[geos-commits] [SCM] GEOS branch main updated. f603af8de7618ab110c661da4896e651f5e44ecb
Thu Jun 25 19:35:40 PDT 2026
the project "GEOS".
The branch, main has been updated
       via  f603af8de7618ab110c661da4896e651f5e44ecb (commit)
       via  436ee7fbc6b7a4d710d64ff3e49f928e9ac61adc (commit)
      from  a4b9ba7d70b4e46143377b4013789f7534033958 (commit)
revisions in full, below.
commit f603af8de7618ab110c661da4896e651f5e44ecb
Author: Daniel Baston <dbaston at gmail.com>
Date:   Wed Jun 24 21:36:10 2026 -0400
    C API: Add GEOSGetNumCurves, GEOSCurveN
diff --git a/capi/geos_c.cpp b/capi/geos_c.cpp
index ec799f7d3..a421eabc0 100644
--- a/capi/geos_c.cpp
+++ b/capi/geos_c.cpp
@@ -899,6 +899,18 @@ extern "C" {
         return GEOSGetGeometryN_r(handle, g, n);
+    int
+    GEOSGetNumCurves(const Geometry* g)
+        return GEOSGetNumCurves_r(handle, g);
+    const Geometry*
+    GEOSGetCurveN(const Geometry* g, int n)
+        return GEOSGetCurveN_r(handle, g, n);
      * Call only on LINESTRING
      * Returns NULL on exception
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index c6e853dea..56b0abc6c 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -1828,6 +1828,16 @@ extern const GEOSGeometry GEOS_DLL *GEOSGetGeometryN_r(
     GEOSContextHandle_t handle,
     const GEOSGeometry* g, int n);
+/** \see GEOSGetNumCurves */
+extern int GEOS_DLL GEOSGetNumCurves_r(
+    GEOSContextHandle_t handle,
+    const GEOSGeometry* g);
+/** \see GEOSGetCurveN */
+extern const GEOSGeometry GEOS_DLL *GEOSGetCurveN_r(
+    const GEOSGeometry* g, int n);
 /** \see GEOSNormalize */
 extern int GEOS_DLL GEOSNormalize_r(
@@ -3146,6 +3156,33 @@ extern const GEOSGeometry GEOS_DLL *GEOSGetGeometryN(
     int n);
+* Returns the number of simple curves in a CompoundCurve.
+* Returns 1 for a non-empty LineString/CircularString, and 0
+* for other inputs.
+* \param g Input geometry
+* \return Number of child curves in this geometry
+* \since 3.15
+extern int GEOS_DLL GEOSGetNumCurves(const GEOSGeometry* g);
+* Returns the specified sub-curve of a geometry. For a simple curve type
+* (LineString/CircularString), returns a pointer to the input.
+* Returns NULL for non-curve types (dimension != 1).
+* Returned object is a pointer to internal storage and must NOT be destroyed
+* directly.
+* \param n Sub-curve index, zero-based
+* \return A const \ref GEOSGeometry, or NULL
+* \since 3.15
+extern const GEOSGeometry GEOS_DLL *GEOSGetCurveN(
+    int n);
 * Read the currently set precision value from the
 * geometry and returns the grid size if it is a fixed
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index c42bf851d..7b06105cf 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -2311,6 +2311,36 @@ extern "C" {
+    int
+    GEOSGetNumCurves_r(GEOSContextHandle_t extHandle, const Geometry* g1)
+        return execute<NotInterruptible>(extHandle, -1, [&]() {
+            const Curve* curve = dynamic_cast<const Curve*>(g1);
+            if (curve) {
+                return static_cast<int>(curve->getNumCurves());
+            return 0;
+    GEOSGetCurveN_r(GEOSContextHandle_t extHandle, const Geometry* g, int n)
+        return execute<NotInterruptible>(extHandle, [&]() -> const Geometry* {
+            if(n < 0) {
+                throw IllegalArgumentException("Index must be non-negative.");
+            const Curve* curve = dynamic_cast<const Curve*>(g);
+            if (curve) {
+                return curve->getCurveN(static_cast<std::size_t>(n));
+            return nullptr;
      * Call only on LineString, CircularString, or CompoundCurve
diff --git a/tests/unit/capi/GEOSCompoundCurveTest.cpp b/tests/unit/capi/GEOSCompoundCurveTest.cpp
index a43aa63f9..6a45c69f0 100644
--- a/tests/unit/capi/GEOSCompoundCurveTest.cpp
+++ b/tests/unit/capi/GEOSCompoundCurveTest.cpp
@@ -142,4 +142,20 @@ void object::test<8>()
     ensure_equals(length, geos::MATH_PI*1.5*5 + 5);
+template<>
+template<>
+void object::test<9>()
+    set_test_name("GEOSGetNumCurves / GEOSGetCurveN");
+    ensure_equals(GEOSGetNumCurves(cc_), 2);
+    geom1_ = fromWKT("CIRCULARSTRING ZM (-5 0 6 7, 4 3 7 8 , 0 -5 8 9)");
+    geom2_ = fromWKT("LINESTRING (0 -5 8 9, -5 -5 9 10)");
+    ensure(GEOSGetCurveN(cc_, -1) == nullptr);
+    ensure_geometry_equals_identical(GEOSGetCurveN(cc_, 0), geom1_);
+    ensure_geometry_equals_identical(GEOSGetCurveN(cc_, 1), geom2_);
 } // namespace tut
diff --git a/tests/unit/capi/GEOSLineStringTest.cpp b/tests/unit/capi/GEOSLineStringTest.cpp
index 4beae5439..f50fa3f12 100644
--- a/tests/unit/capi/GEOSLineStringTest.cpp
+++ b/tests/unit/capi/GEOSLineStringTest.cpp
@@ -184,4 +184,30 @@ void object::test<6>
     ensure_equals(length, 1);
+template<>
+template<>
+void object::test<7>()
+    input_ = fromWKT("LINESTRING (1 1, 2 2)");
+    ensure_equals(GEOSGetNumCurves(input_), 1);
+    ensure(GEOSGetCurveN(input_, -1) == nullptr);
+    ensure(GEOSGetCurveN(input_, 0) == input_);
+template<>
+template<>
+void object::test<8>()
+    set_test_name("GEOSGetNumCurves(LINESTRING EMPTY)");
+    input_ = fromWKT("LINESTRING EMPTY");
+    ensure_equals(GEOSGetNumCurves(input_), 0);
 } // namespace tut
diff --git a/tests/unit/capi/capi_test_utils.h b/tests/unit/capi/capi_test_utils.h
index a9680cf1b..a1e5dadfb 100644
--- a/tests/unit/capi/capi_test_utils.h
+++ b/tests/unit/capi/capi_test_utils.h
@@ -181,7 +181,7 @@ namespace capitest {
         void
-        ensure_geometry_equals_identical(GEOSGeometry* g1, GEOSGeometry* g2)
+        ensure_geometry_equals_identical(const GEOSGeometry* g1, const GEOSGeometry* g2)
             char rslt;
             if (g1 == nullptr || g2 == nullptr) {
@@ -222,7 +222,7 @@ namespace capitest {
         void
-        report_not_equal(const char* tag, GEOSGeometry* g1, GEOSGeometry* g2, double tolerance, char rslt)
+        report_not_equal(const char* tag, const GEOSGeometry* g1, const GEOSGeometry* g2, double tolerance, char rslt)
             if (rslt == 1) return;
             //TODO: handle rslt exception value
commit 436ee7fbc6b7a4d710d64ff3e49f928e9ac61adc
Date:   Wed Jun 24 21:35:56 2026 -0400
    SimpleCurve: Make getNumCurves return 0 for EMPTY curve
diff --git a/src/geom/SimpleCurve.cpp b/src/geom/SimpleCurve.cpp
index d65689714..2ea39e55c 100644
--- a/src/geom/SimpleCurve.cpp
+++ b/src/geom/SimpleCurve.cpp
@@ -267,7 +267,7 @@ SimpleCurve::getEndPoint() const
 std::size_t
 SimpleCurve::getNumCurves() const
-    return 1;
+    return isEmpty() ? 0 : 1;
 std::size_t
Summary of changes:
 capi/geos_c.cpp                           | 12 ++++++++++
 capi/geos_c.h.in                          | 37 +++++++++++++++++++++++++++++++
 capi/geos_ts_c.cpp                        | 30 +++++++++++++++++++++++++
 src/geom/SimpleCurve.cpp                  |  2 +-
 tests/unit/capi/GEOSCompoundCurveTest.cpp | 16 +++++++++++++
 tests/unit/capi/GEOSLineStringTest.cpp    | 26 ++++++++++++++++++++++
 tests/unit/capi/capi_test_utils.h         |  4 ++--
 7 files changed, 124 insertions(+), 3 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
