[geos-commits] [SCM] GEOS branch main updated. c6e5ea1bee84a255495413887e8db4b7ab7d323d
Fri Jul 10 07:27:26 PDT 2026
the project "GEOS".
The branch, main has been updated
       via  c6e5ea1bee84a255495413887e8db4b7ab7d323d (commit)
      from  9cccf277d788e6326ca2dbb6d2d928941f211b97 (commit)
revisions in full, below.
commit c6e5ea1bee84a255495413887e8db4b7ab7d323d
Author: Pieter Roggemans <pieter.roggemans at gmail.com>
Date:   Fri Jul 10 16:27:07 2026 +0200
    DOC: small improvements to docs of CoverageCleanWithParams (#1475)
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index 26b88aca6..8121146ba 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -4979,18 +4979,22 @@ GEOSCoverageCleanParams_destroy(
     GEOSCoverageCleanParams* params);
+* Set the snapping distance to use when cleaning a coverage.
 * Snapping to nearby vertices and line segment snapping
 * is used to improve noding robustness
-* and eliminate small errors in an efficient way,
+* and eliminate small errors in an efficient way.
 * By default this uses a very small snapping distance
 * based on the extent of the input data.
-* The snapping distance may be specified explicitly.
-* This can reduce the number of overlaps and gaps that need to be merged,
-* and reduce the risk of spikes formed by merging gaps.
-* However, a large snapping distance may introduce undesirable
+* Specifying a larger snapping distance can reduce the number of overlaps and
+* gaps that need to be merged, and reduce the risk of spikes formed by merging
+* gaps. However, a large snapping distance can also introduce undesirable
 * data alteration.
 * A distance of zero prevents snapping from being used.
 * \see geos::coverage::CoverageCleaner::setSnappingDistance
 * \param params The GEOSCoverageCleanParams to operate on
 * \param snappingDistance Set to 0.0 for no snapping.
@@ -5004,19 +5008,22 @@ GEOSCoverageCleanParams_setSnappingDistance(
     double snappingDistance);
-* Gaps which are wider than a given distance are merged with an adjacent polygon.
-* Polygon width is determined as twice the radius of the MaximumInscribedCircle
-* of the gap polygon.
-* Gaps are merged with the adjacent polygon with longest shared border.
+* Set the maximum width of gaps to merge when cleaning a coverage.
+* Gaps wider than the given distance are merged with the adjacent polygon
+* having the longest shared border with the gap. (The overlap merge strategy
+* is not used.)
+* Gaps are defined as enclosed empty areas with width less than a distance tolerance.
 * Empty holes in input polygons are treated as gaps, and may be filled in.
 * Gaps which are not fully enclosed ("inlets") are not removed.
-* The width of a gap is twice the radius of the Maximum Inscribed Circle in the gap polygon,
+* Width is computed as the diameter of the Maximum Inscribed Circle of the gap polygon.
 * A width of zero prevents gaps from being merged.
 * \see geos::coverage::CoverageCleaner::setGapMaximumWidth
-* \param gapMaximumWidth Set to 0.0 for no snapping.
+* \param gapMaximumWidth Set to 0.0 for no gap merging.
 * \return 0 on exception, 1 on success.
 * \since 3.14
@@ -5026,21 +5033,23 @@ GEOSCoverageCleanParams_setGapMaximumWidth(
     GEOSCoverageCleanParams* params,
     double gapMaximumWidth);
 * Sets the overlap merge strategy to use, using one from \ref GEOSOverlapMerge.
-* Overlaps are merged with an adjacent polygon chosen according to a specified merge strategy.
-* The supported strategies are:
-*   * **Longest Border**: (default) merge with the polygon with longest shared border (GEOS_MERGE_LONGEST_BORDER.)
-*   * **Maximum/Minimum Area**: merge with the polygon with largest or smallest area (GEOS_MERGE_MAX_AREA, GEOS_MERGE_MIN_AREA.)
-*   * **Minimum Index**: merge with the polygon with the lowest index in the input array (GEOS_MERGE_MIN_INDEX.)
+* Overlaps are merged with an adjacent polygon chosen according to a specified
+* merge strategy. The supported strategies are:
-* This allows sorting the input according to some criteria to provide a priority
-* for merging gaps.
+* - **Longest Border**: (default) merge with the polygon with longest shared
+*   border (GEOS_MERGE_LONGEST_BORDER.)
+* - **Maximum/Minimum Area**: merge with the polygon with largest or smallest
+*   area (GEOS_MERGE_MAX_AREA, GEOS_MERGE_MIN_AREA.)
+* - **Minimum Index**: merge with the polygon with the lowest index in the
+*   input array (GEOS_MERGE_MIN_INDEX.). This allows sorting the input
+*   according to some criteria to provide a priority for merging gaps.
 * The default is GEOS_MERGE_LONGEST_BORDER.
-* \see geos::coverage::CoverageCleaner::setGapMaximumWidth
+* \see geos::coverage::CoverageCleaner::setOverlapMergeStrategy
 * \param overlapMergeStrategy One of \ref GEOSOverlapMerge strategies
@@ -5053,9 +5062,11 @@ GEOSCoverageCleanParams_setOverlapMergeStrategy(
     int overlapMergeStrategy);
+* Clean a coverage.
 * Operates on a list of polygonal geometry with "exactly matching"
-* edge geometry, to fix cases where the geometry does not in fact
-* exactly match.
+* edge geometry. Removes any overlaps and fixes cases where the geometry
+* does not in fact exactly match.
 * The input is a collection of polygons, and the output is a collection
 * with the same number of cleaned polygons, in the same order as
diff --git a/include/geos/coverage/CoverageCleaner.h b/include/geos/coverage/CoverageCleaner.h
index 233302045..612c9589e 100644
--- a/include/geos/coverage/CoverageCleaner.h
+++ b/include/geos/coverage/CoverageCleaner.h
@@ -288,7 +288,7 @@ public:
      * Sets the maximum width of the gaps that will be filled and merged.
-     * The width of a gap is twice the radius of the Maximum Inscribed Circle in the gap polygon,
+     * The width of a gap is the diameter of the Maximum Inscribed Circle in the gap polygon.
      * @param maxWidth the maximum gap width to merge
Summary of changes:
 capi/geos_c.h.in                        | 55 ++++++++++++++++++++-------------
 include/geos/coverage/CoverageCleaner.h |  2 +-
 2 files changed, 34 insertions(+), 23 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
