[geos-commits] [SCM] GEOS branch main updated. c0b00fc4a4b3a33dd16c4266f247dbf931241564
git at osgeo.org
git at osgeo.org
Thu Nov 27 08:26:52 PST 2025
the project "GEOS".
The branch, main has been updated
via c0b00fc4a4b3a33dd16c4266f247dbf931241564 (commit)
via 67af53be83f544626d71a0afe3dd85b1925dd4d9 (commit)
via eee29c967914469b6539cc165c95514bf35812ca (commit)
via 53a58127135515b7ff7f5573f4f732b891925974 (commit)
via c080c524bf24fb633ae80a8545f869eab379fa4d (commit)
via 3d1723b2809c5ae44c99d54660fa11c155dae4c8 (commit)
via cbfeefae155eb9abc11858f54b0a44d59d891adc (commit)
via a49a6b37c86783f2a08baf112b2351dd03a5f090 (commit)
via f24391283eaa4f25e8dbf86bd83af017d2bfaebf (commit)
via d6bfe03ca9b8c21bef7927bebcf2a56811bf9c06 (commit)
via f9b2389b982f7028ca74e62164ccfd147251621e (commit)
via 3b4d3b2481ff5c9ac5df1bc7a7f68ae21d4fa58f (commit)
via 40d22f0948486fef5945b8bd68a76f1a6bdd8431 (commit)
via 88304f605e3f1c8190d0daf491a09210f87fe8e2 (commit)
via 81dbbc8c57069ad3e1571e959e759b2ba87bd123 (commit)
via d1ccf4d11234360108dc927e4d1576f3126ca9b8 (commit)
via e5f3fbe76e4aaabbef9dcb9419e92bc2a7b930fc (commit)
via ea3b27bc3b6b78e8bee510edb8225a51fa08dcfb (commit)
via 8373a284b1420f8685dd2d2f28a33b61cbc1747b (commit)
via 2060b11ae91fb1e210afa7cdbc8469dc158d33fa (commit)
via 0da3930ef5fbb0c1f9c37b9313a85d7a70b585bc (commit)
via bb1ddd2f98e5831ee4b31ddf5c49155520dc6276 (commit)
via dcea054725c4d43d2a11cc03130ea631ffca195e (commit)
from 640d3758eeafc859e7484ca7ab7e6d76fc48719d (commit)
revisions in full, below.
commit c0b00fc4a4b3a33dd16c4266f247dbf931241564
Author: Daniel Baston <dbaston at gmail.com>
Date: Thu Nov 27 11:10:53 2025 -0500
GEOSSubdivideByGrid: Add comment on behavior with 3D inputs
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index 03529ff24..942663671 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -4046,6 +4046,9 @@ extern GEOSGeometry GEOS_DLL *GEOSClipByRect(
* \return A geometry collection whose components represent the
* intersection with each cell in the grid.
* Caller is responsible for freeing with GEOSGeom_destroy().
+* This algorithm operates in 2D only; Z and M values in the input will be dropped.
* \see GEOSGetGridIntersectionFractions
* \since 3.14.0
commit 67af53be83f544626d71a0afe3dd85b1925dd4d9
Date: Thu Nov 27 10:58:25 2025 -0500
TraversalAreas: Add comments, remove repeated code
diff --git a/src/operation/grid/TraversalAreas.cpp b/src/operation/grid/TraversalAreas.cpp
index a99163bdd..9150b286a 100644
--- a/src/operation/grid/TraversalAreas.cpp
+++ b/src/operation/grid/TraversalAreas.cpp
@@ -13,7 +13,6 @@
#include <limits>
-#include <iomanip>
#include <optional>
#include <vector>
@@ -23,14 +22,12 @@
#include <geos/geom/CoordinateSequence.h>
#include <geos/geom/Geometry.h>
#include <geos/geom/GeometryFactory.h>
+#include <geos/geom/util/GeometryFixer.h>
#include <geos/operation/grid/PerimeterDistance.h>
#include <geos/operation/grid/Traversal.h>
-#include <geos/geom/util/GeometryFixer.h>
-#include <geos/operation/polygonize/Polygonizer.h>
#include <geos/operation/grid/TraversalAreas.h>
-#include "geos/operation/valid/RepeatedPointRemover.h"
+#include <geos/operation/polygonize/Polygonizer.h>
+#include <geos/operation/valid/RepeatedPointRemover.h>
using geos::geom::CoordinateSequence;
using geos::geom::CoordinateXY;
@@ -40,6 +37,10 @@ using geos::geom::Envelope;
#define DEBUG_TRAVERSAL_AREAS 0
+#if DEBUG_TRAVERSAL_AREAS
+#include <iomanip>
+#endif
namespace geos::operation::grid {
/// A CoordinateChain stores a set of coordinates whose start and end points lie on
@@ -48,7 +49,7 @@ struct CoordinateChain
const double start; // perimeter distance value of the first coordinate
const double stop; // perimeter distance value of the last coordinate
- const void* parentage;
+ const void* parentage; // pointer to track the linear geometry from which the coordinates originated
bool visited;
CoordinateChain(double p_start, double p_stop, const std::vector<CoordinateXY>& p_coords)
@@ -113,7 +114,7 @@ getNextChain(std::vector<CoordinateChain>& chains,
continue;
- double distance = exit_to_entry_perimeter_distance_ccw(*chain, candidate, perimeter);
+ const double distance = exit_to_entry_perimeter_distance_ccw(*chain, candidate, perimeter);
std::cout << "Distance " << distance << ", start " << candidate.start << ", stop " << candidate.stop << ": ";
@@ -154,6 +155,15 @@ hasMultipleUniqueCoordinates(const T& vec)
return false;
+static bool
+isRingCCW(const std::vector<CoordinateXY>& coords)
+ // TODO: Remove copy
+ CoordinateSequence seq(0, false, false);
+ seq.setPoints(coords);
+ return algorithm::Orientation::isCCW(&seq);
static bool
isRing(const std::vector<CoordinateXY>& coords)
@@ -234,11 +244,14 @@ visitRings(const Envelope& box, const std::vector<const Traversal*>& traversals,
chains.reserve(traversals.size() + 4);
std::deque<std::vector<CoordinateXY>> coordinateStore;
- std::vector<CoordinateXY> boxPoints;
+ std::vector<CoordinateXY> boxPoints; // a list of nodes to be included in the boundary of the
+ // polygon, if it is the same as the boundary of the
+ // cell. Necessary to form a correctly noded polygon
+ // coverage.
+ std::optional<bool> isInterior; // whether the cell is entirely inside the polygon.
- double areaCCW = 0;
- double areaCW = 0;
- std::optional<bool> isInterior;
+ double areaCCW = 0; // cumulative area of CCW-oriented rings
+ double areaCW = 0; // cumulative area of CW-oriented rings
for (const auto& traversal : traversals) {
if (!traversal->hasMultipleUniqueCoordinates()) {
@@ -255,10 +268,7 @@ visitRings(const Envelope& box, const std::vector<const Traversal*>& traversals,
if (isRing(*coords)) {
if constexpr (!validPolygonsAndCoverage) {
- CoordinateSequence seq(0, false, false);
- // TODO: Remove copy
- seq.setPoints(*coords);
- const bool isCCW = algorithm::Orientation::isCCW(&seq);
+ const bool isCCW = isRingCCW(*coords);
visitor(*coords, isCCW, false);
@@ -272,10 +282,7 @@ visitRings(const Envelope& box, const std::vector<const Traversal*>& traversals,
if (containsProperly(box, *coords) || !hasEdgeSegment(box, *coords)) {
// Add nodes to box edges
for (const auto& c : *coords) {
@@ -468,7 +475,8 @@ visitRings(const Envelope& box, const std::vector<const Traversal*>& traversals,
if (areaCW > areaCCW || (areaCCW == 0 && areaCW == 0 && isInterior.value())) {
- bool sortIsNeeded = !boxPoints.empty();
+ // Ring is the same as the cell envelope
+ const bool sortIsNeeded = !boxPoints.empty();
boxPoints.emplace_back(box.getMinX(), box.getMinY());
boxPoints.emplace_back(box.getMaxX(), box.getMinY());
@@ -477,8 +485,7 @@ visitRings(const Envelope& box, const std::vector<const Traversal*>& traversals,
if (sortIsNeeded) {
std::sort(boxPoints.begin(), boxPoints.end(), [&box](const CoordinateXY& lhs, const CoordinateXY& rhs) {
- return PerimeterDistance::getPerimeterDistance(box, lhs) <
- PerimeterDistance::getPerimeterDistance(box, rhs);
+ return PerimeterDistance::isLessThan(box, lhs, rhs);
@@ -520,7 +527,7 @@ TraversalAreas::getLeftHandRings(const GeometryFactory& gfact, const Envelope& b
visitRings<validPolygons>(box, coord_lists, [&gfact, &shells, &holes, &checkValidity](const std::vector<CoordinateXY>& coords, bool isCCW, bool hasMultipleParents) {
// If a given ring was created from traversals from both a ring and shell, for example, it is possible for
- // the ring to self-intersect. Rather than try and detect self-intersections o the fly (rare?) we check and
+ // the ring to self-intersect. Rather than try and detect self-intersections on the fly (rare?) we check and
// repair validity in this limited case.
checkValidity |= hasMultipleParents;
@@ -536,9 +543,6 @@ TraversalAreas::getLeftHandRings(const GeometryFactory& gfact, const Envelope& b
if (seq->hasRepeatedPoints()) {
seq = valid::RepeatedPointRemover::removeRepeatedPoints(seq.get());
- //for (const auto& coord : coords) {
- // seq->add(coord, false);
auto ring = gfact.createLinearRing(std::move(seq));
if (isCCW) {
commit eee29c967914469b6539cc165c95514bf35812ca
Date: Wed Nov 26 15:35:01 2025 -0500
GridIntersection: Add comments, remove unused variable
diff --git a/include/geos/operation/grid/Grid.h b/include/geos/operation/grid/Grid.h
index 58ba4f455..d94d80916 100644
--- a/include/geos/operation/grid/Grid.h
+++ b/include/geos/operation/grid/Grid.h
@@ -20,8 +20,6 @@
#include <geos/geom/Envelope.h>
-constexpr double DEFAULT_GRID_COMPAT_TOL = 1e-6;
struct infinite_extent
@@ -33,11 +31,19 @@ struct bounded_extent
static constexpr size_t padding = 0;
+ * @brief The Grid class represents a grid of constant-size rectangular cells that covers a specified envelope.
+ * The width of the cells may be different from the height. If the Grid has an "infinite" extent rather than
+ * a "bounded" extent, then an extra row and column will be added on all side of the grid. The size of the cells
+ * in these columns may be larger than those in the primary grid, such that the extended grid covers a "domain"
+ * that is larger than the extent of the regular grid.
template<typename extent_tag>
class GEOS_DLL Grid
public:
+ /// Construct a bounded grid covering a specified extent.
Grid(const geom::Envelope& extent, double dx, double dy)
: m_extent{ extent }
, m_domain{}
@@ -50,6 +56,8 @@ class GEOS_DLL Grid
static_assert(std::is_same_v<extent_tag, bounded_extent>);
+ /// Construct an infinite grid covering a specified extent with regularly-sized cells, and adding a row and column
+ /// of variably-sized cells to each edge of the primary grid such that the specified domain is covered.
Grid(const geom::Envelope& extent, double dx, double dy, const geom::Envelope& domain)
, m_domain{ domain }
@@ -73,6 +81,7 @@ class GEOS_DLL Grid
+ /// Get the column in which the specified x coordinate would fall.
size_t getColumn(double x) const
if (extent_tag::padding) {
@@ -98,6 +107,7 @@ class GEOS_DLL Grid
getColumn(m_extent.getMaxX()));
+ /// Get the row in which the specified y coordinate would fall.
size_t getRow(double y) const
@@ -123,6 +133,8 @@ class GEOS_DLL Grid
getRow(m_extent.getMinY()));
+ /// Get the cell index in which the specified x and y values would fall. Cells are indexed from left-to-right,
+ /// then top-to-bottom.
std::size_t getCell(double x, double y) const
return getRow(y) * getNumCols() + getColumn(x);
@@ -150,12 +162,20 @@ class GEOS_DLL Grid
const geom::Envelope& getExtent() const { return m_extent; }
+ /// Return the number of rows by which another grid is offset from this Grid. It is assumed that the two
+ /// grids have the same resolution, and that the maximum y value of the other grid is less than or equal
+ /// to the maximum y value of this grid.
size_t getRowOffset(const Grid& other) const { return static_cast<size_t>(std::round(std::abs(other.m_extent.getMaxY() - m_extent.getMaxY()) / m_dy)); }
+ /// Return the number of columns by which another grid is offset from this Grid. It is assumed that the two
+ /// grids have the same resolution, and that the minimum x value of the other grid is greater than or equal
+ /// to the minimum x value of this grid.
size_t getColOffset(const Grid& other) const { return static_cast<size_t>(std::round(std::abs(m_extent.getMinX() - other.m_extent.getMinX()) / m_dx)); }
+ /// Get the x coordinate at the center of the specified column.
double getColX(size_t col) const { return m_extent.getMinX() + (static_cast<double>(col - extent_tag::padding) + 0.5) * m_dx; }
+ /// Get the y coordinate at the center of the specified row.
double getRowY(size_t row) const { return m_extent.getMaxY() - (static_cast<double>(row - extent_tag::padding) + 0.5) * m_dy; }
Grid crop(const geom::Envelope& e) const
@@ -167,6 +187,10 @@ class GEOS_DLL Grid
+ /// Reduce the size of the grid to contain only the provided Envelope
+ /// If calcExtentFromNewGrid is true, then the xmax and ymin of the new
+ /// grid will be calculated relative to the origin point of the original grid
+ /// rather than the newly cropped grid.
Grid<extent_tag> shrinkToFit(const geom::Envelope& b, bool calcExtentFromNewGrid=true) const
if (b.getArea() == 0) {
@@ -295,11 +319,12 @@ class GEOS_DLL Grid
double m_dx;
double m_dy;
- double m_xOrig;
+ double m_xOrig; // origin point that is distinct from xmin of m_extent. Used to allow a subgrid to calculate
+ // sub-envelopes that exactly match those of the parent grid
double m_yOrig;
- size_t m_skipRows{0};
- size_t m_skipCols{0};
+ size_t m_skipRows{0}; // number of rows to skip when computing a cell envelope using m_yOrig
+ size_t m_skipCols{0}; // number of cols to skip when computing a cell envelope using m_xOrig
size_t m_num_rows;
size_t m_num_cols;
diff --git a/include/geos/operation/grid/GridIntersection.h b/include/geos/operation/grid/GridIntersection.h
index 85a9e2cbd..c97d4e8b5 100644
--- a/include/geos/operation/grid/GridIntersection.h
+++ b/include/geos/operation/grid/GridIntersection.h
@@ -60,14 +60,25 @@ class GEOS_DLL GridIntersection
* @brief Partition a polygonal geometry by a grid
+ * @param grid the Grid by which the polygon should be partitioned. The Grid does not need to cover the polygon.
+ * @param g a polygonal geometry
+ * @param includeExterior whether the result should contain any portions of the input that fall outside the grid.
+ * @return a GeometryCollection containing the partitioned polygon.
- static std::unique_ptr<geom::Geometry> subdividePolygon(const Grid<bounded_extent>& p_grid, const geom::Geometry& g, bool includeExterior);
+ static std::unique_ptr<geom::Geometry> subdividePolygon(const Grid<bounded_extent>& grid, const geom::Geometry& g, bool includeExterior);
+ * @brief Calculate the fraction of each cell in a Grid that is covered by a polygon.
+ * @param grid the Grid for which coverage fractions should be returned
+ * @param g a polygonal or linear geometry
+ * @return a matrix having the same number of rows and columns as the grid, whose values contain either the
+ * fraction of the cell area (for polygonal inputs) or the length of the intersection (for linear inputs)
+ static std::shared_ptr<Matrix<float>>
+ getIntersectionFractions(const Grid<bounded_extent>& grid, const geom::Geometry& g);
- getIntersectionFractions(const Grid<bounded_extent>& raster_grid, const geom::Geometry& g);
- static std::shared_ptr<Matrix<float>>
- getIntersectionFractions(const Grid<bounded_extent>& raster_grid, const geom::Envelope& box);
+ getIntersectionFractions(const Grid<bounded_extent>& grid, const geom::Envelope& box);
* @brief Determines the bounding box of the raster-vector intersection. Considers the bounding boxes
commit 53a58127135515b7ff7f5573f4f732b891925974
Date: Wed Nov 26 11:43:46 2025 -0500
GEOSSubdivideByGrid: rename include_exterior argument, add test
index 9e7ff2640..03529ff24 100644
@@ -1175,7 +1175,7 @@ extern GEOSGeometry GEOS_DLL *GEOSSubdivideByGrid_r(
double xmin, double ymin,
double xmax, double ymax,
unsigned nx, unsigned ny,
- int include_exterior);
+ int includeExterior);
/** \see GEOSGridIntersectionFractions */
extern int GEOS_DLL GEOSGridIntersectionFractions_r(
@@ -4040,7 +4040,7 @@ extern GEOSGeometry GEOS_DLL *GEOSClipByRect(
* \param ymax Upper bound of grid
* \param nx number of columns in grid
* \param ny number of rows in grid
-* \param include_exterior whether to include portions of the
+* \param includeExterior whether to include portions of the
input geometry that do not intersect the grid in
the returned result.
@@ -4055,7 +4055,7 @@ extern GEOSGeometry GEOS_DLL *GEOSSubdivideByGrid(
* Determine the fraction of each cell in a rectangular grid
diff --git a/src/operation/grid/GridIntersection.cpp b/src/operation/grid/GridIntersection.cpp
index c4717a7f3..7c4815b75 100644
--- a/src/operation/grid/GridIntersection.cpp
+++ b/src/operation/grid/GridIntersection.cpp
@@ -569,7 +569,6 @@ GridIntersection::subdividePolygon(const Grid<bounded_extent>& p_grid, const Geo
const geom::GeometryFactory& gfact = *g.getFactory();
const auto cropped_grid = p_grid.shrinkToFit(p_grid.getExtent().intersection(*g.getEnvelopeInternal()), false);
- //const auto cropped_grid = p_grid;
geom::Envelope gridExtent = *g.getEnvelopeInternal();
gridExtent.expandBy(1);
@@ -619,6 +618,8 @@ GridIntersection::subdividePolygon(const Grid<bounded_extent>& p_grid, const Geo
if (!edge_geoms.empty()) {
auto edge_coll = gfact.createGeometryCollection(std::move(edge_geoms));
geoms.push_back(overlayng::CoverageUnion::geomunion(edge_coll.get()));
+ // Polygon generated here may have extra nodes that do not match adjacent polygons not processed through
+ // subdividePolygon.
return gfact.createGeometryCollection(std::move(geoms));
diff --git a/tests/unit/operation/grid/GridIntersectionTest.cpp b/tests/unit/operation/grid/GridIntersectionTest.cpp
index eb02da54c..2c5cb8a01 100644
--- a/tests/unit/operation/grid/GridIntersectionTest.cpp
+++ b/tests/unit/operation/grid/GridIntersectionTest.cpp
@@ -976,4 +976,26 @@ void object::test<52>()
check_subdivided_polygon(*g, *subd);
+template<>
+template<>
+void object::test<53>() {
+ set_test_name("includeExterior = true");
+ Envelope e(0, 10, 0, 10);
+ Grid<bounded_extent> ext(e, 1, 1);
+ auto g = wkt_reader_.read("POLYGON ((9.5 9.5, 11 9.5, 11 11, 9.5 11, 9.5 9.5))");
+ auto subd = GridIntersection::subdividePolygon(ext, *g, true);
+ auto inside = wkt_reader_.read("POLYGON ((9.5 9.5, 10 9.5, 10 10, 9.5 10, 9.5 9.5))");
+ auto outside = wkt_reader_.read("POLYGON ((9.5 10, 10 10, 10 9.5, 11 9.5, 11 11, 9.5 11, 9.5 10))");
+ ensure_equals(subd->getNumGeometries(), 2u);
+ // ensure_equals_geometry would fail here because the generated results have extra nodes at grid cell boundaries
+ ensure(subd->getGeometryN(0)->equals(inside.get()));
+ ensure(subd->getGeometryN(1)->equals(outside.get()));
commit c080c524bf24fb633ae80a8545f869eab379fa4d
Date: Wed Nov 26 10:04:05 2025 -0500
GridIntersection: skip slow tests on CI
index 14ab2e2d6..eb02da54c 100644
@@ -538,6 +538,7 @@ template<>
void object::test<26>()
set_test_name("Robustness regression test #1");
+ skip_on_ci();
// This test exercises some challenging behavior where a polygon follows
// ymin, but the grid resolution is such that ymin < (ymax - ny*dy)
@@ -558,6 +559,7 @@ template<>
void object::test<27>()
set_test_name("Robustness regression test #2");
+ skip_on_ci();
// xmax, but the grid resolution is such that xmax < (xmin + nx*m_dx)
@@ -597,6 +599,7 @@ template<>
void object::test<30>()
set_test_name("Robustness regression test #4");
+ skip_on_ci();
Grid<bounded_extent> ext{ { -166.84166666666667, -152.625, 66.991666666666674, 71.358333333333334 }, 0.0083333333333333332, 0.0083333333333333332 };
diff --git a/tests/unit/utility.h b/tests/unit/utility.h
index 5d3993d10..562a95dc8 100644
--- a/tests/unit/utility.h
+++ b/tests/unit/utility.h
@@ -581,6 +581,14 @@ struct wkb_hex_decoder {
// Base class with helpers
struct GEOSTestBase {
+ static void
+ skip_on_ci()
+ if (std::getenv("CI")) {
+ skip("Skip slow test on CI");
static std::string load_resource(const std::string& fname) {
#if HAVE_STD_FILESYSTEM
if (RESOURCE_DIR == "") {
commit 3d1723b2809c5ae44c99d54660fa11c155dae4c8
Date: Tue Nov 25 21:40:26 2025 -0500
GridIntersection: Strengthen asserts on some existing regression tests
index 304c87a8f..58ba4f455 100644
@@ -250,31 +250,25 @@ class GEOS_DLL Grid
if constexpr (std::is_same_v<extent_tag, bounded_extent>) {
Grid<extent_tag> reduced{reduced_box, m_dx, m_dy};
- if (b.getMinX() < reduced.xmin() || b.getMinY() < reduced.ymin() || b.getMaxX() > reduced.xmax() || b.
- getMaxY() > reduced.ymax()) {
- throw std::runtime_error("Shrink operation failed.");
if (!calcExtentFromNewGrid) {
reduced.m_xOrig = m_xOrig;
reduced.m_yOrig = m_yOrig;
reduced.m_skipRows = reduced.getRowOffset(*this);
reduced.m_skipCols = reduced.getColOffset(*this);
+ } else if (!reduced.getExtent().contains(b)) {
+ throw std::runtime_error("Shrink operation failed.");
return reduced;
} else {
Grid<extent_tag> reduced{reduced_box, m_dx, m_dy, m_domain};
+ }else if (!reduced.getExtent().contains(b)) {
return reduced;
index cd45402d5..a99163bdd 100644
@@ -391,7 +391,7 @@ visitRings(const Envelope& box, const std::vector<const Traversal*>& traversals,
std::cout << std::endl << std::fixed;
- std::cout << std::setprecision(1);
+ std::cout << std::setprecision(18);
std::cout << "Identifying rings in box " << box.getMinX() << ":" << box.getMaxX() << "," << box.getMinY() << ":" << box.getMaxY() << std::endl;
std::cout << "Available chains:" << std::endl;
@@ -437,9 +437,18 @@ visitRings(const Envelope& box, const std::vector<const Traversal*>& traversals,
coords.push_back(coords[0]);
- std::cout << "Completed chain ";
- for (const auto& c : coords) {
- std::cout << c << ", ";
+ std::cout << "Completed chain LINESTRING (";
+ bool first = true;
+ for (const auto& c : coords) {
+ if (first) {
+ first = false;
+ } else {
+ std::cout << ", ";
+ std::cout << c;
+ std::cout << ")";
std::cout<< std::endl;
#endif
index 9c47fd47d..14ab2e2d6 100644
@@ -65,7 +65,7 @@ struct test_gridintersectiontest_data : GEOSTestBase {
std::string error = "subdivided polygon area does not match input: " + subdivided.toString();
- ensure_equals(error, tot_area, input.getArea(), input.getArea() * 1e-14);
+ ensure_equals(error, tot_area, input.getArea(), input.getArea() * 1e-6);
@@ -490,8 +490,11 @@ void object::test<23>()
Grid<bounded_extent> extent{ { -180.5, 180.5, -90.5, 90.5 }, 0.5, 0.5 };
auto g = wkt_reader_.read("MULTIPOLYGON (((178.3736000000001 -17.33992000000002, 178.71806000000007 -17.62845999999996, 178.5527099999999 -18.150590000000008, 177.93266000000008 -18.287990000000036, 177.38145999999992 -18.164319999999975, 177.28504000000007 -17.72464999999997, 177.67087 -17.381139999999974, 178.12557000000007 -17.50480999999995, 178.3736000000001 -17.33992000000002)), ((179.36414266196417 -16.801354076946836, 178.7250593629972 -17.012041674368007, 178.5968385951172 -16.63915000000003, 179.0966093629972 -16.43398427754741, 179.4135093629972 -16.379054277547382, 180.00000000000003 -16.06713266364241, 180.00000000000003 -16.555216566639146, 179.36414266196417 -16.801354076946836)), ((-179.91736938476527 -16.501783135649347, -179.99999999999997 -16.555216566639146, -179.99999999999997 -16.06713266364241, -179.79332010904858 -16.020882256741217, -179.91736938476527 -16.501783135649347)))");
+ auto rci = GridIntersection::getIntersectionFractions(extent, *g);
+ check_area(*rci, extent, *g);
- ensure_NO_THROW(GridIntersection(extent, *g));
+ auto subd = GridIntersection::subdividePolygon(extent, *g, false);
+ check_subdivided_polygon(*g, *subd);
template<>
@@ -539,10 +542,15 @@ void object::test<26>()
- Grid<bounded_extent> extent{ { -180, 180, -90, 90 }, 1.0 / 6, 1.0 / 6 };
+ Grid<bounded_extent> ext{ { -180, 180, -90, 90 }, 1.0 / 6, 1.0 / 6 };
auto g = wkt_reader_.read(load_resource("antarctica.wkt"));
+ auto rci = GridIntersection::getIntersectionFractions(ext, *g);
+ check_area(*rci, ext, *g);
+ auto subd = GridIntersection::subdividePolygon(ext, *g, false);
template<>
@@ -553,12 +561,15 @@ void object::test<27>()
auto g = wkt_reader_.read(load_resource("russia.wkt"));
template<>
@@ -574,7 +585,11 @@ void object::test<29>()
Envelope env = g->getEnvelopeInternal()->intersection(extent.getExtent());
extent = extent.shrinkToFit(env);
- ensure_NO_THROW( GridIntersection::getIntersectionFractions(extent, *g));
template<>
@@ -583,11 +598,15 @@ void object::test<30>()
- Grid<bounded_extent> extent{ { -166.84166666666667, -152.625, 66.991666666666674, 71.358333333333334 }, 0.0083333333333333332, 0.0083333333333333332 };
+ Grid<bounded_extent> ext{ { -166.84166666666667, -152.625, 66.991666666666674, 71.358333333333334 }, 0.0083333333333333332, 0.0083333333333333332 };
auto g = wkt_reader_.read(load_resource("regression4.wkt"));
template<>
@@ -596,38 +615,32 @@ void object::test<31>()
set_test_name("robustness regression test #5");
- Grid<bounded_extent> extent{ { 0, 10, 0, 10 }, 1, 1 };
+ Grid<bounded_extent> ext{ { 0, 10, 0, 10 }, 1, 1 };
auto g = wkt_reader_.read("POINT (2 2)")->buffer(1, 30);
template<>
template<>
void object::test<32>()
- return;
set_test_name("Robustness regression test #6");
- Grid<bounded_extent> ex{ { 145.925, 147.375, -35.525, -33.475 }, 0.05, 0.05 };
+ Grid<bounded_extent> ext{ { 145.925, 147.375, -35.525, -33.475 }, 0.05, 0.05 };
auto g = wkt_reader_.read(load_resource("regression6.wkt"));
- GridIntersection gi(ex, *g);
- const auto& result = *gi.getResults();
- float tot = 0;
- for (size_t i = 0; i < result.getNumRows(); i++) {
- for (size_t j = 0; j < result.getNumCols(); j++) {
- tot += result(i, j);
- if (result(i, j) < 0 || result(i, j) > 1) {
- fail();
- ensure_equals(tot, 823.0f);
template<>
@@ -638,6 +651,7 @@ void object::test<33>()
Grid<bounded_extent> ex{ { 487800, 492800, 5813800, 5818800 }, 100, 100 };
+ // Polygon is a tiny sliver with an area of 1e-8
auto g = wkt_reader_.read("POLYGON ((492094.9283999996 5816959.8553, 492374.9335527361 5816811.352641133, 492374.9335527363 5816811.352641133, 492094.9283999996 5816959.8553))");
ex = ex.shrinkToFit(*g->getEnvelopeInternal());
@@ -657,7 +671,8 @@ void object::test<33>()
template<>
template<>
-void object::test<34>() {set_test_name("Processing region is empty when there are no polygons");
+void object::test<34>() {
+ set_test_name("Processing region is empty when there are no polygons");
Envelope raster_extent{ 0, 10, 0, 10 };
@@ -691,7 +706,6 @@ void object::test<36>()
auto g = wkt_reader_.read("POLYGON ((1 3, 9 5, 8 9, 1 3))") ;
auto subdivided = GridIntersection::subdividePolygon(ext, *g, false);
check_subdivided_polygon(*g, *subdivided);
@@ -707,7 +721,6 @@ void object::test<37>()
auto g = wkt_reader_.read("POLYGON ((8.5 8.7, 12 8, 12 12, 8 12, 8.5 8.7))");
auto subdivided = GridIntersection::subdividePolygon(ext, *g, true);
@@ -767,14 +780,11 @@ void object::test<41>()
auto g = wkt_reader_.read("POLYGON ((5 5, 25 5, 25 25, 5 25, 5 5), (12 12, 12 14, 14 14, 12 12))");
- auto fracs = GridIntersection::getIntersectionFractions(ext, *g);
- float sum = 0;
- for (const auto& frac : *fracs) {
- sum += frac * 100;
- ensure_equals("", static_cast<double>(sum), g->getArea(), 1e-5);
template<>
@@ -854,7 +864,6 @@ void object::test<46>()
@@ -964,6 +973,4 @@ void object::test<52>()
commit cbfeefae155eb9abc11858f54b0a44d59d891adc
Date: Tue Nov 25 21:32:54 2025 -0500
PerimeterDistance: Add robust comparator
diff --git a/include/geos/operation/grid/PerimeterDistance.h b/include/geos/operation/grid/PerimeterDistance.h
index 2cf91dc2e..b02ac2750 100644
--- a/include/geos/operation/grid/PerimeterDistance.h
+++ b/include/geos/operation/grid/PerimeterDistance.h
@@ -50,6 +50,11 @@ class GEOS_DLL PerimeterDistance {
static bool
isBetweenCCW(double x, double a, double b);
+ /** Tests whether the perimeter distance of c1 is less than the perimeter distance of c2, in a
+ * robust way.
+ static bool
+ isLessThan(const geom::Envelope& e, const geom::CoordinateXY& c1, const geom::CoordinateXY& c2);
index 1c7297a3d..c4717a7f3 100644
@@ -519,8 +519,7 @@ createRectangle(const geom::GeometryFactory& gfact, const Envelope& env, std::ve
return gfact.toGeometry(&env);
} else {
auto perimeterDistanceCmp = [&env](const CoordinateXY& a, const CoordinateXY& b) {
- return PerimeterDistance::getPerimeterDistance(env, a) <
- PerimeterDistance::getPerimeterDistance(env, b);
+ return PerimeterDistance::isLessThan(env, a, b);
points.emplace_back(env.getMinX(), env.getMinY());
diff --git a/src/operation/grid/PerimeterDistance.cpp b/src/operation/grid/PerimeterDistance.cpp
index a8c3ff679..15c789e6f 100644
--- a/src/operation/grid/PerimeterDistance.cpp
+++ b/src/operation/grid/PerimeterDistance.cpp
@@ -61,7 +61,8 @@ PerimeterDistance::getPerimeterDistanceCCW(double measure1, double measure2, dou
return perimeter + measure1 - measure2;
-bool PerimeterDistance::isBetweenCCW(double x, double a, double b)
+bool
+PerimeterDistance::isBetweenCCW(double x, double a, double b)
if (a < b) {
return x <= a || x >= b;
@@ -69,5 +70,41 @@ bool PerimeterDistance::isBetweenCCW(double x, double a, double b)
return x <= a && x >= b;
+bool
+PerimeterDistance::isLessThan(const geom::Envelope& env, const geom::CoordinateXY& a, const geom::CoordinateXY& b) {
+ const auto pda = getPerimeterDistance(env, a);
+ const auto pdb = getPerimeterDistance(env, b);
+ if (pda < pdb) {
+ return true;
+ if (pda > pdb) {
+ return false;
+ if (a.equals2D(b)) {
+ return false;
+ // Points are not equal but are so close that their perimeter distance is the same.
+ // Need to figure out the spatial arrangement of the points.
+ if (a.y == b.y) {
+ // top
+ if (a.y == env.getMaxY()) {
+ return a.x < b.x;
+ // bottom
+ if (a.y == env.getMinY()) {
+ return b.x > a.x;
+ // left
+ if (a.x == env.getMinX()) {
+ return a.y < b.y;
+ // right
+ return b.y > a.y;
diff --git a/tests/unit/operation/grid/TraversalAreasTest.cpp b/tests/unit/operation/grid/TraversalAreasTest.cpp
index ff97182cd..a4664c8e2 100644
--- a/tests/unit/operation/grid/TraversalAreasTest.cpp
+++ b/tests/unit/operation/grid/TraversalAreasTest.cpp
@@ -2,9 +2,11 @@
#include <tut/tut_macros.hpp>
#include <utility.h>
+#include <geos/operation/grid/PerimeterDistance.h>
+using geos::operation::grid::PerimeterDistance;
using geos::operation::grid::Side;
using geos::operation::grid::Traversal;
using geos::operation::grid::TraversalAreas;
@@ -547,4 +549,57 @@ void object::test<29>()
ensure_equals(TraversalAreas::getLeftHandArea(b, traversals), 0);
+template<>
+template<>
+void object::test<30>()
+ set_test_name("PerimeterDistance::isLessThan robustness test");
+ Envelope env{ 146.52500000000001, 146.57500000000002, -33.625, -33.575000000000003};
+ // ----p1--p2--+
+ CoordinateXY p1{std::nextafter(env.getMaxX(), geos::DoubleNegInfinity), env.getMaxY()};
+ CoordinateXY p2{env.getMaxX(), env.getMaxY()};
+ ensure("points along ymax", PerimeterDistance::isLessThan(env, p1, p2));
+ // ----p2--p1--+
+ CoordinateXY p1{env.getMaxX(), env.getMinY()};
+ CoordinateXY p2{std::nextafter(env.getMaxX(), geos::DoubleNegInfinity), env.getMinY()};
+ ensure("points along ymin", PerimeterDistance::isLessThan(env, p1, p2));
+ // p2
+ // p1
+ CoordinateXY p1{env.getMinX(), std::nextafter(env.getMaxY(), geos::DoubleNegInfinity)};
+ CoordinateXY p2{env.getMinX(), env.getMaxY()};
+ ensure("points along xmin", PerimeterDistance::isLessThan(env, p1, p2));
+ // p1
+ // p2
+ CoordinateXY p1{env.getMaxX(), std::nextafter(env.getMinY(), geos::DoubleInfinity)};
+ CoordinateXY p2{env.getMaxX(), env.getMinY()};
+ ensure("points along xmax", PerimeterDistance::isLessThan(env, p1, p2));
commit a49a6b37c86783f2a08baf112b2351dd03a5f090
Date: Sun Nov 23 13:26:23 2025 -0500
GridIntersection: Fix mingw64 build
diff --git a/src/operation/grid/Grid.cpp b/src/operation/grid/Grid.cpp
index 8d3f9edf8..d4db6659b 100644
--- a/src/operation/grid/Grid.cpp
+++ b/src/operation/grid/Grid.cpp
@@ -19,7 +19,7 @@ using geos::geom::Envelope;
template<>
-Envelope
+Envelope GEOS_DLL
Grid<bounded_extent>::getCellEnvelope(size_t row, size_t col) const
// The ternary clauses below are used to make sure that the cells along
@@ -36,7 +36,7 @@ Grid<bounded_extent>::getCellEnvelope(size_t row, size_t col) const
template<>
-Envelope
+Envelope GEOS_DLL
Grid<infinite_extent>::getCellEnvelope(size_t row, size_t col) const
double cell_xmin, cell_xmax, cell_ymin, cell_ymax;
commit f24391283eaa4f25e8dbf86bd83af017d2bfaebf
Date: Sun Nov 23 13:17:38 2025 -0500
GridIntersection: Quiet cppcheck
index b3e8438ff..cd45402d5 100644
@@ -312,7 +312,7 @@ visitRings(const Envelope& box, const std::vector<const Traversal*>& traversals,
size_t from = 0;
size_t uniquePoints = 1;
- for (size_t to = 1; to < coords->size(); to++) {
+ for (size_t to = 1; to < coords->size(); to++) { // cppcheck-suppress invalidContainer
const CoordinateXY& prev = (*coords)[from];
const CoordinateXY& c = (*coords)[to];
commit d6bfe03ca9b8c21bef7927bebcf2a56811bf9c06
Date: Sun Nov 23 13:08:10 2025 -0500
GridIntersection: Fix MSVC build
index 9c983f61a..304c87a8f 100644
@@ -34,7 +34,7 @@ struct bounded_extent
-class Grid
+class GEOS_DLL Grid
public:
index c6b7a3d3d..b3e8438ff 100644
@@ -344,10 +344,9 @@ visitRings(const Envelope& box, const std::vector<const Traversal*>& traversals,
if (isEdgeSegment) {
- //if (isInterior) {
boxPoints.push_back(c);
boxPoints.push_back(prev);
coordinateStore.emplace_back(std::vector<CoordinateXY>{c});
double m = PerimeterDistance::getPerimeterDistance(box, c);
chains.emplace_back(m, m, coordinateStore.back());
commit f9b2389b982f7028ca74e62164ccfd147251621e
Date: Sun Nov 23 11:52:08 2025 -0500
GridIntersection: Address clang-tidy issues
diff --git a/include/geos/operation/grid/Cell.h b/include/geos/operation/grid/Cell.h
index 2079c73b9..a307cdaf4 100644
--- a/include/geos/operation/grid/Cell.h
+++ b/include/geos/operation/grid/Cell.h
@@ -79,6 +79,10 @@ class Cell
* @param c Coordinate to process
* @param prev_original The last *uninterpolated* coordinate preceding `c` in the
* boundary being processed
+ * @param exitOnBoundary Whether to exit the cell if `c` lies on the boundary. This is needed to ensure that
+ * exit nodes are added to both polygons whose shared boundary is coincident with the
+ * Cell boundary. If these nodes are not needed (for example, in the area-only case),
+ * it is more efficient to _not_ exit the cell.
* @param parentage an optional pointer indicating the source of the coordinate.
* @return `true` if the Coordinate was inside this cell, `false` otherwise
index e85d401cb..85a9e2cbd 100644
@@ -45,13 +45,13 @@ class GEOS_DLL GridIntersection
* @brief Compute the fraction of each cell in a rectangular grid that is covered by a Geometry.
* A matrix can be provided to which the fractions will be added.
- GridIntersection(const Grid<bounded_extent>& raster_grid, const geom::Geometry& g, std::shared_ptr<Matrix<float>> cov = nullptr);
+ GridIntersection(const Grid<bounded_extent>& raster_grid, const geom::Geometry& g, const std::shared_ptr<Matrix<float>>& cov = nullptr);
* @brief Compute the fraction of each cell in a rectangular grid that is covered by an Envelope.
- GridIntersection(const Grid<bounded_extent>& raster_grid, const geom::Envelope& box, std::shared_ptr<Matrix<float>> cov = nullptr);
+ GridIntersection(const Grid<bounded_extent>& raster_grid, const geom::Envelope& box, const std::shared_ptr<Matrix<float>>& cov = nullptr);
* @brief Return the intersection result matrix
index f728d012e..1c7297a3d 100644
@@ -85,7 +85,7 @@ GridIntersection::processingRegion(const Envelope& raster_extent, const Geometry
return ret;
-GridIntersection::GridIntersection(const Grid<bounded_extent>& raster_grid, const Geometry& g, std::shared_ptr<Matrix<float>> cov)
+GridIntersection::GridIntersection(const Grid<bounded_extent>& raster_grid, const Geometry& g, const std::shared_ptr<Matrix<float>>& cov)
: m_geometry_grid{ make_infinite(raster_grid, *g.getEnvelopeInternal()) }
, m_results{ cov ? cov : std::make_shared<Matrix<float>>(raster_grid.getNumRows(), raster_grid.getNumCols()) }
, m_first_geom{ true }
@@ -100,9 +100,11 @@ GridIntersection::GridIntersection(const Grid<bounded_extent>& raster_grid, cons
-GridIntersection::GridIntersection(const Grid<bounded_extent>& raster_grid, const Envelope& box, std::shared_ptr<Matrix<float>> cov)
+GridIntersection::GridIntersection(const Grid<bounded_extent>& raster_grid, const Envelope& box, const std::shared_ptr<Matrix<float>>& cov)
: m_geometry_grid{ make_infinite(raster_grid, box) }
+ , m_first_geom { true }
+ , m_areal{ false }
if (!m_geometry_grid.isEmpty()) {
processRectangularRing(box, true);
commit 3b4d3b2481ff5c9ac5df1bc7a7f68ae21d4fa58f
Date: Sun Nov 23 11:40:52 2025 -0500
GridIntersection: Avoid extra steps to generate valid polygons if they're not needed
index fe50d7106..2079c73b9 100644
@@ -83,7 +83,7 @@ class Cell
- bool take(const geom::CoordinateXY& c, const geom::CoordinateXY* prev_original, const void* parentage);
+ bool take(const geom::CoordinateXY& c, const geom::CoordinateXY* prev_original, bool exitOnBoundary, const void* parentage);
private:
std::vector<const Traversal*> getTraversals() const;
diff --git a/src/operation/grid/Cell.cpp b/src/operation/grid/Cell.cpp
index 9e1e7f680..45b652d7c 100644
--- a/src/operation/grid/Cell.cpp
+++ b/src/operation/grid/Cell.cpp
@@ -202,7 +202,7 @@ Cell::getLastTraversal()
bool
-Cell::take(const CoordinateXY& c, const CoordinateXY* prev_original, const void* parentage)
+Cell::take(const CoordinateXY& c, const CoordinateXY* prev_original, bool exitOnBoundary, const void* parentage)
Traversal& t = traversal_in_progress();
@@ -217,7 +217,9 @@ Cell::take(const CoordinateXY& c, const CoordinateXY* prev_original, const void*
const auto loc = getLocation(c);
- if (loc == Location::INSIDE) { //!= Location::OUTSIDE) {
+ const bool canTakeCoordinate = exitOnBoundary ? (loc == Location::INSIDE) : (loc != Location::OUTSIDE);
+ if (canTakeCoordinate) {
#if DEBUG_CELL
std::cout << "Still in " << m_box << " with " << c << std::endl;
#endif
index d35fa2cf9..f728d012e 100644
@@ -312,7 +312,7 @@ collect_lengths(const Matrix<std::unique_ptr<Cell>>& cells)
static void
-traverse_cells(Matrix<std::unique_ptr<Cell>>& cells, std::vector<CoordinateXY>& coords, const Grid<infinite_extent>& ring_grid, bool areal, const void* parentage)
+traverseCells(Matrix<std::unique_ptr<Cell>>& cells, std::vector<CoordinateXY>& coords, const Grid<infinite_extent>& ring_grid, bool areal, bool exitOnBoundary, const void* parentage)
size_t pos = 0;
size_t row = ring_grid.getRow(coords.front().y);
@@ -326,7 +326,7 @@ traverse_cells(Matrix<std::unique_ptr<Cell>>& cells, std::vector<CoordinateXY>&
const CoordinateXY* next_coord = last_exit ? last_exit : &coords[pos];
const CoordinateXY* prev_coord = pos > 0 ? &coords[pos - 1] : nullptr;
- cell.take(*next_coord, prev_coord, parentage);
+ cell.take(*next_coord, prev_coord, exitOnBoundary, parentage);
if (cell.getLastTraversal().isExited()) {
// Only push our exit coordinate if it's not same as the
@@ -440,7 +440,7 @@ GridIntersection::processLine(const LineString& ls, bool exterior_ring)
Matrix<std::unique_ptr<Cell>> cells(ring_grid.getNumRows(), ring_grid.getNumCols());
- traverse_cells(cells, coordsVec, ring_grid, m_areal, &ls);
+ traverseCells(cells, coordsVec, ring_grid, m_areal, false, &ls);
// Compute the fraction covered for all cells and assign it to
// the area matrix
@@ -466,8 +466,8 @@ GridIntersection::addRingResults(size_t i0, size_t j0, const Matrix<float>& area
-void
-traverse_ring(Matrix<std::unique_ptr<Cell>>& cells, const Grid<infinite_extent>& grid, const LineString& g, bool want_ccw)
+static void
+traverseRing(Matrix<std::unique_ptr<Cell>>& cells, const Grid<infinite_extent>& grid, const LineString& g, bool want_ccw, bool exitOnBoundary)
const geom::CoordinateSequence& seq = *g.getCoordinatesRO();
@@ -477,11 +477,11 @@ traverse_ring(Matrix<std::unique_ptr<Cell>>& cells, const Grid<infinite_extent>&
if (want_ccw != algorithm::Orientation::isCCW(&seq)) {
std::reverse(coords.begin(), coords.end());
- traverse_cells(cells, coords, grid, true, &g);
+ traverseCells(cells, coords, grid, true, exitOnBoundary, &g);
-void
-traverse_polygons(Matrix<std::unique_ptr<Cell>>& cells, const Grid<infinite_extent>& grid, const Geometry& g)
+static void
+traversePolygons(Matrix<std::unique_ptr<Cell>>& cells, const Grid<infinite_extent>& grid, const Geometry& g, bool exitOnBoundary)
using geom::GeometryTypeId;
@@ -493,14 +493,14 @@ traverse_polygons(Matrix<std::unique_ptr<Cell>>& cells, const Grid<infinite_exte
if (typ == GeometryTypeId::GEOS_POLYGON) {
const Polygon& poly = static_cast<const Polygon&>(gi);
const LineString& shell = *poly.getExteriorRing();
- traverse_ring(cells, grid, shell, true);
+ traverseRing(cells, grid, shell, true, exitOnBoundary);
std::size_t nrings = poly.getNumInteriorRing();
for (std::size_t j = 0; j < nrings; j++) {
- traverse_ring(cells, grid, *poly.getInteriorRingN(j), false);
+ traverseRing(cells, grid, *poly.getInteriorRingN(j), false, exitOnBoundary);
} else if (typ == GeometryTypeId::GEOS_MULTIPOLYGON || typ == GeometryTypeId::GEOS_GEOMETRYCOLLECTION) {
- traverse_polygons(cells, grid, gi);
+ traversePolygons(cells, grid, gi, exitOnBoundary);
} else {
throw util::GEOSException("Unsupported geometry type");
@@ -576,7 +576,7 @@ GridIntersection::subdividePolygon(const Grid<bounded_extent>& p_grid, const Geo
const Grid<infinite_extent> cell_grid = make_infinite(cropped_grid, gridExtent);
Matrix<std::unique_ptr<Cell>> cells(cell_grid.getNumRows(), cell_grid.getNumCols());
- traverse_polygons(cells, cell_grid, g);
+ traversePolygons(cells, cell_grid, g, true);
const auto areas = collectAreas(cells, cropped_grid, g);
index c485dd069..c6b7a3d3d 100644
@@ -221,12 +221,12 @@ hasEdgeSegment(const Envelope& box, const std::vector<CoordinateXY>& coords)
* @brief Identify counter-clockwise rings formed by the supplied coordinate vectors and the boundary of this box.
* @param box Box to be included in rings
- * @param coord_lists A list of coordinate vectors, with each vector representing a traversal of `box` or a closed ring.
+ * @param traversals A list of Traversals, with each vector representing a traversal of `box` or a closed ring.
* @param visitor Function be applied to each ring identified. Because `coord_lists` may include both clockwise and
* counter-clockwise closed rings, `visitor` will be provided with the orientation of each ring as an
* argument.
-template<typename F>
+template<bool validPolygonsAndCoverage, typename F>
void
visitRings(const Envelope& box, const std::vector<const Traversal*>& traversals, F&& visitor)
@@ -242,16 +242,35 @@ visitRings(const Envelope& box, const std::vector<const Traversal*>& traversals,
- const auto& coords = traversal->getCoordinates();
- double m = PerimeterDistance::getPerimeterDistance(box, coords.front());
- chains.emplace_back(m, m, coords);
- boxPoints.push_back(coords.front());
+ if constexpr (validPolygonsAndCoverage) {
+ const auto& coords = traversal->getCoordinates();
+ double m = PerimeterDistance::getPerimeterDistance(box, coords.front());
+ chains.emplace_back(m, m, coords);
+ boxPoints.push_back(coords.front());
continue;
const std::vector<CoordinateXY>* coords = &traversal->getCoordinates();
+ if constexpr (!validPolygonsAndCoverage) {
+ seq.setPoints(*coords);
+ const bool isCCW = algorithm::Orientation::isCCW(&seq);
+ visitor(*coords, isCCW, false);
+ if (isCCW) {
+ areaCCW += algorithm::Area::ofRing(*coords);
+ } else {
+ areaCW += algorithm::Area::ofRing(*coords);
+ continue;
@@ -279,71 +298,77 @@ visitRings(const Envelope& box, const std::vector<const Traversal*>& traversals,
continue;
- // TODO add node on edge.
+ // TODO add node on edge.
auto modCoords = scrollRingToStartOnEdge(box, *coords);
coordinateStore.push_back(std::move(modCoords));
coords = &coordinateStore.back();
- // Split coordinates into separate chains when they touch an edge
- // This prevents the creation of self-touching rings.
- // For area calculations, this doesn't matter, and the step can be skipped.
- size_t from = 0;
- size_t uniquePoints = 1;
+ // Split coordinates into separate chains when they touch an edge
+ // This prevents the creation of self-touching rings.
+ // For area calculations, this doesn't matter, and the step can be skipped.
+ size_t from = 0;
+ size_t uniquePoints = 1;
- const CoordinateXY& prev = (*coords)[from];
- const CoordinateXY& c = (*coords)[to];
+ const CoordinateXY& prev = (*coords)[from];
+ const CoordinateXY& c = (*coords)[to];
- if (!c.equals2D(prev)) {
- uniquePoints++;
- const bool ptOnTop = c.y == box.getMaxY();
- const bool ptOnBottom = c.y == box.getMinY();
- const bool ptOnLeft = c.x == box.getMinX();
- const bool ptOnRight = c.x == box.getMaxX();
- if (ptOnTop || ptOnBottom || ptOnLeft || ptOnRight) {
- bool isEdgeSegment = false;
- if (uniquePoints == 2) {
- if (ptOnTop && prev.y == c.y) {
- isEdgeSegment = true;
- isInterior = c.x < prev.x;
- } else if (ptOnBottom && prev.y == c.y) {
- isInterior = c.x > prev.x;
- } else if (ptOnLeft && prev.x == c.x) {
- isInterior = c.y < prev.y;
- } else if (ptOnRight && prev.x == c.x) {
- isInterior = c.y > prev.y;
+ if (!c.equals2D(prev)) {
+ uniquePoints++;
- if (isEdgeSegment) {
+ const bool ptOnTop = c.y == box.getMaxY();
+ const bool ptOnBottom = c.y == box.getMinY();
+ const bool ptOnLeft = c.x == box.getMinX();
+ const bool ptOnRight = c.x == box.getMaxX();
+ if (ptOnTop || ptOnBottom || ptOnLeft || ptOnRight) {
+ bool isEdgeSegment = false;
+ if (uniquePoints == 2) {
+ if (ptOnTop && prev.y == c.y) {
+ isEdgeSegment = true;
+ isInterior = c.x < prev.x;
+ } else if (ptOnBottom && prev.y == c.y) {
+ isInterior = c.x > prev.x;
+ } else if (ptOnLeft && prev.x == c.x) {
+ isInterior = c.y < prev.y;
+ } else if (ptOnRight && prev.x == c.x) {
+ isInterior = c.y > prev.y;
+ if (isEdgeSegment) {
+ //if (isInterior) {
- coordinateStore.emplace_back(std::vector<CoordinateXY>{c});
- double m = PerimeterDistance::getPerimeterDistance(box, c);
- chains.emplace_back(m, m, coordinateStore.back());
+ coordinateStore.emplace_back(std::vector<CoordinateXY>{c});
+ double m = PerimeterDistance::getPerimeterDistance(box, c);
+ chains.emplace_back(m, m, coordinateStore.back());
- coordinateStore.emplace_back(std::vector<CoordinateXY>{prev});
- m = PerimeterDistance::getPerimeterDistance(box, prev);
+ coordinateStore.emplace_back(std::vector<CoordinateXY>{prev});
+ m = PerimeterDistance::getPerimeterDistance(box, prev);
- } else {
- double start = PerimeterDistance::getPerimeterDistance(box, (*coords)[from]);
- double stop = PerimeterDistance::getPerimeterDistance(box, (*coords)[to]);
- chains.emplace_back(start, stop, *coords, from, to, traversal->getParentage());
+ } else {
+ double start = PerimeterDistance::getPerimeterDistance(box, (*coords)[from]);
+ double stop = PerimeterDistance::getPerimeterDistance(box, (*coords)[to]);
+ chains.emplace_back(start, stop, *coords, from, to, traversal->getParentage());
+ from = to;
+ uniquePoints = 1;
- from = to;
- uniquePoints = 1;
+ } else {
+ double start = PerimeterDistance::getPerimeterDistance(box, coords->front());
+ double stop = PerimeterDistance::getPerimeterDistance(box, coords->back());
+ chains.emplace_back(start, stop, *coords);
@@ -461,7 +486,9 @@ TraversalAreas::getLeftHandArea(const Envelope& box, const std::vector<const Tra
double ccw_sum = 0;
double cw_sum = 0;
- visitRings(box, coord_lists, [&cw_sum, &ccw_sum](const std::vector<CoordinateXY>& coords, bool isCCW, bool) {
+ constexpr bool validPolygons = false;
+ visitRings<validPolygons>(box, coord_lists, [&cw_sum, &ccw_sum](const std::vector<CoordinateXY>& coords, bool isCCW, bool) {
if (isCCW) {
ccw_sum += algorithm::Area::ofRing(coords);
} else {
@@ -481,7 +508,9 @@ TraversalAreas::getLeftHandRings(const GeometryFactory& gfact, const Envelope& b
bool checkValidity = false;
- visitRings(box, coord_lists, [&gfact, &shells, &holes, &checkValidity](const std::vector<CoordinateXY>& coords, bool isCCW, bool hasMultipleParents) {
+ constexpr bool validPolygons = true;
+ visitRings<validPolygons>(box, coord_lists, [&gfact, &shells, &holes, &checkValidity](const std::vector<CoordinateXY>& coords, bool isCCW, bool hasMultipleParents) {
commit 40d22f0948486fef5945b8bd68a76f1a6bdd8431
Date: Mon Sep 29 09:38:57 2025 -0400
GridIntersection: Generate valid coverage when polygon boundaries match
cell boundaries
index 054d10526..9c983f61a 100644
@@ -43,6 +43,8 @@ class Grid
, m_domain{}
, m_dx{ dx }
, m_dy{ dy }
+ , m_xOrig { extent.getMinX() }
+ , m_yOrig { extent.getMaxY() }
, m_num_rows{ 2 * extent_tag::padding + (extent.getMaxY() > extent.getMinY() ? static_cast<size_t>(std::round(extent.getHeight() / dy)) : 0) }
, m_num_cols{ 2 * extent_tag::padding + (extent.getMaxX() > extent.getMinX() ? static_cast<size_t>(std::round(extent.getWidth() / dx)) : 0) } {
@@ -53,6 +55,8 @@ class Grid
, m_dx{ dx }
, m_dy{ dy }
@@ -163,7 +167,7 @@ class Grid
- Grid<extent_tag> shrinkToFit(const geom::Envelope& b) const
+ Grid<extent_tag> shrinkToFit(const geom::Envelope& b, bool calcExtentFromNewGrid=true) const
return makeEmpty();
@@ -180,8 +184,8 @@ class Grid
double snapped_xmin = m_extent.getMinX() + static_cast<double>(col0 - extent_tag::padding) * m_dx;
double snapped_ymax = m_extent.getMaxY() - static_cast<double>(row1 - extent_tag::padding) * m_dy;
- // Make sure x0 and y1 are within the reduced extent. Because of
- // floating point round-off errors, this is not always the case.
+ // Make sure snapped_xmin and snapped_ymax are within the reduced extent.
+ // Because of floating point round-off errors, this is not always the case.
if (b.getMinX() < snapped_xmin) {
snapped_xmin -= m_dx;
col0--;
@@ -210,14 +214,17 @@ class Grid
num_cols--;
+ const double snapped_xmax = m_extent.getMinX() + static_cast<double>(col0 + num_cols - extent_tag::padding) * m_dx;
+ const double snapped_ymin = m_extent.getMaxY() - static_cast<double>(row1 + num_rows - extent_tag::padding) * m_dy;
// Perform offsets relative to the new xmin, ymax origin
// points. If this is not done, then floating point roundoff
// error can cause progressive shrink() calls with the same
// inputs to produce different results.
geom::Envelope reduced_box = {
snapped_xmin,
- std::max(snapped_xmin + static_cast<double>(num_cols) * m_dx, b.getMaxX()),
- std::min(snapped_ymax - static_cast<double>(num_rows) * m_dy, b.getMinY()),
+ calcExtentFromNewGrid ? std::max(snapped_xmin + static_cast<double>(num_cols) * m_dx, b.getMaxX()) : snapped_xmax,
+ calcExtentFromNewGrid ? std::min(snapped_ymax - static_cast<double>(num_rows) * m_dy, b.getMinY()) : snapped_ymin,
snapped_ymax
@@ -241,22 +248,35 @@ class Grid
- Grid<extent_tag> reduced{ reduced_box, m_dx, m_dy };
+ Grid<extent_tag> reduced{reduced_box, m_dx, m_dy};
- if (b.getMinX() < reduced.xmin() || b.getMinY() < reduced.ymin() || b.getMaxX() > reduced.xmax() || b.getMaxY() > reduced.ymax()) {
+ if (b.getMinX() < reduced.xmin() || b.getMinY() < reduced.ymin() || b.getMaxX() > reduced.xmax() || b.
+ getMaxY() > reduced.ymax()) {
+ if (!calcExtentFromNewGrid) {
+ reduced.m_xOrig = m_xOrig;
+ reduced.m_yOrig = m_yOrig;
+ reduced.m_skipRows = reduced.getRowOffset(*this);
+ reduced.m_skipCols = reduced.getColOffset(*this);
return reduced;
} else {
- Grid<extent_tag> reduced{ reduced_box, m_dx, m_dy , m_domain };
+ Grid<extent_tag> reduced{reduced_box, m_dx, m_dy, m_domain};
return reduced;
@@ -281,8 +301,17 @@ class Grid
double m_dx;
double m_dy;
+ double m_xOrig;
+ double m_yOrig;
size_t m_num_rows;
size_t m_num_cols;
+ friend Grid<infinite_extent> make_infinite(const Grid<bounded_extent>&, const geom::Envelope&);
+ friend Grid<bounded_extent> make_finite(const Grid<infinite_extent>&);
index 8acfd7466..9e1e7f680 100644
@@ -22,12 +22,15 @@
#define DEBUG_CELL 0
#include <iomanip>
+#include "geos/geom/GeometryFactory.h"
using geos::geom::Geometry;
using geos::geom::GeometryFactory;
+// Report where we leave an Envelope e when moving from c1 to c2
static Crossing
crossing(const geom::Envelope& e, const CoordinateXY& c1, const CoordinateXY& c2)
@@ -37,6 +40,10 @@ crossing(const geom::Envelope& e, const CoordinateXY& c1, const CoordinateXY& c2
return Crossing{ Side::TOP, c1.x, e.getMaxY() };
} else if (c2.y <= e.getMinY()) {
return Crossing{ Side::BOTTOM, c1.x, e.getMinY() };
+ //} else if (c2.x == e.getMinX()) {
+ // return Crossing{ Side::LEFT, c2.x, c2.y };
+ //} else if (c2.x == e.getMaxX()) {
+ // return Crossing{ Side::RIGHT, c2.x, c2.y };
} else {
throw std::runtime_error("Never get here.");
@@ -48,6 +55,10 @@ crossing(const geom::Envelope& e, const CoordinateXY& c1, const CoordinateXY& c2
return Crossing{ Side::RIGHT, e.getMaxX(), c1.y };
} else if (c2.x <= e.getMinX()) {
return Crossing{ Side::LEFT, e.getMinX(), c1.y };
+ //} else if (c2.y == e.getMinY()) {
+ // return Crossing{ Side::BOTTOM, c2.x, c2.y };
+ //} else if (c2.y == e.getMaxY()) {
+ // return Crossing{ Side::TOP, c2.x, c2.y };
} else {
throw std::runtime_error("Never get here");
@@ -205,7 +216,8 @@ Cell::take(const CoordinateXY& c, const CoordinateXY* prev_original, const void*
return true;
- if (getLocation(c) != Location::OUTSIDE) {
+ const auto loc = getLocation(c);
+ if (loc == Location::INSIDE) { //!= Location::OUTSIDE) {
#if DEBUG_CELL
#endif
@@ -217,6 +229,17 @@ Cell::take(const CoordinateXY& c, const CoordinateXY* prev_original, const void*
return true;
+ } else if (loc == Location::BOUNDARY) {
+ if (c.x == m_box.getMaxX()) {
+ t.exit(c, Side::RIGHT);
+ } else if (c.y == m_box.getMaxY()) {
+ t.exit(c, Side::TOP);
+ } else if (c.x == m_box.getMinX()) {
+ t.exit(c, Side::LEFT);
+ } else {
+ t.exit(c, Side::BOTTOM);
+ return false;
// We need to calculate the coordinate of the cell exit point using only uninterpolated coordinates.
index 28b84c709..8d3f9edf8 100644
@@ -23,15 +23,15 @@ Envelope
- // the right and bottom edges of our grid are slightly larger than m_dx,dy
+ // the right and bottom edges of our grid are slightly larger than m_dx, m_dy
// if needed to make sure that we capture our whole extent. This is necessary
// because xmin + nx*m_dx may be less than xmax because of floating point
// errors.
return {
- xmin() + static_cast<double>(col) * dx(),
- row == (getNumRows() - 1) ? ymin() : (ymax() - static_cast<double>(row + 1) * dy()),
- col == (getNumCols() - 1) ? xmax() : (xmin() + static_cast<double>(col + 1) * dx()),
- ymax() - static_cast<double>(row) * dy()
+ m_xOrig + static_cast<double>(col + m_skipCols) * dx(),
+ col == (getNumCols() - 1) ? xmax() : (m_xOrig + static_cast<double>(col + m_skipCols + 1) * dx()),
+ row == (getNumRows() - 1) ? ymin() : (m_yOrig - static_cast<double>(row + m_skipRows + 1) * dy()),
+ m_yOrig - static_cast<double>(row + m_skipRows) * dy()
@@ -44,56 +44,76 @@ Grid<infinite_extent>::getCellEnvelope(size_t row, size_t col) const
constexpr double PADDED_CELL_SIZE = 1.0;
if (col == 0) {
+ // Left-side padding
cell_xmin = std::min(xmin() - PADDED_CELL_SIZE, m_domain.getMinX());
} else if (col == getNumCols() - 1) {
+ // Right-side padding
cell_xmin = xmax(); // because rightmost col of regular may have different width from others
} else {
- cell_xmin = xmin() + static_cast<double>(col - 1) * dx();
+ // Internal
+ cell_xmin = m_xOrig + static_cast<double>(m_skipCols + col - 1) * dx();
switch (getNumCols() - col) {
case 1:
cell_xmax = std::max(xmax() + PADDED_CELL_SIZE, m_domain.getMaxX());
break;
case 2:
+ // Rightmost internal cell
cell_xmax = xmax();
break;
default:
- cell_xmax = xmin() + static_cast<double>(col) * dx();
+ cell_xmax = m_xOrig + static_cast<double>(m_skipCols + col) * dx();
if (row == 0) {
+ // Top row padding
cell_ymax = std::max(ymax() + PADDED_CELL_SIZE, m_domain.getMaxY());
} else if (row == getNumRows() - 1) {
+ // Bottom row padding
cell_ymax = ymin(); // because bottom row of regular may have different height from others
} else {
- cell_ymax = ymax() - static_cast<double>(row - 1) * dy();
+ cell_ymax = m_yOrig - static_cast<double>(m_skipRows + row - 1) * dy();
switch (getNumRows() - row) {
case 1:
cell_ymin = std::min(xmin() - PADDED_CELL_SIZE, m_domain.getMinY());
break;
case 2:
+ // Bottom-most internal row
cell_ymin = ymin();
break;
default:
- cell_ymin = ymax() - static_cast<double>(row) * dy();
+ cell_ymin = m_yOrig - static_cast<double>(m_skipRows + row) * dy();
- return { cell_xmin, cell_xmax, cell_ymin, cell_ymax };
+ Envelope box{ cell_xmin, cell_xmax, cell_ymin, cell_ymax };
+ return box;
make_infinite(const Grid<bounded_extent>& grid, const Envelope& domain)
- return { grid.getExtent(), grid.dx(), grid.dy() , domain };
+ Grid<infinite_extent> ret{ grid.getExtent(), grid.dx(), grid.dy() , domain };
+ ret.m_xOrig = grid.m_xOrig;
+ ret.m_yOrig = grid.m_yOrig;
+ ret.m_skipCols = grid.m_skipCols;
+ ret.m_skipRows = grid.m_skipRows;
+ return ret;
make_finite(const Grid<infinite_extent>& grid)
- return { grid.getExtent(), grid.dx(), grid.dy() };
+ Grid<bounded_extent> ret{ grid.getExtent(), grid.dx(), grid.dy() };
+ return ret;
index 93a388540..d35fa2cf9 100644
@@ -51,6 +51,8 @@ GridIntersection::getIntersectionFractions(const Grid<bounded_extent>& raster_gr
static Cell*
get_cell(Matrix<std::unique_ptr<Cell>>& cells, const Grid<infinite_extent>& ex, size_t row, size_t col)
+ assert(row < cells.getNumRows());
+ assert(col < cells.getNumCols());
if (cells(row, col) == nullptr) {
cells(row, col) = std::make_unique<Cell>(ex.getCellEnvelope(row, col));
@@ -565,9 +567,13 @@ GridIntersection::subdividePolygon(const Grid<bounded_extent>& p_grid, const Geo
- const auto cropped_grid = p_grid.crop(*g.getEnvelopeInternal());
+ const auto cropped_grid = p_grid.shrinkToFit(p_grid.getExtent().intersection(*g.getEnvelopeInternal()), false);
+ //const auto cropped_grid = p_grid;
- const Grid<infinite_extent> cell_grid = make_infinite(cropped_grid, *g.getEnvelopeInternal());
+ geom::Envelope gridExtent = *g.getEnvelopeInternal();
+ gridExtent.expandBy(1);
+ const Grid<infinite_extent> cell_grid = make_infinite(cropped_grid, gridExtent);
diff --git a/src/operation/grid/Traversal.cpp b/src/operation/grid/Traversal.cpp
index b1d2b544a..035c85b53 100644
--- a/src/operation/grid/Traversal.cpp
+++ b/src/operation/grid/Traversal.cpp
@@ -25,7 +25,9 @@ namespace geos::operation::grid {
void
Traversal::add(const CoordinateXY& c)
- m_coords.push_back(c);
+ if (m_coords.empty() || (m_coords.back() != c)) {
+ m_coords.push_back(c);
bool
index f49da38db..c485dd069 100644
@@ -13,6 +13,7 @@
#include <limits>
+#include <iomanip>
#include <optional>
#include <vector>
@@ -29,6 +30,8 @@
+#include "geos/operation/valid/RepeatedPointRemover.h"
@@ -229,7 +232,7 @@ visitRings(const Envelope& box, const std::vector<const Traversal*>& traversals,
std::vector<CoordinateChain> chains;
- std::vector<std::vector<CoordinateXY>> coordinateStore;
+ std::deque<std::vector<CoordinateXY>> coordinateStore;
@@ -239,6 +242,10 @@ visitRings(const Envelope& box, const std::vector<const Traversal*>& traversals,
continue;
@@ -317,10 +324,18 @@ visitRings(const Envelope& box, const std::vector<const Traversal*>& traversals,
- if (isInterior) {
} else {
@@ -352,7 +367,9 @@ visitRings(const Envelope& box, const std::vector<const Traversal*>& traversals,
- std::cout << "Identifying rings in box " << box.getMinX() << "-" << box.getMaxX() << ", " << box.getMinY() << "-" << box.getMaxY() << std::endl;
+ std::cout << std::setprecision(1);
+ std::cout << "Identifying rings in box " << box.getMinX() << ":" << box.getMaxX() << "," << box.getMinY() << ":" << box.getMaxY() << std::endl;
for (const auto& chain : chains) {
for (const auto& coord : chain) {
@@ -395,6 +412,13 @@ visitRings(const Envelope& box, const std::vector<const Traversal*>& traversals,
} while (chain != first_chain);
+ std::cout << "Completed chain ";
+ std::cout << c << ", ";
+ std::cout<< std::endl;
+#endif
if (hasMultipleUniqueCoordinates(coords)) {
visitor(coords, isCCW, hasMultipleParents);
@@ -471,9 +495,13 @@ TraversalAreas::getLeftHandRings(const GeometryFactory& gfact, const Envelope& b
auto seq = std::make_unique<CoordinateSequence>(0, false, false);
seq->reserve(coords.size());
- for (const auto& coord : coords) {
- seq->add(coord, false);
+ seq->setPoints(coords);
+ if (seq->hasRepeatedPoints()) {
+ seq = valid::RepeatedPointRemover::removeRepeatedPoints(seq.get());
+ //for (const auto& coord : coords) {
+ // seq->add(coord, false);
if (isCCW) {
index eee7f7242..9c47fd47d 100644
@@ -2,6 +2,7 @@
#include <geos/coverage/CoverageValidator.h>
#include <geos/operation/grid/GridIntersection.h>
+#include <geos/io/WKBReader.h>
#include <geos/io/WKTReader.h>
@@ -16,6 +17,7 @@ using geos::geom::Geometry;
namespace tut {
geos::io::WKTReader wkt_reader_;
+ geos::io::WKBReader wkb_reader_;
static void
check_cell_intersections(const Matrix<float>& actual, const std::vector<std::vector<float>>& v)
@@ -51,7 +53,16 @@ struct test_gridintersectiontest_data : GEOSTestBase {
tot_area += subg->getArea();
- ensure("subdivided polygons do not form a valid coverage", geos::coverage::CoverageValidator::isValid(components));
+ if (!geos::coverage::CoverageValidator::isValid(components))
+ auto invalidEdges = geos::coverage::CoverageValidator::validate(components);
+ invalidEdges.erase(std::remove_if(invalidEdges.begin(), invalidEdges.end(), [](const auto& edge) {
+ return edge == nullptr;
+ }), invalidEdges.end());
+ auto invalidEdgeGeom = input.getFactory()->buildGeometry(std::move(invalidEdges));
+ std::string message = "subdivided polygons do not form a valid coverage.\nsubdivided: " + subdivided.toString() + "\ninvalid edges: " + invalidEdgeGeom->toString();
+ fail(message);
@@ -596,6 +607,7 @@ template<>
template<>
+ return;
@@ -849,6 +861,24 @@ void object::test<46>()
template<>
template<>
void object::test<47>()
+ set_test_name("subdivide polygon whose edges follow cell boundaries (3)");
+ auto g = wkt_reader_.read("POLYGON ((4.5 0, 6.5 0, 6.5 2, 6.8 2, 6.5 4, 6.8 4, 5.5 7, 4.2 4, 4.5 4, 4.2 2, 4.5 2, 4.5 0))");
+template<>
+template<>
+void object::test<48>()
set_test_name("valid polygon coverage obtained when a traversed cell covered area ~= cell area");
@@ -864,7 +894,7 @@ void object::test<47>()
template<>
template<>
-void object::test<48>()
+void object::test<49>()
set_test_name("self-touching rings force geometry to be corrected");
@@ -879,7 +909,7 @@ void object::test<48>()
template<>
template<>
-void object::test<49>()
+void object::test<50>()
set_test_name("island in lake");
@@ -896,5 +926,44 @@ void object::test<49>()
+template<>
+template<>
+void object::test<51>()
+ set_test_name("subdivide polygon whose edges follow cell boundaries (4)");
+ Envelope e(-180, 180, -90, 90);
+ Grid<bounded_extent> ext(e, 0.1, 0.1);
+ std::stringstream wkb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
00000003A401A14CD0358C165C00000000000003A403925202661C165C00000000000003A4063F2069879C165C0A795422097003A40552FBFD3E4C165C0E46723D74D053A40B8B1D991EAC165C0C7F5EFFACC053A40C26B97361CC265C0F48B12F4170A3A405C1C959B28C265C0329067976F0D3A4039D384ED27C265C03D62F4DC420F3A40");
+ auto g = wkb_reader_.readHEX(wkb);
+template<>
+template<>
+void object::test<52>()
+ set_test_name("subdivide polygon whose edges follow cell boundaries (5)");
+ Grid<bounded_extent> ext(e, 0.05, 0.05);
+ std::stringstream wkb("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
79060dfd13d0344060f3ead6489663c0ab87f59b29d1344060f3ead6489663c040f1323236e13440172bf28ed68e63c040f1323236e13440172bf28ed68e63c09c4ce66215b8344006ae5057349063c09c4ce66215b83440b6b9313d619063c0aeefc34142bc3440");
diff --git a/tests/unit/operation/grid/GridTest.cpp b/tests/unit/operation/grid/GridTest.cpp
index c8160e3d6..0df5ea8a7 100644
--- a/tests/unit/operation/grid/GridTest.cpp
+++ b/tests/unit/operation/grid/GridTest.cpp
@@ -283,4 +283,54 @@ void object::test<15>()
ensure_equals(g2.getColOffset(g1), 20u);
+template<>
+template<>
+void object::test<16>()
+ set_test_name("Crop bounded grid while calculating cell boundaries relative to parent");
+ double res = 1.0/3601;
+ Grid<bounded_extent> grid{global, res, res};
+ const auto env0 = grid.getCellEnvelope(30, 30);
+ Envelope cropEnv(global.getMinX() + 17*res + 1e-6, global.getMaxX(), global.getMinY(), global.getMaxY() - 17*res - 1e-6);
+ auto cropped = grid.shrinkToFit(cropEnv, false);
+ const auto env1 = cropped.getCellEnvelope(13, 13);
+ ensure_equals("minX", env0.getMinX(), env1.getMinX());
+ ensure_equals("maxX", env0.getMaxX(), env1.getMaxX());
+ ensure_equals("minY", env0.getMinY(), env1.getMinY());
+ ensure_equals("maxY", env0.getMaxY(), env1.getMaxY());
+template<>
+template<>
+void object::test<17>()
+ set_test_name("Crop infinite grid while calculating cell boundaries relative to parent");
+ Grid<infinite_extent> grid{global, res, res, global};
+ auto rowOffset = cropped.getRowOffset(grid);
+ auto colOffset = cropped.getColOffset(grid);
+ const auto env1 = cropped.getCellEnvelope(30 - rowOffset, 30 - colOffset);
index 2053626c6..ff97182cd 100644
@@ -238,7 +238,7 @@ void object::test<11>()
TraversalVector traversals{ &t1, &t2 };
ensure_equals(TraversalAreas::getLeftHandArea(b, traversals), 99);
- ensure_equals_geometry(TraversalAreas::getLeftHandRings(gfact, b, traversals).get(), "POLYGON ((0 0, 10 0, 10 10, 0 10, 0 0), (1 1, 1 2, 2 2, 2 1, 1 1))");
+ ensure_equals_geometry(TraversalAreas::getLeftHandRings(gfact, b, traversals).get(), "POLYGON ((0 0, 10 0, 10 5, 10 10, 0 10, 0 0), (1 1, 1 2, 2 2, 2 1, 1 1))");
template<>
commit 88304f605e3f1c8190d0daf491a09210f87fe8e2
Author: Daniel Baston <dbaston at gmail.com>
Date: Fri Aug 29 13:41:09 2025 -0400
GridIntersection: Add extra nodes to rectangular Polygon outputs so that coverage is valid
index cc6b87277..fe50d7106 100644
@@ -40,6 +40,9 @@ class Cell
+ /// Get all points that fall on the specified side of this cell.
+ void getEdgePoints(Side s, std::vector<geom::CoordinateXY>& points) const;
const geom::Envelope& box() const { return m_box; }
double getWidth() const;
diff --git a/include/geos/operation/grid/Traversal.h b/include/geos/operation/grid/Traversal.h
index 539bb5a03..67164cc0b 100644
--- a/include/geos/operation/grid/Traversal.h
+++ b/include/geos/operation/grid/Traversal.h
@@ -61,6 +61,8 @@ class GEOS_DLL Traversal
Side getExitSide() const { return m_exit; }
+ const geom::CoordinateXY& getFirstCoordinate() const;
const geom::CoordinateXY& getLastCoordinate() const;
const geom::CoordinateXY& getExitCoordinate() const;
index fef8ed599..8acfd7466 100644
@@ -291,4 +291,20 @@ Cell::getCoveredPolygons(const GeometryFactory& gfact) const
return TraversalAreas::getLeftHandRings(gfact, m_box, coord_lists);
+void Cell::getEdgePoints(Side s, std::vector<CoordinateXY> &edgePoints) const
+ for (const Traversal& t : m_traversals) {
+ const auto& coords = t.getCoordinates();
+ if ((s == Side::LEFT && c.x == m_box.getMinX()) ||
+ (s == Side::RIGHT && c.x == m_box.getMaxX()) ||
+ (s == Side::BOTTOM && c.y == m_box.getMinY()) ||
+ (s == Side::TOP && c.y == m_box.getMaxY())) {
+ edgePoints.push_back(c);
index 1993486c7..93a388540 100644
@@ -22,6 +22,7 @@
#include <geos/operation/grid/Cell.h>
#include <geos/operation/grid/FloodFill.h>
#include <geos/operation/overlayng/CoverageUnion.h>
#include <geos/util.h>
@@ -504,6 +505,58 @@ traverse_polygons(Matrix<std::unique_ptr<Cell>>& cells, const Grid<infinite_exte
+// Create a rectangular polygon from a set of points lying on the boundary
+// of a specified envelope. The provided points do not need to include the
+// corners of the envelope itself.
+static std::unique_ptr<Geometry>
+createRectangle(const geom::GeometryFactory& gfact, const Envelope& env, std::vector<CoordinateXY>& points)
+ if (points.empty()) {
+ return gfact.toGeometry(&env);
+ } else {
+ auto perimeterDistanceCmp = [&env](const CoordinateXY& a, const CoordinateXY& b) {
+ return PerimeterDistance::getPerimeterDistance(env, a) <
+ PerimeterDistance::getPerimeterDistance(env, b);
+ points.emplace_back(env.getMinX(), env.getMinY());
+ points.emplace_back(env.getMinX(), env.getMaxY());
+ points.emplace_back(env.getMaxX(), env.getMinY());
+ points.emplace_back(env.getMaxX(), env.getMaxY());
+ std::sort(points.begin(), points.end(), perimeterDistanceCmp);
+ points.push_back(points.front());
+ auto seq = std::make_unique<geom::CoordinateSequence>(0, false, false);
+ seq->reserve(points.size());
+ for (const auto& c : points) {
+ seq->add(c, false);
+ auto ring = gfact.createLinearRing(std::move(seq));
+ return gfact.createPolygon(std::move(ring));
+// Get any points from adjacent cells that are also on the boundary of this cell.
+static std::vector<CoordinateXY>
+getExtraNodes(const Matrix<std::unique_ptr<Cell> > &cells, size_t i, size_t j) {
+ std::vector<CoordinateXY> points;
+ if (const Cell *above = cells(i - 1, j).get()) {
+ above->getEdgePoints(Side::BOTTOM, points);
+ if (const Cell *below = cells(i + 1, j).get()) {
+ below->getEdgePoints(Side::TOP, points);
+ if (const Cell *left = cells(i, j - 1).get()) {
+ left->getEdgePoints(Side::RIGHT, points);
+ if (const Cell *right = cells(i, j + 1).get()) {
+ right->getEdgePoints(Side::LEFT, points);
+ return points;
GridIntersection::subdividePolygon(const Grid<bounded_extent>& p_grid, const Geometry& g, bool includeExterior)
@@ -547,9 +600,11 @@ GridIntersection::subdividePolygon(const Grid<bounded_extent>& p_grid, const Geo
} else if (!edge && areas(i - 1, j - 1) == fill_values<float>::INTERIOR) {
// Cell is entirely covered by polygon
- // TODO: Add nodes from adjacent polygons?
+ // In order to have the outputs forms a properly noded coverage,
+ // we need to add nodes from adjacent polygons.
Envelope env = cell_grid.getCellEnvelope(i, j);
- geoms.push_back(gfact.toGeometry(&env));
+ std::vector<CoordinateXY> points = getExtraNodes(cells, i, j);
+ geoms.push_back(createRectangle(gfact, env, points));
index 4d31bbacd..b1d2b544a 100644
@@ -96,10 +96,16 @@ Traversal::isTraversed() const
return isEntered() && isExited();
+const CoordinateXY&
+Traversal::getFirstCoordinate() const
+ return m_coords.front();
const CoordinateXY&
Traversal::getLastCoordinate() const
- return m_coords.at(m_coords.size() - 1);
+ return m_coords.back();
const CoordinateXY&
index f4b76f95b..eee7f7242 100644
@@ -696,7 +696,7 @@ void object::test<37>()
- ensure_equals("", subdivided->getArea(), g->getArea(), 1e-8);
+ check_subdivided_polygon(*g, *subdivided);
template<>
@@ -710,9 +710,8 @@ void object::test<38>()
auto g = wkt_reader_.read("POINT (5 5)")->buffer(20);
- auto subdivided = GridIntersection::subdividePolygon(ext, *g, true);
template<>
@@ -726,9 +725,8 @@ void object::test<39>()
auto g = GeometryFactory::getDefaultInstance()->toGeometry(&e);
- auto subdivided = GridIntersection::subdividePolygon(ext, *g, false);
- ensure_equals("", subdivided->getArea(), e.getArea(), 1e-8);
template<>
@@ -742,9 +740,8 @@ void object::test<40>()
auto g = wkt_reader_.read("MULTIPOLYGON (((1 1, 15 1, 15 25, 1 25, 1 1), (12 12, 12 14, 14 14, 14 12, 12 12)), ((16 1, 25 1, 25 25, 16 25, 16 1)))");
template<>
@@ -827,10 +824,7 @@ void object::test<45>()
- // TODO: Currently fails because polygons do not form a valid coverage.
- // When we create a rectangle polygon for a fully interior cell, we do not add interior nodes
- // along its edges if they are present in the input geometry.
- //check_subdivided_polygon(*g, *subd);
template<>
@@ -849,10 +843,7 @@ void object::test<46>()
template<>
commit 81dbbc8c57069ad3e1571e959e759b2ba87bd123
Date: Tue Aug 12 10:16:48 2025 -0400
GridIntersection: Add (failing) test for coverage validity
index 5cbb2d522..1993486c7 100644
@@ -547,6 +547,7 @@ GridIntersection::subdividePolygon(const Grid<bounded_extent>& p_grid, const Geo
+ // TODO: Add nodes from adjacent polygons?
index 7f643c666..f4b76f95b 100644
@@ -823,17 +823,41 @@ void object::test<45>()
auto g = wkt_reader_.read("POLYGON ((4 0, 6 0, 6 2, 8 2, 6 4, 8 4, 5 7, 2 4, 4 4, 2 2, 4 2, 4 0))");
- //check_area(*rci, ext, *g);
- check_subdivided_polygon(*g, *subd);
+ // TODO: Currently fails because polygons do not form a valid coverage.
+ // When we create a rectangle polygon for a fully interior cell, we do not add interior nodes
+ // along its edges if they are present in the input geometry.
+ //check_subdivided_polygon(*g, *subd);
template<>
template<>
+ set_test_name("subdivide polygon whose edges follow cell boundaries (2)");
+ auto g = wkt_reader_.read("POLYGON ((4.5 0, 6.5 0, 6.5 2, 8.5 2, 6.5 4, 8.5 4, 5.5 7, 2.5 4, 4.5 4, 2.5 2, 4.5 2, 4.5 0))");
+template<>
+template<>
+void object::test<47>()
@@ -849,7 +873,7 @@ void object::test<46>()
template<>
template<>
-void object::test<47>()
@@ -864,7 +888,7 @@ void object::test<47>()
template<>
template<>
commit d1ccf4d11234360108dc927e4d1576f3126ca9b8
Date: Mon Aug 11 15:06:03 2025 -0400
GridIntersection: Generate correct polygons with nested shells
index 9451c3b1d..539bb5a03 100644
@@ -39,6 +39,8 @@ class GEOS_DLL Traversal
bool isClosedRing() const;
+ bool isClosedRingWithArea() const;
bool isEmpty() const;
bool isEntered() const;
index 82994912a..fef8ed599 100644
@@ -246,7 +246,11 @@ bool
Cell::isDetermined() const
for (const auto& t : m_traversals) {
- if (!t.isTraversed() && !t.isClosedRing()) {
+ if (t.isClosedRing()) {
+ if (!t.isClosedRingWithArea()) {
+ continue;
+ } else if (!t.isTraversed()) {
continue;
@@ -265,7 +269,7 @@ Cell::getTraversals() const
traversals.reserve(m_traversals.size());
- if (t.isTraversed() || t.isClosedRing()) {
+ if (t.isTraversed() || t.isClosedRingWithArea()) {
traversals.push_back(&t);
index 4750e4a0d..5cbb2d522 100644
@@ -247,7 +247,7 @@ GridIntersection::setAreal(bool areal)
m_areal = areal;
} else {
if (m_areal != areal) {
- throw std::runtime_error("Mixed-type geometries not supported.");
+ throw util::GEOSException("Mixed-type geometries not supported.");
@@ -371,7 +371,7 @@ traverse_cells(Matrix<std::unique_ptr<Cell>>& cells, std::vector<CoordinateXY>&
col++;
break;
default:
- throw std::runtime_error("Invalid traversal");
+ throw util::GEOSException("Invalid traversal");
@@ -499,7 +499,7 @@ traverse_polygons(Matrix<std::unique_ptr<Cell>>& cells, const Grid<infinite_exte
} else {
- throw std::runtime_error("Unsupported geometry type");
+ throw util::GEOSException("Unsupported geometry type");
index 2d9aa6705..4d31bbacd 100644
@@ -15,6 +15,7 @@
#include <cstddef>
#include <stdexcept>
+#include <geos/algorithm/Area.h>
#include <geos/operation/grid/Traversal.h>
using geos::geom::CoordinateXY;
@@ -58,6 +59,13 @@ Traversal::isClosedRing() const
return m_coords.size() >= 3 && m_coords[0] == m_coords[m_coords.size() - 1];
+bool
+Traversal::isClosedRingWithArea() const
+ // TODO: Don't actually need to compute the area here, just need to make sure there are >= 3 unique points.
+ return isClosedRing() && algorithm::Area::ofRing(m_coords) > 0;
bool
Traversal::isEntered() const
diff --git a/src/operation/grid/TraversalAreas.cpp b/src/operation/grid/TraversalAreas.cpp
index ca194efe3..f49da38db 100644
--- a/src/operation/grid/TraversalAreas.cpp
+++ b/src/operation/grid/TraversalAreas.cpp
@@ -13,6 +13,7 @@
#include <limits>
+#include <optional>
#include <vector>
@@ -156,6 +157,63 @@ isRing(const std::vector<CoordinateXY>& coords)
return coords.front() == coords.back() && hasMultipleUniqueCoordinates(coords);
+static bool
+containsProperly(const Envelope& e, const std::vector<CoordinateXY>& coords)
+ return std::all_of(coords.begin(), coords.end(), [&e](const auto& c) {
+ return e.containsProperly(c);
+scrollRingToStartOnEdge(const Envelope& box, const std::vector<CoordinateXY>& coords)
+ for (std::size_t i = 0; i < coords.size(); i++)
+ // Potentially this ring as an ordinary Traversal.
+ if (!box.containsProperly(coords[i])) {
+ // First, modify the ring so that its start point lies on the boundary.
+ std::vector<CoordinateXY> mod;
+ mod.reserve(coords.size());
+ for (std::size_t j = i; j < coords.size(); j++) {
+ if (mod.empty() || mod.back() != coords[j]) {
+ mod.push_back(coords[j]);
+ for (std::size_t j = 0; j < i; j++) {
+ mod.push_back(mod.front()); // close ring
+ return mod;
+ throw std::runtime_error("Ring does not touch box");
+static bool
+hasEdgeSegment(const Envelope& box, const std::vector<CoordinateXY>& coords)
+ for (size_t i = 1; i < coords.size(); i++) {
+ const CoordinateXY& p0 = coords[i - 1];
+ const CoordinateXY& p1 = coords[i];
+ if (p0.x == p1.x && (p0.x == box.getMinX() || p0.x == box.getMaxX())) {
+ return true;
+ if (p0.y == p1.y && (p0.y == box.getMinY() || p0.y == box.getMaxY())) {
+ return true;
+ return false;
@@ -171,37 +229,105 @@ visitRings(const Envelope& box, const std::vector<const Traversal*>& traversals,
chains.reserve(traversals.size() + 4);
+ std::vector<std::vector<CoordinateXY>> coordinateStore;
+ std::vector<CoordinateXY> boxPoints;
+ double areaCCW = 0;
+ double areaCW = 0;
+ std::optional<bool> isInterior;
for (const auto& traversal : traversals) {
if (!traversal->hasMultipleUniqueCoordinates()) {
continue;
+ const std::vector<CoordinateXY>* coords = &traversal->getCoordinates();
- if (isRing(coords)) {
- // Closed ring. Check orientation.
+ if (isRing(*coords)) {
+ if (containsProperly(box, *coords) || !hasEdgeSegment(box, *coords)) {
+ // TODO: Remove copy
+ CoordinateSequence seq(0, false, false);
- // TODO: Remove copy
- CoordinateSequence seq(0, false, false);
- seq.setPoints(coords);
- const bool isCCW = algorithm::Orientation::isCCW(&seq);
- constexpr bool hasMultipleParents = false;
- visitor(coords, isCCW, hasMultipleParents);
- } else {
- size_t from = 0;
- for (size_t to = 1; to < coords.size(); to++) {
- const CoordinateXY& c = coords[to];
- const bool ptIsOnEdge = c.x == box.getMinX() || c.x == box.getMaxX() || c.y == box.getMinY() || c.y == box.getMaxY();
- if (ptIsOnEdge) {
- double start = PerimeterDistance::getPerimeterDistance(box, coords[from]);
- double stop = PerimeterDistance::getPerimeterDistance(box, coords[to]);
- chains.emplace_back(start, stop, coords, from, to, traversal->getParentage());
- from = to;
+ // Add nodes to box edges
+ for (const auto& c : *coords) {
+ if (!box.containsProperly(c)) {
+ boxPoints.push_back(c);
+ constexpr bool hasMultipleParents = false;
+ visitor(*coords, isCCW, hasMultipleParents);
+ if (isCCW) {
+ } else {
+ continue;
+ auto modCoords = scrollRingToStartOnEdge(box, *coords);
+ coordinateStore.push_back(std::move(modCoords));
+ coords = &coordinateStore.back();
+ size_t from = 0;
+ uniquePoints++;
+ if (isInterior) {
+ boxPoints.push_back(prev);
+ } else {
+ from = to;
+ uniquePoints = 1;
@@ -272,8 +398,37 @@ visitRings(const Envelope& box, const std::vector<const Traversal*>& traversals,
+ double area = algorithm::Area::ofRing(coords);
+ areaCCW += area;
+ if (area == 0) {
+ isInterior = false;
+ if (areaCCW == 0 && areaCW == 0 && !isInterior.has_value()) {
+ throw util::GEOSException("Cannot determine coverage fraction (it is either 0 or 100%)");
+ if (areaCW > areaCCW || (areaCCW == 0 && areaCW == 0 && isInterior.value())) {
+ bool sortIsNeeded = !boxPoints.empty();
+ boxPoints.emplace_back(box.getMinX(), box.getMinY());
+ boxPoints.emplace_back(box.getMaxX(), box.getMinY());
+ boxPoints.emplace_back(box.getMaxX(), box.getMaxY());
+ boxPoints.emplace_back(box.getMinX(), box.getMaxY());
+ if (sortIsNeeded) {
+ std::sort(boxPoints.begin(), boxPoints.end(), [&box](const CoordinateXY& lhs, const CoordinateXY& rhs) {
+ return PerimeterDistance::getPerimeterDistance(box, lhs) <
+ PerimeterDistance::getPerimeterDistance(box, rhs);
+ boxPoints.push_back(boxPoints.front());
+ visitor(boxPoints, true, false);
double
@@ -281,11 +436,8 @@ TraversalAreas::getLeftHandArea(const Envelope& box, const std::vector<const Tra
double ccw_sum = 0;
double cw_sum = 0;
- bool found_a_ring = false;
- visitRings(box, coord_lists, [&cw_sum, &ccw_sum, &found_a_ring](const std::vector<CoordinateXY>& coords, bool isCCW, bool) {
- found_a_ring = true;
+ visitRings(box, coord_lists, [&cw_sum, &ccw_sum](const std::vector<CoordinateXY>& coords, bool isCCW, bool) {
if (isCCW) {
} else {
@@ -293,16 +445,6 @@ TraversalAreas::getLeftHandArea(const Envelope& box, const std::vector<const Tra
- if (!found_a_ring) {
- throw std::runtime_error("Cannot determine coverage fraction (it is either 0 or 100%)");
- // If this box has only clockwise rings (holes) then the area
- // of those holes should be subtracted from the complete box area.
- if (ccw_sum < cw_sum) {
- ccw_sum += box.getArea();
return ccw_sum - cw_sum;
@@ -313,15 +455,13 @@ TraversalAreas::getLeftHandRings(const GeometryFactory& gfact, const Envelope& b
std::vector<std::unique_ptr<LinearRing>> shells;
std::vector<std::unique_ptr<LinearRing>> holes;
- bool foundARing = false;
- visitRings(box, coord_lists, [&gfact, &shells, &holes, &foundARing, &checkValidity](const std::vector<CoordinateXY>& coords, bool isCCW, bool hasMultipleParents) {
+ visitRings(box, coord_lists, [&gfact, &shells, &holes, &checkValidity](const std::vector<CoordinateXY>& coords, bool isCCW, bool hasMultipleParents) {
// If a given ring was created from traversals from both a ring and shell, for example, it is possible for
// the ring to self-intersect. Rather than try and detect self-intersections o the fly (rare?) we check and
// repair validity in this limited case.
checkValidity |= hasMultipleParents;
- foundARing = true;
// finding a collapsed ring is sufficient to determine whether the cell interior is inside or outside,
// but we don't want to actually construct the ring.
@@ -344,10 +484,6 @@ TraversalAreas::getLeftHandRings(const GeometryFactory& gfact, const Envelope& b
- if (!foundARing) {
#if DEBUG_TRAVERSAL_AREAS
std::cout << "SHELLS" << std::endl;
for (const auto& shell: shells) {
@@ -363,17 +499,6 @@ TraversalAreas::getLeftHandRings(const GeometryFactory& gfact, const Envelope& b
return gfact.createPolygon();
- if (shells.empty() && !holes.empty()) {
- auto seq = std::make_unique<CoordinateSequence>(5, false, false);
- seq->setAt(CoordinateXY{box.getMinX(), box.getMinY()}, 0);
- seq->setAt(CoordinateXY{box.getMaxX(), box.getMinY()}, 1);
- seq->setAt(CoordinateXY{box.getMaxX(), box.getMaxY()}, 2);
- seq->setAt(CoordinateXY{box.getMinX(), box.getMaxY()}, 3);
- seq->setAt(CoordinateXY{box.getMinX(), box.getMinY()}, 4);
- shells.push_back(gfact.createLinearRing(std::move(seq)));
std::unique_ptr<Geometry> result;
if (holes.empty()) {
diff --git a/tests/unit/operation/grid/GridIntersectionTest.cpp b/tests/unit/operation/grid/GridIntersectionTest.cpp
index 7e2c9591e..7f643c666 100644
--- a/tests/unit/operation/grid/GridIntersectionTest.cpp
+++ b/tests/unit/operation/grid/GridIntersectionTest.cpp
@@ -33,7 +33,7 @@ struct test_gridintersectiontest_data : GEOSTestBase {
tot_area += static_cast<double>(f) * ext.dx()*ext.dy();
- ensure_equals(tot_area, input.getArea());
+ ensure_equals("Area does not equal input", tot_area, input.getArea(), 1e-6*tot_area);
static void
@@ -822,11 +822,13 @@ void object::test<45>()
Envelope e(0, 10, 0, 10);
Grid<bounded_extent> ext(e, 1, 1);
- auto tree = wkt_reader_.read("POLYGON ((4 0, 6 0, 6 2, 8 2, 6 4, 8 4, 5 7, 2 4, 4 4, 2 2, 4 2, 4 0))");
+ auto g = wkt_reader_.read("POLYGON ((4 0, 6 0, 6 2, 8 2, 6 4, 8 4, 5 7, 2 4, 4 4, 2 2, 4 2, 4 0))");
- auto subd = GridIntersection::subdividePolygon(ext, *tree, false);
+ auto rci = GridIntersection::getIntersectionFractions(ext, *g);
+ //check_area(*rci, ext, *g);
- check_subdivided_polygon(*tree, *subd);
+ auto subd = GridIntersection::subdividePolygon(ext, *g, false);
+ check_subdivided_polygon(*g, *subd);
template<>
@@ -860,5 +862,24 @@ void object::test<47>()
+template<>
+template<>
+ set_test_name("island in lake");
+ Envelope e(0, 30, 0, 30 );
+ Grid<bounded_extent> ext(e, 10, 10);
+ auto g = wkt_reader_.read("MULTIPOLYGON (((5 5, 25 5, 25 25, 5 25, 5 5), (11 11, 11 19, 19 19, 19 11, 11 11)), ((12 12, 14 12, 14 14, 12 14, 12 12)))");
+ check_area(*rci, ext, *g);
index 2933bbc1e..2053626c6 100644
@@ -194,7 +194,7 @@ template<>
template<>
void object::test<9>()
- set_test_name("Closed ring ccw overlapping edge");
+ set_test_name("Closed ring ccw touching edge");
Envelope b{ 0, 10, 00, 10 };
@@ -219,6 +219,7 @@ void object::test<10>()
TraversalVector traversals{ &t1 };
@@ -262,14 +263,14 @@ void object::test<13>()
set_test_name("Closed ring cw touching edge interior");
- Envelope b{ 0, 10, 0, 10 };
- std::vector<CoordinateXY> c1 = { { 1, 0 }, { 2, 2 }, { 3, 2 }, { 1, 0 } };
+ Envelope b(0, 10, 0, 10);
+ std::vector<CoordinateXY> c1{{8, 8}, {5, 0}, {5, 8}, {8, 8}};
Traversal t1 = make_traversal(c1);
- ensure_equals(TraversalAreas::getLeftHandArea(b, traversals), 99);
- ensure_equals_geometry(TraversalAreas::getLeftHandRings(gfact, b, traversals).get(), "POLYGON ((0 0, 10 0, 10 10, 0 10, 0 0), (1 0, 2 2, 3 2, 1 0))");
+ ensure_equals(TraversalAreas::getLeftHandArea(b, traversals), 88);
+ "POLYGON ((0 10, 10 10, 10 0, 5 0, 0 0, 0 10), (8 8, 5 8, 5 0, 8 8))");
template<>
@@ -278,14 +279,14 @@ void object::test<14>()
set_test_name("Closed ring cw overlapping edge");
- std::vector<CoordinateXY> c1 = { { 1, 0 }, { 1, 1 }, { 2, 1 }, { 1, 0 } };
+ std::vector<CoordinateXY> c1{{8, 8}, {8, 0}, {5, 0}, {5, 8}, {8, 8}};
- ensure_equals(TraversalAreas::getLeftHandArea(b, traversals), 99.5);
- ensure_equals_geometry(TraversalAreas::getLeftHandRings(gfact, b, traversals).get(), "POLYGON ((0 0, 10 0, 10 10, 0 10, 0 0), (1 0, 1 1, 2 1, 1 0))");
+ ensure_equals(TraversalAreas::getLeftHandArea(b, traversals), 76);
+ "POLYGON ((0 10, 10 10, 10 0, 8 0, 8 8, 5 8, 5 0, 0 0, 0 10))");
template<>
@@ -495,7 +496,26 @@ void object::test<26>()
template<>
template<>
-void object::test<28>() {
+void object::test<27>()
+ set_test_name("island with lake");
+ std::vector<CoordinateXY> c1{{1, 1}, {9, 1}, {9, 9}, {1, 9}, {1, 1}};
+ std::vector<CoordinateXY> c2{{2, 2}, {2, 4}, {4, 4}, {4, 2}, {2, 2}};
+ Traversal island = make_traversal(c1, &c1);
+ Traversal lake = make_traversal(c2, &c2);
+ TraversalVector traversals{ &island, &lake };
+ ensure_equals(TraversalAreas::getLeftHandArea(b, traversals), 60);
+ "POLYGON ((1 1, 1 9, 9 9, 9 1, 1 1), (2 2, 4 2, 4 4, 2 4, 2 2))");
+template<>
+template<>
+void object::test<28>()
set_test_name("lake with island");
@@ -506,8 +526,25 @@ void object::test<28>() {
ensure_equals(TraversalAreas::getLeftHandArea(b, traversals), 40);
- //ensure_equals_geometry(TraversalAreas::getLeftHandRings(gfact, b, traversals).get(),
- //"MULTIPOLYGON (((0 0, 10 0, 10 10, 0 10, 0 0), (1 1, 9 1, 9 9, 1 9, 1 1)), ((2 2, 4 2, 4 4, 2 4, 2 2)))");
+ "MULTIPOLYGON (((0 0, 10 0, 10 10, 0 10, 0 0), (1 1, 9 1, 9 9, 1 9, 1 1)), ((2 2, 4 2, 4 4, 2 4, 2 2)))");
+template<>
+template<>
+void object::test<29>()
+ set_test_name("traversals define region with no area");
+ // this can occur only with invalid polygons but we have historically handled these correctly
+ std::vector<CoordinateXY> c1{{0, 5}, {10, 5}};
+ std::vector<CoordinateXY> c2{{10, 5}, {0, 5}};
+ Traversal t1 = make_traversal(c1, &c1);
+ Traversal t2 = make_traversal(c2, &c2);
+ TraversalVector traversals{ &t1, &t2 };
+ ensure_equals(TraversalAreas::getLeftHandArea(b, traversals), 0);
commit e5f3fbe76e4aaabbef9dcb9419e92bc2a7b930fc
Date: Sun Aug 10 15:29:22 2025 -0400
GridIntersection: Avoid passing self-touching rings to Polygonizer
index ead45a77d..cc6b87277 100644
@@ -76,13 +76,14 @@ class Cell
+ * @param parentage an optional pointer indicating the source of the coordinate.
- bool take(const geom::CoordinateXY& c, const geom::CoordinateXY* prev_original = nullptr);
+ bool take(const geom::CoordinateXY& c, const geom::CoordinateXY* prev_original, const void* parentage);
private:
- std::vector<const std::vector<geom::CoordinateXY>*> getCoordLists() const;
+ std::vector<const Traversal*> getTraversals() const;
enum class Location
index 68bc516d7..9451c3b1d 100644
@@ -14,11 +14,12 @@
#pragma once
-#include <vector>
+#include <geos/export.h>
#include <geos/geom/Coordinate.h>
#include <geos/operation/grid/Side.h>
+#include <vector>
@@ -26,12 +27,13 @@ namespace geos::operation::grid {
* within a grid cell, as well as the `Side` from which the line
* entered and exited the cell.
-class Traversal
+class GEOS_DLL Traversal
public:
Traversal()
: m_entry{ Side::NONE }
, m_exit{ Side::NONE }
+ , m_parentage{ nullptr }
@@ -48,7 +50,7 @@ class Traversal
bool hasMultipleUniqueCoordinates() const;
/// Begin a Traversal on the specified `Side`
- void enter(const geom::CoordinateXY& c, Side s);
+ void enter(const geom::CoordinateXY& c, Side s, const void* parentage);
/// Complete a Traversal on the specified `Side`
void exit(const geom::CoordinateXY& c, Side s);
@@ -67,10 +69,13 @@ class Traversal
const std::vector<geom::CoordinateXY>& getCoordinates() const { return m_coords; }
+ const void* getParentage() const { return m_parentage; }
private:
std::vector<geom::CoordinateXY> m_coords;
Side m_entry;
Side m_exit;
+ const void* m_parentage;
diff --git a/include/geos/operation/grid/TraversalAreas.h b/include/geos/operation/grid/TraversalAreas.h
index 5d660c909..d8f88c327 100644
--- a/include/geos/operation/grid/TraversalAreas.h
+++ b/include/geos/operation/grid/TraversalAreas.h
@@ -19,6 +19,8 @@
+class Traversal;
class GEOS_DLL TraversalAreas {
public:
@@ -32,7 +34,7 @@ public:
* @return total area
static double
- getLeftHandArea(const geom::Envelope& box, const std::vector<const std::vector<geom::CoordinateXY>*>& coord_lists);
+ getLeftHandArea(const geom::Envelope& box, const std::vector<const Traversal*>& coord_lists);
* @brief Return an areal geometry representing the closed rings formed by this box and the provided Coordinate sequences
@@ -46,7 +48,7 @@ public:
* @return a Polygon or MultiPolygon geometry
static std::unique_ptr<geom::Geometry>
- getLeftHandRings(const geom::GeometryFactory& gfact, const geom::Envelope& box, const std::vector<const std::vector<geom::CoordinateXY>*>& coord_lists);
+ getLeftHandRings(const geom::GeometryFactory& gfact, const geom::Envelope& box, const std::vector<const Traversal*>& coord_lists);
index 38e121788..82994912a 100644
@@ -191,7 +191,7 @@ Cell::getLastTraversal()
bool
-Cell::take(const CoordinateXY& c, const CoordinateXY* prev_original)
+Cell::take(const CoordinateXY& c, const CoordinateXY* prev_original, const void* parentage)
@@ -201,7 +201,7 @@ Cell::take(const CoordinateXY& c, const CoordinateXY* prev_original)
std::cout << "Entering " << m_box << " from " << getSide(c) << " at " << c << std::endl;
#endif
- t.enter(c, getSide(c));
+ t.enter(c, getSide(c), parentage);
return true;
@@ -258,32 +258,32 @@ Cell::isDetermined() const
return false;
-std::vector<const std::vector<CoordinateXY>*>
-Cell::getCoordLists() const
+std::vector<const Traversal*>
+Cell::getTraversals() const
- std::vector<const std::vector<CoordinateXY>*> coord_lists;
- coord_lists.reserve(m_traversals.size());
+ std::vector<const Traversal*> traversals;
+ traversals.reserve(m_traversals.size());
- coord_lists.push_back(&t.getCoordinates());
+ traversals.push_back(&t);
- return coord_lists;
+ return traversals;
double
Cell::getCoveredFraction() const
- auto coord_lists = getCoordLists();
+ auto coord_lists = getTraversals();
return TraversalAreas::getLeftHandArea(m_box, coord_lists) / getArea();
diff --git a/src/operation/grid/GridIntersection.cpp b/src/operation/grid/GridIntersection.cpp
index 419c4f6eb..4750e4a0d 100644
--- a/src/operation/grid/GridIntersection.cpp
+++ b/src/operation/grid/GridIntersection.cpp
@@ -308,8 +308,8 @@ collect_lengths(const Matrix<std::unique_ptr<Cell>>& cells)
return lengths;
-void
-traverse_cells(Matrix<std::unique_ptr<Cell>>& cells, std::vector<CoordinateXY>& coords, const Grid<infinite_extent>& ring_grid, bool areal)
+static void
+traverse_cells(Matrix<std::unique_ptr<Cell>>& cells, std::vector<CoordinateXY>& coords, const Grid<infinite_extent>& ring_grid, bool areal, const void* parentage)
size_t pos = 0;
@@ -323,7 +323,7 @@ traverse_cells(Matrix<std::unique_ptr<Cell>>& cells, std::vector<CoordinateXY>&
- cell.take(*next_coord, prev_coord);
+ cell.take(*next_coord, prev_coord, parentage);
@@ -437,7 +437,7 @@ GridIntersection::processLine(const LineString& ls, bool exterior_ring)
- traverse_cells(cells, coordsVec, ring_grid, m_areal);
+ traverse_cells(cells, coordsVec, ring_grid, m_areal, &ls);
// the area matrix
@@ -473,8 +473,8 @@ traverse_ring(Matrix<std::unique_ptr<Cell>>& cells, const Grid<infinite_extent>&
- traverse_cells(cells, coords, grid, true);
+ traverse_cells(cells, coords, grid, true, &g);
void
index d98ece5ec..2d9aa6705 100644
@@ -34,7 +34,7 @@ Traversal::isEmpty() const
void
-Traversal::enter(const CoordinateXY& c, Side s)
+Traversal::enter(const CoordinateXY& c, Side s, const void* parentage)
if (!m_coords.empty()) {
throw std::runtime_error("Traversal already started");
@@ -42,6 +42,7 @@ Traversal::enter(const CoordinateXY& c, Side s)
add(c);
m_entry = s;
+ m_parentage = parentage;
void
index 3470ec5a2..ca194efe3 100644
@@ -22,6 +22,8 @@
#include <geos/geom/Geometry.h>
#include <geos/geom/GeometryFactory.h>
#include <geos/operation/grid/PerimeterDistance.h>
+#include <geos/operation/grid/Traversal.h>
+#include <geos/geom/util/GeometryFixer.h>
#include <geos/operation/polygonize/Polygonizer.h>
#include <geos/operation/grid/TraversalAreas.h>
@@ -42,37 +44,29 @@ struct CoordinateChain
const double start; // perimeter distance value of the first coordinate
const double stop; // perimeter distance value of the last coordinate
+ const void* parentage;
bool visited;
CoordinateChain(double p_start, double p_stop, const std::vector<CoordinateXY>& p_coords)
: start{ p_start }
, stop{ p_stop }
+ , parentage{ nullptr }
, visited{ false }
, m_start{ p_coords.begin() }
, m_stop{ p_coords.end() }
- CoordinateChain(double p_start, double p_stop, const std::vector<CoordinateXY>& p_coords, size_t from, size_t to)
+ CoordinateChain(double p_start, double p_stop, const std::vector<CoordinateXY>& p_coords, size_t from, size_t to, const void* p_parentage)
: start{ p_start }
, stop{ p_stop }
+ , parentage{ p_parentage }
, visited{ false }
, m_start{ std::next(p_coords.begin(), static_cast<std::ptrdiff_t>(from)) }
, m_stop{ std::next(p_coords.begin(), static_cast<std::ptrdiff_t>(to + 1)) }
- CoordinateChain(double pDistStart, double pDistStop,
- const std::vector<CoordinateXY>::const_iterator& itStart,
- const std::vector<CoordinateXY>::const_iterator& itStop)
- : start{ pDistStart }
- , stop{ pDistStop }
- , visited{ false }
- , m_start{ itStart }
- , m_stop{ itStop}
auto begin() const {
return m_start;
@@ -85,30 +79,6 @@ struct CoordinateChain
return m_stop - m_start;
-#if 0
- /// Tests whether this chain intersects the interior of the box.
- bool crossesInterior(const Envelope& box) const
- if (getSize() < 2) {
- return false;
- const CoordinateXY& origin = *begin();
- for (const auto& coord: *this) {
- if (coord.x != origin.x && coord.y != origin.y) {
- // Both X and Y have changed, we cannot be on the
- // edge where we started.
- return true;
- if (box.containsProperly(coord)) {
- return true;
- return false;
-#endif
private:
const std::vector<CoordinateXY>::const_iterator m_start;
const std::vector<CoordinateXY>::const_iterator m_stop;
@@ -197,75 +167,45 @@ isRing(const std::vector<CoordinateXY>& coords)
void
-visitRings(const Envelope& box, const std::vector<const std::vector<CoordinateXY>*>& coord_lists, F&& visitor)
+visitRings(const Envelope& box, const std::vector<const Traversal*>& traversals, F&& visitor)
- chains.reserve(coord_lists.size() + 4);
+ chains.reserve(traversals.size() + 4);
- bool validPolygons = true;
- for (const auto& coords : coord_lists) {
- if (!hasMultipleUniqueCoordinates(*coords)) {
+ for (const auto& traversal : traversals) {
+ if (!traversal->hasMultipleUniqueCoordinates()) {
continue;
- if (isRing(*coords)) {
+ if (isRing(coords)) {
- seq.setPoints(*coords);
- bool is_ccw = algorithm::Orientation::isCCW(&seq);
- visitor(*coords, is_ccw);
- } else if (validPolygons) {
+ seq.setPoints(coords);
+ visitor(coords, isCCW, hasMultipleParents);
+ } else {
size_t from = 0;
- for (size_t to = 1; to < coords->size(); to++) {
+ for (size_t to = 1; to < coords.size(); to++) {
+ const CoordinateXY& c = coords[to];
if (ptIsOnEdge) {
- chains.emplace_back(start, stop, *coords, from, to);
+ double start = PerimeterDistance::getPerimeterDistance(box, coords[from]);
+ double stop = PerimeterDistance::getPerimeterDistance(box, coords[to]);
+ chains.emplace_back(start, stop, coords, from, to, traversal->getParentage());
from = to;
- } else {
- auto from = coords->begin();
- auto to = coords->end();
- double start = PerimeterDistance::getPerimeterDistance(box, *from);
- double stop = PerimeterDistance::getPerimeterDistance(box, *std::prev(to));
- chains.emplace_back(start, stop, from, to);
-#if 0
- if (validPolygons) {
- const bool crossesInterior = std::any_of(chains.begin(), chains.end(), [&box](const auto& chain) {
- return chain.crossesInterior(box);
- if (crossesInterior) {
- for (auto& chain_ref : chains) {
- // Pre-visit all edge segments, and do nothing with them.
- if (chain_ref.getSize() == 2) {
- const CoordinateXY& from = *chain_ref.begin();
- const CoordinateXY& to = *std::next(chain_ref.begin());
- if (from.x == to.x &&(from.x == box.getMinX() || from.x == box.getMaxX())) {
- chain_ref.visited = true;
- else if (from.y == to.y && (from.y == box.getMinY() || from.y == box.getMaxY())) {
-#endif
double height{ box.getHeight() };
double width{ box.getWidth() };
double perimeter{ box.getPerimeter() };
@@ -285,7 +225,8 @@ visitRings(const Envelope& box, const std::vector<const std::vector<CoordinateXY
std::vector<CoordinateXY> coords;
- std::cout << "Identifying rings in box " << box << std::endl;
+ std::cout << std::endl << std::fixed;
+ std::cout << "Identifying rings in box " << box.getMinX() << "-" << box.getMaxX() << ", " << box.getMinY() << "-" << box.getMaxY() << std::endl;
std::cout << "Available chains:" << std::endl;
@@ -306,10 +247,16 @@ visitRings(const Envelope& box, const std::vector<const std::vector<CoordinateXY
#endif
CoordinateChain* chain = std::addressof(chain_ref);
const CoordinateChain* first_chain = chain;
+ bool hasMultipleParents = false;
+ constexpr bool isCCW = true;
do {
chain->visited = true;
coords.insert(coords.end(), chain->begin(), chain->end());
+ if (chain->parentage != nullptr && chain->parentage != first_chain->parentage) {
+ hasMultipleParents = true;
std::cout << "Added chain ";
for (const auto& c : *chain) {
@@ -324,22 +271,22 @@ visitRings(const Envelope& box, const std::vector<const std::vector<CoordinateXY
coords.push_back(coords[0]);
- visitor(coords, true);
double
-TraversalAreas::getLeftHandArea(const Envelope& box, const std::vector<const std::vector<CoordinateXY>*>& coord_lists)
+TraversalAreas::getLeftHandArea(const Envelope& box, const std::vector<const Traversal*>& coord_lists)
double ccw_sum = 0;
double cw_sum = 0;
- visitRings(box, coord_lists, [&cw_sum, &ccw_sum, &found_a_ring](const std::vector<CoordinateXY>& coords, bool is_ccw) {
+ visitRings(box, coord_lists, [&cw_sum, &ccw_sum, &found_a_ring](const std::vector<CoordinateXY>& coords, bool isCCW, bool) {
- if (is_ccw) {
+ if (isCCW) {
} else {
@@ -360,17 +307,21 @@ TraversalAreas::getLeftHandArea(const Envelope& box, const std::vector<const std
-TraversalAreas::getLeftHandRings(const GeometryFactory& gfact, const Envelope& box, const std::vector<const std::vector<CoordinateXY>*>& coord_lists)
+TraversalAreas::getLeftHandRings(const GeometryFactory& gfact, const Envelope& box, const std::vector<const Traversal*>& coord_lists) {
using geom::LinearRing;
+ bool foundARing = false;
+ bool checkValidity = false;
- visitRings(box, coord_lists, [&gfact, &box, &shells, &holes, &found_a_ring](const std::vector<CoordinateXY>& coords, bool is_ccw) {
+ visitRings(box, coord_lists, [&gfact, &shells, &holes, &foundARing, &checkValidity](const std::vector<CoordinateXY>& coords, bool isCCW, bool hasMultipleParents) {
+ // If a given ring was created from traversals from both a ring and shell, for example, it is possible for
+ // the ring to self-intersect. Rather than try and detect self-intersections o the fly (rare?) we check and
+ // repair validity in this limited case.
+ checkValidity |= hasMultipleParents;
+ foundARing = true;
@@ -381,71 +332,50 @@ TraversalAreas::getLeftHandRings(const GeometryFactory& gfact, const Envelope& b
-#if 0
- if (!seq.isEmpty()) {
- const CoordinateXY& prev = seq.back();
- const bool isHorizontal = coord.y == prev.y;
- const bool isVertical = coord.x == prev.x;
- // When an input geometry linework follows grid cell boundaries, we can end up
- // with duplicate points or zero-area spikes in rings. These don't affect the
- // area calculations, but we need to remove them before constructing the geometry.
- // Skip duplicate points
- if (isHorizontal && isVertical) {
- continue;
- // Skip rightward along top edge
- if (isHorizontal && coord.y == box.getMaxY() && coord.x > prev.x) {
- continue;
- // Skip leftward along bottom edge
- if (isHorizontal && coord.y == box.getMinY() && coord.x < prev.x) {
- continue;
- // Skip downward along right edge
- if (isVertical && coord.x == box.getMaxX() && coord.y < prev.y) {
- continue;
- // Skip upward along left edge
- if (isVertical && coord.x == box.getMinX() && coord.y > prev.y) {
- continue;
-#endif
- if (is_ccw) {
+ if (isCCW) {
shells.push_back(std::move(ring));
} else {
holes.push_back(std::move(ring));
+ if (!foundARing) {
+#if DEBUG_TRAVERSAL_AREAS
+ std::cout << "SHELLS" << std::endl;
+ for (const auto& shell: shells) {
+ std::cout << shell->toString() << std::endl;
+ std::cout << "HOLES" << std::endl;
+ for (const auto& hole: holes) {
+ std::cout << hole->toString() << std::endl;
+#endif
if (shells.empty() && holes.empty()) {
- CoordinateSequence seq(5, false, false);
- seq.setAt(CoordinateXY{box.getMinX(), box.getMinY()}, 0);
- seq.setAt(CoordinateXY{box.getMaxX(), box.getMinY()}, 1);
- seq.setAt(CoordinateXY{box.getMaxX(), box.getMaxY()}, 2);
- seq.setAt(CoordinateXY{box.getMinX(), box.getMaxY()}, 3);
- seq.setAt(CoordinateXY{box.getMinX(), box.getMinY()}, 4);
+ auto seq = std::make_unique<CoordinateSequence>(5, false, false);
+ seq->setAt(CoordinateXY{box.getMinX(), box.getMinY()}, 0);
+ seq->setAt(CoordinateXY{box.getMaxX(), box.getMinY()}, 1);
+ seq->setAt(CoordinateXY{box.getMaxX(), box.getMaxY()}, 2);
+ seq->setAt(CoordinateXY{box.getMinX(), box.getMaxY()}, 3);
+ seq->setAt(CoordinateXY{box.getMinX(), box.getMinY()}, 4);
+ std::unique_ptr<Geometry> result;
std::vector<std::unique_ptr<Geometry>> polygons;
for (auto& shell : shells) {
@@ -453,27 +383,44 @@ TraversalAreas::getLeftHandRings(const GeometryFactory& gfact, const Envelope& b
if (polygons.size() == 1) {
- return std::move(polygons.front());
+ result = std::move(polygons.front());
} else {
- return gfact.createMultiPolygon(std::move(polygons));
+ result = gfact.createMultiPolygon(std::move(polygons));
+ } else if (shells.size() == 1) {
+ result = gfact.createPolygon(std::move(shells.front()), std::move(holes));
+ } else {
+ polygonize::Polygonizer polygonizer(true);
+ std::vector<std::unique_ptr<Geometry>> holder;
+ for (const auto& shell : shells) {
+ if (checkValidity && !shell->isSimple()) {
+ holder.push_back(shell->Union());
+ polygonizer.add(holder.back().get());
+ } else {
+ polygonizer.add(static_cast<const Geometry*>(shell.get()));
+ for (const auto& hole : holes) {
+ if (checkValidity && !hole->isSimple()) {
+ holder.push_back(hole->Union());
+ } else {
+ polygonizer.add(static_cast<const Geometry*>(hole.get()));
+ auto polygonized = polygonizer.getPolygons();
+ result = gfact.createMultiPolygon(std::move(polygonized));
+ checkValidity = false;
- if (shells.size() == 1) {
- return gfact.createPolygon(std::move(shells.front()), std::move(holes));
+ if (checkValidity && !result->isValid()) {
+ result = geom::util::GeometryFixer::fix(result.get());
- polygonize::Polygonizer polygonizer(true);
- for (const auto& shell : shells) {
- polygonizer.add(static_cast<const Geometry*>(shell.get()));
- for (const auto& hole : holes) {
- polygonizer.add(static_cast<const Geometry*>(hole.get()));
- auto polygonized = polygonizer.getPolygons();
- return gfact.createMultiPolygon(std::move(polygonized));
+ return result;
index 1919d2fb0..7e2c9591e 100644
@@ -25,6 +25,17 @@ struct test_gridintersectiontest_data : GEOSTestBase {
ensure_equals(actual, expected);
+ static void
+ check_area(const Matrix<float>& actual, const Grid<bounded_extent> ext, const Geometry& input)
+ double tot_area = 0;
+ for (float f : actual) {
+ tot_area += static_cast<double>(f) * ext.dx()*ext.dy();
+ ensure_equals(tot_area, input.getArea());
static void
check_subdivided_polygon(const Geometry& input, const Geometry& subdivided)
@@ -43,7 +54,7 @@ struct test_gridintersectiontest_data : GEOSTestBase {
std::string error = "subdivided polygon area does not match input: " + subdivided.toString();
- ensure_equals(error, tot_area, input.getArea(), 1e-14);
+ ensure_equals(error, tot_area, input.getArea(), input.getArea() * 1e-14);
@@ -834,4 +845,20 @@ void object::test<46>()
+template<>
+template<>
+ set_test_name("self-touching rings force geometry to be corrected");
+ Envelope e(3000000, 10000000, 525000, 6595000);
+ Grid<bounded_extent> ext(e, 10000, 10000);
+ auto g = wkt_reader_.read("MultiPolygon (((5196000 2052000, 5184185 2054473, 5182537 2054890, 5182796 2055916, 5182006 2056057, 5182183 2056774, 5181023 2058767, 5180374 2058127, 5180034 2058226, 5179989 2057895, 5179854 2057364, 5179674 2056658, 5179236 2056764, 5179289 2055146, 5180169 2052000, 5175958 2052000, 5175900 2068000, 5196000 2068000, 5196000 2052000),(5183832 2056356, 5183529 2055571, 5184300 2055372, 5184506 2056186, 5183832 2056356),(5179491 2062463, 5179636 2059879, 5180441 2059638, 5180438 2059666, 5180855 2061320, 5180076 2061534, 5180260 2062270, 5179491 2062463),(5181043 2062069, 5181035 2065286, 5180449.50561340618878603 2064531.85610372573137283, 5179685 2063225, 5180476 2063057, 5180260 2062270, 5181043 2062069)),((5180501 2056431, 5180341 2055640, 5179465 2055835, 5179674 2056658, 5180501 2056431)),((5180501 2056431, 5180641 2057164, 5181406 2056969, 5181239 2056302, 5180501 2056431))) ");
diff --git a/tests/unit/operation/grid/TraversalAreasTest.cpp b/tests/unit/operation/grid/TraversalAreasTest.cpp
index 980439c45..2933bbc1e 100644
--- a/tests/unit/operation/grid/TraversalAreasTest.cpp
+++ b/tests/unit/operation/grid/TraversalAreasTest.cpp
@@ -2,8 +2,11 @@
#include <tut/tut_macros.hpp>
#include <utility.h>
+using geos::operation::grid::Side;
+using geos::operation::grid::Traversal;
using geos::operation::grid::TraversalAreas;
using geos::geom::Envelope;
@@ -11,7 +14,23 @@ using geos::geom::GeometryFactory;
namespace tut {
struct test_traversalareastest_data : GEOSTestBase {
- using TraversalVector = std::vector<const std::vector<CoordinateXY>*>;
+ using TraversalVector = std::vector<const Traversal*>;
+ Traversal make_traversal(const std::vector<CoordinateXY>& coords, void* parentage=nullptr)
+ Traversal t;
+ if (!coords.empty()) {
+ t.enter(coords.front(), Side::NONE, parentage);
+ for (std::size_t i = 1; i < coords.size() - 1; i++) {
+ t.add(coords[i]);
+ t.exit(coords.back(), Side::NONE);
+ return t;
const GeometryFactory& gfact = *GeometryFactory::getDefaultInstance();
@@ -30,13 +49,16 @@ void object::test<1>()
- std::vector<CoordinateXY> traversal{ { 7, 0 }, { 7, 1 }, { 6, 1 }, { 6, 0 } };
- TraversalVector traversals{ &traversal };
+ std::vector<CoordinateXY> coords{ { 7, 0 }, { 7, 1 }, { 6, 1 }, { 6, 0 } };
+ Traversal t = make_traversal(coords);
+ TraversalVector traversals{ &t };
ensure_equals(TraversalAreas::getLeftHandArea(b, traversals), 1);
ensure_equals_geometry(TraversalAreas::getLeftHandRings(gfact, b, traversals).get(), "POLYGON ((6 0, 7 0, 7 1, 6 1, 6 0))");
- std::reverse(traversal.begin(), traversal.end());
+ std::reverse(coords.begin(), coords.end());
+ t = make_traversal(coords);
+ traversals = { &t };
ensure_equals_geometry(TraversalAreas::getLeftHandRings(gfact, b, traversals).get(), "POLYGON ((0 0, 6 0, 6 1, 7 1, 7 0, 10 0, 10 10, 0 10, 0 0))");
@@ -49,8 +71,9 @@ void object::test<2>()
- std::vector<CoordinateXY> traversal{ { 5, 0 }, { 5, 5 }, { 0, 5 } };
+ std::vector<CoordinateXY> coords{ { 5, 0 }, { 5, 5 }, { 0, 5 } };
ensure_equals(TraversalAreas::getLeftHandArea(b, traversals), 25);
ensure_equals_geometry(TraversalAreas::getLeftHandRings(gfact, b, traversals).get(), "POLYGON ((0 0, 5 0, 5 5, 0 5, 0 0))");
@@ -64,8 +87,9 @@ void object::test<3>()
- std::vector<CoordinateXY> traversal{ { 4, 0 }, { 4, 10 } };
+ std::vector<CoordinateXY> coords{ { 4, 0 }, { 4, 10 } };
ensure_equals_geometry(TraversalAreas::getLeftHandRings(gfact, b, traversals).get(), "POLYGON ((0 0, 4 0, 4 10, 0 10, 0 0))");
@@ -79,9 +103,10 @@ void object::test<4>()
- std::vector<CoordinateXY> t1 = { { 2, 10 }, { 2, 0 } };
- std::vector<CoordinateXY> t2 = { { 4, 0 }, { 4, 10 } };
+ std::vector<CoordinateXY> c1 = { { 2, 10 }, { 2, 0 } };
+ std::vector<CoordinateXY> c2 = { { 4, 0 }, { 4, 10 } };
+ Traversal t1 = make_traversal(c1);
+ Traversal t2 = make_traversal(c2);
ensure_equals(TraversalAreas::getLeftHandArea(b, traversals), 20);
@@ -96,13 +121,21 @@ void object::test<5>()
- std::vector<CoordinateXY> t1 = { { 2, 0 }, { 2, 2 }, { 0, 2 } }; // 2x2 = 4
- std::vector<CoordinateXY> t2 = { { 3, 10 }, { 3, 0 } };
- std::vector<CoordinateXY> t3 = { { 5, 0 }, { 5, 10 } }; // 2x10 = 20
- std::vector<CoordinateXY> t4 = { { 8, 10 }, { 10, 8 } }; // 2x2/2 = 2
- std::vector<CoordinateXY> t5 = { { 10, 6 }, { 8, 6 }, { 8, 3 }, { 10, 3 } }; // 2x3 = 6
- std::vector<CoordinateXY> t6 = { { 10, 4 }, { 9, 4 }, { 9, 5 }, { 10, 5 } }; // 1x1 = 1 (subtracted)
- std::vector<CoordinateXY> t7 = { { 10, 2 }, { 8, 2 }, { 8, 0 } }; // 2x2 = 4
+ std::vector<CoordinateXY> c1 = { { 2, 0 }, { 2, 2 }, { 0, 2 } }; // 2x2 = 4
+ std::vector<CoordinateXY> c2 = { { 3, 10 }, { 3, 0 } };
+ std::vector<CoordinateXY> c3 = { { 5, 0 }, { 5, 10 } }; // 2x10 = 20
+ std::vector<CoordinateXY> c4 = { { 8, 10 }, { 10, 8 } }; // 2x2/2 = 2
+ std::vector<CoordinateXY> c5 = { { 10, 6 }, { 8, 6 }, { 8, 3 }, { 10, 3 } }; // 2x3 = 6
+ std::vector<CoordinateXY> c6 = { { 10, 4 }, { 9, 4 }, { 9, 5 }, { 10, 5 } }; // 1x1 = 1 (subtracted)
+ std::vector<CoordinateXY> c7 = { { 10, 2 }, { 8, 2 }, { 8, 0 } }; // 2x2 = 4
+ Traversal t3 = make_traversal(c3);
+ Traversal t4 = make_traversal(c4);
+ Traversal t5 = make_traversal(c5);
+ Traversal t6 = make_traversal(c6);
+ Traversal t7 = make_traversal(c7);
TraversalVector traversals{ &t1, &t2, &t3, &t4, &t5, &t6, &t7 };
@@ -133,7 +166,8 @@ void object::test<7>()
- std::vector<CoordinateXY> t1{ { 4, 0 }, { 4, 0 } };
+ std::vector<CoordinateXY> c1{ { 4, 0 }, { 4, 0 } };
ensure_THROW(TraversalAreas::getLeftHandArea(b, traversals), std::exception);
@@ -148,7 +182,8 @@ void object::test<8>()
- std::vector<CoordinateXY> t1 = { { 1, 1 }, { 2, 1 }, { 2, 2 }, { 1, 2 }, { 1, 1 } };
+ std::vector<CoordinateXY> c1 = { { 1, 1 }, { 2, 1 }, { 2, 2 }, { 1, 2 }, { 1, 1 } };
@@ -163,7 +198,8 @@ void object::test<9>()
- std::vector<CoordinateXY> t1 = { { 1, 0 }, { 2, 1 }, { 1, 1 }, { 1, 0 } };
+ std::vector<CoordinateXY> c1 = { { 1, 0 }, { 2, 1 }, { 1, 1 }, { 1, 0 } };
ensure_equals(TraversalAreas::getLeftHandArea(b, traversals), 0.5);
@@ -178,7 +214,8 @@ void object::test<10>()
- std::vector<CoordinateXY> t1 = { { 1, 1 }, { 1, 2 }, { 2, 2 }, { 2, 1 }, { 1, 1 } };
+ std::vector<CoordinateXY> c1 = { { 1, 1 }, { 1, 2 }, { 2, 2 }, { 2, 1 }, { 1, 1 } };
@@ -193,8 +230,10 @@ void object::test<11>()
- std::vector<CoordinateXY> t2 = { { 10, 5 }, { 10, 5 } };
+ std::vector<CoordinateXY> c2 = { { 10, 5 }, { 10, 5 } };
@@ -209,7 +248,8 @@ void object::test<12>()
- std::vector<CoordinateXY> t1 = { { 0, 0 }, { 2, 2 }, { 3, 2 }, { 0, 0 } };
+ std::vector<CoordinateXY> c1 = { { 0, 0 }, { 2, 2 }, { 3, 2 }, { 0, 0 } };
@@ -224,7 +264,8 @@ void object::test<13>()
- std::vector<CoordinateXY> t1 = { { 1, 0 }, { 2, 2 }, { 3, 2 }, { 1, 0 } };
+ std::vector<CoordinateXY> c1 = { { 1, 0 }, { 2, 2 }, { 3, 2 }, { 1, 0 } };
@@ -239,7 +280,8 @@ void object::test<14>()
- std::vector<CoordinateXY> t1 = { { 1, 0 }, { 1, 1 }, { 2, 1 }, { 1, 0 } };
+ std::vector<CoordinateXY> c1 = { { 1, 0 }, { 1, 1 }, { 2, 1 }, { 1, 0 } };
@@ -254,7 +296,8 @@ void object::test<15>()
- std::vector<CoordinateXY> t1{ { 4, 0 }, { 10, 0 } };
+ std::vector<CoordinateXY> c1{ { 4, 0 }, { 10, 0 } };
ensure_equals(TraversalAreas::getLeftHandArea(b, traversals), 100);
@@ -269,7 +312,8 @@ void object::test<16>()
Envelope b{ 2, 3, 2, 3 };
- std::vector<CoordinateXY> t1{ { 2, 2 }, { 2, 2.5 }, { 2, 2.5 } };
+ std::vector<CoordinateXY> c1{ { 2, 2 }, { 2, 2.5 }, { 2, 2.5 } };
@@ -283,7 +327,8 @@ void object::test<17>()
set_test_name("interior and edge traversal");
Envelope b(6, 7, 3, 4);
- std::vector<CoordinateXY> t1{{7, 3}, {6, 4}, {7, 4}};
+ std::vector<CoordinateXY> c1{{7, 3}, {6, 4}, {7, 4}};
@@ -297,7 +342,8 @@ void object::test<18>()
set_test_name("interior-edge segment-interior traversal");
- std::vector<CoordinateXY> t1{{10, 5}, {8, 0}, {4, 0}, {0, 3}};
+ std::vector<CoordinateXY> c1{{10, 5}, {8, 0}, {4, 0}, {0, 3}};
ensure_equals(TraversalAreas::getLeftHandArea(b, traversals), 11);
@@ -311,7 +357,8 @@ void object::test<19>()
set_test_name("interior-edge point-interior traversal");
- std::vector<CoordinateXY> t1{{10, 5}, {8, 0}, {0, 3}};
+ std::vector<CoordinateXY> c1{{10, 5}, {8, 0}, {0, 3}};
ensure_equals(TraversalAreas::getLeftHandArea(b, traversals), 17);
@@ -325,7 +372,8 @@ void object::test<20>()
set_test_name("interior-edge point-interior traversal, with repeated points");
- std::vector<CoordinateXY> t1{{10, 5}, {8, 0}, {8, 0}, {0, 3}};
+ std::vector<CoordinateXY> c1{{10, 5}, {8, 0}, {8, 0}, {0, 3}};
@@ -340,7 +388,8 @@ void object::test<21>()
- std::vector<CoordinateXY> t1{{10, 5}, {5, 10}, {2, 0}, {0, 5}};
+ std::vector<CoordinateXY> c1{{10, 5}, {5, 10}, {2, 0}, {0, 5}};
ensure_equals(TraversalAreas::getLeftHandArea(b, traversals), 57.5);
@@ -355,7 +404,8 @@ void object::test<22>()
- std::vector<CoordinateXY> t1{{5, 10}, {5, 0}, {10, 2}};
+ std::vector<CoordinateXY> c1{{5, 10}, {5, 0}, {10, 2}};
ensure_equals(TraversalAreas::getLeftHandArea(b, traversals), 45);
@@ -371,8 +421,10 @@ void object::test<23>()
set_test_name("along top, then bottom to top");
- std::vector<CoordinateXY> t1{{5, 10}, {0, 10}};
- std::vector<CoordinateXY> t2{{5, 0}, {5, 10}};
+ std::vector<CoordinateXY> c1{{5, 10}, {0, 10}};
+ std::vector<CoordinateXY> c2{{5, 0}, {5, 10}};
ensure_equals(TraversalAreas::getLeftHandArea(b, traversals), 50);
@@ -380,14 +432,77 @@ void object::test<23>()
"POLYGON ((5 10, 0 10, 0 0, 5 0, 5 10))");
+template<>
+template<>
+void object::test<24>()
+ set_test_name("two traversals, touching in interior");
+ // This would occur when two touching holes are present in the cell, and the shell is not present.
+ // Or it could occur when a shell and hole touch
+ std::vector<CoordinateXY> c1{{10, 0}, {5, 5}, {10, 10}};
+ std::vector<CoordinateXY> c2{{0, 10}, {5, 5}, {0, 0}};
+ ensure_equals(TraversalAreas::getLeftHandArea(b, traversals), 50);
+ "MULTIPOLYGON (((5 5, 0 10, 10 10, 5 5)), ((5 5, 10 0, 0 0, 5 5)))");
+template<>
+template<>
+void object::test<25>()
+ set_test_name("two traversals, touching in interior, plus complete hole");
+ // This is the same as #24 but the complete hole forces use of the polygonizer
+ std::vector<CoordinateXY> c3{{5, 1}, {5, 2}, {6, 2}, {6, 1}, {5, 1}};
+ Traversal t3 = make_traversal(c3, &c3);
+ TraversalVector traversals{ &t1, &t2, &t3 };
+ ensure_equals(TraversalAreas::getLeftHandArea(b, traversals), 49);
+ "MULTIPOLYGON (((0 10, 10 10, 5 5, 0 10)), ((0 0, 5 5, 10 0, 0 0), (5 1, 6 1, 6 2, 5 2, 5 1)))");
+template<>
+template<>
+void object::test<26>()
+ set_test_name("multiple holes touching at endpoints");
+ std::vector<CoordinateXY> c1{{0, 10}, {3, 1}, {0, 0}};
+ std::vector<CoordinateXY> c2{{0, 10}, {10, 9}};
+ std::vector<CoordinateXY> c3{{10, 7}, {0, 10}};
+ Traversal t3 = make_traversal(c3, &c2);
+ ensure_equals(TraversalAreas::getLeftHandArea(b, traversals), 75);
+ "MULTIPOLYGON (((0 10, 3 1, 0 0, 10 0, 10 7, 0 10)), ((0 10, 10 9, 10 10, 0 10)))");
template<>
template<>
- std::vector<CoordinateXY> lake{{1, 1}, {1, 9}, {9, 9}, {9, 1}, {1, 1}};
- std::vector<CoordinateXY> island{{2, 2}, {4, 2}, {4, 4}, {2, 4}, {2, 2}};
+ std::vector<CoordinateXY> c1{{1, 1}, {1, 9}, {9, 9}, {9, 1}, {1, 1}};
+ std::vector<CoordinateXY> c2{{2, 2}, {4, 2}, {4, 4}, {2, 4}, {2, 2}};
+ Traversal lake = make_traversal(c1, &c1);
+ Traversal island = make_traversal(c2, &c2);
commit ea3b27bc3b6b78e8bee510edb8225a51fa08dcfb
Date: Sun Jul 13 08:59:37 2025 -0400
GridIntersection::subdividePolygon: crop grid to geometry extent
diff --git a/include/geos/operation/grid/Grid.h b/include/geos/operation/grid/Grid.h
index b18b84b5c..054d10526 100644
--- a/include/geos/operation/grid/Grid.h
+++ b/include/geos/operation/grid/Grid.h
@@ -154,6 +154,15 @@ class Grid
double getRowY(size_t row) const { return m_extent.getMaxY() - (static_cast<double>(row - extent_tag::padding) + 0.5) * m_dy; }
+ Grid crop(const geom::Envelope& e) const
+ if (m_extent.intersects(e)) {
+ return shrinkToFit(e.intersection(m_extent));
+ } else {
+ return makeEmpty();
Grid<extent_tag> shrinkToFit(const geom::Envelope& b) const
if (b.getArea() == 0) {
index e8bd6a371..419c4f6eb 100644
@@ -512,12 +512,14 @@ GridIntersection::subdividePolygon(const Grid<bounded_extent>& p_grid, const Geo
const geom::GeometryFactory& gfact = *g.getFactory();
- Grid<infinite_extent> grid = make_infinite(p_grid, *g.getEnvelopeInternal());
- Matrix<std::unique_ptr<Cell>> cells(grid.getNumRows(), grid.getNumCols());
+ const auto cropped_grid = p_grid.crop(*g.getEnvelopeInternal());
- traverse_polygons(cells, grid, g);
+ const Grid<infinite_extent> cell_grid = make_infinite(cropped_grid, *g.getEnvelopeInternal());
+ Matrix<std::unique_ptr<Cell>> cells(cell_grid.getNumRows(), cell_grid.getNumCols());
- const auto areas = collectAreas(cells, p_grid, g);
+ traverse_polygons(cells, cell_grid, g);
+ const auto areas = collectAreas(cells, cropped_grid, g);
std::vector<std::unique_ptr<Geometry>> geoms;
std::vector<std::unique_ptr<Geometry>> edge_geoms;
@@ -545,7 +547,7 @@ GridIntersection::subdividePolygon(const Grid<bounded_extent>& p_grid, const Geo
- Envelope env = grid.getCellEnvelope(i, j);
+ Envelope env = cell_grid.getCellEnvelope(i, j);
commit 8373a284b1420f8685dd2d2f28a33b61cbc1747b
Date: Thu Aug 7 14:12:47 2025 -0400
GridIntersection: Ensure same points are constructed for all polygons in a coverage
diff --git a/src/operation/grid/Cell.cpp b/src/operation/grid/Cell.cpp
index 8569032d4..38e121788 100644
--- a/src/operation/grid/Cell.cpp
+++ b/src/operation/grid/Cell.cpp
@@ -19,6 +19,9 @@
#include <geos/operation/grid/Crossing.h>
+#define DEBUG_CELL 0
+#include <iomanip>
using geos::geom::Geometry;
@@ -50,15 +53,16 @@ crossing(const geom::Envelope& e, const CoordinateXY& c1, const CoordinateXY& c2
- double m = std::abs((c2.y - c1.y) / (c2.x - c1.x));
+ const double m = std::abs((c2.y - c1.y) / (c2.x - c1.x));
- bool up = c2.y > c1.y;
- bool right = c2.x > c1.x;
+ const bool up = c2.y > c1.y;
+ const bool right = c2.x > c1.x;
if (up) {
if (right) {
// 1st quadrant
- double y2 = c1.y + m * (e.getMaxX() - c1.x);
+ const double y2 = c1.y + m * (e.getMaxX() - c1.x);
if (y2 < e.getMaxY()) {
return Crossing{ Side::RIGHT, e.getMaxX(), std::clamp(y2, e.getMinY(), e.getMaxY()) };
@@ -68,7 +72,7 @@ crossing(const geom::Envelope& e, const CoordinateXY& c1, const CoordinateXY& c2
} else {
// 2nd quadrant
- double y2 = c1.y + m * (c1.x - e.getMinX());
+ const double y2 = c1.y + m * (c1.x - e.getMinX());
return Crossing{ Side::LEFT, e.getMinX(), std::clamp(y2, e.getMinY(), e.getMaxY()) };
@@ -78,24 +82,29 @@ crossing(const geom::Envelope& e, const CoordinateXY& c1, const CoordinateXY& c2
} else {
+ // For downward segments, we calculate constructed coordinates relative to c2, not c1. This is so the
+ // same coordinate will be calculated regardless of the segment orientation. This is important for maintaining
+ // valid polygon coverages (the same segment will be processed with opposite orientation along shared
+ // boundaries)
if (right) {
// 4th quadrant
- double y2 = c1.y - m * (e.getMaxX() - c1.x);
+ const double y2 = c2.y + m * (c2.x - e.getMaxX());
if (y2 > e.getMinY()) {
} else {
- double x2 = c1.x + (c1.y - e.getMinY()) / m;
+ double x2 = c2.x - (e.getMinY() - c2.y) / m;
return Crossing{ Side::BOTTOM, std::clamp(x2, e.getMinX(), e.getMaxX()), e.getMinY() };
} else {
// 3rd quadrant
- double y2 = c1.y - m * (c1.x - e.getMinX());
+ const double y2 = c2.y + m * (e.getMinX() - c2.x);
} else {
- double x2 = c1.x - (c1.y - e.getMinY()) / m;
+ double x2 = c2.x + (e.getMinY() - c2.y) / m;
@@ -187,14 +196,19 @@ Cell::take(const CoordinateXY& c, const CoordinateXY* prev_original)
Traversal& t = traversal_in_progress();
if (t.isEmpty()) {
- //std::cout << "Entering " << m_box << " from " << getSide(c) << " at " << c << std::endl;
+#if DEBUG_CELL
+ std::cout << std::setprecision(17);
+ std::cout << "Entering " << m_box << " from " << getSide(c) << " at " << c << std::endl;
+#endif
return true;
if (getLocation(c) != Location::OUTSIDE) {
- // std::cout << "Still in " << m_box << " with " << c << std::endl;
+#if DEBUG_CELL
+ std::cout << "Still in " << m_box << " with " << c << std::endl;
+#endif
t.add(c);
@@ -212,8 +226,10 @@ Cell::take(const CoordinateXY& c, const CoordinateXY* prev_original)
Crossing x = prev_original ? crossing(m_box, *prev_original, c) : crossing(m_box, t.getLastCoordinate(), c);
t.exit(x.getCoord(), x.getSide());
- // std::cout << "Leaving " << m_box << " from " << x.getSide() << " at " << x.getCoord();
- // std::cout << " on the way to " << c << std::endl;
+#if DEBUG_CELL
+ std::cout << "Leaving " << m_box << " from " << x.getSide() << " at " << x.getCoord();
+ std::cout << " on the way to " << c << std::endl;
+#endif
return false;
commit 2060b11ae91fb1e210afa7cdbc8469dc158d33fa
Date: Thu Aug 7 14:04:57 2025 -0400
GridIntersection: Produce valid polygon coverage when traversed cell area ~= cell area
index 54e67424f..e8bd6a371 100644
@@ -529,18 +529,19 @@ GridIntersection::subdividePolygon(const Grid<bounded_extent>& p_grid, const Geo
const bool col_edge = j == 0 || j == cells.getNumCols() - 1;
const bool edge = row_edge || col_edge;
- if (cells(i, j) != nullptr) {
+ const Cell* cell = cells(i, j).get();
+ if (cell != nullptr && cell->isDetermined()) {
+ // It is possible for the area to equal the cell area when the polygon is not the same as the
+ // cell area. (See GridIntersectionTest test #46). So, we only compare the area to
+ // fill_values<float>::INTERIOR for cells that have not been traversed.
if (edge) {
if (includeExterior) {
- edge_geoms.push_back(cells(i, j)->getCoveredPolygons(gfact));
+ edge_geoms.push_back(cell->getCoveredPolygons(gfact));
- } else if (areas(i - 1, j - 1) == fill_values<float>::INTERIOR) {
- // Cell is completely covered by polygon
- Envelope env = cells(i, j)->box();
} else if (areas(i - 1, j - 1) != fill_values<float>::EXTERIOR) {
// Cell is partly covered by polygon
- geoms.push_back(cells(i, j)->getCoveredPolygons(gfact));
+ geoms.push_back(cell->getCoveredPolygons(gfact));
index 9db36250b..1919d2fb0 100644
@@ -1,11 +1,13 @@
#include <tut/tut.hpp>
+#include <geos/coverage/CoverageValidator.h>
#include <geos/operation/grid/GridIntersection.h>
#include <geos/io/WKTReader.h>
using namespace geos::operation::grid;
@@ -28,14 +30,20 @@ struct test_gridintersectiontest_data : GEOSTestBase {
+ std::vector<const Geometry*> components;
for (size_t i = 0; i < subdivided.getNumGeometries(); i++) {
const Geometry* subg = subdivided.getGeometryN(i);
+ components.push_back(subg);
ensure("subdivided component " + subg->toString() + " is invalid",subg->isValid());
tot_area += subg->getArea();
+ ensure("subdivided polygons do not form a valid coverage", geos::coverage::CoverageValidator::isValid(components));
- ensure_equals(error, tot_area, input.getArea());
+ ensure_equals(error, tot_area, input.getArea(), 1e-14);
@@ -810,4 +818,20 @@ void object::test<45>()
+template<>
+template<>
+void object::test<46>()
+ set_test_name("valid polygon coverage obtained when a traversed cell covered area ~= cell area");
+ Envelope e(-180, 180, -90, 90);
+ Grid<bounded_extent> ext(e, 0.5, 0.5);
+ auto g = wkt_reader_.read("Polygon ((-179.99999999999991473 70.99201035500004764, -179.99999999999991473 71.05263157900003534, -179.99999999999991473 71.5366879880000397, -179.86286373599992316 71.53864166900007149, -179.91222083199991744 71.55585358300004373, -179.90074622299991347 71.55849844000005078, -179.79881751199991413 71.56907786700003271, -179.75743567599991479 71.58319733300004373, -179.73595130099991479 71.58641185100003668, -179.7154434889999095 71.58323802300003535, -179.69749915299991017 71.57733795800004373, -179.67870032499990884 71.57367584800005034, -179.61082923099991149 71.58519114800003535, -179.37205969999990884 71.56907786700003271, -179.3267716139999095 71.55548737200007281, -179.30683346299991854 71.55756256700004769, -179.28718014199992581 71.56293366100004505, -179.24286861899992118 71.56907786700003271, -179.20466061099992316 71.58319733300004373, -179.07457434799991347 71.60004303600004505, -178.73471025299991766 71.57037995000004571, -178.394846157
99992184 71.54071686400004637, -178.32319088399989937 71.51837799700007281, -178.25963294199991083 71.51068756700004769, -178.30488033799991854 71.51312897300005034, -178.32347571499991545 71.51512278900003139, -178.3415421209999181 71.51752350500004241, -178.32245846299991854 71.50543854400007149, -178.21532141799991678 71.47801341400003139, -178.19347083199991744 71.47662995000007413, -178.14777584499989871 71.48517487200007281, -178.12446041599991986 71.48187897300005034, -178.00572669199991083 71.44863515800005871, -178.01720130099991479 71.44139232000003403, -178.05418860599991149 71.42877838700007942, -178.04706783799991854 71.42572663000004241, -178.03343665299991017 71.4177920590000781, -178.02623450399991611 71.41510651200007942, -178.03010006399992449 71.41347890800005871, -178.03990637899991611 71.40766022300005034, -177.97089596299991854 71.39642975500004241, -177.77985592399991788 71.33319733300004373, -177.71837317599991479 71.30524323100007678, -177.70641028599990818
71.30390045800004373, -177.68211829299991678 71.30487702000004901, -177.67027747299991347 71.30182526200007942, -177.65538489499991215 71.29315827000004901, -177.58759518099992647 71.28595612200007281, -177.5485733709999181 71.29486725500004241, -177.53111731699991083 71.29633209800005034, -177.51410885299992515 71.29340241100004505, -177.4986466139999095 71.28473541900007149, -177.50621497299991347 71.26862213700007942, -177.48700924399992118 71.25873444200004769, -177.45970618399991281 71.24990469000005078, -177.44343014199992581 71.23700592700004108, -177.4459122389999095 71.22264232000003403, -177.45775305899991281 71.20937734600005342, -177.50780188699991413 71.17377350500004241, -177.58116614499991215 71.1476097680000521, -177.63764400899989937 71.1170108090000781, -177.68415279899991788 71.11098867400005474, -177.7519018219999225 71.09296295800004373, -177.81928463399989937 71.08466217700004108, -177.87767493399991281 71.0525576840000781, -177.93049068899992449 71.04144928600
004505, -178.20661373599992316 71.03839752800007545, -178.31012936099992316 71.01361725500004241, -178.59302730999991127 70.99732086800005959, -178.87592525899989937 70.98102448100007678, -178.9802953769999192 70.95066966400003139, -179.34211178299992184 70.9080264340000781, -179.33625240799992184 70.91107819200004769, -179.32225501199991413 70.9216983090000781, -179.36449133999991545 70.93024323100007678, -179.45750891799991678 70.91551341400003139, -179.50121008999991545 70.919663804000038, -179.66600501199991413 70.96548086100006003, -179.85338294199991083 70.97943756700004769, -179.88878333199991744 70.99359772300005034, -179.90754146999989871 70.99677155200004108, -179.99999999999991473 70.99201035500004764))");
commit 0da3930ef5fbb0c1f9c37b9313a85d7a70b585bc
Author: Daniel Baston <dbaston at gmail.com>
Date: Thu Aug 7 11:17:03 2025 -0400
GridIntersection: Prevent creation of self-touching rings
diff --git a/include/geos/operation/grid/Cell.h b/include/geos/operation/grid/Cell.h
index a58ffc8f0..ead45a77d 100644
--- a/include/geos/operation/grid/Cell.h
+++ b/include/geos/operation/grid/Cell.h
@@ -95,9 +95,9 @@ class Cell
std::vector<Traversal> m_traversals;
- Side side(const geom::CoordinateXY& c) const;
+ Side getSide(const geom::CoordinateXY& c) const;
- Location location(const geom::CoordinateXY& c) const;
+ Location getLocation(const geom::CoordinateXY& c) const;
/// If no Traversals have been started or the most recent Traversal has been completed,
/// return a new Traversal. Otherwise, return the most recent Traversal.
diff --git a/include/geos/operation/grid/PerimeterDistance.h b/include/geos/operation/grid/PerimeterDistance.h
index 86691d257..2cf91dc2e 100644
--- a/include/geos/operation/grid/PerimeterDistance.h
+++ b/include/geos/operation/grid/PerimeterDistance.h
@@ -38,12 +38,18 @@ class GEOS_DLL PerimeterDistance {
/** Calculates the counter-clockwise distance between two locations on the perimeter
* of an Envelope. The locations are specified as clockwise distances from the
- * lower left corner of the Envelope, consistent with the `perimeter_distance`
+ * lower left corner of the Envelope, consistent with the `getPerimeterDistance`
* function.
static double
getPerimeterDistanceCCW(double measure1, double measure2, double perimeter);
+ /** Tests whether measure x would be passed when traveling from a to b in a CCW
+ * direction.
+ static bool
+ isBetweenCCW(double x, double a, double b);
diff --git a/include/geos/operation/grid/Side.h b/include/geos/operation/grid/Side.h
index b9015f7a1..f91866908 100644
--- a/include/geos/operation/grid/Side.h
+++ b/include/geos/operation/grid/Side.h
@@ -27,7 +27,28 @@ enum class Side
BOTTOM
-std::ostream&
-operator<<(std::ostream& os, const Side& s);
+inline std::ostream&
+operator<<(std::ostream& os, const Side& s)
+ switch (s) {
+ case Side::NONE:
+ os << "none";
+ return os;
+ case Side::LEFT:
+ os << "left";
+ return os;
+ case Side::RIGHT:
+ os << "right";
+ return os;
+ case Side::TOP:
+ os << "top";
+ return os;
+ case Side::BOTTOM:
+ os << "bottom";
+ return os;
+ return os; // unreachable statement needed for -Werror=return-type
index 3ae5cb156..8569032d4 100644
@@ -25,11 +25,6 @@ using geos::geom::GeometryFactory;
-static bool
-strictly_contains(const geom::Envelope& e, const geom::CoordinateXY& c) {
- return e.getMinX() < c.x && e.getMaxX() > c.x && e.getMinY() < c.y && e.getMaxY() > c.y;
static Crossing
crossing(const geom::Envelope& e, const CoordinateXY& c1, const CoordinateXY& c2)
@@ -127,7 +122,7 @@ Cell::getArea() const
Side
-Cell::side(const CoordinateXY& c) const
+Cell::getSide(const CoordinateXY& c) const
if (c.x == m_box.getMinX()) {
return Side::LEFT;
@@ -151,15 +146,15 @@ Cell::forceExit()
const CoordinateXY& last = getLastTraversal().getLastCoordinate();
- if (location(last) == Location::BOUNDARY) {
- getLastTraversal().forceExit(side(last));
+ if (getLocation(last) == Location::BOUNDARY) {
+ getLastTraversal().forceExit(getSide(last));
Cell::Location
-Cell::location(const CoordinateXY& c) const
+Cell::getLocation(const CoordinateXY& c) const
- if (strictly_contains(m_box, c)) {
+ if (m_box.containsProperly(c)) {
return Cell::Location::INSIDE;
@@ -192,13 +187,13 @@ Cell::take(const CoordinateXY& c, const CoordinateXY* prev_original)
if (t.isEmpty()) {
- // std::cout << "Entering " << m_box << " from " << side(c) << " at " << c << std::endl;
+ //std::cout << "Entering " << m_box << " from " << getSide(c) << " at " << c << std::endl;
- t.enter(c, side(c));
+ t.enter(c, getSide(c));
return true;
- if (location(c) != Cell::Location::OUTSIDE) {
+ if (getLocation(c) != Location::OUTSIDE) {
t.add(c);
@@ -217,7 +212,7 @@ Cell::take(const CoordinateXY& c, const CoordinateXY* prev_original)
- // std::cout << "Leaving " << m_box << " from " << x.side() << " at " << x.coord();
+ // std::cout << "Leaving " << m_box << " from " << x.getSide() << " at " << x.getCoord();
return false;
diff --git a/src/operation/grid/PerimeterDistance.cpp b/src/operation/grid/PerimeterDistance.cpp
index 540680178..a8c3ff679 100644
--- a/src/operation/grid/PerimeterDistance.cpp
+++ b/src/operation/grid/PerimeterDistance.cpp
@@ -61,4 +61,13 @@ PerimeterDistance::getPerimeterDistanceCCW(double measure1, double measure2, dou
return perimeter + measure1 - measure2;
+bool PerimeterDistance::isBetweenCCW(double x, double a, double b)
+ if (a < b) {
+ return x <= a || x >= b;
+ return x <= a && x >= b;
index 9b3cd59ca..3470ec5a2 100644
@@ -32,22 +32,86 @@ using geos::geom::Geometry;
+#define DEBUG_TRAVERSAL_AREAS 0
+/// A CoordinateChain stores a set of coordinates whose start and end points lie on
+/// the envelope.
- double start; // perimeter distance value of the first coordinate
- double stop; // perimeter distance value of the last coordinate
- const std::vector<CoordinateXY>* coordinates;
+ const double start; // perimeter distance value of the first coordinate
+ const double stop; // perimeter distance value of the last coordinate
bool visited;
- CoordinateChain(double p_start, double p_stop, const std::vector<CoordinateXY>* p_coords)
+ CoordinateChain(double p_start, double p_stop, const std::vector<CoordinateXY>& p_coords)
: start{ p_start }
, stop{ p_stop }
- , coordinates{ p_coords }
, visited{ false }
+ , m_start{ p_coords.begin() }
+ , m_stop{ p_coords.end() }
+ CoordinateChain(double p_start, double p_stop, const std::vector<CoordinateXY>& p_coords, size_t from, size_t to)
+ : start{ p_start }
+ , stop{ p_stop }
+ , visited{ false }
+ , m_start{ std::next(p_coords.begin(), static_cast<std::ptrdiff_t>(from)) }
+ , m_stop{ std::next(p_coords.begin(), static_cast<std::ptrdiff_t>(to + 1)) }
+ CoordinateChain(double pDistStart, double pDistStop,
+ const std::vector<CoordinateXY>::const_iterator& itStart,
+ const std::vector<CoordinateXY>::const_iterator& itStop)
+ : start{ pDistStart }
+ , stop{ pDistStop }
+ , m_start{ itStart }
+ , m_stop{ itStop}
+ auto begin() const {
+ return m_start;
+ auto end() const {
+ return m_stop;
+ auto getSize() const {
+ return m_stop - m_start;
+#if 0
+ /// Tests whether this chain intersects the interior of the box.
+ bool crossesInterior(const Envelope& box) const
+ if (getSize() < 2) {
+ return false;
+ const CoordinateXY& origin = *begin();
+ for (const auto& coord: *this) {
+ if (coord.x != origin.x && coord.y != origin.y) {
+ // Both X and Y have changed, we cannot be on the
+ // edge where we started.
+ return true;
+ if (box.containsProperly(coord)) {
+ return true;
+ return false;
+#endif
+private:
+ const std::vector<CoordinateXY>::const_iterator m_start;
+ const std::vector<CoordinateXY>::const_iterator m_stop;
static double
@@ -66,12 +130,30 @@ getNextChain(std::vector<CoordinateChain>& chains,
CoordinateChain* min = nullptr;
double min_distance = std::numeric_limits<double>::max();
+ std::cout << "Acceptable range: " << chain->stop << " " << kill->start << std::endl;
+#endif
for (CoordinateChain& candidate : chains) {
if (candidate.visited && std::addressof(candidate) != kill) {
continue;
double distance = exit_to_entry_perimeter_distance_ccw(*chain, candidate, perimeter);
+ std::cout << "Distance " << distance << ", start " << candidate.start << ", stop " << candidate.stop << ": ";
+ for (const auto& c : candidate) {
+ std::cout << c << ", ";
+ std::cout<< std::endl;
+#endif
+ if (distance == 0 && std::addressof(candidate) != kill && !PerimeterDistance::isBetweenCCW(candidate.stop, chain->stop, kill->start)) {
+ // Make sure the candidate chain closes the ring instead of starting a new ring.
+ continue;
if (distance < min_distance) {
min_distance = distance;
min = std::addressof(candidate);
@@ -98,6 +180,12 @@ hasMultipleUniqueCoordinates(const T& vec)
return false;
+static bool
+isRing(const std::vector<CoordinateXY>& coords)
+ return coords.front() == coords.back() && hasMultipleUniqueCoordinates(coords);
* @brief Identify counter-clockwise rings formed by the supplied coordinate vectors and the boundary of this box.
@@ -114,12 +202,14 @@ visitRings(const Envelope& box, const std::vector<const std::vector<CoordinateXY
std::vector<CoordinateChain> chains;
+ bool validPolygons = true;
continue;
- if (coords->front() == coords->back() && hasMultipleUniqueCoordinates(*coords)) {
@@ -127,14 +217,55 @@ visitRings(const Envelope& box, const std::vector<const std::vector<CoordinateXY
+ } else if (validPolygons) {
+ // Split coordinates into separate chains when they touch an edge
+ // This prevents the creation of self-touching rings.
+ // For area calculations, this doesn't matter, and the step can be skipped.
+ size_t from = 0;
+ for (size_t to = 1; to < coords->size(); to++) {
+ const CoordinateXY& c = (*coords)[to];
+ const bool ptIsOnEdge = c.x == box.getMinX() || c.x == box.getMaxX() || c.y == box.getMinY() || c.y == box.getMaxY();
+ if (ptIsOnEdge) {
+ double start = PerimeterDistance::getPerimeterDistance(box, (*coords)[from]);
+ double stop = PerimeterDistance::getPerimeterDistance(box, (*coords)[to]);
+ chains.emplace_back(start, stop, *coords, from, to);
+ from = to;
} else {
- double start = PerimeterDistance::getPerimeterDistance(box, coords->front());
- double stop = PerimeterDistance::getPerimeterDistance(box, coords->back());
- chains.emplace_back(start, stop, coords);
+ auto from = coords->begin();
+ auto to = coords->end();
+ double start = PerimeterDistance::getPerimeterDistance(box, *from);
+ double stop = PerimeterDistance::getPerimeterDistance(box, *std::prev(to));
+ chains.emplace_back(start, stop, from, to);
+#if 0
+ if (validPolygons) {
+ const bool crossesInterior = std::any_of(chains.begin(), chains.end(), [&box](const auto& chain) {
+ return chain.crossesInterior(box);
+ if (crossesInterior) {
+ for (auto& chain_ref : chains) {
+ // Pre-visit all edge segments, and do nothing with them.
+ if (chain_ref.getSize() == 2) {
+ const CoordinateXY& from = *chain_ref.begin();
+ const CoordinateXY& to = *std::next(chain_ref.begin());
+ if (from.x == to.x &&(from.x == box.getMinX() || from.x == box.getMaxX())) {
+ chain_ref.visited = true;
+ else if (from.y == to.y && (from.y == box.getMinY() || from.y == box.getMaxY())) {
+#endif
@@ -146,24 +277,47 @@ visitRings(const Envelope& box, const std::vector<const std::vector<CoordinateXY
std::vector<CoordinateXY> bottom_right = { CoordinateXY(box.getMaxX(), box.getMinY()) };
// Add chains for corners
- chains.emplace_back(0.0, 0.0, &bottom_left);
- chains.emplace_back(height, height, &top_left);
- chains.emplace_back(height + width, height + width, &top_right);
- chains.emplace_back(2 * height + width, 2 * height + width, &bottom_right);
+ chains.emplace_back(0.0, 0.0, bottom_left);
+ chains.emplace_back(height, height, top_left);
+ chains.emplace_back(height + width, height + width, top_right);
+ chains.emplace_back(2 * height + width, 2 * height + width, bottom_right);
+ std::cout << "Identifying rings in box " << box << std::endl;
+ std::cout << "Available chains:" << std::endl;
+ for (const auto& chain : chains) {
+ for (const auto& coord : chain) {
+ std:: cout << coord << ", ";
+ std::cout << std::endl;
+#endif
- if (chain_ref.visited || chain_ref.coordinates->size() == 1) {
+ if (chain_ref.visited || chain_ref.getSize() == 1) {
continue;
coords.clear();
+ std::cout << "New ring." << std::endl;
+#endif
- CoordinateChain* first_chain = chain;
+ const CoordinateChain* first_chain = chain;
do {
- coords.insert(coords.end(), chain->coordinates->cbegin(), chain->coordinates->cend());
+ coords.insert(coords.end(), chain->begin(), chain->end());
+ std::cout << "Added chain ";
+ for (const auto& c : *chain) {
+#endif
chain = getNextChain(chains, chain, first_chain, perimeter);
} while (chain != first_chain);
@@ -215,17 +369,55 @@ TraversalAreas::getLeftHandRings(const GeometryFactory& gfact, const Envelope& b
bool found_a_ring = false;
- visitRings(box, coord_lists, [&gfact, &shells, &holes, &found_a_ring](const std::vector<CoordinateXY>& coords, bool is_ccw) {
+ visitRings(box, coord_lists, [&gfact, &box, &shells, &holes, &found_a_ring](const std::vector<CoordinateXY>& coords, bool is_ccw) {
found_a_ring = true;
- // finding a collapsed ring is sufficient to determine whether the cell interior is inside our outside,
+ // finding a collapsed ring is sufficient to determine whether the cell interior is inside or outside,
if (algorithm::Area::ofRing(coords) == 0) {
return;
- CoordinateSequence seq(0, false, false);
- seq.setPoints(coords);
+ auto seq = std::make_unique<CoordinateSequence>(0, false, false);
+ seq->reserve(coords.size());
+ for (const auto& coord : coords) {
+#if 0
+ if (!seq.isEmpty()) {
+ const CoordinateXY& prev = seq.back();
+ const bool isHorizontal = coord.y == prev.y;
+ const bool isVertical = coord.x == prev.x;
+ // When an input geometry linework follows grid cell boundaries, we can end up
+ // with duplicate points or zero-area spikes in rings. These don't affect the
+ // area calculations, but we need to remove them before constructing the geometry.
+ // Skip duplicate points
+ if (isHorizontal && isVertical) {
+ continue;
+ // Skip rightward along top edge
+ if (isHorizontal && coord.y == box.getMaxY() && coord.x > prev.x) {
+ continue;
+ // Skip leftward along bottom edge
+ if (isHorizontal && coord.y == box.getMinY() && coord.x < prev.x) {
+ continue;
+ // Skip downward along right edge
+ if (isVertical && coord.x == box.getMaxX() && coord.y < prev.y) {
+ continue;
+ // Skip upward along left edge
+ if (isVertical && coord.x == box.getMinX() && coord.y > prev.y) {
+ continue;
+#endif
+ seq->add(coord, false);
auto ring = gfact.createLinearRing(std::move(seq));
if (is_ccw) {
index c7bf4965b..9db36250b 100644
@@ -22,6 +22,21 @@ struct test_gridintersectiontest_data : GEOSTestBase {
+ static void
+ check_subdivided_polygon(const Geometry& input, const Geometry& subdivided)
+ for (size_t i = 0; i < subdivided.getNumGeometries(); i++) {
+ const Geometry* subg = subdivided.getGeometryN(i);
+ ensure("subdivided component " + subg->toString() + " is invalid",subg->isValid());
+ tot_area += subg->getArea();
+ std::string error = "subdivided polygon area does not match input: " + subdivided.toString();
+ ensure_equals(error, tot_area, input.getArea());
typedef test_group<test_gridintersectiontest_data, 255> group;
@@ -646,7 +661,7 @@ void object::test<36>()
auto subdivided = GridIntersection::subdividePolygon(ext, *g, false);
- ensure_equals(g->getArea(), subdivided->getArea());
+ check_subdivided_polygon(*g, *subdivided);
template<>
@@ -779,4 +794,20 @@ void object::test<44>()
ensure_THROW(GridIntersection::getIntersectionFractions(ext, *g), std::exception);
+template<>
+template<>
+void object::test<45>()
+ set_test_name("subdivide polygon whose edges follow cell boundaries");
+ Envelope e(0, 10, 0, 10);
+ Grid<bounded_extent> ext(e, 1, 1);
+ auto tree = wkt_reader_.read("POLYGON ((4 0, 6 0, 6 2, 8 2, 6 4, 8 4, 5 7, 2 4, 4 4, 2 2, 4 2, 4 0))");
+ auto subd = GridIntersection::subdividePolygon(ext, *tree, false);
+ check_subdivided_polygon(*tree, *subd);
index e11f46274..980439c45 100644
@@ -102,15 +102,13 @@ void object::test<5>()
- std::vector<CoordinateXY> t7 = { { 10, 3 }, { 8, 3 }, { 8, 0 } }; // 2x3 = 6
+ std::vector<CoordinateXY> t7 = { { 10, 2 }, { 8, 2 }, { 8, 0 } }; // 2x2 = 4
- ensure_equals(TraversalAreas::getLeftHandArea(b, traversals), 4 + 20 + 2 + 6 - 1 + 6);
- ensure_equals_geometry(TraversalAreas::getLeftHandRings(gfact, b, traversals).get(), "MULTIPOLYGON (((2 0, 2 2, 0 2, 0 0, 2 0)), "
- "((3 10, 3 0, 5 0, 5 10, 3 10)), "
- "((8 10, 10 8, 10 10, 8 10)), "
- "((10 6, 8 6, 8 3, 10 3, 10 3, 8 3, 8 0, 10 0, 10 4, 9 4, 9 5, 10 5, 10 6)))");
+ ensure_equals(TraversalAreas::getLeftHandArea(b, traversals), 4 + 20 + 2 + 6 - 1 + 4);
+ ensure_equals_geometry(TraversalAreas::getLeftHandRings(gfact, b, traversals).get(), "MULTIPOLYGON (((2 0, 2 2, 0 2, 0 0, 2 0)), ((3 10, 3 0, 5 0, 5 10, 3 10)), ((8 10, 10 8, 10 10, 8 10)), ((10 6, 8 6, 8 3, 10 3, 10 4, 9 4, 9 5, 10 5, 10 6)), ((10 2, 8 2, 8 0, 10 0, 10 2)))");
template<>
@@ -260,8 +258,7 @@ void object::test<15>()
TraversalVector traversals{ &t1 };
- // FIXME remove repeated point from result
- ensure_equals_geometry(TraversalAreas::getLeftHandRings(gfact, b, traversals).get(), "POLYGON ((0 0, 4 0, 10 0, 10 0, 10 10, 0 10, 0 0))");
+ ensure_equals_geometry(TraversalAreas::getLeftHandRings(gfact, b, traversals).get(), "POLYGON ((0 0, 4 0, 10 0, 10 10, 0 10, 0 0))");
template<>
@@ -281,7 +278,111 @@ void object::test<16>()
template<>
template<>
-void object::test<17>() {
+void object::test<17>()
+ set_test_name("interior and edge traversal");
+ Envelope b(6, 7, 3, 4);
+ std::vector<CoordinateXY> t1{{7, 3}, {6, 4}, {7, 4}};
+ TraversalVector traversals{ &t1 };
+ ensure_equals(TraversalAreas::getLeftHandArea(b, traversals), 0.5);
+ ensure_equals_geometry(TraversalAreas::getLeftHandRings(gfact, b, traversals).get(), "POLYGON ((6 3, 7 3, 6 4, 6 3))");
+template<>
+template<>
+void object::test<18>()
+ set_test_name("interior-edge segment-interior traversal");
+ Envelope b(0, 10, 0, 10);
+ std::vector<CoordinateXY> t1{{10, 5}, {8, 0}, {4, 0}, {0, 3}};
+ ensure_equals(TraversalAreas::getLeftHandArea(b, traversals), 11);
+ ensure_equals_geometry(TraversalAreas::getLeftHandRings(gfact, b, traversals).get(), "MULTIPOLYGON (((10 5, 8 0, 10 0, 10 5)), ((4 0, 0 3, 0 0, 4 0)))");
+template<>
+template<>
+void object::test<19>()
+ set_test_name("interior-edge point-interior traversal");
+ std::vector<CoordinateXY> t1{{10, 5}, {8, 0}, {0, 3}};
+ ensure_equals(TraversalAreas::getLeftHandArea(b, traversals), 17);
+ ensure_equals_geometry(TraversalAreas::getLeftHandRings(gfact, b, traversals).get(), "MULTIPOLYGON (((8 0, 10 5, 10 0, 8 0)), ((8 0, 0 0, 0 3, 8 0)))");
+template<>
+template<>
+void object::test<20>()
+ set_test_name("interior-edge point-interior traversal, with repeated points");
+ std::vector<CoordinateXY> t1{{10, 5}, {8, 0}, {8, 0}, {0, 3}};
+template<>
+template<>
+void object::test<21>()
+ set_test_name("bouncing off multiple edges");
+ std::vector<CoordinateXY> t1{{10, 5}, {5, 10}, {2, 0}, {0, 5}};
+ ensure_equals(TraversalAreas::getLeftHandArea(b, traversals), 57.5);
+ ensure_equals_geometry(TraversalAreas::getLeftHandRings(gfact, b, traversals).get(), "MULTIPOLYGON (((10 5, 5 10, 2 0, 10 0, 10 5)), ((2 0, 0 5, 0 0, 2 0)))");
+template<>
+template<>
+void object::test<22>()
+ set_test_name("enter top, bounce bottom, exit right");
+ std::vector<CoordinateXY> t1{{5, 10}, {5, 0}, {10, 2}};
+ ensure_equals(TraversalAreas::getLeftHandArea(b, traversals), 45);
+ "POLYGON ((5 10, 5 0, 10 2, 10 10, 5 10))"
+template<>
+template<>
+void object::test<23>()
+ set_test_name("along top, then bottom to top");
+ std::vector<CoordinateXY> t1{{5, 10}, {0, 10}};
+ std::vector<CoordinateXY> t2{{5, 0}, {5, 10}};
+ TraversalVector traversals{ &t1, &t2 };
+ "POLYGON ((5 10, 0 10, 0 0, 5 0, 5 10))");
+template<>
+template<>
+void object::test<28>() {
set_test_name("lake with island");
commit bb1ddd2f98e5831ee4b31ddf5c49155520dc6276
Date: Wed Aug 6 13:18:52 2025 -0400
Add Envelope::containsProperly
diff --git a/include/geos/geom/Envelope.h b/include/geos/geom/Envelope.h
index 61e074be8..687dbbae1 100644
--- a/include/geos/geom/Envelope.h
+++ b/include/geos/geom/Envelope.h
@@ -562,6 +562,19 @@ public:
return covers(x, y);
+ /** \brief
+ * Check if the point p lies in the interior of this Envelope.
+ * @param p the Coordinate to be tested
+ * @return true if the point lies in the interior
+ bool
+ containsProperly(const CoordinateXY& p) const
+ return std::isless(p.x, maxx) && std::isgreater(p.x, minx) &&
+ std::isless(p.y, maxy) && std::isgreater(p.y, miny);
/** \brief
* Check if the point p intersects (lies inside) the region of this Envelope.
diff --git a/src/operation/union/OverlapUnion.cpp b/src/operation/union/OverlapUnion.cpp
index dbc638772..aef18801b 100644
--- a/src/operation/union/OverlapUnion.cpp
+++ b/src/operation/union/OverlapUnion.cpp
@@ -196,22 +196,11 @@ intersects(const Envelope& env, const Coordinate& p0, const Coordinate& p1)
return env.intersects(p0) || env.intersects(p1);
-/* static */
-static bool
-containsProperly(const Envelope& env, const Coordinate& p)
- if (env.isNull()) return false;
- return p.x > env.getMinX() &&
- p.x < env.getMaxX() &&
- p.y > env.getMinY() &&
- p.y < env.getMaxY();
/* static */
static bool
containsProperly(const Envelope& env, const Coordinate& p0, const Coordinate& p1)
- return containsProperly(env, p0) && containsProperly(env, p1);
+ return env.containsProperly(p0) && env.containsProperly(p1);
/* private */
diff --git a/tests/unit/geom/EnvelopeTest.cpp b/tests/unit/geom/EnvelopeTest.cpp
index b1250a63e..a816f84f3 100644
--- a/tests/unit/geom/EnvelopeTest.cpp
+++ b/tests/unit/geom/EnvelopeTest.cpp
@@ -655,5 +655,23 @@ void object::test<20>
ensure_equals(set.size(), 2u);
-} // namespace tut
+template<>
+template<>
+ set_test_name("containsProperly");
+ Envelope env;
+ ensure(env.isNull());
+ ensure(!env.containsProperly({0, 0}));
+ env.expandToInclude({3, 7});
+ env.expandToInclude( {5, 9});
+ ensure(!env.containsProperly({3, 7}));
+ ensure(!env.containsProperly({3, 8}));
+ ensure(env.containsProperly({3.0000001, 8}));
commit dcea054725c4d43d2a11cc03130ea631ffca195e
Date: Wed Jan 22 16:40:14 2025 -0500
Add GEOSSubdivideByGrid
diff --git a/capi/geos_c.cpp b/capi/geos_c.cpp
index 35d14fd18..d26db0966 100644
--- a/capi/geos_c.cpp
+++ b/capi/geos_c.cpp
@@ -727,6 +727,13 @@ extern "C" {
return GEOSClipByRect_r(handle, g, xmin, ymin, xmax, ymax);
+ Geometry*
+ GEOSSubdivideByGrid(const Geometry* g, double xmin, double ymin, double xmax, double ymax,
+ unsigned nx, unsigned ny, int include_exterior)
+ return GEOSSubdivideByGrid_r(handle, g, xmin, ymin, xmax, ymax, nx, ny, include_exterior);
int
GEOSGridIntersectionFractions(const Geometry* g, double xmin, double ymin, double xmax, double ymax,
unsigned nx, unsigned ny, float* buf)
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index 7c80f7016..9e7ff2640 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -1168,6 +1168,15 @@ extern GEOSGeometry GEOS_DLL *GEOSClipByRect_r(
double xmax, double ymax);
+/** \see GEOSSubdivideByGrid */
+extern GEOSGeometry GEOS_DLL *GEOSSubdivideByGrid_r(
+ GEOSContextHandle_t handle,
+ const GEOSGeometry* g,
+ double xmin, double ymin,
+ double xmax, double ymax,
+ int include_exterior);
/** \see GEOSGridIntersectionFractions */
extern int GEOS_DLL GEOSGridIntersectionFractions_r(
@@ -4021,6 +4030,33 @@ extern GEOSGeometry GEOS_DLL *GEOSClipByRect(
+* Compute the intersection of a geometry with each polygon in
+* a rectangular grid.
+* \param g The input geometry to be clipped
+* \param xmin Left bound of grd
+* \param ymin Lower bound of grid
+* \param xmax Right bound of grid
+* \param ymax Upper bound of grid
+* \param nx number of columns in grid
+* \param ny number of rows in grid
+* \param include_exterior whether to include portions of the
+ input geometry that do not intersect the grid in
+ the returned result.
+* \return A geometry collection whose components represent the
+* intersection with each cell in the grid.
+* Caller is responsible for freeing with GEOSGeom_destroy().
+* \see GEOSGetGridIntersectionFractions
+* \since 3.14.0
+extern GEOSGeometry GEOS_DLL *GEOSSubdivideByGrid(
* Determine the fraction of each cell in a rectangular grid
* that is covered by a polygon.
@@ -4069,7 +4105,6 @@ extern GEOSGeometry GEOS_DLL *GEOSSharedPaths(
/* ========== Clustering functions ========== */
/** @name Clustering
-* Functions for clustering geometries
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index f4690f04f..d8b57fd87 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -1819,6 +1819,20 @@ extern "C" {
+ Geometry*
+ GEOSSubdivideByGrid_r(GEOSContextHandle_t extHandle, const Geometry* g, double xmin, double ymin,
+ double xmax, double ymax, unsigned nx, unsigned ny, int include_exterior)
+ return execute(extHandle, [&]() {
+ Envelope env(xmin, xmax, ymin, ymax);
+ double dx = env.getWidth() / static_cast<double>(nx);
+ double dy = env.getHeight() / static_cast<double>(ny);
+ geos::operation::grid::Grid<geos::operation::grid::bounded_extent> grid(env, dx, dy);
+ return geos::operation::grid::GridIntersection::subdividePolygon(grid, *g, include_exterior).release();
int
GEOSGridIntersectionFractions_r(GEOSContextHandle_t extHandle, const Geometry* g, double xmin, double ymin,
double xmax, double ymax, unsigned nx, unsigned ny, float* buf)
diff --git a/tests/unit/capi/GEOSSubdivideByGridTest.cpp b/tests/unit/capi/GEOSSubdivideByGridTest.cpp
new file mode 100644
index 000000000..d734c5bca
--- /dev/null
+++ b/tests/unit/capi/GEOSSubdivideByGridTest.cpp
@@ -0,0 +1,56 @@
+#include <tut/tut.hpp>
+#include <geos_c.h>
+#include "capi_test_utils.h"
+namespace tut {
+struct test_capigeossubdividebygrid_data : public capitest::utility {};
+typedef test_group<test_capigeossubdividebygrid_data> group;
+typedef group::object object;
+group test_capigeossubdividebygrid_group("capi::GEOSSubdivideByGrid");
+template<>
+template<>
+void object::test<1>()
+ set_test_name("rectangle overlapping grid");
+ input_ = fromWKT("POLYGON ((0.5 0.5, 2.5 0.5, 2.5 2.5, 0.5 2.5, 0.5 0.5))");
+ expected_ = fromWKT("GEOMETRYCOLLECTION ("
+ "POLYGON ((2 2.5, 1 2.5, 1 2, 2 2, 2 2.5)),"
+ "POLYGON ((2.5 2, 2.5 2.5, 2 2.5, 2 2, 2.5 2)),"
+ "POLYGON ((1 1, 2 1, 2 2, 1 2, 1 1)),"
+ "POLYGON ((2.5 1, 2.5 2, 2 2, 2 1, 2.5 1)),"
+ "POLYGON ((1 0.5, 2 0.5, 2 1, 1 1, 1 0.5)),"
+ "POLYGON ((2 0.5, 2.5 0.5, 2.5 1, 2 1, 2 0.5)))");
+ result_ = GEOSSubdivideByGrid(input_, 1, 0, 5, 3, 4, 3, false);
+ ensure_geometry_equals_identical(expected_, result_);
+template<>
+template<>
+void object::test<2>()
+ set_test_name("includeExterior = true");
+ "POLYGON ((2 0.5, 2.5 0.5, 2.5 1, 2 1, 2 0.5)),"
+ "POLYGON ((0.5 2.5, 1 2.5, 1 2, 1 1, 1 0.5, 0.5 0.5, 0.5 1, 0.5 2, 0.5 2.5)))");
+ result_ = GEOSSubdivideByGrid(input_, 1, 0, 5, 3, 4, 3, true);
\ No newline at end of file
index d73cbc3a7..e11f46274 100644
@@ -294,5 +294,4 @@ void object::test<17>() {
//"MULTIPOLYGON (((0 0, 10 0, 10 10, 0 10, 0 0), (1 1, 9 1, 9 9, 1 9, 1 1)), ((2 2, 4 2, 4 4, 2 4, 2 2)))");
Summary of changes:
capi/geos_c.cpp | 7 +
capi/geos_c.h.in | 40 +-
capi/geos_ts_c.cpp | 14 +
include/geos/geom/Envelope.h | 13 +
include/geos/operation/grid/Cell.h | 16 +-
include/geos/operation/grid/Grid.h | 99 +++-
include/geos/operation/grid/GridIntersection.h | 21 +-
include/geos/operation/grid/PerimeterDistance.h | 15 +-
include/geos/operation/grid/Side.h | 25 +-
include/geos/operation/grid/Traversal.h | 17 +-
include/geos/operation/grid/TraversalAreas.h | 6 +-
src/operation/grid/Cell.cpp | 128 ++++--
src/operation/grid/Grid.cpp | 48 +-
src/operation/grid/GridIntersection.cpp | 129 ++++--
src/operation/grid/PerimeterDistance.cpp | 46 ++
src/operation/grid/Traversal.cpp | 23 +-
src/operation/grid/TraversalAreas.cpp | 499 +++++++++++++++++----
src/operation/union/OverlapUnion.cpp | 13 +-
tests/unit/capi/GEOSSubdivideByGridTest.cpp | 56 +++
tests/unit/geom/EnvelopeTest.cpp | 20 +-
tests/unit/operation/grid/GridIntersectionTest.cpp | 311 +++++++++++--
tests/unit/operation/grid/GridTest.cpp | 50 +++
tests/unit/operation/grid/TraversalAreasTest.cpp | 409 ++++++++++++++---
tests/unit/utility.h | 8 +
24 files changed, 1695 insertions(+), 318 deletions(-)
create mode 100644 tests/unit/capi/GEOSSubdivideByGridTest.cpp
hooks/post-receive
More information about the geos-commits
