[geos-commits] [SCM] GEOS branch main updated. 678482bd85082ab0c671a100373a1d9c46764ffe
git at osgeo.org
git at osgeo.org
Tue Jul 7 18:11:23 PDT 2026
the project "GEOS".
The branch, main has been updated
via 678482bd85082ab0c671a100373a1d9c46764ffe (commit)
from 1cd8399189d96ca1b9fac9a02517e84ce9aadee4 (commit)
revisions in full, below.
commit 678482bd85082ab0c671a100373a1d9c46764ffe
Author: Tom Payne <twpayne at gmail.com>
Date: Wed Jul 8 03:10:55 2026 +0200
geos_c.h: Make enums available with GEOS_USE_ONLY_R_API defined (#1470)
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index cb91502fd..26b88aca6 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -1108,6 +1108,16 @@ extern GEOSGeometry GEOS_DLL *GEOSPolygonHullSimplify_r(
unsigned int isOuter,
double vertexNumFraction);
+* Controls the behavior of the GEOSPolygonHullSimplify parameter.
+enum GEOSPolygonHullParameterModes {
+ /** Fraction of input vertices retained */
+ GEOSHULL_PARAM_VERTEX_RATIO = 1,
+ /** Ratio of simplified hull area to input area */
+ GEOSHULL_PARAM_AREA_RATIO = 2
/** \see GEOSPolygonHullSimplifyMode */
extern GEOSGeometry GEOS_DLL *GEOSPolygonHullSimplifyMode_r(
GEOSContextHandle_t handle,
@@ -1371,6 +1381,17 @@ extern GEOSGeometry GEOS_DLL * GEOSConstrainedDelaunayTriangulation_r(
const GEOSGeometry *g);
+/** Change behaviour of \ref GEOSVoronoiDiagram */
+enum GEOSVoronoiFlags
+ /** Return only edges of the Voronoi cells, as a MultiLineString **/
+ GEOS_VORONOI_ONLY_EDGES = 1,
+ /** Preserve order of inputs, such that the nth cell in the result corresponds
+ * to the nth vertex in the input. If this cannot be done, such as for inputs
+ * that contain repeated points, \ref GEOSVoronoiDiagram will return NULL. **/
+ GEOS_VORONOI_PRESERVE_ORDER = 2
/** \see GEOSVoronoiDiagram */
extern GEOSGeometry GEOS_DLL * GEOSVoronoiDiagram_r(
GEOSContextHandle_t extHandle,
@@ -5282,16 +5303,6 @@ extern GEOSGeometry GEOS_DLL *GEOSPolygonHullSimplify(
-* Controls the behavior of the GEOSPolygonHullSimplify parameter.
-enum GEOSPolygonHullParameterModes {
- /** Fraction of input vertices retained */
- GEOSHULL_PARAM_VERTEX_RATIO = 1,
- /** Ratio of simplified hull area to input area */
- GEOSHULL_PARAM_AREA_RATIO = 2
* Computes a topology-preserving simplified hull of a polygonal geometry,
* with hull shape determined by the parameter, controlled by a parameter
@@ -5521,17 +5532,6 @@ extern GEOSGeometry GEOS_DLL * GEOSDelaunayTriangulation(
extern GEOSGeometry GEOS_DLL * GEOSConstrainedDelaunayTriangulation(
-/** Change behaviour of \ref GEOSVoronoiDiagram */
-enum GEOSVoronoiFlags
- /** Return only edges of the Voronoi cells, as a MultiLineString **/
- GEOS_VORONOI_ONLY_EDGES = 1,
- /** Preserve order of inputs, such that the nth cell in the result corresponds
- * to the nth vertex in the input. If this cannot be done, such as for inputs
- * that contain repeated points, \ref GEOSVoronoiDiagram will return NULL. **/
- GEOS_VORONOI_PRESERVE_ORDER = 2
* Returns the 2D Voronoi polygons or edges computed from the vertices
* of the given geometry.
Summary of changes:
capi/geos_c.h.in | 42 +++++++++++++++++++++---------------------
1 file changed, 21 insertions(+), 21 deletions(-)
hooks/post-receive
More information about the geos-commits
