[geos-commits] [SCM] GEOS branch main updated. 4fb859518f4642a0ac8b0f967d1dd54d2a2a7f02
Thu Jul 9 11:18:48 PDT 2026
the project "GEOS".
The branch, main has been updated
       via  4fb859518f4642a0ac8b0f967d1dd54d2a2a7f02 (commit)
      from  b50bb516081b9c3193fbc8001c08493d275f8fa2 (commit)
revisions in full, below.
commit 4fb859518f4642a0ac8b0f967d1dd54d2a2a7f02
Author: Daniel Baston <dbaston at gmail.com>
Date:   Thu Jul 9 14:18:30 2026 -0400
    UnaryUnionOp: support curved geometries (#1468)
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index f95c294df..ee6391ca2 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -2077,9 +2077,10 @@ extern "C" {
     Geometry*
     GEOSUnaryUnion_r(GEOSContextHandle_t extHandle, const Geometry* g)
-        return convertCurvesAndExecute<Interruptible, ReportsProgress>(extHandle, g, [&](const Geometry* input1) {
-            return geos::operation::geounion::UnaryUnionOp::Union(*input1, &extHandle->progressFunction);
-            return input1->Union();
+        return execute<Interruptible, ReportsProgress>(extHandle, [&]() {
+            auto g3 = geos::operation::geounion::UnaryUnionOp::Union(*g, &extHandle->progressFunction);
+            g3->setSRID(g->getSRID());
+            return g3.release();
diff --git a/include/geos/operation/union/CascadedPolygonUnion.h b/include/geos/operation/union/CascadedPolygonUnion.h
index fcc5ba9a7..710a56ac4 100644
--- a/include/geos/operation/union/CascadedPolygonUnion.h
+++ b/include/geos/operation/union/CascadedPolygonUnion.h
@@ -32,7 +32,7 @@ namespace geos {
 namespace geom {
 class GeometryFactory;
 class Geometry;
-class Polygon;
+class Surface;
 class MultiPolygon;
 class Envelope;
@@ -103,7 +103,7 @@ private:
 class GEOS_DLL CascadedPolygonUnion {
 private:
-    std::vector<geom::Polygon*>* inputPolys;
+    const std::vector<const geom::Surface*>& inputPolys;
     geom::GeometryFactory const* geomFactory;
@@ -116,23 +116,23 @@ private:
     static int const STRTREE_NODE_CAPACITY = 4;
     /** \brief
-     * Computes a [Geometry](@ref geom::Geometry) containing only polygonal components.
+     * Computes a [Geometry](@ref geom::Geometry) containing only
+     * surface components (dimension == 2).
-     * Extracts the [Polygons](@ref geom::Polygon) from the input
+     * Extracts the [Surfaces](@ref geom::Surface) from the input
      * and returns them as an appropriate polygonal geometry.
-     * If the input is already `Polygonal`, it is returned unchanged.
+     * If the input is already a surface, it is returned unchanged.
-     * A particular use case is to filter out non-polygonal components
+     * A particular use case is to filter out non-surface components
      * returned from an overlay operation.
      * @param g the geometry to filter
-     * @return a Polygonal geometry
+     * @return a Surface geometry
-    static std::unique_ptr<geom::Geometry> restrictToPolygons(std::unique_ptr<geom::Geometry> g);
+    static std::unique_ptr<geom::Geometry> restrictToSurfaces(std::unique_ptr<geom::Geometry> g);
 public:
-    CascadedPolygonUnion();
     /** \brief
      * Computes the union of a collection of polygonal [Geometrys](@ref geom::Geometry).
@@ -140,13 +140,13 @@ public:
      * @param polys a collection of polygonal [Geometrys](@ref geom::Geometry).
      *              ownership of elements *and* vector are left to caller.
-    static std::unique_ptr<geom::Geometry> Union(std::vector<geom::Polygon*>* polys);
-    static std::unique_ptr<geom::Geometry> Union(std::vector<geom::Polygon*>* polys, UnionStrategy* unionFun, geos::util::ProgressFunction* progressFunction);
+    static std::unique_ptr<geom::Geometry> Union(const std::vector<const geom::Surface*>& polys);
+    static std::unique_ptr<geom::Geometry> Union(const std::vector<const geom::Surface*>& polys, UnionStrategy* unionFun, geos::util::ProgressFunction* progressFunction);
     /** \brief
-     * Computes the union of a set of polygonal [Geometrys](@ref geom::Geometry).
+     * Computes the union of a set of surface [Geometrys](@ref geom::Geometry).
-     * @tparam T an iterator yielding something castable to const Polygon *
+     * @tparam T an iterator yielding something castable to const Surface*
      * @param start start iterator
      * @param end end iterator
      * @param unionStrategy strategy to apply
@@ -156,12 +156,12 @@ public:
     Union(T start, T end, UnionStrategy *unionStrategy, geos::util::ProgressFunction* progressFunction)
-        std::vector<geom::Polygon*> polys;
+        std::vector<const geom::Surface*> polys;
         for(T i = start; i != end; ++i) {
-            const geom::Polygon* p = dynamic_cast<const geom::Polygon*>(*i);
-            polys.push_back(const_cast<geom::Polygon*>(p));
+            const auto* p = dynamic_cast<const geom::Surface*>(*i);
+            polys.push_back(p);
-        return Union(&polys, unionStrategy, progressFunction);
+        return Union(polys, unionStrategy, progressFunction);
     /** \brief
@@ -177,16 +177,16 @@ public:
      * Creates a new instance to union the given collection of
      * [Geometrys](@ref geom::Geometry).
-     * @param polys a collection of polygonal [Geometrys](@ref geom::Geometry).
+     * @param polys a collection of surface [Geometrys](@ref geom::Geometry).
      *              Ownership of elements *and* vector are left to caller.
-    CascadedPolygonUnion(std::vector<geom::Polygon*>* polys)
+    explicit CascadedPolygonUnion(const std::vector<const geom::Surface*>& polys)
         : inputPolys(polys)
         , geomFactory(nullptr)
         , unionFunction(&defaultUnionFunction)
-    CascadedPolygonUnion(std::vector<geom::Polygon*>* polys, UnionStrategy* unionFun)
+    CascadedPolygonUnion(const std::vector<const geom::Surface*>& polys, UnionStrategy* unionFun)
         : inputPolys(polys)
         , unionFunction(unionFun)
@@ -232,7 +232,7 @@ private:
     std::unique_ptr<geom::Geometry> unionSafe(const geom::Geometry* g0, const geom::Geometry* g1) const;
-    std::unique_ptr<geom::Geometry> unionSafe(std::unique_ptr<geom::Geometry> &&, std::unique_ptr<geom::Geometry> &&);
+    std::unique_ptr<geom::Geometry> unionSafe(std::unique_ptr<geom::Geometry> &&, std::unique_ptr<geom::Geometry> &&) const;
      * Encapsulates the actual unioning of two polygonal geometries.
diff --git a/include/geos/operation/union/UnaryUnionOp.h b/include/geos/operation/union/UnaryUnionOp.h
index 98b6a9e70..39e127d89 100644
--- a/include/geos/operation/union/UnaryUnionOp.h
+++ b/include/geos/operation/union/UnaryUnionOp.h
@@ -171,21 +171,7 @@ private:
-    void
-    extract(const geom::Geometry& geom)
-        util::ensureNoCurvedComponents(geom);
-        using namespace geom::util;
-        if(! geomFact) {
-            geomFact = geom.getFactory();
-        GeometryExtracter::extract<geom::Polygon>(geom, polygons);
-        GeometryExtracter::extract<geom::LineString>(geom, lines);
-        GeometryExtracter::extract<geom::Point>(geom, points);
+    void extract(const geom::Geometry& geom);
      * Computes a unary union with no extra optimization,
@@ -217,14 +203,14 @@ private:
      * @return the union of the input(s)
      * @return null if both inputs are null
-    std::unique_ptr<geom::Geometry> unionWithNull(
+    static std::unique_ptr<geom::Geometry> unionWithNull(
         std::unique_ptr<geom::Geometry> g0,
         std::unique_ptr<geom::Geometry> g1
     // Members
-    std::vector<const geom::Polygon*> polygons;
-    std::vector<const geom::LineString*> lines;
+    std::vector<const geom::Surface*> polygons;
+    std::vector<const geom::Curve*> lines;
     std::vector<const geom::Point*> points;
     const geom::GeometryFactory* geomFact;
diff --git a/src/operation/union/CascadedPolygonUnion.cpp b/src/operation/union/CascadedPolygonUnion.cpp
index aac120c80..4973124a3 100644
--- a/src/operation/union/CascadedPolygonUnion.cpp
+++ b/src/operation/union/CascadedPolygonUnion.cpp
@@ -21,13 +21,13 @@
 #include <geos/geom/Geometry.h>
 #include <geos/geom/GeometryFactory.h>
 #include <geos/geom/MultiPolygon.h>
+#include <geos/geom/MultiSurface.h>
 #include <geos/geom/Polygon.h>
 #include <geos/index/strtree/TemplateSTRtree.h>
 #include <geos/operation/overlayng/OverlayNG.h>
 #include <geos/operation/overlayng/OverlayNGRobust.h>
 #include <geos/operation/union/CascadedPolygonUnion.h>
 #include <geos/operation/valid/IsValidOp.h>
-#include <geos/operation/valid/IsSimpleOp.h>
 #include <geos/util/TopologyException.h>
 // std
@@ -44,7 +44,7 @@ namespace geounion {  // geos.operation.geounion
-CascadedPolygonUnion::Union(std::vector<geom::Polygon*>* polys)
+CascadedPolygonUnion::Union(const std::vector<const geom::Surface*>& polys)
     CascadedPolygonUnion op(polys);
     geos::util::ProgressFunction* progressFunction = nullptr;
@@ -52,7 +52,7 @@ CascadedPolygonUnion::Union(std::vector<geom::Polygon*>* polys)
-CascadedPolygonUnion::Union(std::vector<geom::Polygon*>* polys, UnionStrategy* unionFun, geos::util::ProgressFunction* progressFunction)
+CascadedPolygonUnion::Union(const std::vector<const geom::Surface*>& polys, UnionStrategy* unionFun, geos::util::ProgressFunction* progressFunction)
     CascadedPolygonUnion op(polys, unionFun);
     return op.Union(progressFunction);
@@ -61,24 +61,24 @@ CascadedPolygonUnion::Union(std::vector<geom::Polygon*>* polys, UnionStrategy* u
 CascadedPolygonUnion::Union(const geom::MultiPolygon* multipoly, geos::util::ProgressFunction* progressFunction)
     for(const auto& g : *multipoly) {
         polys.push_back(dynamic_cast<geom::Polygon*>(g.get()));
-    CascadedPolygonUnion op(&polys);
+    CascadedPolygonUnion op(polys);
 CascadedPolygonUnion::Union(geos::util::ProgressFunction* progressFunction)
-    if(inputPolys->empty()) {
+    if(inputPolys.empty()) {
         return nullptr;
-    geomFactory = inputPolys->front()->getFactory();
+    geomFactory = inputPolys.front()->getFactory();
      * A spatial index to organize the collection
@@ -87,8 +87,8 @@ CascadedPolygonUnion::Union(geos::util::ProgressFunction* progressFunction)
      * to be eliminated on each round.
-    index::strtree::TemplateSTRtree<const geom::Geometry*> index(10, inputPolys->size());
-    for (const auto& p : *inputPolys) {
+    index::strtree::TemplateSTRtree<const geom::Geometry*> index(10, inputPolys.size());
+    for (const auto& p : inputPolys) {
         index.insert(p);
@@ -153,7 +153,7 @@ CascadedPolygonUnion::unionSafe(const geom::Geometry* g0, const geom::Geometry*
-CascadedPolygonUnion::unionSafe(std::unique_ptr<geom::Geometry> && g0, std::unique_ptr<geom::Geometry> && g1)
+CascadedPolygonUnion::unionSafe(std::unique_ptr<geom::Geometry> && g0, std::unique_ptr<geom::Geometry> && g1) const
     if(g0 == nullptr && g1 == nullptr) {
         return nullptr;
@@ -174,7 +174,7 @@ CascadedPolygonUnion::unionActual(const geom::Geometry* g0, const geom::Geometry
     std::unique_ptr<geom::Geometry> ug;
     ug = unionFunction->Union(g0, g1);
-    return restrictToPolygons(std::move(ug));
+    return restrictToSurfaces(std::move(ug));
@@ -182,11 +182,11 @@ CascadedPolygonUnion::unionActual(std::unique_ptr<geom::Geometry> && g0, std::un
     ug = unionFunction->Union(std::move(g0), std::move(g1));
-CascadedPolygonUnion::restrictToPolygons(std::unique_ptr<geom::Geometry> g)
+CascadedPolygonUnion::restrictToSurfaces(std::unique_ptr<geom::Geometry> g)
     using namespace geom;
@@ -199,12 +199,19 @@ CascadedPolygonUnion::restrictToPolygons(std::unique_ptr<geom::Geometry> g)
     auto coll = dynamic_cast<GeometryCollection*>(g.get());
     if (coll) {
-        // Release polygons from the collection and re-form into MultiPolygon
+        // Release polygons from the collection and re-form into Surface
         auto components = coll->releaseGeometries();
         components.erase(std::remove_if(components.begin(), components.end(), [](const std::unique_ptr<Geometry> & cmp) {
             return !cmp->isPolygonal();
         }), components.end());
+        const bool hasCurves = std::any_of(components.begin(), components.end(), [](const auto & cmp) {
+            return cmp->hasCurvedComponents();
+        if (hasCurves) {
+            return gfact->createMultiSurface(std::move(components));
         return gfact->createMultiPolygon(std::move(components));
     } else {
         // Not polygonal and not a collection? No polygons here.
diff --git a/src/operation/union/UnaryUnionOp.cpp b/src/operation/union/UnaryUnionOp.cpp
index 7b6601c14..94f1bafff 100644
--- a/src/operation/union/UnaryUnionOp.cpp
+++ b/src/operation/union/UnaryUnionOp.cpp
@@ -34,8 +34,9 @@
 #include <geos/geom/util/GeometryCombiner.h>
 #include <geos/algorithm/PointLocator.h>
+#include <geos/util.h>
-#include "geos/util.h"
+using geos::geom::util::GeometryExtracter;
 namespace geos {
 namespace operation { // geos::operation
@@ -62,6 +63,18 @@ UnaryUnionOp::unionWithNull(std::unique_ptr<geom::Geometry> g0,
     return ret;
+void
+UnaryUnionOp::extract(const geom::Geometry& geom)
+    if(! geomFact) {
+        geomFact = geom.getFactory();
+    GeometryExtracter::extract<geom::Surface>(geom, polygons);
+    GeometryExtracter::extract<geom::Curve>(geom, lines);
+    GeometryExtracter::extract<geom::Point>(geom, points);
 /*public*/
 UnaryUnionOp::Union(geos::util::ProgressFunction* progressFunction)
diff --git a/tests/unit/capi/GEOSUnaryUnionTest.cpp b/tests/unit/capi/GEOSUnaryUnionTest.cpp
index 24f99fcb9..af484b8ef 100644
--- a/tests/unit/capi/GEOSUnaryUnionTest.cpp
+++ b/tests/unit/capi/GEOSUnaryUnionTest.cpp
@@ -220,37 +220,15 @@ template<>
 template<>
 void object::test<12>()
-    set_test_name("curved inputs");
-    useContext();
+    set_test_name("curved dim=1 inputs -> CompoundCurve");
-    input_ = fromWKT("MULTICURVE (CIRCULARSTRING (-5 0, 0 5, 5 0), (-5 3, 5 3))");
-    ensure(input_);
-    GEOSSetSRID_r(ctxt_, input_, 4326);
-    double input_length = -1;
-    ensure(GEOSLength_r(ctxt_, input_, &input_length));
+    input_ = fromWKT("MULTICURVE (CIRCULARSTRING (-5 0, 0 5, 5 0), (5 0, 5 3))");
-    result_ = GEOSUnaryUnion_r(ctxt_, input_);
-    ensure(result_ == nullptr);
-    GEOSCurveToLineParams_setMaxStepDegrees_r(ctxt_, curveToLineParams_, 1);
-    GEOSContext_setCurveToLineParams_r(ctxt_, curveToLineParams_);
-    // Input converted to line, output not converted to curve
+    result_ = GEOSUnaryUnion(input_);
     ensure(result_);
-    ensure_equals(GEOSGeomTypeId_r(ctxt_, result_), GEOS_MULTILINESTRING);
-    ensure_equals(GEOSGetSRID_r(ctxt_, result_), 4326);
-    GEOSGeom_destroy_r(ctxt_, result_);
-    // Input converted to line, output converted to curve
-    GEOSContext_setLineToCurveParams_r(ctxt_, lineToCurveParams_);
-    ensure_equals(GEOSGeomTypeId_r(ctxt_, result_), GEOS_MULTICURVE);
-    double result_length = -1;
-    ensure(GEOSLength_r(ctxt_, result_, &result_length));
-    ensure_equals("length does not match", result_length, input_length, 1e-5);
+    expected_ = fromWKT("COMPOUNDCURVE (CIRCULARSTRING (-5 0, 0 5, 5 0), (5 0, 5 3))");
+    ensure_geometry_equals(result_, expected_);
 template<>
@@ -308,6 +286,53 @@ void object::test<14>() {
     ensure_equals(fracs[0], 1.0);
+template<>
+template<>
+void object::test<15>()
+    set_test_name("curved polygonal inputs");
+    input_ = fromWKT("MULTISURFACE (CURVEPOLYGON (COMPOUNDCURVE ((5 0, 0 0, 0 5, 5 5), CIRCULARSTRING (5 5, 2.5 2.5, 5 0))), CURVEPOLYGON (COMPOUNDCURVE (CIRCULARSTRING (5 0, 1.5 2.5, 5 5), (5 5, 10 5, 10 0, 5 0))))");
+    ensure(result_);
+    expected_ = fromWKT("CURVEPOLYGON (COMPOUNDCURVE ((0 0, 0 5, 3.2857142857 5), CIRCULARSTRING (3.2857142857 5, 4.1428571429 5.1428571429, 5 5), (5 5, 10 5, 10 0, 5 0), CIRCULARSTRING (5 0, 4.1428571429 -0.1428571429, 3.2857142857 0), (3.2857142857 0, 0 0)))");
+    ensure_geometry_equals(result_, expected_, 1e-6);
+template<>
+template<>
+void object::test<16>()
+    set_test_name("curved dim=1 inputs -> MultiCurve");
+    input_ = fromWKT("MULTICURVE (CIRCULARSTRING (-5 0, 0 5, 5 0), (0 0, 5 5))");
+    ensure(result_);
+    expected_ = fromWKT("MULTICURVE (CIRCULARSTRING (3.5355339059 3.5355339059, 4.6193976626 1.9134171618, 5 0), CIRCULARSTRING (-5 0, -1.9134171618 4.6193976626, 3.5355339059 3.5355339059), (3.5355339059 3.5355339059, 5 5), (0 0, 3.5355339059 3.5355339059))");
+template<>
+template<>
+void object::test<17>()
+    set_test_name("curved input is not linearized when CurveToLineParams registered with a context");
+    useContext();
+    input_ = fromWKT("CIRCULARSTRING (0 0, 1 1, 2 0)");
+    GEOSCurveToLineParams_setMaxStepDegrees_r(ctxt_, curveToLineParams_, 45);
+    GEOSContext_setCurveToLineParams_r(ctxt_, curveToLineParams_);
+    result_ = GEOSUnaryUnion_r(ctxt_, input_);
+    ensure_geometry_equals(result_, input_, 1e-8);
 } // namespace tut
diff --git a/tests/unit/geom/CircularStringTest.cpp b/tests/unit/geom/CircularStringTest.cpp
index 59f0de931..3be6a7b7e 100644
--- a/tests/unit/geom/CircularStringTest.cpp
+++ b/tests/unit/geom/CircularStringTest.cpp
@@ -169,7 +169,7 @@ void object::test<3>()
     ensure("equalsIdentical", cs_->equalsIdentical(cs2.get()));
     // Overlay
-    ensure_THROW(cs_->Union(), geos::util::UnsupportedOperationException);
+    ensure_equals_geometry(cs_->Union().get(), static_cast<const Geometry*>(cs_.get()));
     ensure_equals(cs_->Union(cs_.get())->getLength(), cs_->getLength());
     ensure(cs_->difference(cs_.get())->isEmpty());
     ensure_equals(cs_->intersection(cs_.get())->getLength(), cs_->getLength());
diff --git a/tests/unit/geom/CompoundCurveTest.cpp b/tests/unit/geom/CompoundCurveTest.cpp
index 79956e095..d6f5cbfde 100644
--- a/tests/unit/geom/CompoundCurveTest.cpp
+++ b/tests/unit/geom/CompoundCurveTest.cpp
@@ -170,11 +170,10 @@ void object::test<3>()
     ensure("equalsIdentical", cc_->equalsIdentical(cc2.get()));
     // Overlay
-    ensure_THROW(cc_->Union(), geos::util::UnsupportedOperationException);
-    // TODO: Prevent overlay from degrading CompoundCurve into MultiCurve
-    //ensure_equals_geometry(cc_->Union(cc_.get()).get(), static_cast<const Geometry*>(cc_.get()));
+    ensure_equals_geometry(cc_->Union().get(), static_cast<const Geometry*>(cc_.get()));
+    ensure_equals_geometry(cc_->Union(cc_.get()).get(), static_cast<const Geometry*>(cc_.get()));
     ensure(cc_->difference(cc_.get())->isEmpty());
-    //ensure_equals_geometry(cc_->intersection(cc_.get()).get(), static_cast<const Geometry*>(cc_.get()));
+    ensure_equals_geometry(cc_->intersection(cc_.get()).get(), static_cast<const Geometry*>(cc_.get()));
     ensure(cc_->symDifference(cc_.get())->isEmpty());
     // Distance
diff --git a/tests/unit/geom/CurvePolygonTest.cpp b/tests/unit/geom/CurvePolygonTest.cpp
index 52eb905b2..562b27637 100644
--- a/tests/unit/geom/CurvePolygonTest.cpp
+++ b/tests/unit/geom/CurvePolygonTest.cpp
@@ -167,7 +167,7 @@ void object::test<3>()
     ensure("equalsIdentical", cp_->equalsIdentical(cp2.get()));
     // Overlay
-    ensure_THROW(cp_->Union(), geos::util::UnsupportedOperationException);
+    ensure_equals_geometry(cp_->Union().get(), static_cast<const Geometry*>(cp_.get()));
     ensure_equals(cp_->Union(cp_.get())->getLength(), cp_->getLength());
     ensure(cp_->difference(cp_.get())->isEmpty());
     ensure_equals(cp_->intersection(cp_.get())->getLength(), cp_->getLength());
diff --git a/tests/unit/geom/MultiCurveTest.cpp b/tests/unit/geom/MultiCurveTest.cpp
index e4f264c8c..3ec6cd3d2 100644
--- a/tests/unit/geom/MultiCurveTest.cpp
+++ b/tests/unit/geom/MultiCurveTest.cpp
@@ -154,11 +154,10 @@ void object::test<3>()
     ensure("equalsIdentical", mc_->equalsIdentical(cc2.get()));
     // Overlay
-    ensure_THROW(mc_->Union(), geos::util::UnsupportedOperationException);
-    //ensure_equals_geometry(mc_->Union(mc_.get()).get(), static_cast<const Geometry*>(mc_.get()));
+    ensure_equals_geometry(mc_->Union().get(), static_cast<const Geometry*>(mc_.get()));
+    ensure_equals_geometry(mc_->Union(mc_.get()).get(), static_cast<const Geometry*>(mc_.get()));
     ensure(mc_->difference(mc_.get())->isEmpty());
-    //ensure_equals_geometry(mc_->intersection(mc_.get()).get(), static_cast<const Geometry*>(mc_.get()));
+    ensure_equals_geometry(mc_->intersection(mc_.get()).get(), static_cast<const Geometry*>(mc_.get()));
     ensure(mc_->symDifference(mc_.get())->isEmpty());
     // Distance
diff --git a/tests/unit/geom/MultiSurfaceTest.cpp b/tests/unit/geom/MultiSurfaceTest.cpp
index 9f84cdc28..46679188e 100644
--- a/tests/unit/geom/MultiSurfaceTest.cpp
+++ b/tests/unit/geom/MultiSurfaceTest.cpp
@@ -143,7 +143,7 @@ void object::test<3>()
     ensure("equalsIdentical", ms_->equalsIdentical(cp2.get()));
     // Overlay
-    ensure_THROW(ms_->Union(), geos::util::UnsupportedOperationException);
+    ensure_equals_geometry(ms_->Union().get(), static_cast<const Geometry*>(ms_.get()));
     ensure_equals_geometry(ms_->Union(ms_.get()).get(), static_cast<const Geometry*>(ms_.get()));
     ensure(ms_->difference(ms_.get())->isEmpty());
     ensure_equals_geometry(ms_->intersection(ms_.get()).get(), static_cast<const Geometry*>(ms_.get()));
diff --git a/tests/unit/operation/geounion/CascadedPolygonUnionTest.cpp b/tests/unit/operation/geounion/CascadedPolygonUnionTest.cpp
index adf5b2628..b084e7f39 100644
--- a/tests/unit/operation/geounion/CascadedPolygonUnionTest.cpp
+++ b/tests/unit/operation/geounion/CascadedPolygonUnionTest.cpp
@@ -42,13 +42,12 @@ typedef group::object object;
 group test_cascadedpolygonuniontest_group("geos::operation::geounion::CascadedPolygonUnion");
 // test runner
-geos::geom::Geometry*
-unionIterated(
-    std::vector<geos::geom::Polygon*>* geoms)
+std::unique_ptr<geos::geom::Geometry>
+unionIterated(const std::vector<const geos::geom::Surface*>& geoms)
     std::unique_ptr<geos::geom::Geometry> unionAll;
-    for(const auto& p : *geoms) {
+    for(const auto& p : geoms) {
         if(unionAll == nullptr) {
             unionAll = p->clone();
@@ -56,20 +55,19 @@ unionIterated(
             unionAll = unionAll->Union(p);
-    return unionAll.release();
+    return unionAll;
 unionCascaded(
+    const std::vector<const geos::geom::Surface*>& geoms)
     using geos::operation::geounion::CascadedPolygonUnion;
     return CascadedPolygonUnion::Union(geoms);
 void
-p_test_runner(
+p_test_runner(const std::vector<const geos::geom::Surface*>& geoms)
     std::unique_ptr<geos::geom::Geometry> union1(unionIterated(geoms));
     std::unique_ptr<geos::geom::Geometry> union2(unionCascaded(geoms));
@@ -78,12 +76,6 @@ p_test_runner(
     ensure_equals_geometry(union1.get(), union2.get(), 0.000001);
-void
-delete_geometry(geos::geom::Geometry* g)
-    delete g;
 // Test Cases
@@ -100,7 +92,7 @@ void object::test<1>
         nullptr
-    std::vector<geos::geom::Polygon*> g;
+    std::vector<const geos::geom::Surface*> g;
     for(char const * const* p = polygons; *p != nullptr; ++p) {
         std::string wkt(*p);
         geos::geom::Polygon* geom =
@@ -108,9 +100,11 @@ void object::test<1>
         g.push_back(geom);
-    p_test_runner(&g);
+    p_test_runner(g);
-    for_each(g.begin(), g.end(), delete_geometry);
+    for (auto& p : g) {
+        delete p;
 void
Summary of changes:
 capi/geos_ts_c.cpp                                 |  7 +-
 .../geos/operation/union/CascadedPolygonUnion.h    | 42 ++++++------
 include/geos/operation/union/UnaryUnionOp.h        | 22 ++----
 src/operation/union/CascadedPolygonUnion.cpp       | 35 ++++++----
 src/operation/union/UnaryUnionOp.cpp               | 15 +++-
 tests/unit/capi/GEOSUnaryUnionTest.cpp             | 79 ++++++++++++++--------
 tests/unit/geom/CircularStringTest.cpp             |  2 +-
 tests/unit/geom/CompoundCurveTest.cpp              |  7 +-
 tests/unit/geom/CurvePolygonTest.cpp               |  2 +-
 tests/unit/geom/MultiCurveTest.cpp                 |  7 +-
 tests/unit/geom/MultiSurfaceTest.cpp               |  2 +-
 .../geounion/CascadedPolygonUnionTest.cpp          | 28 +++-----
 12 files changed, 136 insertions(+), 112 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
