[geos-commits] [SCM] GEOS branch main updated. b50bb516081b9c3193fbc8001c08493d275f8fa2
git at osgeo.org
git at osgeo.org
Thu Jul 9 11:12:51 PDT 2026
the project "GEOS".
The branch, main has been updated
via b50bb516081b9c3193fbc8001c08493d275f8fa2 (commit)
from 7dfd43b6b5ab718abfc4ebee79834b27eb4bd9b1 (commit)
revisions in full, below.
commit b50bb516081b9c3193fbc8001c08493d275f8fa2
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Thu Jul 9 11:12:05 2026 -0700
Add in Curve geometry info to WKB section
Closes #1472
diff --git a/web/content/specifications/wkb.md b/web/content/specifications/wkb.md
index 048f96794..57c5ee024 100644
--- a/web/content/specifications/wkb.md
+++ b/web/content/specifications/wkb.md
@@ -85,18 +85,23 @@ with each ordinate value set to an IEEE-754 quiet NaN value
GEOS only supports the seven original simple features geometry types.
-enum wkbGeometryType {
+enum wkbType {
wkbPoint = 1,
wkbLineString = 2,
wkbPolygon = 3,
wkbMultiPoint = 4,
wkbMultiLineString = 5,
wkbMultiPolygon = 6,
- wkbGeometryCollection = 7
+ wkbGeometryCollection = 7,
+ wkbCircularString = 8,
+ wkbCompoundCurve = 9,
+ wkbCurvePolygon = 10,
+ wkbMultiCurve = 11,
+ wkbMultiSurface = 12
-Other systems (eg PostGIS) support a wider range of types (for example, CircularString, CurvePolygon), and hence more geometry type numbers, but GEOS is currently unable to consume those geometries.
+Other systems (eg PostGIS) support a wider range of types (for example, PolyhedralSurface, TIN), and hence even more geometry type numbers, but GEOS is cannot consume those geometries.
WKBPoint {
@@ -133,7 +138,7 @@ WKBMultiLineString {
WKBLineString WKBLineStrings[numWkbLineStrings];
-wkbMultiPolygon {
+WKBMultiPolygon {
byte byteOrder;
uint32 wkbType; // 6
uint32 numWkbPolygons;
@@ -158,8 +163,59 @@ WKBGeometryCollection {
uint32 numWkbGeometries;
WKBGeometry wkbGeometries[numWkbGeometries];
+WKBCurve {
+ union {
+ WKBLineString linestring;
+ WKBCircularString circstring;
+ WKBCompoundCurve compound;
+WKBCircularString {
+ byte byteOrder;
+ uint32 wkbType; // 8
+ uint32 numPoints;
+ Point points[numPoints];
+WKBCompoundCurve {
+ byte byteOrder;
+ uint32 wkbType; // 9
+ uint32 numCurves;
+ WKBCurve curves[numCurves]; // start/end points must match
+WKBCurvePolygon {
+ byte byteOrder;
+ uint32 wkbType; // 10
+ uint32 numRings;
+ WKBCurve rings[numRings]; // rings must be closed
+WKBSurface {
+ union {
+ WKBPolygon polygon;
+ WKBCurvePolygon curvepoly;
+WKBMultiCurve {
+ byte byteOrder;
+ uint32 wkbType; // 11
+ uint32 numCurves;
+WKBMultiSurface {
+ byte byteOrder;
+ uint32 wkbType; // 12
+ uint32 numSurfaces;
+ WKBSurface surfaces[numSurfaces];
### Example
The following bytes (in hex) make up the WKB for a `LINESTRING(0 0, 1 1, 2 1)`:
Summary of changes:
web/content/specifications/wkb.md | 64 ++++++++++++++++++++++++++++++++++++---
1 file changed, 60 insertions(+), 4 deletions(-)
hooks/post-receive
More information about the geos-commits
