[geos-commits] [SCM] GEOS branch main updated. 96292c0df9587f6a6cb9d0b00e52772db2672348
git at osgeo.org
git at osgeo.org
Wed Jul 8 17:05:59 PDT 2026
the project "GEOS".
The branch, main has been updated
via 96292c0df9587f6a6cb9d0b00e52772db2672348 (commit)
from b4a4ace48b2c3fe6ac4d9a0219d6b232158ca931 (commit)
revisions in full, below.
commit 96292c0df9587f6a6cb9d0b00e52772db2672348
Author: Daniel Baston <dbaston at gmail.com>
Date: Wed Jul 8 20:05:36 2026 -0400
C API: Do not linearize inputs to overlay functions (#1471)
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index 91ac5898e..f95c294df 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -1636,8 +1636,10 @@ extern "C" {
Geometry*
GEOSIntersection_r(GEOSContextHandle_t extHandle, const Geometry* g1, const Geometry* g2)
- return convertCurvesAndExecute(extHandle, g1, g2, [](const Geometry* geom1, const Geometry* geom2) {
- return geom1->intersection(geom2);
+ return execute(extHandle, [&]() {
+ auto g3 = g1->intersection(g2);
+ g3->setSRID(g1->getSRID());
+ return g3.release();
@@ -2028,8 +2030,10 @@ extern "C" {
Geometry*
GEOSUnion_r(GEOSContextHandle_t extHandle, const Geometry* g1, const Geometry* g2)
- return convertCurvesAndExecute(extHandle, g1, g2, [&](const Geometry* input1, const Geometry* input2) {
- return input1->Union(input2);
+ auto g3 = g1->Union(g2);
diff --git a/tests/unit/capi/GEOSDifferenceTest.cpp b/tests/unit/capi/GEOSDifferenceTest.cpp
index c5f70196b..259376fc0 100644
--- a/tests/unit/capi/GEOSDifferenceTest.cpp
+++ b/tests/unit/capi/GEOSDifferenceTest.cpp
@@ -104,5 +104,23 @@ void object::test<4>()
ensure_equals(fracs[0], 1.0);
+template<>
+template<>
+void object::test<5>()
+ set_test_name("curved input is not linearized when CurveToLineParams registered with a context");
+ useContext();
+ geom1_ = fromWKT("CIRCULARSTRING (0 0, 1 1, 2 0)");
+ geom2_ = fromWKT("POINT (2 0)");
+ GEOSCurveToLineParams_setMaxStepDegrees_r(ctxt_, curveToLineParams_, 45);
+ GEOSContext_setCurveToLineParams_r(ctxt_, curveToLineParams_);
+ result_ = GEOSDifference_r(ctxt_, geom1_, geom2_);
+ ensure_geometry_equals(result_, geom1_, 1e-8);
} // namespace tut
diff --git a/tests/unit/capi/GEOSIntersectionTest.cpp b/tests/unit/capi/GEOSIntersectionTest.cpp
index a4aabb439..8f4d67467 100644
--- a/tests/unit/capi/GEOSIntersectionTest.cpp
+++ b/tests/unit/capi/GEOSIntersectionTest.cpp
@@ -177,5 +177,23 @@ void object::test<9>()
ensure("HasM", GEOSHasM(result_));
+template<>
+template<>
+void object::test<10>()
+ useContext();
+ geom2_ = fromWKT("POLYGON ((0 0, 2 0, 2 2, 0 2, 0 0))");
+ result_ = GEOSIntersection_r(ctxt_, geom1_, geom2_);
} // namespace tut
diff --git a/tests/unit/capi/GEOSSymDifferenceTest.cpp b/tests/unit/capi/GEOSSymDifferenceTest.cpp
index 63436e135..61d27eb9b 100644
--- a/tests/unit/capi/GEOSSymDifferenceTest.cpp
+++ b/tests/unit/capi/GEOSSymDifferenceTest.cpp
@@ -45,5 +45,23 @@ void object::test<2>()
ensure_geometry_equals(result_, expected_, 1e-8);
+template<>
+template<>
+void object::test<3>()
+ useContext();
+ result_ = GEOSSymDifference_r(ctxt_, geom1_, geom2_);
} // namespace tut
diff --git a/tests/unit/capi/GEOSUnionTest.cpp b/tests/unit/capi/GEOSUnionTest.cpp
index 835aaaf0f..2c0567dab 100644
--- a/tests/unit/capi/GEOSUnionTest.cpp
+++ b/tests/unit/capi/GEOSUnionTest.cpp
@@ -79,5 +79,24 @@ void object::test<3>()
+template<>
+template<>
+ useContext();
+ result_ = GEOSUnion_r(ctxt_, geom1_, geom2_);
} // namespace tut
Summary of changes:
capi/geos_ts_c.cpp | 12 ++++++++----
tests/unit/capi/GEOSDifferenceTest.cpp | 18 ++++++++++++++++++
tests/unit/capi/GEOSIntersectionTest.cpp | 18 ++++++++++++++++++
tests/unit/capi/GEOSSymDifferenceTest.cpp | 18 ++++++++++++++++++
tests/unit/capi/GEOSUnionTest.cpp | 19 +++++++++++++++++++
5 files changed, 81 insertions(+), 4 deletions(-)
hooks/post-receive
More information about the geos-commits
