util::GEOSException(
                 "Tolerance is too small compared to geometry length");
@@ -128,18 +125,20 @@ Densifier::densifyPoints(const CoordinateSequence& pts, double distanceTolerance
             double densifiedSegLen = len / densifiedSegCount;
             for(int j = 1; j < densifiedSegCount; j++) {
                 double segFract = (j * densifiedSegLen) / len;
-                Coordinate p;
-                seg.pointAlong(segFract, p);
+                auto p = LineSegment::pointAlong(segFract, p0, p1);
                 precModel->makePrecise(p);
                 coordList->add(p, false);
         else {
             // no densification required; insert the last coordinate and continue
-            coordList->add(seg.p1, false);
+            coordList->add(p1, false);
-    coordList->add(pts[pts.size() - 1], false);
+    pts.applyAt(pts.size() - 1, [&coordList](const auto& pt) {
+        coordList->add(pt, false);
     return coordList;
diff --git a/tests/unit/capi/GEOSDensifyTest.cpp b/tests/unit/capi/GEOSDensifyTest.cpp
index 721e91dc2..752441ddb 100644
--- a/tests/unit/capi/GEOSDensifyTest.cpp
+++ b/tests/unit/capi/GEOSDensifyTest.cpp
@@ -169,6 +169,7 @@ void object::test<10>()
     result_ = GEOSDensify(input_, 0.1);
     ensure("curved geometries not supported", result_ == nullptr);
 // Densify a LINESTRING Z, check that Z gets interpolated
 template <>
 template <>
@@ -205,4 +206,17 @@ void object::test<13>()
+template <>
+template <>
+void object::test<14>()
+    set_test_name("M values are interpolated");
+    testDensify(
+        "LINESTRING M (0 0 0, 0 6 2)",
+        "LINESTRING M (0 0 0, 0 3 1, 0 6 2)",
+        3.0
 } // namespace tut
commit 174866213c52f91d24cda3cfdb32dea6e4a4684e
Date:   Wed Oct 22 10:30:29 2025 -0400
    CoordinateSequence: add forEachSegment method
diff --git a/include/geos/geom/CoordinateSequence.h b/include/geos/geom/CoordinateSequence.h
index 2d952f137..5e0a7776b 100644
--- a/include/geos/geom/CoordinateSequence.h
+++ b/include/geos/geom/CoordinateSequence.h
@@ -710,6 +710,16 @@ public:
+    template<typename F>
+    void forEachSegment(F&& fun) const {
+        switch(getCoordinateType()) {
+            case CoordinateType::XY:    forEachSegmentImpl<CoordinateXY, F>(std::move(fun)); break;
+            case CoordinateType::XYZ:   forEachSegmentImpl<Coordinate, F>(std::move(fun)); break;
+            case CoordinateType::XYM:   forEachSegmentImpl<CoordinateXYM, F>(std::move(fun)); break;
+            case CoordinateType::XYZM:  forEachSegmentImpl<CoordinateXYZM, F>(std::move(fun)); break;
     template<typename T, typename F>
     void forEach(std::size_t from, std::size_t to, F&& fun) const
@@ -797,6 +807,24 @@ private:
         orig = c;
+    template<typename CoordType, typename F>
+    void forEachSegmentImpl(F&& fun) const {
+        auto p0it = items<CoordType>().cbegin();
+        const auto end = items<CoordType>().end();
+        if (p0it == end) {
+            return;
+        auto p1it = std::next(p0it);
+        while (p1it != end) {
+            fun(*p0it, *p1it);
+            ++p0it;
+            ++p1it;
     void make_space(std::size_t pos, std::size_t n) {
         m_vect.insert(std::next(m_vect.begin(), static_cast<std::ptrdiff_t>(pos * stride())),
                       m_stride * n,
diff --git a/tests/unit/geom/CoordinateSequenceTest.cpp b/tests/unit/geom/CoordinateSequenceTest.cpp
index 4786c20c8..e2a94fb41 100644
--- a/tests/unit/geom/CoordinateSequenceTest.cpp
+++ b/tests/unit/geom/CoordinateSequenceTest.cpp
@@ -1536,4 +1536,48 @@ void object::test<56>
     ensure_equals_xyz(seq1.getAt(3), Coordinate{10, 11, DoubleNotANumber});
+template<>
+template<>
+void object::test<57>()
+    set_test_name("CoordinateSequence::forEachSegment called on empty CoordinateSequence");
+    CoordinateSequence empty;
+    empty.forEachSegment([](const auto&, const auto&) {
+        fail();
+template<>
+template<>
+void object::test<58>()
+    set_test_name("CoordinateSequence::forEachSegment called on single-point CoordinateSequence");
+    CoordinateSequence seq;
+    seq.add(CoordinateXY{3, 6});
+    seq.forEachSegment([](const auto&, const auto&) {
+        fail();
+template<>
+template<>
+void object::test<59>()
+    set_test_name("CoordinateSequence::forEachSegment basic test");
+    seq.add(CoordinateXY{0, 0});
+    seq.add(CoordinateXY{3, 0});
+    seq.add(CoordinateXY{3, 5});
+    double length = 0;
+    seq.forEachSegment([&length](const auto& p0, const auto& p1) {
+        length += p0.distance(p1);
+    ensure_equals(length, 8);
 } // namespace tut
commit b0b52d238eee1b70388404e1401f7d3d7d90bc02
Date:   Wed Oct 22 10:30:12 2025 -0400
    LineSegment: Add static pointAlong interpolation methods
diff --git a/include/geos/geom/LineSegment.h b/include/geos/geom/LineSegment.h
index aea0fefd8..f6ef755ac 100644
--- a/include/geos/geom/LineSegment.h
+++ b/include/geos/geom/LineSegment.h
@@ -326,6 +326,34 @@ public:
             p0.z + segmentLengthFraction * (p1.z - p0.z));
+    static CoordinateXY pointAlong(double segmentLengthFraction, const CoordinateXY& p0, const CoordinateXY& p1)
+        return { p0.x + segmentLengthFraction * (p1.x - p0.x),
+                 p0.y + segmentLengthFraction * (p1.y - p0.y) };
+    static Coordinate pointAlong(double segmentLengthFraction, const Coordinate& p0, const Coordinate& p1)
+                 p0.y + segmentLengthFraction * (p1.y - p0.y),
+                 p0.z + segmentLengthFraction * (p1.z - p0.z) };
+    static CoordinateXYM pointAlong(double segmentLengthFraction, const CoordinateXYM& p0, const CoordinateXYM& p1)
+                 p0.m + segmentLengthFraction * (p1.m - p0.m) };
+    static CoordinateXYZM pointAlong(double segmentLengthFraction, const CoordinateXYZM& p0, const CoordinateXYZM& p1)
+                 p0.z + segmentLengthFraction * (p1.z - p0.z),
     /** \brief
      * Computes the {@link Coordinate} that lies a given
      * fraction along the line defined by this segment and offset from
Summary of changes:
 include/geos/geom/CoordinateSequence.h     | 28 +++++++++++++++++++
 include/geos/geom/LineSegment.h            | 28 +++++++++++++++++++
 src/geom/util/Densifier.cpp                | 29 ++++++++++----------
 tests/unit/capi/GEOSDensifyTest.cpp        | 14 ++++++++++
 tests/unit/geom/CoordinateSequenceTest.cpp | 44 ++++++++++++++++++++++++++++++
 5 files changed, 128 insertions(+), 15 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
