[geos-commits] [SCM] GEOS branch 3.14 updated. 70f292941d2e2243f2db66cf1292bfcffcc001fb
Fri Jun 19 15:21:34 PDT 2026
the project "GEOS".
The branch, 3.14 has been updated
       via  70f292941d2e2243f2db66cf1292bfcffcc001fb (commit)
       via  64e97b299d3f08160debd796c629fd7075b57892 (commit)
       via  b7ec1cbad96d0f518badeac697da4ab3381a86da (commit)
      from  a80d3c2da06305ce5d6cf03b882c2809c5ee43ab (commit)
revisions in full, below.
commit 70f292941d2e2243f2db66cf1292bfcffcc001fb
Author: Daniel Baston <dbaston at gmail.com>
Date:   Thu Jun 18 12:49:34 2026 -0400
    KdTree: Disable optimizations in latest MSVC version
    References #1449
diff --git a/src/index/kdtree/KdTree.cpp b/src/index/kdtree/KdTree.cpp
index a0c2dfbff..9142a0789 100644
--- a/src/index/kdtree/KdTree.cpp
+++ b/src/index/kdtree/KdTree.cpp
@@ -226,6 +226,11 @@ KdTree::queryNode(KdNode* currentNode, const geom::Envelope& queryEnv, bool odd,
+#if defined(_MSC_VER) && _MSC_FULL_VER > 195035734
+// Avoid segfault with MSVC 19.51.36246.0
+// See https://github.com/libgeos/geos/issues/1449
+#pragma optimize("", off)
+#endif
 /*private*/
 KdNode*
 KdTree::queryNodePoint(KdNode* currentNode, const geom::Coordinate& queryPt, bool odd)
@@ -257,7 +262,9 @@ KdTree::queryNodePoint(KdNode* currentNode, const geom::Coordinate& queryPt, boo
     return nullptr;
+#pragma optimize("", on)
+#endif
 /*public*/
 void
commit 64e97b299d3f08160debd796c629fd7075b57892
Date:   Fri Jun 19 09:24:45 2026 -0400
    KdTree: Add minimal test for #1449
diff --git a/tests/unit/index/kdtree/KdTreeTest.cpp b/tests/unit/index/kdtree/KdTreeTest.cpp
index 2de94f162..1121ca25b 100644
--- a/tests/unit/index/kdtree/KdTreeTest.cpp
+++ b/tests/unit/index/kdtree/KdTreeTest.cpp
@@ -189,6 +189,24 @@ void object::test<8> ()
     ensure(node->isRepeated());
+template<>
+template<>
+void object::test<9>()
+    set_test_name("query by point");
+    // minimal test for https://github.com/libgeos/geos/issues/1449
+    KdTree index;
+    ensure(index.query({ 6, 8 }) == nullptr);
+    const KdNode* node68 = index.insert({ 6, 8 });
+    ensure(node68);
+    ensure_equals(index.query({ 6, 8 }), node68);
+    const KdNode* node28 = index.insert({ 2, 8 });
+    ensure(node28);
+    ensure_equals(index.query({ 2, 8 }), node28);
commit b7ec1cbad96d0f518badeac697da4ab3381a86da
Author: Kurt Schwehr <schwehr at gmail.com>
Date:   Wed Jun 17 14:04:09 2026 -0700
    Fix `size_t <<` debug prints (#1452)
    Bug introduced in https://github.com/libgeos/geos/commit/d271aaa9a1939fe5a51c5b5d05f1a3d547a2f900
diff --git a/src/io/WKBReader.cpp b/src/io/WKBReader.cpp
index 442d28506..0016e6328 100644
--- a/src/io/WKBReader.cpp
+++ b/src/io/WKBReader.cpp
@@ -46,6 +46,9 @@
 //#define DEBUG_WKB_READER 1
+#if DEBUG_WKB_READER
+#include <iostream>
+#endif
 using namespace geos::geom;
@@ -174,7 +177,7 @@ WKBReader::readHEX(std::istream& is)
             static_cast<unsigned char>((result_high << 4) + result_low);
 #if DEBUG_HEX_READER
-        std::size_t << "HEX " << high << low << " -> DEC " << (int)value << std::endl;
+        std::cout << "HEX " << high << low << " -> DEC " << (int)value << std::endl;
 #endif
         // write the value to the output stream
         os << value;
@@ -265,7 +268,7 @@ WKBReader::readGeometry()
     unsigned char byteOrder = dis.readByte();
-    std::size_t << "WKB byteOrder: " << (int)byteOrder << std::endl;
+    std::cout << "WKB byteOrder: " << (int)byteOrder << std::endl;
 #endif
     // default is machine endian
@@ -288,7 +291,7 @@ WKBReader::readGeometry()
     int sfsqlHasM = (typeInt & 0x40000000) != 0;
-    std::size_t << "WKB geometryType: " << geometryType << std::endl;
+    std::cout << "WKB geometryType: " << geometryType << std::endl;
 #endif
     hasZ = sfsqlHasZ || isoHasZ;
@@ -304,17 +307,17 @@ WKBReader::readGeometry()
-    std::size_t << "WKB hasZ: " << hasZ << std::endl;
+    std::cout << "WKB hasZ: " << hasZ << std::endl;
 #endif
-    std::size_t << "WKB dimensions: " << inputDimension << std::endl;
+    std::cout << "WKB dimensions: " << inputDimension << std::endl;
 #endif
     bool hasSRID = ((typeInt & 0x20000000) != 0);
-    std::size_t << "WKB hasSRID: " << hasSRID << std::endl;
+    std::cout << "WKB hasSRID: " << hasSRID << std::endl;
 #endif
     int SRID = 0;
@@ -391,7 +394,7 @@ WKBReader::readLineString()
     uint32_t size = dis.readUnsigned();
     minMemSize(GEOS_LINESTRING, size);
-    std::size_t << "WKB npoints: " << size << std::endl;
+    std::cout << "WKB npoints: " << size << std::endl;
 #endif
     auto pts = readCoordinateSequence(size);
     return factory.createLineString(std::move(pts));
@@ -403,7 +406,7 @@ WKBReader::readLinearRing()
     minMemSize(GEOS_LINEARRING, size);
 #endif
     // Replace unclosed ring with closed
@@ -444,7 +447,7 @@ WKBReader::readPolygon()
     minMemSize(GEOS_POLYGON, numRings);
-    std::size_t << "WKB numRings: " << numRings << std::endl;
+    std::cout << "WKB numRings: " << numRings << std::endl;
 #endif
     std::unique_ptr<LinearRing> shell;
@@ -474,7 +477,7 @@ WKBReader::readCurvePolygon()
 #endif
     if (numRings == 0) {
@@ -617,7 +620,7 @@ WKBReader::readCoordinate()
-    std::size_t << "WKB coordinate: " << ordValues[0] << "," << ordValues[1] << std::endl;
+    std::cout << "WKB coordinate: " << ordValues[0] << "," << ordValues[1] << std::endl;
 #endif
diff --git a/src/io/WKBWriter.cpp b/src/io/WKBWriter.cpp
index f7c83d38d..95c64b044 100644
--- a/src/io/WKBWriter.cpp
+++ b/src/io/WKBWriter.cpp
@@ -42,6 +42,10 @@
 #undef DEBUG_WKB_WRITER
+#endif
@@ -380,7 +384,7 @@ void
 WKBWriter::writeCoordinate(const CoordinateSequence& cs, std::size_t idx)
 #if DEBUG_WKB_WRITER
-    std::size_t << "writeCoordinate: X:" << cs.getX(idx) << " Y:" << cs.getY(idx) << std::endl;
+    std::cout << "writeCoordinate: X:" << cs.getX(idx) << " Y:" << cs.getY(idx) << std::endl;
 #endif
     assert(outStream);
@@ -442,4 +446,3 @@ WKBWriter::getWkbType(const Geometry& g) {
 } // namespace geos.io
 } // namespace geos
diff --git a/src/operation/overlay/snap/GeometrySnapper.cpp b/src/operation/overlay/snap/GeometrySnapper.cpp
index a2aed6eaa..294c2f93d 100644
--- a/src/operation/overlay/snap/GeometrySnapper.cpp
+++ b/src/operation/overlay/snap/GeometrySnapper.cpp
@@ -203,8 +203,8 @@ GeometrySnapper::snap(const geom::Geometry& g0,
     GeometrySnapper snapper1(g1);
     snapGeom.second = snapper1.snapTo(*snapGeom.first, snapTolerance);
-//	std::size_t << *snapGeom.first << std::endl;
-//	std::size_t << *snapGeom.second << std::endl;
+//	std::cout << *snapGeom.first << std::endl;
+//	std::cout << *snapGeom.second << std::endl;
@@ -222,4 +222,3 @@ GeometrySnapper::snapToSelf(const geom::Geometry& g,
 } // namespace geos.operation.overlay
 } // namespace geos
Summary of changes:
 src/index/kdtree/KdTree.cpp                    |  9 ++++++++-
 src/io/WKBReader.cpp                           | 25 ++++++++++++++-----------
 src/io/WKBWriter.cpp                           |  7 +++++--
 src/operation/overlay/snap/GeometrySnapper.cpp |  5 ++---
 tests/unit/index/kdtree/KdTreeTest.cpp         | 18 ++++++++++++++++++
 5 files changed, 47 insertions(+), 17 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
