[geos-commits] [SCM] GEOS branch main updated. 9cccf277d788e6326ca2dbb6d2d928941f211b97
Thu Jul 9 17:51:08 PDT 2026
the project "GEOS".
The branch, main has been updated
       via  9cccf277d788e6326ca2dbb6d2d928941f211b97 (commit)
       via  bf1980bed13ebb05fac0cff5e1f75e91a33c967d (commit)
       via  d4fb3df21da6ec42792409f7e7269ef4a8abe6b2 (commit)
      from  6354193e908802263057d0ef8dcd3689f6c99a4a (commit)
revisions in full, below.
commit 9cccf277d788e6326ca2dbb6d2d928941f211b97
Author: Daniel Baston <dbaston at gmail.com>
Date:   Thu Jul 9 13:51:37 2026 -0400
    EdgeNodingBuilder: avoid clipping linear rings of a CurvePolygon
diff --git a/src/operation/overlayng/EdgeNodingBuilder.cpp b/src/operation/overlayng/EdgeNodingBuilder.cpp
index ded0c128b..b0818bce9 100644
--- a/src/operation/overlayng/EdgeNodingBuilder.cpp
+++ b/src/operation/overlayng/EdgeNodingBuilder.cpp
@@ -375,9 +375,12 @@ EdgeNodingBuilder::clip(const LineString* ring) const
      * If no clipper or ring is completely contained then no need to clip.
+     * We also cannot clip if any input contains curves, because curved
+     * rings are not currently clipped and clipping only some rings could
+     * disrupt the polygon topology.
      * But repeated points must be removed to ensure correct noding.
-    if (clipper == nullptr || clipEnv->covers(env)) {
+    if (clipper == nullptr || clipEnv->covers(env) || inputHasCurves) {
         return removeRepeatedPoints(ring);
diff --git a/tests/xmltester/tests/general/TestOverlayCurvesAA.xml b/tests/xmltester/tests/general/TestOverlayCurvesAA.xml
new file mode 100644
index 000000000..0629b027f
--- /dev/null
+++ b/tests/xmltester/tests/general/TestOverlayCurvesAA.xml
@@ -0,0 +1,16 @@
+<run>
+    <case>
+        <desc>AA - A with hole intersecting B</desc>
+        <a>
+            CURVEPOLYGON((20 20, 20 160, 160 160, 160 20, 20 20), COMPOUNDCURVE ( CIRCULARSTRING (140 40, 115 115, 40 140), (40 140, 40 40, 140 40)))
+        </a>
+        <b>
+            POLYGON((80 100, 220 100, 220 240, 80 240, 80 100))
+        </b>
+        <test>
+            <op name="intersection" arg1="A" arg2="B">
+                CURVEPOLYGON (COMPOUNDCURVE ((80 136.50148808205722, 80 160), (80 160, 160 160, 160 100, 127.04025757937788 100), CIRCULARSTRING (127.04025757937788 100, 106.68619012043186 122.3309157911624, 80 136.50148808205722)))
+            </op>
+        </test>
+    </case>
+</run>
commit bf1980bed13ebb05fac0cff5e1f75e91a33c967d
Date:   Thu Jul 9 10:30:16 2026 -0400
    XMLTester: support curved geometries
diff --git a/tests/xmltester/XMLTester.cpp b/tests/xmltester/XMLTester.cpp
index 01803404b..16b1690aa 100644
--- a/tests/xmltester/XMLTester.cpp
+++ b/tests/xmltester/XMLTester.cpp
@@ -510,28 +510,10 @@ XMLTester::parseGeometry(const std::string& in, const char* label)
     std::unique_ptr<geom::Geometry> ret;
-    switch(first_char) {
-    case '0':
-    case '1':
-    case '2':
-    case '3':
-    case '4':
-    case '5':
-    case '6':
-    case '7':
-    case '8':
-    case '9':
-    case 'A':
-    case 'B':
-    case 'C':
-    case 'D':
-    case 'E':
-    case 'F':
+    if (first_char == '0') {
         ret = wkbreader->readHEX(is);
-        break;
-    default:
+    } else {
         ret = wktreader->read(in);
-        break;
     if(testValidInput) {
@@ -690,16 +672,20 @@ bool
 Test::checkOverlaySuccess(Geometry const& gExpected, Geometry const& gActual)
     double tol = operation::overlay::snap::GeometrySnapper::computeSizeBasedSnapTolerance(gExpected);
-    //-- BUG: this allows all empties to test equal
-    if(gExpected.equals(&gActual)) {
-        return 1;
+    if (!gExpected.hasCurvedComponents()) {
+        //-- BUG: this allows all empties to test equal
+        if(gExpected.equals(&gActual)) {
+            return true;
     //TODO: is this needed by any tests?
     std::cerr << "Using an overlay tolerance of " << tol << std::endl;
     if(gExpected.equalsExact(&gActual, tol)) {
-        return 1;
+        return true;
-    return 0;
+    return false;
 /* static */
commit d4fb3df21da6ec42792409f7e7269ef4a8abe6b2
Date:   Thu Jul 9 10:29:01 2026 -0400
    OverlayNG: improve exception message on curved geometry failure
diff --git a/src/operation/overlayng/OverlayNGRobust.cpp b/src/operation/overlayng/OverlayNGRobust.cpp
index 3e8da6f9d..bca5e6e44 100644
--- a/src/operation/overlayng/OverlayNGRobust.cpp
+++ b/src/operation/overlayng/OverlayNGRobust.cpp
@@ -120,6 +120,10 @@ OverlayNGRobust::Overlay(const Geometry* geom0, const Geometry* geom1, int opCod
         return result;
     catch (const std::runtime_error &ex) {
+        if (geom0->hasCurvedComponents() || geom1->hasCurvedComponents()) {
+            // Snapping strategies do not support curved geometries.
+            throw;
         * Capture original exception,
         * so it can be rethrown if the remaining strategies all fail.
@@ -130,6 +134,7 @@ OverlayNGRobust::Overlay(const Geometry* geom0, const Geometry* geom1, int opCod
 #endif
      * On failure retry using snapping noding with a "safe" tolerance.
      * if this throws an exception just let it go,
Summary of changes:
 src/operation/overlayng/EdgeNodingBuilder.cpp      |  5 ++-
 src/operation/overlayng/OverlayNGRobust.cpp        |  5 +++
 tests/xmltester/XMLTester.cpp                      | 36 +++++++---------------
 .../tests/general/TestOverlayCurvesAA.xml          | 16 ++++++++++
 4 files changed, 36 insertions(+), 26 deletions(-)
 create mode 100644 tests/xmltester/tests/general/TestOverlayCurvesAA.xml
hooks/post-receive
More information about the geos-commits mailing list
