[geos-commits] [SCM] GEOS branch main updated. 6354193e908802263057d0ef8dcd3689f6c99a4a
git at osgeo.org
git at osgeo.org
Thu Jul 9 15:52:24 PDT 2026
the project "GEOS".
The branch, main has been updated
via 6354193e908802263057d0ef8dcd3689f6c99a4a (commit)
from 4fb859518f4642a0ac8b0f967d1dd54d2a2a7f02 (commit)
revisions in full, below.
commit 6354193e908802263057d0ef8dcd3689f6c99a4a
Author: Daniel Baston <dbaston at gmail.com>
Date: Thu Jul 9 18:51:56 2026 -0400
PointGeometryUnion: Avoid dropping M values (#1474)
diff --git a/src/operation/union/PointGeometryUnion.cpp b/src/operation/union/PointGeometryUnion.cpp
index 4ff569957..e997b9aab 100644
--- a/src/operation/union/PointGeometryUnion.cpp
+++ b/src/operation/union/PointGeometryUnion.cpp
@@ -43,7 +43,7 @@ PointGeometryUnion::Union() const
PointLocator locater;
// use a set to eliminate duplicates, as required for union
- std::set<Coordinate> exteriorCoords;
+ std::set<CoordinateXYZM> exteriorCoords;
for(std::size_t i = 0, n = pointGeom.getNumGeometries(); i < n; ++i) {
const Point* point = dynamic_cast<const Point*>(pointGeom.getGeometryN(i));
@@ -53,10 +53,12 @@ PointGeometryUnion::Union() const
continue;
- const Coordinate* coord = static_cast<const Coordinate*>(point->getCoordinate());
+ const CoordinateXY* coord = point->getCoordinate();
Location loc = locater.locate(*coord, &otherGeom);
if(loc == Location::EXTERIOR) {
- exteriorCoords.insert(*coord);
+ CoordinateXYZM ptZM;
+ point->getCoordinatesRO()->getAt(0, ptZM);
+ exteriorCoords.insert(ptZM);
diff --git a/tests/unit/operation/geounion/UnaryUnionOpTest.cpp b/tests/unit/operation/geounion/UnaryUnionOpTest.cpp
index 9f2023e39..e849daa93 100644
--- a/tests/unit/operation/geounion/UnaryUnionOpTest.cpp
+++ b/tests/unit/operation/geounion/UnaryUnionOpTest.cpp
@@ -76,7 +76,7 @@ struct test_unaryuniontest_data {
using std::endl;
GeomPtr a2 = normalize(a);
GeomPtr b2 = normalize(b);
- bool eq = a2->equalsExact(b2.get());
+ bool eq = a2->equalsIdentical(b2.get());
if(! eq) {
cout << "EXPECTED: " << wktwriter.write(a2.get()) << endl;
cout << "OBTAINED: " << wktwriter.write(b2.get()) << endl;
@@ -206,5 +206,19 @@ void object::test<7>
doTest(geoms, "LINESTRING EMPTY");
+template<>
+template<>
+void object::test<8>() {
+ static char const* const geoms[] = {
+ "POLYGON ((0 0, 10 0, 10 10, 0 10, 0 0))",
+ "POINT M (12 13 14)",
+ "POINT Z (12 13 8)",
+ "POINT M (12 13 16)",
+ nullptr
+ doTest(geoms, "GEOMETRYCOLLECTION (POLYGON ((0 0, 10 0, 10 10, 0 10, 0 0)), POINT M (12 13 14))");
} // namespace tut
Summary of changes:
src/operation/union/PointGeometryUnion.cpp | 8 +++++---
tests/unit/operation/geounion/UnaryUnionOpTest.cpp | 16 +++++++++++++++-
2 files changed, 20 insertions(+), 4 deletions(-)
hooks/post-receive
More information about the geos-commits
