[geos-commits] [SCM] GEOS branch main updated. 3b391278f7844f16968e9397dd507c95589ac647
Fri Jan 16 08:18:43 PST 2026
the project "GEOS".
The branch, main has been updated
       via  3b391278f7844f16968e9397dd507c95589ac647 (commit)
       via  49209692ccda59d4f650001ba7a7f8752d54b98b (commit)
       via  c28e77e9502c7496f90e1402dae6420312a69203 (commit)
      from  9563c1805e90523fce74530e8fa3ff4d5e873d35 (commit)
revisions in full, below.
commit 3b391278f7844f16968e9397dd507c95589ac647
Author: Daniel Baston <dbaston at gmail.com>
Date:   Mon Jan 12 10:21:06 2026 -0500
    LineMerger: Retain M values
    Resolves https://github.com/libgeos/geos/issues/1359
diff --git a/src/operation/linemerge/EdgeString.cpp b/src/operation/linemerge/EdgeString.cpp
index 7c10a2a2e..88abfadee 100644
--- a/src/operation/linemerge/EdgeString.cpp
+++ b/src/operation/linemerge/EdgeString.cpp
@@ -27,7 +27,6 @@
 #include <geos/util.h>
 #include <vector>
-#include <cassert>
 using namespace geos::geom;
@@ -60,9 +59,23 @@ EdgeString::getCoordinates() const
     int forwardDirectedEdges = 0;
     int reverseDirectedEdges = 0;
-    auto coordinates = detail::make_unique<CoordinateSequence>();
-    for(std::size_t i = 0, e = directedEdges.size(); i < e; ++i) {
-        LineMergeDirectedEdge* directedEdge = directedEdges[i];
+    bool resultHasZ = false;
+    bool resultHasM = false;
+    for (const LineMergeDirectedEdge* directedEdge : directedEdges) {
+        const LineMergeEdge* lme = detail::down_cast<LineMergeEdge*>(directedEdge->getEdge());
+        resultHasZ |= lme->getLine()->hasZ();
+        resultHasM |= lme->getLine()->hasM();
+    auto coordinates = std::make_unique<CoordinateSequence>(0, resultHasZ, resultHasM);
+    bool lastPointMissingZ = false;
+    bool lastPointMissingM = false;
         if(directedEdge->getEdgeDirection()) {
             forwardDirectedEdges++;
@@ -70,15 +83,30 @@ EdgeString::getCoordinates() const
             reverseDirectedEdges++;
-        LineMergeEdge* lme = detail::down_cast<LineMergeEdge*>(directedEdge->getEdge());
+        const CoordinateSequence* seq = lme->getLine()->getCoordinatesRO();
-        coordinates->add(*lme->getLine()->getCoordinatesRO(),
+        if (lastPointMissingZ && seq->hasZ()) {
+            const double z = directedEdge->getEdgeDirection() ? seq->getZ(0) : seq->getZ(seq->getSize() - 1);
+            coordinates->setZ(coordinates->getSize() - 1, z);
+        if (lastPointMissingM && seq->hasM()) {
+            const double m = directedEdge->getEdgeDirection() ? seq->getM(0) : seq->getM(seq->getSize() - 1);
+            coordinates->setM(coordinates->getSize() - 1, m);
+        coordinates->add(*seq,
                          false,
                          directedEdge->getEdgeDirection());
+        lastPointMissingZ = resultHasZ && !seq->hasZ();
+        lastPointMissingM = resultHasM && !seq->hasM();
     if(reverseDirectedEdges > forwardDirectedEdges) {
         coordinates->reverse();
     return coordinates;
diff --git a/tests/unit/operation/linemerge/LineMergerTest.cpp b/tests/unit/operation/linemerge/LineMergerTest.cpp
index 1fea1cd7b..e99ad4280 100644
--- a/tests/unit/operation/linemerge/LineMergerTest.cpp
+++ b/tests/unit/operation/linemerge/LineMergerTest.cpp
@@ -17,6 +17,8 @@
 #include <string>
 #include <vector>
+#include "utility.h"
 namespace tut {
 // Test Group
@@ -492,5 +494,34 @@ void object::test<19>
     ensure_equals(geom->getLength(), merged[0]->getLength());
+template<>
+template<>
+void object::test<20>
+    std::vector<std::string> wkts{
+        "LINESTRING Z (0 0 0, 1 2 3, 2 4 6)",
+        "LINESTRING M (10 9 8, 2 4 7)",
+        "LINESTRING Z (10 9 2, 11 12 15)"
+    std::vector<std::unique_ptr<Geometry>> geoms;
+    LineMerger lm;
+    for (const auto& wkt : wkts) {
+        auto geom = wktreader.read(wkt);
+        lm.add(geom.get());
+        geoms.push_back(std::move(geom));
+    auto merged = lm.getMergedLineStrings();
+    ensure_equals(merged.size(), 1u);
+    auto expected = wktreader.read("LINESTRING ZM (0 0 0 NaN, 1 2 3 NaN, 2 4 6 7, 10 9 2 8, 11 12 15 NaN)");
+    ensure_equals_exact_geometry_xyzm(merged.front().get(), expected.get(), 0.0);
 } // namespace tut
commit 49209692ccda59d4f650001ba7a7f8752d54b98b
Date:   Mon Jan 12 10:20:50 2026 -0500
    geos_unit: Improve assert failure message in ensure_equals_xyzm
diff --git a/tests/unit/utility.h b/tests/unit/utility.h
index 562a95dc8..c86dbce56 100644
--- a/tests/unit/utility.h
+++ b/tests/unit/utility.h
@@ -428,8 +428,8 @@ ensure_equals_exact_xyzm(const geos::geom::CoordinateSequence* seq1,
         seq2->getAt(i, c2);
         ensure("xy not in tolerance", c1.distance(c2) <= tol);
-        ensure_same("z not same", c1.z, c2.z);
-        ensure_same("z not same", c1.m, c2.m);
+        ensure_same(("index " + std::to_string(i) + "/" + std::to_string(seq1->getSize() - 1) + " z not same").c_str(), c1.z, c2.z);
+        ensure_same(("index " + std::to_string(i) + "/" + std::to_string(seq1->getSize() - 1) + " m not same").c_str(), c1.m, c2.m);
commit c28e77e9502c7496f90e1402dae6420312a69203
Date:   Mon Jan 12 10:20:23 2026 -0500
    CoordinateSequence: Add Z/M accessors
diff --git a/include/geos/geom/CoordinateSequence.h b/include/geos/geom/CoordinateSequence.h
index 5e0a7776b..e4a1c5553 100644
--- a/include/geos/geom/CoordinateSequence.h
+++ b/include/geos/geom/CoordinateSequence.h
@@ -337,6 +337,80 @@ public:
         return m_vect[index * stride() + 1];
+     * Returns ordinate Z of the specified coordinate.
+     * @param index
+     * @return the value of the Z ordinate in the index'th coordinate, or NaN if the
+     *         CoordinateSequence does not store Z values
+    double getZ(std::size_t index) const
+        return getOrdinate(index, Z);
+     * Returns ordinate M of the specified coordinate.
+     * @param index
+     * @return the value of the M ordinate in the index'th coordinate, or NaN if the
+     *         CoordinateSequence does not store M values
+    double getM(std::size_t index) const
+        return getOrdinate(index, M);
+     * Set the X value of the specified coordinate.
+     * @param index
+     * @param x the new X value
+    void setX(std::size_t index, double x)
+        m_vect[index * stride()] = x;
+     * Set the Y value of the specified coordinate.
+     * @param index
+     * @param y the new Y value
+    void setY(std::size_t index, double y)
+        m_vect[index * stride() + 1] = y;
+     * Set the Z value of the specified coordinate.
+     * Has no effect if the CoordinateSequence does not store Z values.
+     * @param index
+     * @param z the new Z value
+    void setZ(std::size_t index, double z)
+        if (hasZ())
+            setOrdinate(index, Z, z);
+     * Set the M value of the specified coordinate.
+     * Has no effect if the CoordinateSequence does not store M values.
+     * @param index
+     * @param m the new M value
+    void setM(std::size_t index, double m)
+        if (hasM())
+            setOrdinate(index, M, m);
     /// Return last Coordinate in the sequence
     template<typename T=Coordinate>
     const T& back() const
diff --git a/tests/unit/geom/CoordinateSequenceTest.cpp b/tests/unit/geom/CoordinateSequenceTest.cpp
index e2a94fb41..a0c86888e 100644
--- a/tests/unit/geom/CoordinateSequenceTest.cpp
+++ b/tests/unit/geom/CoordinateSequenceTest.cpp
@@ -1580,4 +1580,41 @@ void object::test<59>()
     ensure_equals(length, 8);
+template<>
+template<>
+void object::test<60>()
+    set_test_name("Z/M accessors on XY sequence");
+    CoordinateSequence seq(0, false, false);
+    seq.add(CoordinateXY{0, 0});
+    seq.add(CoordinateXY{3, 0});
+    seq.setZ(0, 500);
+    seq.setM(0, 501);
+    ensure(std::isnan(seq.getZ(0)));
+    ensure(std::isnan(seq.getM(0)));
+template<>
+template<>
+void object::test<61>()
+    set_test_name("Z/M accessors on XYZM sequence");
+    CoordinateSequence seq(0, true, true);
+    seq.setZ(0, 500);
+    seq.setM(0, 501);
+    ensure_equals(seq.getZ(0), 500);
+    ensure_equals(seq.getM(0), 501);
+    ensure(std::isnan(seq.getZ(1)));
+    ensure(std::isnan(seq.getM(1)));
 } // namespace tut
Summary of changes:
 include/geos/geom/CoordinateSequence.h            | 74 +++++++++++++++++++++++
 src/operation/linemerge/EdgeString.cpp            | 40 ++++++++++--
 tests/unit/geom/CoordinateSequenceTest.cpp        | 37 ++++++++++++
 tests/unit/operation/linemerge/LineMergerTest.cpp | 31 ++++++++++
 tests/unit/utility.h                              |  4 +-
 5 files changed, 178 insertions(+), 8 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
