[geos-commits] [SCM] GEOS branch main updated. 02cbfe81143f6303f234f8a9ce3d9694ddcec381
Tue Jan 6 05:51:20 PST 2026
the project "GEOS".
The branch, main has been updated
       via  02cbfe81143f6303f234f8a9ce3d9694ddcec381 (commit)
      from  158c588566e08fd2f31f8c9e7ae069518e8264c5 (commit)
revisions in full, below.
commit 02cbfe81143f6303f234f8a9ce3d9694ddcec381
Author: arriopolis <arjan at cwi.nl>
Date:   Tue Jan 6 14:50:56 2026 +0100
    Improve OverlayNG performance (#1353)
    * Incorporated JTS PR 906
    * EdgeRing: Add const qualifiers, use std::make_shared
    Co-authored-by: arriopolis <arjan_rekenamchine at hotmail.com>
    Co-authored-by: Dan Baston <dbaston at gmail.com>
diff --git a/include/geos/geom/Envelope.h b/include/geos/geom/Envelope.h
index 687dbbae1..15d360030 100644
--- a/include/geos/geom/Envelope.h
+++ b/include/geos/geom/Envelope.h
@@ -575,6 +575,19 @@ public:
                 std::isless(p.y, maxy) && std::isgreater(p.y,  miny);
+    /** \brief
+     * Tests if an envelope is properly contained in this one.
+     * The envelope is properly contained if it is contained
+     * by this one but not equal to it.
+     * @param other the envelope to test
+     * @return true if the envelope is properly contained
+    bool containsProperly(const Envelope& other) const {
+        if (equals(&other)) return false;
+        return covers(other);
     /** \brief
      * Check if the point p intersects (lies inside) the region of this Envelope.
diff --git a/include/geos/operation/overlayng/OverlayEdgeRing.h b/include/geos/operation/overlayng/OverlayEdgeRing.h
index b2509f02c..f0e94445a 100644
--- a/include/geos/operation/overlayng/OverlayEdgeRing.h
+++ b/include/geos/operation/overlayng/OverlayEdgeRing.h
@@ -28,6 +28,7 @@ class PointOnGeometryLocator;
 namespace geom {
 class Coordinate;
+class CoordinateXY;
 class CoordinateSequence;
 class GeometryFactory;
 class LinearRing;
@@ -46,6 +47,7 @@ namespace overlayng { // geos.operation.overlayng
 class GEOS_DLL OverlayEdgeRing {
     using Coordinate = geos::geom::Coordinate;
+    using CoordinateXY = geos::geom::CoordinateXY;
     using CoordinateSequence = geos::geom::CoordinateSequence;
     using GeometryFactory = geos::geom::GeometryFactory;
     using LinearRing = geos::geom::LinearRing;
@@ -59,23 +61,25 @@ private:
     OverlayEdge* startEdge;
     std::unique_ptr<LinearRing> ring;
     bool m_isHole;
-    std::unique_ptr<IndexedPointInAreaLocator> locator;
+    mutable std::unique_ptr<IndexedPointInAreaLocator> locator;
     OverlayEdgeRing* shell;
     // a list of EdgeRings which are holes in this EdgeRing
     std::vector<OverlayEdgeRing*> holes;
     // Methods
     void computeRingPts(OverlayEdge* start, CoordinateSequence& pts);
-    void computeRing(std::unique_ptr<CoordinateSequence> && ringPts, const GeometryFactory* geometryFactory);
+    void computeRing(const std::shared_ptr<CoordinateSequence> & ringPts, const GeometryFactory* geometryFactory);
     * Computes the list of coordinates which are contained in this ring.
     * The coordinates are computed once only and cached.
     * @return an array of the {@link Coordinate}s in this ring
-    const CoordinateSequence& getCoordinates();
-    PointOnGeometryLocator* getLocator();
+    const CoordinateSequence& getCoordinates() const;
+    PointOnGeometryLocator* getLocator() const;
     static void closeRing(CoordinateSequence& pts);
+    bool contains(const OverlayEdgeRing& otherRing) const;
+    bool isPointInOrOut(const OverlayEdgeRing& otherRing) const;
 public:
@@ -85,6 +89,8 @@ public:
     std::unique_ptr<LinearRing> getRing();
     const LinearRing* getRingPtr() const;
+    const geom::Envelope& getEnvelope() const;
     * Tests whether this ring is a hole.
     * @return <code>true</code> if this ring is a hole
@@ -114,9 +120,9 @@ public:
     void addHole(OverlayEdgeRing* ring);
-    bool isInRing(const Coordinate& pt);
+    geom::Location locate(const CoordinateXY& pt) const;
-    const Coordinate& getCoordinate();
+    const Coordinate& getCoordinate() const;
     * Computes the {@link Polygon} formed by this ring and any contained holes.
@@ -144,7 +150,7 @@ public:
     * @return containing EdgeRing, if there is one
     * or null if no containing EdgeRing is found
-    OverlayEdgeRing* findEdgeRingContaining(const std::vector<OverlayEdgeRing*>& erList);
+    OverlayEdgeRing* findEdgeRingContaining(const std::vector<OverlayEdgeRing*>& erList) const;
diff --git a/include/geos/operation/polygonize/EdgeRing.h b/include/geos/operation/polygonize/EdgeRing.h
index 30f5be286..18646ee5d 100644
--- a/include/geos/operation/polygonize/EdgeRing.h
+++ b/include/geos/operation/polygonize/EdgeRing.h
@@ -64,9 +64,9 @@ private:
     DeList deList;
     // cache the following data for efficiency
-    std::unique_ptr<geom::LinearRing> ring;
-    std::unique_ptr<geom::CoordinateSequence> ringPts;
-    std::unique_ptr<algorithm::locate::PointOnGeometryLocator> ringLocator;
+    mutable std::unique_ptr<geom::LinearRing> ring;
+    mutable std::shared_ptr<geom::CoordinateSequence> ringPts;
+    mutable std::unique_ptr<algorithm::locate::PointOnGeometryLocator> ringLocator;
     std::unique_ptr<std::vector<std::unique_ptr<geom::LinearRing>>> holes;
@@ -84,19 +84,26 @@ private:
      * @return an array of the Coordinate in this ring
-    const geom::CoordinateSequence* getCoordinates();
+    const geom::CoordinateSequence* getCoordinates() const;
+    const geom::Envelope& getEnvelope() const {
+        return *getRingInternal()->getEnvelopeInternal();
     static void addEdge(const geom::CoordinateSequence* coords,
                         bool isForward,
                         geom::CoordinateSequence* coordList);
-    algorithm::locate::PointOnGeometryLocator* getLocator() {
+    algorithm::locate::PointOnGeometryLocator* getLocator() const {
         if (ringLocator == nullptr) {
             ringLocator.reset(new algorithm::locate::IndexedPointInAreaLocator(*getRingInternal()));
         return ringLocator.get();
+    bool contains(const EdgeRing& otherRing) const;
+    bool isPointInOrOut(const EdgeRing& otherRing) const;
 public:
     /** \brief
      * Adds a DirectedEdge which is known to form part of this ring.
@@ -324,7 +331,7 @@ public:
      * Ownership of ring is retained by the object.
      * Details of problems are written to standard output.
-    geom::LinearRing* getRingInternal();
+    const geom::LinearRing* getRingInternal() const;
     /** \brief
      * Returns this ring as a LinearRing, or null if an Exception
@@ -335,8 +342,8 @@ public:
     std::unique_ptr<geom::LinearRing> getRingOwnership();
-    bool isInRing(const geom::Coordinate & pt) {
-        return geom::Location::EXTERIOR != getLocator()->locate(&pt);
+    geom::Location locate(const geom::CoordinateXY& pt) const {
+        return getLocator()->locate(&pt);
diff --git a/src/operation/overlayng/OverlayEdgeRing.cpp b/src/operation/overlayng/OverlayEdgeRing.cpp
index f45d46418..b9ac01518 100644
--- a/src/operation/overlayng/OverlayEdgeRing.cpp
+++ b/src/operation/overlayng/OverlayEdgeRing.cpp
@@ -42,9 +42,9 @@ OverlayEdgeRing::OverlayEdgeRing(OverlayEdge* start, const GeometryFactory* geom
     , locator(nullptr)
     , shell(nullptr)
-    auto ringPts = detail::make_unique<CoordinateSequence>(0u, start->getCoordinatesRO()->hasZ(), start->getCoordinatesRO()->hasM());
+    auto ringPts = std::make_shared<CoordinateSequence>(0u, start->getCoordinatesRO()->hasZ(), start->getCoordinatesRO()->hasM());
     computeRingPts(start, *ringPts);
-    computeRing(std::move(ringPts), geometryFactory);
+    computeRing(ringPts, geometryFactory);
 /*public*/
@@ -60,6 +60,12 @@ OverlayEdgeRing::getRingPtr() const
     return ring.get();
+const Envelope&
+OverlayEdgeRing::getEnvelope() const
+    return *ring->getEnvelopeInternal();
@@ -149,10 +155,10 @@ OverlayEdgeRing::computeRingPts(OverlayEdge* start, CoordinateSequence& pts)
 /*private*/
 void
-OverlayEdgeRing::computeRing(std::unique_ptr<CoordinateSequence> && p_ringPts, const GeometryFactory* geometryFactory)
+OverlayEdgeRing::computeRing(const std::shared_ptr<CoordinateSequence> & p_ringPts, const GeometryFactory* geometryFactory)
     if (ring != nullptr) return;   // don't compute more than once
-    ring = geometryFactory->createLinearRing(std::move(p_ringPts));
+    ring = geometryFactory->createLinearRing(p_ringPts);
     m_isHole = algorithm::Orientation::isCCW(ring->getCoordinatesRO());
@@ -164,9 +170,9 @@ OverlayEdgeRing::computeRing(std::unique_ptr<CoordinateSequence> && p_ringPts, c
 /*private*/
-OverlayEdgeRing::getCoordinates()
+OverlayEdgeRing::getCoordinates() const
-    return *(detail::down_cast<const CoordinateSequence*>(ring->getCoordinatesRO()));
+    return *ring->getCoordinatesRO();
@@ -189,39 +195,23 @@ OverlayEdgeRing::getCoordinates()
 /*public*/
 OverlayEdgeRing*
-OverlayEdgeRing::findEdgeRingContaining(const std::vector<OverlayEdgeRing*>& erList)
+OverlayEdgeRing::findEdgeRingContaining(const std::vector<OverlayEdgeRing*>& erList) const
-    const LinearRing* testRing = ring.get();
-    const Envelope* testEnv = testRing->getEnvelopeInternal();
-    OverlayEdgeRing* minRing = nullptr;
-    const Envelope* minRingEnv = nullptr;
-    for (auto tryEdgeRing: erList) {
-        const LinearRing* tryRing = tryEdgeRing->getRingPtr();
-        const Envelope* tryShellEnv = tryRing->getEnvelopeInternal();
-        // the hole envelope cannot equal the shell envelope
-        // (also guards against testing rings against themselves)
-        if (tryShellEnv->equals(testEnv)) continue;
-        // hole must be contained in shell
-        if (! tryShellEnv->contains(testEnv)) continue;
-        const Coordinate& testPt = EdgeRing::ptNotInList(testRing->getCoordinatesRO(), tryRing->getCoordinatesRO());
-        bool isContained = tryEdgeRing->isInRing(testPt);
-        // check if the new containing ring is smaller than the current minimum ring
-        if (isContained) {
-            if (minRing == nullptr || minRingEnv->contains(tryShellEnv)) {
-                minRing = tryEdgeRing;
-                minRingEnv = minRing->getRingPtr()->getEnvelopeInternal();
+    OverlayEdgeRing* minContainingRing = nullptr;
+    for (OverlayEdgeRing* edgeRing : erList) {
+        if (edgeRing->contains(*this)) {
+            if (minContainingRing == nullptr
+                || minContainingRing->getEnvelope().contains(edgeRing->getEnvelope())) {
+                minContainingRing = edgeRing;
-    return minRing;
+    return minContainingRing;
 /*private*/
-OverlayEdgeRing::getLocator()
+OverlayEdgeRing::getLocator() const
     if (locator == nullptr) {
       locator.reset(new IndexedPointInAreaLocator(*(getRingPtr())));
@@ -230,18 +220,54 @@ OverlayEdgeRing::getLocator()
 /*public*/
-bool
-OverlayEdgeRing::isInRing(const Coordinate& pt)
+geom::Location
+OverlayEdgeRing::locate(const CoordinateXY& pt) const
     * Use an indexed point-in-polygon for performance
-    return Location::EXTERIOR != getLocator()->locate(&pt);
+ * Tests if an edgeRing is properly contained in this ring.
+ * Relies on property that edgeRings never overlap (although they may
+ * touch at single vertices).
+ * @param ring ring to test
+ * @return true if ring is properly contained
+bool
+OverlayEdgeRing::contains(const OverlayEdgeRing& otherRing) const {
+    // the test envelope must be properly contained
+    // (guards against testing rings against themselves)
+    const Envelope& env = getEnvelope();
+    const Envelope& testEnv = otherRing.getEnvelope();
+    if (! env.containsProperly(testEnv)) {
+        return false;
+    return isPointInOrOut(otherRing);
+bool
+OverlayEdgeRing::isPointInOrOut(const OverlayEdgeRing& otherRing) const {
+    // in most cases only one or two points will be checked
+    for (const CoordinateXY& pt : otherRing.getCoordinates().items<CoordinateXY>()) {
+        geom::Location loc = locate(pt);
+        if (loc == geom::Location::INTERIOR) {
+            return true;
+        if (loc == geom::Location::EXTERIOR) {
+            return false;
+        // pt is on BOUNDARY, so keep checking for a determining location
+    return false;
 /*public*/
 const Coordinate&
-OverlayEdgeRing::getCoordinate()
+OverlayEdgeRing::getCoordinate() const
     return ring->getCoordinatesRO()->getAt(0);
diff --git a/src/operation/polygonize/EdgeRing.cpp b/src/operation/polygonize/EdgeRing.cpp
index 7bff9c787..4f4252a8d 100644
--- a/src/operation/polygonize/EdgeRing.cpp
+++ b/src/operation/polygonize/EdgeRing.cpp
@@ -51,39 +51,16 @@ namespace polygonize { // geos.operation.polygonize
 EdgeRing*
 EdgeRing::findEdgeRingContaining(const std::vector<EdgeRing*> & erList)
-    const LinearRing* testRing = getRingInternal();
-    if(! testRing) {
-        return nullptr;
-    EdgeRing* minRing = nullptr;
-    for(auto& tryEdgeRing : erList) {
-        auto tryRing = tryEdgeRing->getRingInternal();
-        auto tryShellEnv = tryRing->getEnvelopeInternal();
-        if (tryShellEnv->equals(testEnv)) {
-            continue;
-        if (!tryShellEnv->contains(testEnv)) {
-            continue;
-        auto tryCoords = tryRing->getCoordinatesRO();
-        const Coordinate& testPt = ptNotInList(testRing->getCoordinatesRO(), tryCoords);
-        // check if this new containing ring is smaller than the current minimum ring
-        if(tryEdgeRing->isInRing(testPt)) {
-            if(minRing == nullptr || minRingEnv->contains(tryShellEnv)) {
-                minRingEnv = minRing->getRingInternal()->getEnvelopeInternal();
+    EdgeRing* minContainingRing = nullptr;
+    for (auto& edgeRing : erList) {
-    return minRing;
 std::vector<PolygonizeDirectedEdge*>
@@ -214,12 +191,40 @@ EdgeRing::computeValid()
     is_valid = ring->isValid();
+bool
+EdgeRing::contains(const EdgeRing& otherRing) const {
+        return false;
+bool
+EdgeRing::isPointInOrOut(const EdgeRing& otherRing) const {
+    for (const CoordinateXY& pt : otherRing.getCoordinates()->items<CoordinateXY>()) {
+            return true;
+            return false;
+    return false;
 /*private*/
-EdgeRing::getCoordinates()
+EdgeRing::getCoordinates() const
     if(ringPts == nullptr) {
-        ringPts = detail::make_unique<CoordinateSequence>(0u, 0u);
+        ringPts = std::make_shared<CoordinateSequence>(0u, 0u);
         for(const auto& de : deList) {
             auto edge = dynamic_cast<PolygonizeEdge*>(de->getEdge());
             addEdge(edge->getLine()->getCoordinatesRO(),
@@ -234,12 +239,12 @@ std::unique_ptr<LineString>
 EdgeRing::getLineString()
     getCoordinates();
-    return std::unique_ptr<LineString>(factory->createLineString(*ringPts));
+    return factory->createLineString(ringPts);
 /*public*/
-LinearRing*
-EdgeRing::getRingInternal()
+const LinearRing*
+EdgeRing::getRingInternal() const
     if(ring != nullptr) {
         return ring.get();
Summary of changes:
 include/geos/geom/Envelope.h                       | 13 +++
 include/geos/operation/overlayng/OverlayEdgeRing.h | 20 +++--
 include/geos/operation/polygonize/EdgeRing.h       | 23 ++++--
 src/operation/overlayng/OverlayEdgeRing.cpp        | 96 ++++++++++++++--------
 src/operation/polygonize/EdgeRing.cpp              | 75 +++++++++--------
 5 files changed, 142 insertions(+), 85 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
