[geos-commits] [SCM] GEOS branch main updated. cc58aad27d8e8d13fcfcfab00b1305944c6833e7
Wed Jun 17 14:04:31 PDT 2026
the project "GEOS".
The branch, main has been updated
       via  cc58aad27d8e8d13fcfcfab00b1305944c6833e7 (commit)
      from  4150b856e18b4f33460dbe12b23eea449af8095b (commit)
revisions in full, below.
commit cc58aad27d8e8d13fcfcfab00b1305944c6833e7
Author: Kurt Schwehr <schwehr at gmail.com>
Date:   Wed Jun 17 14:04:09 2026 -0700
    Fix `size_t <<` debug prints (#1452)
    Bug introduced in https://github.com/libgeos/geos/commit/d271aaa9a1939fe5a51c5b5d05f1a3d547a2f900
diff --git a/src/io/WKBReader.cpp b/src/io/WKBReader.cpp
index b366d91b9..3562e0147 100644
--- a/src/io/WKBReader.cpp
+++ b/src/io/WKBReader.cpp
@@ -46,6 +46,9 @@
 //#define DEBUG_WKB_READER 1
+#if DEBUG_WKB_READER
+#include <iostream>
+#endif
 using namespace geos::geom;
@@ -174,7 +177,7 @@ WKBReader::readHEX(std::istream& is)
             static_cast<unsigned char>((result_high << 4) + result_low);
 #if DEBUG_HEX_READER
-        std::size_t << "HEX " << high << low << " -> DEC " << (int)value << std::endl;
+        std::cout << "HEX " << high << low << " -> DEC " << (int)value << std::endl;
 #endif
         // write the value to the output stream
         os << value;
@@ -272,7 +275,7 @@ WKBReader::readGeometry()
     unsigned char byteOrder = dis.readByte();
-    std::size_t << "WKB byteOrder: " << (int)byteOrder << std::endl;
+    std::cout << "WKB byteOrder: " << (int)byteOrder << std::endl;
 #endif
     // default is machine endian
@@ -295,7 +298,7 @@ WKBReader::readGeometry()
     int sfsqlHasM = (typeInt & 0x40000000) != 0;
-    std::size_t << "WKB geometryType: " << geometryType << std::endl;
+    std::cout << "WKB geometryType: " << geometryType << std::endl;
 #endif
     hasZ = sfsqlHasZ || isoHasZ;
@@ -311,17 +314,17 @@ WKBReader::readGeometry()
-    std::size_t << "WKB hasZ: " << hasZ << std::endl;
+    std::cout << "WKB hasZ: " << hasZ << std::endl;
 #endif
-    std::size_t << "WKB dimensions: " << inputDimension << std::endl;
+    std::cout << "WKB dimensions: " << inputDimension << std::endl;
 #endif
     bool hasSRID = ((typeInt & 0x20000000) != 0);
-    std::size_t << "WKB hasSRID: " << hasSRID << std::endl;
+    std::cout << "WKB hasSRID: " << hasSRID << std::endl;
 #endif
     int SRID = 0;
@@ -398,7 +401,7 @@ WKBReader::readLineString()
     uint32_t size = dis.readUnsigned();
     minMemSize(GEOS_LINESTRING, size);
-    std::size_t << "WKB npoints: " << size << std::endl;
+    std::cout << "WKB npoints: " << size << std::endl;
 #endif
     auto pts = readCoordinateSequence(size);
     return factory.createLineString(std::move(pts));
@@ -410,7 +413,7 @@ WKBReader::readLinearRing()
     minMemSize(GEOS_LINEARRING, size);
 #endif
     // Replace unclosed ring with closed
@@ -451,7 +454,7 @@ WKBReader::readPolygon()
     minMemSize(GEOS_POLYGON, numRings);
-    std::size_t << "WKB numRings: " << numRings << std::endl;
+    std::cout << "WKB numRings: " << numRings << std::endl;
 #endif
     std::unique_ptr<LinearRing> shell;
@@ -481,7 +484,7 @@ WKBReader::readCurvePolygon()
 #endif
     if (numRings == 0) {
@@ -624,7 +627,7 @@ WKBReader::readCoordinate()
-    std::size_t << "WKB coordinate: " << ordValues[0] << "," << ordValues[1] << std::endl;
+    std::cout << "WKB coordinate: " << ordValues[0] << "," << ordValues[1] << std::endl;
 #endif
diff --git a/src/io/WKBWriter.cpp b/src/io/WKBWriter.cpp
index f7c83d38d..95c64b044 100644
--- a/src/io/WKBWriter.cpp
+++ b/src/io/WKBWriter.cpp
@@ -42,6 +42,10 @@
 #undef DEBUG_WKB_WRITER
+#endif
@@ -380,7 +384,7 @@ void
 WKBWriter::writeCoordinate(const CoordinateSequence& cs, std::size_t idx)
 #if DEBUG_WKB_WRITER
-    std::size_t << "writeCoordinate: X:" << cs.getX(idx) << " Y:" << cs.getY(idx) << std::endl;
+    std::cout << "writeCoordinate: X:" << cs.getX(idx) << " Y:" << cs.getY(idx) << std::endl;
 #endif
     assert(outStream);
@@ -442,4 +446,3 @@ WKBWriter::getWkbType(const Geometry& g) {
 } // namespace geos.io
 } // namespace geos
diff --git a/src/operation/overlay/snap/GeometrySnapper.cpp b/src/operation/overlay/snap/GeometrySnapper.cpp
index c0b429739..a9a4722e6 100644
--- a/src/operation/overlay/snap/GeometrySnapper.cpp
+++ b/src/operation/overlay/snap/GeometrySnapper.cpp
@@ -209,8 +209,8 @@ GeometrySnapper::snap(const geom::Geometry& g0,
     GeometrySnapper snapper1(g1);
     snapGeom.second = snapper1.snapTo(*snapGeom.first, snapTolerance);
-//	std::size_t << *snapGeom.first << std::endl;
-//	std::size_t << *snapGeom.second << std::endl;
+//	std::cout << *snapGeom.first << std::endl;
+//	std::cout << *snapGeom.second << std::endl;
@@ -228,4 +228,3 @@ GeometrySnapper::snapToSelf(const geom::Geometry& g,
 } // namespace geos.operation.overlay
 } // namespace geos
Summary of changes:
 src/io/WKBReader.cpp                           | 25 ++++++++++++++-----------
 src/io/WKBWriter.cpp                           |  7 +++++--
 src/operation/overlay/snap/GeometrySnapper.cpp |  5 ++---
 3 files changed, 21 insertions(+), 16 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
