[geos-commits] [SCM] GEOS branch main updated. d739e315295a113c8705c8e702155d004ac5bc1e
git at osgeo.org
git at osgeo.org
Mon Jul 27 09:46:46 PDT 2026
the project "GEOS".
The branch, main has been updated
via d739e315295a113c8705c8e702155d004ac5bc1e (commit)
from 7ad626072343e4a55096936015101a19e2492ecd (commit)
revisions in full, below.
commit d739e315295a113c8705c8e702155d004ac5bc1e
Author: Daniel Baston <dbaston at gmail.com>
Date: Mon Jul 27 12:46:22 2026 -0400
Polygonizer: Avoid dropped ZM on mixed-dimension inputs (#1485)
Resolves https://github.com/libgeos/geos/issues/1483
Resolves https://github.com/libgeos/geos/issues/1484
diff --git a/src/operation/polygonize/EdgeRing.cpp b/src/operation/polygonize/EdgeRing.cpp
index 091715936..8917c1bf7 100644
--- a/src/operation/polygonize/EdgeRing.cpp
+++ b/src/operation/polygonize/EdgeRing.cpp
@@ -328,17 +328,29 @@ EdgeRing::getRingOwnership()
/*private*/
void
-EdgeRing::addEdge(const CoordinateSequence* coords, bool isForward,
- CoordinateSequence* coordList)
+EdgeRing::addEdge(const CoordinateSequence* srcCoords, bool isForward,
+ CoordinateSequence* dstCoords)
- const std::size_t npts = coords->getSize();
+ const std::size_t npts = srcCoords->getSize();
+ if (!dstCoords->isEmpty() && !srcCoords->isEmpty()) {
+ // Patch Z value in last coordinate, if needed
+ if (srcCoords->hasZ() && std::isnan(dstCoords->getZ(dstCoords->size() - 1))) {
+ dstCoords->setZ(dstCoords->size() - 1, isForward ? srcCoords->getZ(0) : srcCoords->getZ(srcCoords->getSize() - 1));
+ // Patch M value in last coordinate, if needed
+ if (srcCoords->hasM() && std::isnan(dstCoords->getM(dstCoords->size() - 1))) {
+ dstCoords->setM(dstCoords->size() - 1, isForward ? srcCoords->getM(0) : srcCoords->getM(srcCoords->getSize() - 1));
if(isForward) {
- coordList->add(*coords, 0, npts - 1, false);
+ dstCoords->add(*srcCoords, 0, npts - 1, false);
else {
for(std::size_t i = npts; i > 0; --i) {
- coords->applyAt(i-1, [coordList](const auto& coord) {
- coordList->add(coord, false);
+ srcCoords->applyAt(i-1, [&dstCoords](const auto& coord) {
+ dstCoords->add(coord, false);
diff --git a/tests/unit/operation/polygonize/PolygonizeTest.cpp b/tests/unit/operation/polygonize/PolygonizeTest.cpp
index 99f110fea..502fc2c84 100644
--- a/tests/unit/operation/polygonize/PolygonizeTest.cpp
+++ b/tests/unit/operation/polygonize/PolygonizeTest.cpp
@@ -459,5 +459,27 @@ void object::test<14>()
doTest(input, expected, true, POLYGONS);
+template<>
+template<>
+void object::test<15>()
+ set_test_name("mixed dimension inputs");
+ std::vector<std::string> input{
+ "LINESTRING (0 0, 1 0)",
+ "LINESTRING Z (1 0 6, 2 2 9)",
+ "LINESTRING M (2 2 8, 0 0 7)"};
+ std::vector<std::string> expected{
+ "POLYGON ZM ((0 0 NaN 7, 1 0 6 NaN, 2 2 9 8, 0 0 NaN 7))",
+ doTest(input, expected, false, POLYGONS);
+ std::reverse(input.begin(), input.end());
} // namespace tut
diff --git a/tests/unit/operation/split/GeometrySplitterTest.cpp b/tests/unit/operation/split/GeometrySplitterTest.cpp
index 66f06ffa7..954724495 100644
--- a/tests/unit/operation/split/GeometrySplitterTest.cpp
+++ b/tests/unit/operation/split/GeometrySplitterTest.cpp
@@ -882,6 +882,30 @@ void object::test<72>()
"GEOMETRYCOLLECTION (LINESTRING (-11.1111111 70, -8.055555550000001 66.94444445), LINESTRING (-8.055555550000001 66.94444445, 70 -11.1111111))");
+template<>
+template<>
+void object::test<73>()
+ set_test_name("split PolygonZ with LineString");
+ // https://github.com/libgeos/geos/issues/1483
+ testSplit("POLYGONZ ((0 5 10, 0 10 20, 10 10 30, 10 5 20, 0 5 10))",
+ "LINESTRING(1 11, 1 5)",
+ "GEOMETRYCOLLECTION Z (POLYGON Z ((0 5 10, 0 10 20, 1 10 21, 1 5 11, 0 5 10)), POLYGON Z ((1 10 21, 10 10 30, 10 5 20, 1 5 11, 1 10 21)))");
+template<>
+template<>
+void object::test<74>()
+ set_test_name("split MultiPolygonZM with LineString");
+ testSplit(
+ "MULTIPOLYGON ZM (((1000000 6800000 0 0, 1000000 6800100 1 1, 1000200 6800100 2 2, 1000200 6800000 0 0, 1000000 6800000 0 0)))",
+ "LINESTRING( 1000135 6800130, 1000135 6799975)",
+ "GEOMETRYCOLLECTION ZM (POLYGON ZM ((1000000 6800000 0 0, 1000000 6800100 1 1, 1000135 6800100 1.675 1.675, 1000135 6800000 0 0, 1000000 6800000 0 0)), POLYGON ZM ((1000135 6800100 1.675 1.675, 1000200 6800100 2 2, 1000200 6800000 0 0, 1000135 6800000 0 0, 1000135 6800100 1.675 1.675)))"
Summary of changes:
src/operation/polygonize/EdgeRing.cpp | 24 ++++++++++++++++------
tests/unit/operation/polygonize/PolygonizeTest.cpp | 22 ++++++++++++++++++++
.../unit/operation/split/GeometrySplitterTest.cpp | 24 ++++++++++++++++++++++
3 files changed, 64 insertions(+), 6 deletions(-)
hooks/post-receive
More information about the geos-commits
