[geos-commits] [SCM] GEOS branch main updated. 4226b5a034d249e64385d3dac7e69774ff30d6f3
git at osgeo.org
git at osgeo.org
Fri Jun 19 06:59:52 PDT 2026
the project "GEOS".
The branch, main has been updated
via 4226b5a034d249e64385d3dac7e69774ff30d6f3 (commit)
via b0689cbf1ac4f21c9370e8485aae39c8a55d9c47 (commit)
from cc58aad27d8e8d13fcfcfab00b1305944c6833e7 (commit)
revisions in full, below.
commit 4226b5a034d249e64385d3dac7e69774ff30d6f3
Author: Daniel Baston <dbaston at gmail.com>
Date: Thu Jun 18 12:49:34 2026 -0400
KdTree: Disable optimizations in latest MSVC version
References #1449
diff --git a/src/index/kdtree/KdTree.cpp b/src/index/kdtree/KdTree.cpp
index 2118165aa..e11626aed 100644
--- a/src/index/kdtree/KdTree.cpp
+++ b/src/index/kdtree/KdTree.cpp
@@ -226,6 +226,11 @@ KdTree::queryNode(KdNode* currentNode, const geom::Envelope& queryEnv, bool odd,
+#if defined(_MSC_VER) && _MSC_FULL_VER > 195035734
+// Avoid segfault with MSVC 19.51.36246.0
+// See https://github.com/libgeos/geos/issues/1449
+#pragma optimize("", off)
+#endif
/*private*/
KdNode*
KdTree::queryNodePoint(KdNode* currentNode, const geom::Coordinate& queryPt, bool odd)
@@ -257,7 +262,9 @@ KdTree::queryNodePoint(KdNode* currentNode, const geom::Coordinate& queryPt, boo
return nullptr;
+#pragma optimize("", on)
+#endif
/*public*/
void
commit b0689cbf1ac4f21c9370e8485aae39c8a55d9c47
Date: Fri Jun 19 09:24:45 2026 -0400
KdTree: Add minimal test for #1449
diff --git a/tests/unit/index/kdtree/KdTreeTest.cpp b/tests/unit/index/kdtree/KdTreeTest.cpp
index 34ef8d8c6..ec8d238e7 100644
--- a/tests/unit/index/kdtree/KdTreeTest.cpp
+++ b/tests/unit/index/kdtree/KdTreeTest.cpp
@@ -189,6 +189,24 @@ void object::test<8> ()
ensure(node->isRepeated());
+template<>
+template<>
+void object::test<9>()
+ set_test_name("query by point");
+ // minimal test for https://github.com/libgeos/geos/issues/1449
+ KdTree index;
+ ensure(index.query({ 6, 8 }) == nullptr);
+ const KdNode* node68 = index.insert({ 6, 8 });
+ ensure(node68);
+ ensure_equals(index.query({ 6, 8 }), node68);
+ const KdNode* node28 = index.insert({ 2, 8 });
+ ensure(node28);
+ ensure_equals(index.query({ 2, 8 }), node28);
Summary of changes:
src/index/kdtree/KdTree.cpp | 9 ++++++++-
tests/unit/index/kdtree/KdTreeTest.cpp | 18 ++++++++++++++++++
2 files changed, 26 insertions(+), 1 deletion(-)
hooks/post-receive
More information about the geos-commits
