[geos-commits] [SCM] GEOS branch 3.12 updated. ef1e94327bfb9f9f1b175d8a85f8220f72497f41
git at osgeo.org
git at osgeo.org
Sat Jun 20 05:08:47 PDT 2026
the project "GEOS".
The branch, 3.12 has been updated
via ef1e94327bfb9f9f1b175d8a85f8220f72497f41 (commit)
via 34fd1f89d476e8ffcba1d01afa86de7b1685868c (commit)
from a8df87a0ff1989e8b3b088e25785ee7a0e4769a6 (commit)
revisions in full, below.
commit ef1e94327bfb9f9f1b175d8a85f8220f72497f41
Author: Daniel Baston <dbaston at gmail.com>
Date: Thu Jun 18 12:49:34 2026 -0400
KdTree: Disable optimizations in latest MSVC version
References #1449
diff --git a/src/index/kdtree/KdTree.cpp b/src/index/kdtree/KdTree.cpp
index a0c2dfbff..9142a0789 100644
--- a/src/index/kdtree/KdTree.cpp
+++ b/src/index/kdtree/KdTree.cpp
@@ -226,6 +226,11 @@ KdTree::queryNode(KdNode* currentNode, const geom::Envelope& queryEnv, bool odd,
+#if defined(_MSC_VER) && _MSC_FULL_VER > 195035734
+// Avoid segfault with MSVC 19.51.36246.0
+// See https://github.com/libgeos/geos/issues/1449
+#pragma optimize("", off)
+#endif
/*private*/
KdNode*
KdTree::queryNodePoint(KdNode* currentNode, const geom::Coordinate& queryPt, bool odd)
@@ -257,7 +262,9 @@ KdTree::queryNodePoint(KdNode* currentNode, const geom::Coordinate& queryPt, boo
return nullptr;
+#pragma optimize("", on)
+#endif
/*public*/
void
commit 34fd1f89d476e8ffcba1d01afa86de7b1685868c
Date: Fri Jun 19 09:24:45 2026 -0400
KdTree: Add minimal test for #1449
diff --git a/tests/unit/index/kdtree/KdTreeTest.cpp b/tests/unit/index/kdtree/KdTreeTest.cpp
index 2de94f162..1121ca25b 100644
--- a/tests/unit/index/kdtree/KdTreeTest.cpp
+++ b/tests/unit/index/kdtree/KdTreeTest.cpp
@@ -189,6 +189,24 @@ void object::test<8> ()
ensure(node->isRepeated());
+template<>
+template<>
+void object::test<9>()
+ set_test_name("query by point");
+ // minimal test for https://github.com/libgeos/geos/issues/1449
+ KdTree index;
+ ensure(index.query({ 6, 8 }) == nullptr);
+ const KdNode* node68 = index.insert({ 6, 8 });
+ ensure(node68);
+ ensure_equals(index.query({ 6, 8 }), node68);
+ const KdNode* node28 = index.insert({ 2, 8 });
+ ensure(node28);
+ ensure_equals(index.query({ 2, 8 }), node28);
Summary of changes:
src/index/kdtree/KdTree.cpp | 9 ++++++++-
tests/unit/index/kdtree/KdTreeTest.cpp | 18 ++++++++++++++++++
2 files changed, 26 insertions(+), 1 deletion(-)
hooks/post-receive
More information about the geos-commits
