[geos-commits] [SCM] GEOS branch main updated. b4a4ace48b2c3fe6ac4d9a0219d6b232158ca931
Wed Jul 8 04:30:41 PDT 2026
the project "GEOS".
The branch, main has been updated
       via  b4a4ace48b2c3fe6ac4d9a0219d6b232158ca931 (commit)
      from  4f2442b078b7e26df23ced6193dc62f11090f674 (commit)
revisions in full, below.
commit b4a4ace48b2c3fe6ac4d9a0219d6b232158ca931
Author: Daniel Baston <dbaston at gmail.com>
Date:   Wed Jul 8 07:30:23 2026 -0400
    Prepared geometries: linearize test geom if needed (#1469)
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index 21202a2b0..91ac5898e 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -4461,7 +4461,7 @@ extern "C" {
                            const PreparedGeometry* pg, const Geometry* g)
         return execute(extHandle, 2, [&]() {
-            return pg->contains(g);
+            return pg->contains(convertToLineIfNeeded(extHandle, g));
@@ -4479,7 +4479,7 @@ extern "C" {
-            return pg->containsProperly(g);
+            return pg->containsProperly(convertToLineIfNeeded(extHandle, g));
@@ -4488,7 +4488,7 @@ extern "C" {
-            return pg->coveredBy(g);
+            return pg->coveredBy(convertToLineIfNeeded(extHandle, g));
@@ -4497,7 +4497,7 @@ extern "C" {
-            return pg->covers(g);
+            return pg->covers(convertToLineIfNeeded(extHandle, g));
@@ -4506,7 +4506,7 @@ extern "C" {
-            return pg->crosses(g);
+            return pg->crosses(convertToLineIfNeeded(extHandle, g));
@@ -4515,7 +4515,7 @@ extern "C" {
-            return pg->disjoint(g);
+            return pg->disjoint(convertToLineIfNeeded(extHandle, g));
@@ -4524,7 +4524,7 @@ extern "C" {
-            return pg->intersects(g);
+            return pg->intersects(convertToLineIfNeeded(extHandle, g));
@@ -4542,7 +4542,7 @@ extern "C" {
-            return pg->overlaps(g);
+            return pg->overlaps(convertToLineIfNeeded(extHandle, g));
@@ -4551,7 +4551,7 @@ extern "C" {
-            return pg->touches(g);
+            return pg->touches(convertToLineIfNeeded(extHandle, g));
@@ -4560,7 +4560,7 @@ extern "C" {
-            return pg->within(g);
+            return pg->within(convertToLineIfNeeded(extHandle, g));
@@ -4569,7 +4569,7 @@ extern "C" {
         return execute(extHandle, [&]() -> char * {
-            return gstrdup(pg->relate(g)->toString());
+            return gstrdup(pg->relate(convertToLineIfNeeded(extHandle, g))->toString());
@@ -4578,7 +4578,7 @@ extern "C" {
                          const PreparedGeometry* pg, const Geometry* g, const char* imPattern)
-            return pg->relate(g, std::string(imPattern));
+            return pg->relate(convertToLineIfNeeded(extHandle, g), std::string(imPattern));
diff --git a/src/geom/prep/AbstractPreparedPolygonContains.cpp b/src/geom/prep/AbstractPreparedPolygonContains.cpp
index f0dbdeacc..c977c94e6 100644
--- a/src/geom/prep/AbstractPreparedPolygonContains.cpp
+++ b/src/geom/prep/AbstractPreparedPolygonContains.cpp
@@ -106,6 +106,8 @@ AbstractPreparedPolygonContains::findAndClassifyIntersections(const geom::Geomet
 bool
 AbstractPreparedPolygonContains::eval(const geom::Geometry* geom)
+    geos::util::ensureNoCurvedComponents(geom);
     // Do point-in-poly tests first, since they are cheaper and may result
     // in a quick negative result.
     auto outermostLoc = getOutermostTestComponentLocation(geom);
diff --git a/src/geom/prep/PreparedPolygonContainsProperly.cpp b/src/geom/prep/PreparedPolygonContainsProperly.cpp
index 403af5c33..de663576e 100644
--- a/src/geom/prep/PreparedPolygonContainsProperly.cpp
+++ b/src/geom/prep/PreparedPolygonContainsProperly.cpp
@@ -27,6 +27,7 @@
 #include <geos/noding/SegmentString.h>
 #include <geos/noding/SegmentStringUtil.h>
 #include <geos/noding/FastSegmentSetIntersectionFinder.h>
+#include <geos/util/Assert.h>
 namespace geos {
 namespace geom { // geos.geom
@@ -45,6 +46,8 @@ namespace prep { // geos.geom.prep
 bool
 PreparedPolygonContainsProperly::containsProperly(const geom::Geometry* geom)
     // If a point of any test components does not lie in target,
diff --git a/tests/unit/capi/GEOSPreparedGeometryTest.cpp b/tests/unit/capi/GEOSPreparedGeometryTest.cpp
index 28e24b187..5b74ceed4 100644
--- a/tests/unit/capi/GEOSPreparedGeometryTest.cpp
+++ b/tests/unit/capi/GEOSPreparedGeometryTest.cpp
@@ -482,5 +482,91 @@ void object::test<17>()
     GEOSFree(r2);
+template<>
+template<>
+void object::test<18>()
+    set_test_name("Polygon first argument, CurvePolygon second argument");
+    useContext();
+    geom1_ = fromWKT("POLYGON ((0 0, 2 0, 2 8, 8 8, 8 0, 10 0, 10 10, 0 10, 0 0))");
+    geom2_ = fromWKT("CURVEPOLYGON (COMPOUNDCURVE(CIRCULARSTRING (5 1, 6 2, 7 1), (7 1, 5 1)))");
+    geom3_ = fromWKT("CURVEPOLYGON (COMPOUNDCURVE((-100 100, -100 -100, 100 -100, 100 100), CIRCULARSTRING (100 100, 0 200, -100 100)))");
+    prepGeom1_ = GEOSPrepare_r(ctxt_, geom1_);
+    // No curve-to-line params; all functions return 2 (error)
+    ensure_equals("contains", GEOSPreparedContains_r(ctxt_, prepGeom1_, geom2_), 2);
+    ensure_equals("contains properly", GEOSPreparedContainsProperly_r(ctxt_, prepGeom1_, geom2_), 2);
+    ensure_equals("crosses", GEOSPreparedCrosses_r(ctxt_, prepGeom1_, geom2_), 2);
+    ensure_equals("covered by", GEOSPreparedCoveredBy_r(ctxt_, prepGeom1_, geom3_), 2);
+    ensure_equals("touches", GEOSPreparedTouches_r(ctxt_, prepGeom1_, geom2_), 2);
+    ensure_equals("overlaps", GEOSPreparedOverlaps_r(ctxt_, prepGeom1_, geom2_), 2);
+    ensure_equals("intersects", GEOSPreparedIntersects_r(ctxt_, prepGeom1_, geom2_), 2);
+    ensure_equals("disjoint", GEOSPreparedDisjoint_r(ctxt_, prepGeom1_, geom2_), 2);
+    ensure_equals("relate pattern", GEOSPreparedRelatePattern_r(ctxt_, prepGeom1_, geom2_, "T********"), 2);
+    ensure_equals("within", GEOSPreparedWithin_r(ctxt_, prepGeom1_, geom3_), 2);
+    ensure(GEOSPreparedRelate_r(ctxt_, prepGeom1_, geom2_) == nullptr);
+    GEOSContext_setCurveToLineParams_r(ctxt_, curveToLineParams_);
+    ensure_equals("contains", GEOSPreparedContains_r(ctxt_, prepGeom1_, geom2_), 0);
+    ensure_equals("contains properly", GEOSPreparedContainsProperly_r(ctxt_, prepGeom1_, geom2_), 0);
+    ensure_equals("crosses", GEOSPreparedCrosses_r(ctxt_, prepGeom1_, geom2_), 0);
+    ensure_equals("covered by", GEOSPreparedCoveredBy_r(ctxt_, prepGeom1_, geom3_), 1);
+    ensure_equals("touches", GEOSPreparedTouches_r(ctxt_, prepGeom1_, geom2_), 0);
+    ensure_equals("overlaps", GEOSPreparedOverlaps_r(ctxt_, prepGeom1_, geom2_), 0);
+    ensure_equals("intersects", GEOSPreparedIntersects_r(ctxt_, prepGeom1_, geom2_), 0);
+    ensure_equals("disjoint", GEOSPreparedDisjoint_r(ctxt_, prepGeom1_, geom2_), 1);
+    ensure_equals("relate pattern", GEOSPreparedRelatePattern_r(ctxt_, prepGeom1_, geom2_, "T********"), 0);
+    ensure_equals("within", GEOSPreparedWithin_r(ctxt_, prepGeom1_, geom3_), 1);
+    str_ = GEOSPreparedRelate_r(ctxt_, prepGeom1_, geom2_);
+    ensure(str_);
+template<>
+template<>
+void object::test<19>()
+    set_test_name("LineString first argument, CircularString second argument");
+    useContext();
+    geom1_ = fromWKT("LINESTRING (-10 -10, 10 10)");
+    geom2_ = fromWKT("CIRCULARSTRING (-5 0, 0 5, 5 0)");
+    geom3_ = fromWKT("CIRCULARSTRING (-100 -100, 0 100, 100 0)");
+    ensure_equals("crosses", GEOSPreparedCrosses_r(ctxt_, prepGeom1_, geom2_), 1);
+    ensure_equals("covered by", GEOSPreparedCoveredBy_r(ctxt_, prepGeom1_, geom3_), 0);
+    ensure_equals("intersects", GEOSPreparedIntersects_r(ctxt_, prepGeom1_, geom2_), 1);
+    ensure_equals("disjoint", GEOSPreparedDisjoint_r(ctxt_, prepGeom1_, geom2_), 0);
+    ensure_equals("relate pattern", GEOSPreparedRelatePattern_r(ctxt_, prepGeom1_, geom2_, "T********"), 1);
+    ensure_equals("within", GEOSPreparedWithin_r(ctxt_, prepGeom1_, geom3_), 0);
+    ensure(str_);
 } // namespace tut
Summary of changes:
 capi/geos_ts_c.cpp                                | 24 +++----
 src/geom/prep/AbstractPreparedPolygonContains.cpp |  2 +
 src/geom/prep/PreparedPolygonContainsProperly.cpp |  3 +
 tests/unit/capi/GEOSPreparedGeometryTest.cpp      | 86 +++++++++++++++++++++++
 4 files changed, 103 insertions(+), 12 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
