[geos-commits] [SCM] GEOS branch main updated. 9e2348082d2ecd02f8241a90e62954a17f8773af
Tue Jan 6 08:41:48 PST 2026
the project "GEOS".
The branch, main has been updated
       via  9e2348082d2ecd02f8241a90e62954a17f8773af (commit)
      from  02cbfe81143f6303f234f8a9ce3d9694ddcec381 (commit)
revisions in full, below.
commit 9e2348082d2ecd02f8241a90e62954a17f8773af
Author: Sven Jensen <sven at analysis.net>
Date:   Tue Jan 6 08:41:28 2026 -0800
    Add new CAPI functions for Hausdorff distance (#1352)
    * Add new CAPI functions for Hausdorff distance
    Introduce two new CAPI functions:
    - GEOSHausdorffDistanceWithPoints
    - GEOSHausdorffDistanceDensifyWithPoints
    These functions take four additional double pointers
    (pt1_x, pt1_y, pt2_x, pt2_y) and fill them with the
    coordinates used in the Hausdorff distance calculation
    via getCoordinates().
    Also add a unit test verifying the new function behavior.
    * typo in function out parameter documentation
    * GEOSHausdorffDistanceWithPoints: simplify implementation
    Co-authored-by: Dan Baston <dbaston at gmail.com>
diff --git a/capi/geos_c.cpp b/capi/geos_c.cpp
index d26db0966..9a832a64b 100644
--- a/capi/geos_c.cpp
+++ b/capi/geos_c.cpp
@@ -317,12 +317,24 @@ extern "C" {
         return GEOSHausdorffDistance_r(handle, g1, g2, dist);
+    int
+    GEOSHausdorffDistanceWithPoints(const Geometry* g1, const Geometry* g2, double* dist, double* p1x, double* p1y, double* p2x, double* p2y)
+        return GEOSHausdorffDistanceWithPoints_r(handle, g1, g2, dist, p1x, p1y, p2x, p2y);
     int
     GEOSHausdorffDistanceDensify(const Geometry* g1, const Geometry* g2, double densifyFrac, double* dist)
         return GEOSHausdorffDistanceDensify_r(handle, g1, g2, densifyFrac, dist);
+    int
+    GEOSHausdorffDistanceDensifyWithPoints(const Geometry* g1, const Geometry* g2, double densifyFrac, double* dist, double* p1x, double* p1y, double* p2x, double* p2y)
+        return GEOSHausdorffDistanceDensifyWithPoints_r(handle, g1, g2, densifyFrac, dist, p1x, p1y, p2x, p2y);
     int
     GEOSFrechetDistance(const Geometry* g1, const Geometry* g2, double* dist)
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index 942663671..44bb6d3ed 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -1954,6 +1954,15 @@ extern int GEOS_DLL GEOSHausdorffDistance_r(
     const GEOSGeometry *g2,
     double *dist);
+/** \see GEOSHausdorffDistanceWithPoints */
+extern int GEOS_DLL GEOSHausdorffDistanceWithPoints_r(
+    GEOSContextHandle_t handle,
+    const GEOSGeometry *g1,
+    const GEOSGeometry *g2,
+    double *dist,
+    double *p1x, double *p1y,
+    double *p2x, double *p2y);
 /** \see GEOSHausdorffDistanceDensify */
 extern int GEOS_DLL GEOSHausdorffDistanceDensify_r(
@@ -1961,6 +1970,15 @@ extern int GEOS_DLL GEOSHausdorffDistanceDensify_r(
     double densifyFrac, double *dist);
+/** \see GEOSHausdorffDistanceDensifyWithPoints */
+extern int GEOS_DLL GEOSHausdorffDistanceDensifyWithPoints_r(
+    double densifyFrac, double* dist,
 /** \see GEOSFrechetDistance */
 extern int GEOS_DLL GEOSFrechetDistance_r(
@@ -3704,6 +3722,30 @@ extern int GEOS_DLL GEOSHausdorffDistance(
     double *dist);
+* Calculate the Hausdorff distance between two geometries and return
+* the coordinates of the points that determine the distance.
+* \param[in] g1 Input geometry
+* \param[in] g2 Input geometry
+* \param[out] dist Pointer to be filled in with distance result
+* \param[out] p1x X coordinate of point on g1
+* \param[out] p1y Y coordinate of point on g1
+* \param[out] p2x X coordinate of point on g2
+* \param[out] p2y Y coordinate of point on g2
+* \return 1 on success, 0 on exception.
+* \see geos::algorithm::distance::DiscreteHausdorffDistance
+* \since 3.15
+extern int GEOS_DLL GEOSHausdorffDistanceWithPoints(
+    double *dist,
 * Calculate a more precise Hausdorff distance between two geometries,
 * by densifying the inputs before computation.
@@ -3724,6 +3766,33 @@ extern int GEOS_DLL GEOSHausdorffDistanceDensify(
     double densifyFrac,
     double *dist);
+ * Calculate a more precise Hausdorff distance between two geometries,
+ * by densifying the inputs before computation and return the points
+ * that determine the distance.
+ * [Hausdorff distance](https://en.wikipedia.org/wiki/Hausdorff_distance)
+ * is the largest distance between two geometries.
+ * \param[in] g1 Input geometry
+ * \param[in] g2 Input geometry
+ * \param[in] densifyFrac The largest % of the overall line length that
+ * any given two point segment should be.
+ * \param[out] dist Pointer to be filled in with distance result
+ * \param[out] p1x X coordinate of point on g1
+ * \param[out] p1y Y coordinate of point on g1
+ * \param[out] p2x X coordinate of point on g2
+ * \param[out] p2y Y coordinate of point on g2
+ * \return 1 on success, 0 on exception.
+ * \see goes::algorithm::distance::DiscreteHausdorffDistance
+ * \since 3.15
+extern int GEOS_DLL GEOSHausdorffDistanceDensifyWithPoints(
+    double *dist,
+    double* p1x, double* p1y,
+    double* p2x, double* p2y);
 * Calculate the
 * [Frechet distance](https://en.wikipedia.org/wiki/Fr%C3%A9chet_distance)
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index d8b57fd87..e082f799c 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -968,6 +968,24 @@ extern "C" {
+    int
+    GEOSHausdorffDistanceWithPoints_r(GEOSContextHandle_t extHandle,
+        const Geometry* g1, const Geometry* g2,
+        double* dist, double* p1x, double* p1y,
+        return execute(extHandle, 0, [&]() {
+            DiscreteHausdorffDistance dhd(*g1, *g2);
+            *dist = dhd.distance();
+            const auto& pts = dhd.getCoordinates();
+            *p1x = pts[0].x;
+            *p1y = pts[0].y;
+            *p2x = pts[1].x;
+            *p2y = pts[1].y;
+            return 1;
     int
     GEOSHausdorffDistanceDensify_r(GEOSContextHandle_t extHandle, const Geometry* g1, const Geometry* g2,
@@ -978,6 +996,23 @@ extern "C" {
+    int
+    GEOSHausdorffDistanceDensifyWithPoints_r(GEOSContextHandle_t extHandle, const Geometry* g1, const Geometry* g2,
+		                   double densifyFrac, double* dist, double* p1x, double* p1y, double* p2x, double* p2y)
+            dhd.setDensifyFraction(densifyFrac);
+            *p1x = pts[0].x;
+            *p1y = pts[0].y;
+            *p2x = pts[1].x;
+            *p2y = pts[1].y;
+            return 1;
     int
     GEOSFrechetDistance_r(GEOSContextHandle_t extHandle, const Geometry* g1, const Geometry* g2, double* dist)
diff --git a/include/geos/algorithm/distance/DiscreteHausdorffDistance.h b/include/geos/algorithm/distance/DiscreteHausdorffDistance.h
index be136edee..74876ec7b 100644
--- a/include/geos/algorithm/distance/DiscreteHausdorffDistance.h
+++ b/include/geos/algorithm/distance/DiscreteHausdorffDistance.h
@@ -96,7 +96,7 @@ public:
     static double distance(const geom::Geometry& g0,
                            const geom::Geometry& g1, double densifyFrac);
     DiscreteHausdorffDistance(const geom::Geometry& p_g0,
                               const geom::Geometry& p_g1)
@@ -130,7 +130,7 @@ public:
         return ptDist.getDistance();
-    const std::array<geom::CoordinateXY, 2>
+    const std::array<geom::CoordinateXY, 2>&
     getCoordinates() const
         return ptDist.getCoordinates();
diff --git a/src/algorithm/distance/DiscreteHausdorffDistance.cpp b/src/algorithm/distance/DiscreteHausdorffDistance.cpp
index 3712b0a40..6b0e7914d 100644
--- a/src/algorithm/distance/DiscreteHausdorffDistance.cpp
+++ b/src/algorithm/distance/DiscreteHausdorffDistance.cpp
@@ -79,8 +79,8 @@ DiscreteHausdorffDistance::distance(const geom::Geometry& g0,
     return dist.distance();
-/* public */
+/* public */
 void DiscreteHausdorffDistance::setDensifyFraction(double dFrac)
     // !(dFrac > 0) written that way to catch NaN
diff --git a/tests/unit/capi/GEOSHausdorffDistanceTest.cpp b/tests/unit/capi/GEOSHausdorffDistanceTest.cpp
index eb569c60a..747d2a9df 100644
--- a/tests/unit/capi/GEOSHausdorffDistanceTest.cpp
+++ b/tests/unit/capi/GEOSHausdorffDistanceTest.cpp
@@ -72,4 +72,45 @@ void object::test<3>()
     ensure_equals("curved geometry not supported", GEOSHausdorffDistance(geom2_, geom1_, &dist), 0);
+template<>
+template<>
+void object::test<4>()
+    set_test_name("GEOSHausdorffDistanceWithPoints");
+    geom1_ = fromWKT("LINEARRING (1 1, 1 2, 5 1, 1 1)");
+    geom2_ = fromWKT("LINEARRING (0 0, -5 0, 0 -1, 0 0)");
+    double dist;
+    double p1x, p1y, p2x, p2y;
+    ensure_equals(GEOSHausdorffDistanceWithPoints(geom1_, geom2_, &dist, &p1x, &p1y, &p2x, &p2y), 1);
+    ensure_equals("dist", dist, 6.082763, 1e-5);
+    ensure_equals(p1x, 1);
+    ensure_equals(p1y, 1);
+    ensure_equals(p2x, -5);
+    ensure_equals(p2y, 0);
+template<>
+template<>
+void object::test<5>()
+    set_test_name("GEOSHausdorffDistanceDensifyWithPoints");
+    constexpr double densifyFrac = 0.001;
+    double dist;
+    ensure_equals(GEOSHausdorffDistanceDensifyWithPoints(geom1_, geom2_, densifyFrac, &dist, &p1x, &p1y, &p2x, &p2y), 1);
 } // namespace tut
Summary of changes:
 capi/geos_c.cpp                                    | 12 ++++
 capi/geos_c.h.in                                   | 69 ++++++++++++++++++++++
 capi/geos_ts_c.cpp                                 | 35 +++++++++++
 .../algorithm/distance/DiscreteHausdorffDistance.h |  4 +-
 .../distance/DiscreteHausdorffDistance.cpp         |  2 +-
 tests/unit/capi/GEOSHausdorffDistanceTest.cpp      | 41 +++++++++++++
 6 files changed, 160 insertions(+), 3 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
