[geos-commits] [SCM] GEOS branch main updated. a180ae12ad185da32746e665ee068b63b1ac4644
Tue Feb 17 12:28:12 PST 2026
the project "GEOS".
The branch, main has been updated
       via  a180ae12ad185da32746e665ee068b63b1ac4644 (commit)
      from  9bc6ca8716552f8d35e90cd22be433123c06b175 (commit)
revisions in full, below.
commit a180ae12ad185da32746e665ee068b63b1ac4644
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Feb 17 12:27:46 2026 -0800
    Preserve ZM when creating edges in Coverage (#1384)
    * When creating the edges for a new Coverage, check the dimensionality
    of the inputs and create coordinate sequences with the same dimensionality,
    so the extra dims pass through. Closes GH-1366.
diff --git a/src/coverage/CoverageEdge.cpp b/src/coverage/CoverageEdge.cpp
index a3504a2f6..53252b964 100644
--- a/src/coverage/CoverageEdge.cpp
+++ b/src/coverage/CoverageEdge.cpp
@@ -79,13 +79,19 @@ std::unique_ptr<CoordinateSequence>
 CoverageEdge::extractEdgePoints(const CoordinateSequence& ring,
     std::size_t start, std::size_t end)
-    auto pts = detail::make_unique<CoordinateSequence>();
     std::size_t size = start < end
                   ? end - start + 1
                   : ring.getSize() - start + end;
+    // Create CoordinateSequence with the same dimensions as the input ring
+    auto pts = detail::make_unique<CoordinateSequence>(size, ring.hasZ(), ring.hasM());
     std::size_t iring = start;
     for (std::size_t i = 0; i < size; i++) {
-        pts->add(ring.getAt(iring));
+        // Use applyAt to correctly add coordinates while preserving dimension
+        ring.applyAt(iring, [&pts, &i](const auto& c){
+            pts->setAt(c, i);
         iring += 1;
         if (iring >= ring.getSize())
             iring = 1;
diff --git a/src/coverage/CoverageRingEdges.cpp b/src/coverage/CoverageRingEdges.cpp
index 99c53b04e..fa87c2885 100644
--- a/src/coverage/CoverageRingEdges.cpp
+++ b/src/coverage/CoverageRingEdges.cpp
@@ -369,7 +369,8 @@ CoverageRingEdges::buildRing(const LinearRing* ring) const
     // CoordinateList ptsList = new CoordinateList();
-    std::unique_ptr<CoordinateSequence> pts(new CoordinateSequence());
+    // Create CoordinateSequence with the same dimensions as the original ring
+    std::unique_ptr<CoordinateSequence> pts(new CoordinateSequence(0, ring->hasZ(), ring->hasM()));
     Coordinate nullPt = Coordinate::getNull();
     for (std::size_t i = 0; i < ringEdges->size(); i++) {
         Coordinate& lastPt = pts->isEmpty() ? nullPt : pts->back();
diff --git a/src/simplify/LinkedLine.cpp b/src/simplify/LinkedLine.cpp
index 684e493e9..2d55ccf24 100644
--- a/src/simplify/LinkedLine.cpp
+++ b/src/simplify/LinkedLine.cpp
@@ -156,11 +156,14 @@ LinkedLine::remove(std::size_t index)
 LinkedLine::getCoordinates() const
-    std::unique_ptr<CoordinateSequence> coords(new CoordinateSequence());
+    // Create CoordinateSequence with the same dimensions as the original m_coord
+    std::unique_ptr<CoordinateSequence> coords(new CoordinateSequence(0, m_coord.hasZ(), m_coord.hasM()));
     std::size_t len = m_isRing ? m_coord.size() - 1 : m_coord.size();
     for (std::size_t i = 0; i < len; i++) {
         if (hasCoordinate(i)) {
-            coords->add(m_coord.getAt(i), false);
+            m_coord.applyAt(i, [&coords](const auto& c){ // Use applyAt for safe coordinate copy
+                coords->add(c, false);
     if (m_isRing) {
diff --git a/tests/unit/coverage/CoverageSimplifierTest.cpp b/tests/unit/coverage/CoverageSimplifierTest.cpp
index 1973ae965..be8b1938c 100644
--- a/tests/unit/coverage/CoverageSimplifierTest.cpp
+++ b/tests/unit/coverage/CoverageSimplifierTest.cpp
@@ -6,6 +6,10 @@
 // geos
 #include <geos/coverage/CoverageSimplifier.h>
+#include <geos/geom/Polygon.h> // Added for Polygon
+#include <geos/geom/SimpleCurve.h> // Added for SimpleCurve
 using geos::coverage::CoverageSimplifier;
@@ -502,5 +506,20 @@ void object::test<31> ()
     ensure("did not throw IllegalArgumentException", false);
+// Test GH-1366: M values are preserved
+template<>
+template<>
+void object::test<32> ()
+    std::string wktInput = "POLYGON ZM ((0 0 0 0, 10 0 1 1, 10 10 2 2, 0 10 3 3, 0 0 0 0))";
+    std::string wktExpected = "POLYGON ZM ((0 0 0 0, 10 0 1 1, 10 10 2 2, 0 10 3 3, 0 0 0 0))"; // No simplification occurs with tolerance 0
+    std::vector<std::unique_ptr<Geometry>> input = readArray({ wktInput });
+    std::vector<std::unique_ptr<Geometry>> expected = readArray({ wktExpected });
+    std::vector<std::unique_ptr<Geometry>> actual = CoverageSimplifier::simplify(input, 0.0);
+    ensure_equals_exact_geometry_xyzm(actual[0].get(), expected[0].get(), 0.001);
 } // namespace tut
Summary of changes:
 src/coverage/CoverageEdge.cpp                  | 10 ++++++++--
 src/coverage/CoverageRingEdges.cpp             |  3 ++-
 src/simplify/LinkedLine.cpp                    |  7 +++++--
 tests/unit/coverage/CoverageSimplifierTest.cpp | 19 +++++++++++++++++++
 4 files changed, 34 insertions(+), 5 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
