[geos-commits] [SCM] GEOS branch main updated. 5936422beec01ab882b7009a142ce3b43cefc272
git at osgeo.org
git at osgeo.org
Tue Jul 28 07:56:57 PDT 2026
the project "GEOS".
The branch, main has been updated
via 5936422beec01ab882b7009a142ce3b43cefc272 (commit)
from d739e315295a113c8705c8e702155d004ac5bc1e (commit)
revisions in full, below.
commit 5936422beec01ab882b7009a142ce3b43cefc272
Author: Joris Van den Bossche <jorisvandenbossche at gmail.com>
Date: Tue Jul 28 16:56:30 2026 +0200
GeometrySplitter: always raise error for point input geometry (#1491)
diff --git a/src/operation/split/GeometrySplitter.cpp b/src/operation/split/GeometrySplitter.cpp
index 0331cd033..ee0cef7e8 100644
--- a/src/operation/split/GeometrySplitter.cpp
+++ b/src/operation/split/GeometrySplitter.cpp
@@ -173,6 +173,10 @@ GeometrySplitter::splitAtPoints(const Geometry& geom, const Geometry& splitPoint
std::unique_ptr<Geometry>
GeometrySplitter::split(const Geometry &geom, const Geometry &splitGeom)
+ if (geom.hasDimension(geom::Dimension::P)) {
+ throw util::IllegalArgumentException("Input geometry must be linear or polygonal.");
if (geom.isEmpty() || splitGeom.isEmpty()) {
std::vector<std::unique_ptr<Geometry>> geoms;
geoms.push_back(geom.clone());
diff --git a/tests/unit/capi/GEOSSplitTest.cpp b/tests/unit/capi/GEOSSplitTest.cpp
index c6c795088..2c9387bbf 100644
--- a/tests/unit/capi/GEOSSplitTest.cpp
+++ b/tests/unit/capi/GEOSSplitTest.cpp
@@ -44,9 +44,28 @@ void object::test<2>()
geom1_ = fromWKT("POINT (3 7)");
geom2_ = fromWKT("LINESTRING (3 7, 3 8)");
+ geom3_ = fromWKT("POINT (3 7)");
result_ = GEOSSplit(geom1_, geom2_); // cannot split a point geometry
ensure(!result_);
+ result_ = GEOSSplit(geom1_, geom3_); // cannot split a point geometry
+ ensure(!result_);
+template<>
+template<>
+void object::test<3>()
+ geom1_ = fromWKT("GEOMETRYCOLLECTION (POINT (3 7), LINESTRING (3 7, 3 8))");
+ geom2_ = fromWKT("LINESTRING (3 7, 3 8)");
+ result_ = GEOSSplit(geom1_, geom2_); // cannot split collection with a point geometry
+ ensure(!result_);
+ result_ = GEOSSplit(geom1_, geom3_); // cannot split collection with a point geometry
+ ensure(!result_);
} // namespace tut
Summary of changes:
src/operation/split/GeometrySplitter.cpp | 4 ++++
tests/unit/capi/GEOSSplitTest.cpp | 19 +++++++++++++++++++
2 files changed, 23 insertions(+)
hooks/post-receive
More information about the geos-commits
