[geos-commits] [SCM] GEOS branch main updated. 4f2442b078b7e26df23ced6193dc62f11090f674
Wed Jul 8 04:30:09 PDT 2026
the project "GEOS".
The branch, main has been updated
       via  4f2442b078b7e26df23ced6193dc62f11090f674 (commit)
      from  678482bd85082ab0c671a100373a1d9c46764ffe (commit)
revisions in full, below.
commit 4f2442b078b7e26df23ced6193dc62f11090f674
Author: Daniel Baston <dbaston at gmail.com>
Date:   Wed Jul 8 07:29:46 2026 -0400
    GEOSPreparedDistance: fallback to brute-force distance for curved inputs (#1467)
    * FacetSequenceTreeBuilder: guard against curved components
    * GEOSPreparedDistance: fallback to brute-force distance for curved inputs
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index 32254f9e3..21202a2b0 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -4587,6 +4587,10 @@ extern "C" {
                          const PreparedGeometry* pg, const Geometry* g)
         return execute(extHandle, [&]() -> geos::geom::CoordinateSequence* {
+            if (g->hasCurvedComponents()) {
+                geos::operation::distance::DistanceOp dop(pg->getGeometry(), *g);
+                return dop.nearestPoints().release();
             return pg->nearestPoints(g).release();
@@ -4597,7 +4601,11 @@ extern "C" {
                          const Geometry* g, double* dist)
         return execute(extHandle, 0, [&]() {
-            *dist = pg->distance(g);
+                *dist = pg->getGeometry().distance(g);
+            } else {
+                *dist = pg->distance(g);
             return 1;
@@ -4608,10 +4616,14 @@ extern "C" {
                          const Geometry* g, double dist)
         return execute(extHandle, 2, [&]() {
+                return pg->getGeometry().isWithinDistance(g, dist);
             return pg->isWithinDistance(g, dist);
 // STRtree
diff --git a/src/operation/distance/FacetSequenceTreeBuilder.cpp b/src/operation/distance/FacetSequenceTreeBuilder.cpp
index ec10c8c57..9727abe19 100644
--- a/src/operation/distance/FacetSequenceTreeBuilder.cpp
+++ b/src/operation/distance/FacetSequenceTreeBuilder.cpp
@@ -30,6 +30,8 @@ namespace distance {
 std::unique_ptr<TemplateSTRtree<const FacetSequence*>>
 FacetSequenceTreeBuilder::build(const Geometry* g)
+    util::ensureNoCurvedComponents(g);
     std::unique_ptr<TemplateSTRtree<const FacetSequence*>> tree(new FacetSequenceTree(computeFacetSequences(g)));
     tree->build();
diff --git a/tests/unit/capi/GEOSPreparedDistanceTest.cpp b/tests/unit/capi/GEOSPreparedDistanceTest.cpp
index 5ea53f1e0..758d18432 100644
--- a/tests/unit/capi/GEOSPreparedDistanceTest.cpp
+++ b/tests/unit/capi/GEOSPreparedDistanceTest.cpp
@@ -213,5 +213,18 @@ void object::test<14>
+template<>
+template<>
+void object::test<15>()
+    set_test_name("curved second geometry argument");
+    checkDistance(
+        "LINESTRING (0 0, 0 5)",
+        "CIRCULARSTRING (-5 0, 0 -5, 5 0)",
+        5
 } // namespace tut
diff --git a/tests/unit/capi/GEOSPreparedDistanceWithinTest.cpp b/tests/unit/capi/GEOSPreparedDistanceWithinTest.cpp
index 7be2a2d2b..f29c54fb1 100644
--- a/tests/unit/capi/GEOSPreparedDistanceWithinTest.cpp
+++ b/tests/unit/capi/GEOSPreparedDistanceWithinTest.cpp
@@ -280,5 +280,19 @@ void object::test<16>()
+template<>
+template<>
+void object::test<17>()
+    checkDistanceWithin(
+        5,
+        1
 } // namespace tut
diff --git a/tests/unit/capi/GEOSPreparedNearestPointsTest.cpp b/tests/unit/capi/GEOSPreparedNearestPointsTest.cpp
index effa0628b..800266ee1 100644
--- a/tests/unit/capi/GEOSPreparedNearestPointsTest.cpp
+++ b/tests/unit/capi/GEOSPreparedNearestPointsTest.cpp
@@ -153,5 +153,19 @@ void object::test<6>
+template<>
+template<>
+void object::test<7>()
+    checkNearestPoints(
+        "LINESTRING (3 0, 4 0)",
+        "CIRCULARSTRING (0 0, 1 1, 2 0)",
+        3, 0, 2, 0
 } // namespace tut
Summary of changes:
 capi/geos_ts_c.cpp                                  | 14 +++++++++++++-
 src/operation/distance/FacetSequenceTreeBuilder.cpp |  2 ++
 tests/unit/capi/GEOSPreparedDistanceTest.cpp        | 13 +++++++++++++
 tests/unit/capi/GEOSPreparedDistanceWithinTest.cpp  | 14 ++++++++++++++
 tests/unit/capi/GEOSPreparedNearestPointsTest.cpp   | 14 ++++++++++++++
 5 files changed, 56 insertions(+), 1 deletion(-)
hooks/post-receive
More information about the geos-commits mailing list
