[geos-commits] [SCM] GEOS branch main updated. 9563c1805e90523fce74530e8fa3ff4d5e873d35
Thu Jan 15 23:31:11 PST 2026
the project "GEOS".
The branch, main has been updated
       via  9563c1805e90523fce74530e8fa3ff4d5e873d35 (commit)
      from  aefb2e4be129e466e4e75ea52ad1c9b18dd06b9d (commit)
revisions in full, below.
commit 9563c1805e90523fce74530e8fa3ff4d5e873d35
Author: Mike Taves <mwtoews at gmail.com>
Date:   Fri Jan 16 20:30:51 2026 +1300
    CI: add FreeBSD build and test (#1376)
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index 729951169..108465511 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -485,6 +485,46 @@ jobs:
       working-directory: ./build
       run: ctest -V --output-on-failure -C ${{ matrix.build_type }}
+  freebsd:
+    name: FreeBSD
+    runs-on: ubuntu-latest
+    steps:
+    - uses: actions/checkout at v5
+    - name: Retrieve build cache
+      uses: actions/cache/restore at v4
+      id: restore-cache
+      with:
+        path: .ccache
+        key: freebsd-${{ github.ref_name }}-${{ github.run_id }}
+        restore-keys: freebsd
+    - name: Build and test
+      uses: vmactions/freebsd-vm at v1
+      with:
+        release: "15.0"
+        envs: CCACHE_COMPRESS CCACHE_COMPRESSLEVEL CCACHE_MAXSIZE
+        usesh: true
+        prepare: |
+          pkg install -y cmake ccache
+        run: |
+          set -e
+          export CCACHE_DIR=$PWD/.ccache
+          cmake --version
+          cmake -S . -B _build -D USE_CCACHE=ON ..
+          cmake --build _build -j $(nproc)
+          ccache --show-stats
+          cd _build
+          ctest --output-on-failure
+          cd ..
+          rm -rf _build
+    - name: Save build cache
+      uses: actions/cache/save at v4
+      with:
+        path: .ccache
+        key: ${{ steps.restore-cache.outputs.cache-primary-key }}
   emscripten:
     name: Emscripten WASM build
Summary of changes:
 .github/workflows/ci.yml | 40 ++++++++++++++++++++++++++++++++++++++++
 1 file changed, 40 insertions(+)
hooks/post-receive
More information about the geos-commits mailing list
