[geos-commits] [SCM] GEOS branch main updated. 4150b856e18b4f33460dbe12b23eea449af8095b
Wed Jun 17 12:36:00 PDT 2026
the project "GEOS".
The branch, main has been updated
       via  4150b856e18b4f33460dbe12b23eea449af8095b (commit)
      from  3ffdc29d3973d77d2b3505557ed793b3c4ca8111 (commit)
revisions in full, below.
commit 4150b856e18b4f33460dbe12b23eea449af8095b
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Jun 17 21:35:42 2026 +0200
    Ensure rpath is used for libgeos_c.so (#1436)
    * Ensure rpath is used for libgeos_c.so
    This ensures each C library links to its corresponding C++ library
    Closes GH-1435
    * Allow CMAKE_INSTALL_RPATH override from commandline, handle MacOS
diff --git a/CMakeLists.txt b/CMakeLists.txt
index d114245cf..541288b93 100644
--- a/CMakeLists.txt
+++ b/CMakeLists.txt
@@ -406,6 +406,18 @@ if(BUILD_SHARED_LIBS)
     PRIVATE $<$<BOOL:${WIN32}>:GEOS_DLL_EXPORT>)
   set_target_properties(geos_c PROPERTIES VERSION ${CAPI_VERSION})
+  # See https://github.com/libgeos/geos/issues/1435
+  if(NOT DEFINED CMAKE_INSTALL_RPATH)
+    # Use relative rpath
+    if(APPLE)
+      set_target_properties(geos_c PROPERTIES
+        INSTALL_RPATH "@loader_path")
+    else()
+      set_target_properties(geos_c PROPERTIES INSTALL_RPATH "\$ORIGIN")
+    endif()
+  endif()
   if(NOT WIN32 OR MINGW)
     set_target_properties(geos_c PROPERTIES SOVERSION ${CAPI_VERSION_MAJOR})
   endif()
Summary of changes:
 CMakeLists.txt | 12 ++++++++++++
 1 file changed, 12 insertions(+)
hooks/post-receive
More information about the geos-commits mailing list
