[geos-commits] [SCM] GEOS branch main updated. a4b9ba7d70b4e46143377b4013789f7534033958
git at osgeo.org
git at osgeo.org
Thu Jun 25 09:26:29 PDT 2026
the project "GEOS".
The branch, main has been updated
via a4b9ba7d70b4e46143377b4013789f7534033958 (commit)
from 2c89410f5c6aef61a3f0d72a29c1f88cfb3573a4 (commit)
revisions in full, below.
commit a4b9ba7d70b4e46143377b4013789f7534033958
Author: Daniel Baston <dbaston at gmail.com>
Date: Thu Jun 25 12:26:08 2026 -0400
GeometrySplitter: Return input CompoundCurve when split line is disjoint (#1457)
Resolves https://github.com/libgeos/geos/issues/1456
diff --git a/src/operation/split/GeometrySplitter.cpp b/src/operation/split/GeometrySplitter.cpp
index e78fffef9..904f01081 100644
--- a/src/operation/split/GeometrySplitter.cpp
+++ b/src/operation/split/GeometrySplitter.cpp
@@ -289,11 +289,17 @@ GeometrySplitter::splitLinealWithEdge(const Geometry &geom, const Geometry &edge
noder.setOnlyFirstGeomEdges(true);
noder.setPreserveCompoundCurves(true);
- auto nodedMLS = noder.getNoded();
+ auto noded = noder.getNoded();
- auto nodedGC = geom.getFactory()->createGeometryCollection(detail::down_cast<GeometryCollection*>(nodedMLS.get())->releaseGeometries());
+ // Already a collection type? Convert to a generic GeometryCollection and return.
+ if (auto* coll = dynamic_cast<GeometryCollection*>(noded.get())) {
+ return geom.getFactory()->createGeometryCollection(coll->releaseGeometries());
- return nodedGC;
+ // Promote single-part geometries to a collection type
+ std::vector<std::unique_ptr<Geometry>> geoms;
+ geoms.push_back(std::move(noded));
+ return geom.getFactory()->createGeometryCollection(std::move(geoms));
static std::unique_ptr<Point>
diff --git a/tests/unit/operation/split/GeometrySplitterTest.cpp b/tests/unit/operation/split/GeometrySplitterTest.cpp
index 526144e03..2fa6f7767 100644
--- a/tests/unit/operation/split/GeometrySplitterTest.cpp
+++ b/tests/unit/operation/split/GeometrySplitterTest.cpp
@@ -848,4 +848,26 @@ void object::test<69>()
"GEOMETRYCOLLECTION (LINESTRING (-10 0, -8 0), LINESTRING (-8 0, -5 0), COMPOUNDCURVE (CIRCULARSTRING (-5 0, 0 5, 5 0), (5 0, 8 0)), LINESTRING (8 0, 10 0), CIRCULARSTRING (10 0, 15 -5, 20 0))");
+template<>
+template<>
+void object::test<70>()
+ set_test_name("split CompoundCurve with disjoint LineString");
+ testSplit("COMPOUNDCURVE ((-10 0, -5 0), CIRCULARSTRING (-5 0, 0 5, 5 0), (5 0, 10 0))",
+ "LINESTRING (0 0, 0 4)",
+ "GEOMETRYCOLLECTION(COMPOUNDCURVE ((-10 0, -5 0), CIRCULARSTRING (-5 0, 0 5, 5 0), (5 0, 10 0)))");
+template<>
+template<>
+void object::test<71>()
+ set_test_name("split CompoundCurve with disjoint Point");
+ "POINT (0 0)",
Summary of changes:
src/operation/split/GeometrySplitter.cpp | 12 +++++++++---
.../unit/operation/split/GeometrySplitterTest.cpp | 22 ++++++++++++++++++++++
2 files changed, 31 insertions(+), 3 deletions(-)
hooks/post-receive
More information about the geos-commits
