[geos-commits] [SCM] GEOS branch main updated. aefb2e4be129e466e4e75ea52ad1c9b18dd06b9d
Thu Jan 15 16:42:11 PST 2026
the project "GEOS".
The branch, main has been updated
       via  aefb2e4be129e466e4e75ea52ad1c9b18dd06b9d (commit)
      from  36d2dcfdea9cf2738dc5a233ee917417511e7945 (commit)
revisions in full, below.
commit aefb2e4be129e466e4e75ea52ad1c9b18dd06b9d
Author: Loïc Bartoletti <lbartoletti at users.noreply.github.com>
Date:   Fri Jan 16 01:41:47 2026 +0100
    test(bsd): disable FE_INVALID check on EnvelopeTest (#1375)
diff --git a/tests/unit/geom/EnvelopeTest.cpp b/tests/unit/geom/EnvelopeTest.cpp
index 1e9385e81..7c281aaee 100644
--- a/tests/unit/geom/EnvelopeTest.cpp
+++ b/tests/unit/geom/EnvelopeTest.cpp
@@ -103,8 +103,12 @@ struct test_envelope_data {
         //ensure("FE_INEXACT raised", !std::fetestexcept(FE_INEXACT));
 //#endif
 #ifdef FE_INVALID
+        // Skip FE_INVALID check on FreeBSD and OpenBSD due to platform-specific behavior
+        // See: https://github.com/libgeos/geos/issues/1206
+#if !defined(__FreeBSD__) && !defined(__OpenBSD__)
         ensure("FE_INVALID raised", !std::fetestexcept(FE_INVALID));
 #endif
+#endif
 #ifdef FE_OVERFLOW
         ensure("FE_OVERFLOW raised", !std::fetestexcept(FE_OVERFLOW));
 #endif
Summary of changes:
 tests/unit/geom/EnvelopeTest.cpp | 4 ++++
 1 file changed, 4 insertions(+)
hooks/post-receive
More information about the geos-commits mailing list
