[geos-commits] [SCM] GEOS branch main updated. b54d1466e1c699f418770a4176ceb12d3cf7c6c6
git at osgeo.org
git at osgeo.org
Tue Jun 30 11:58:14 PDT 2026
the project "GEOS".
The branch, main has been updated
via b54d1466e1c699f418770a4176ceb12d3cf7c6c6 (commit)
from f603af8de7618ab110c661da4896e651f5e44ecb (commit)
revisions in full, below.
commit b54d1466e1c699f418770a4176ceb12d3cf7c6c6
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Tue Jun 30 11:57:51 2026 -0700
GeometrySplitter: Fix crash splitting by 3D multi-part geometry (#1462)
Repairs some issues in the flag/geometry type caching in GeometrySplitter, adds relevant test case.
diff --git a/include/geos/geom/GeometryCollection.h b/include/geos/geom/GeometryCollection.h
index 1fd3826bb..8d147c396 100644
--- a/include/geos/geom/GeometryCollection.h
+++ b/include/geos/geom/GeometryCollection.h
@@ -265,6 +265,7 @@ protected:
void geometryChangedAction() override {
envelope.setToNull();
+ flags.flagsCalculated = false;
int compareToSameClass(const Geometry* gc) const override;
diff --git a/src/geom/GeometryCollection.cpp b/src/geom/GeometryCollection.cpp
index 8071260fe..d2dab2733 100644
--- a/src/geom/GeometryCollection.cpp
+++ b/src/geom/GeometryCollection.cpp
@@ -150,6 +150,15 @@ GeometryCollection::setFlags() const {
return;
+ // Reset before accumulating, otherwise stale values (e.g. carried over
+ // by a clone) would never clear once flagsCalculated is invalidated.
+ flags.hasPoints = false;
+ flags.hasLines = false;
+ flags.hasPolygons = false;
+ flags.hasM = false;
+ flags.hasZ = false;
+ flags.hasCurves = false;
for (const auto& geom : geometries) {
flags.hasPoints |= geom->hasDimension(Dimension::P);
flags.hasLines |= geom->hasDimension(Dimension::L);
diff --git a/src/operation/split/GeometrySplitter.cpp b/src/operation/split/GeometrySplitter.cpp
index 904f01081..0331cd033 100644
--- a/src/operation/split/GeometrySplitter.cpp
+++ b/src/operation/split/GeometrySplitter.cpp
@@ -131,22 +131,24 @@ class RemoveCoordinateZM : public geom::CoordinateSequenceFilter {
public:
- void filter_rw(geom::CoordinateSequence& seq, std::size_t) override {
- seq.setZM(false, false);
- m_done = true;
+ void filter_rw(geom::CoordinateSequence& seq, std::size_t i) override {
+ // setZM rewrites the entire sequence, so we only need to act once
+ // per sequence (at the first coordinate).
+ if (i == 0) {
+ seq.setZM(false, false);
bool isDone() const override {
- return m_done;
- bool isGeometryChanged() const override {
- // We didn't change the XY coords; no need to update the envelope.
+ // We must visit every sequence in the geometry, so never stop early.
return false;
-private:
- bool m_done{false};
+ bool isGeometryChanged() const override {
+ // We dropped the Z/M dimensions, so cached dimensional flags
+ // must be recomputed.
+ return true;
std::unique_ptr<Geometry>
diff --git a/tests/unit/operation/split/GeometrySplitterTest.cpp b/tests/unit/operation/split/GeometrySplitterTest.cpp
index 2fa6f7767..66f06ffa7 100644
--- a/tests/unit/operation/split/GeometrySplitterTest.cpp
+++ b/tests/unit/operation/split/GeometrySplitterTest.cpp
@@ -870,4 +870,18 @@ void object::test<71>()
"GEOMETRYCOLLECTION(COMPOUNDCURVE ((-10 0, -5 0), CIRCULARSTRING (-5 0, 0 5, 5 0), (5 0, 10 0)))");
+template<>
+template<>
+void object::test<72>()
+ set_test_name("split LineString with 3D MultiLineString edge");
+ testSplit("LINESTRING(-11.1111111 70,70 -11.1111111)",
+ "MULTILINESTRING((-10 40 1,-9 41 1),(-9 41 1,-8 42 2),(-10 65 1,-9 66 1),(-9 66 1,-8 67 2),(10 40 1,11 41 1),(11 41 1,12 42 2),(10 65 1,11 66 1),(11 66 1,12 67 2),(30 40 1,31 41 1),(31 41 1,32 42 2),(30 65 1,31 66 1),(31 66 1,32 67 2),(50 40 1,51 41 1),(51 41 1,52 42 2),(50 65 1,51 66 1),(51 66 1,52 67 2))",
+ "GEOMETRYCOLLECTION (LINESTRING (-11.1111111 70, -8.055555550000001 66.94444445), LINESTRING (-8.055555550000001 66.94444445, 70 -11.1111111))");
Summary of changes:
include/geos/geom/GeometryCollection.h | 1 +
src/geom/GeometryCollection.cpp | 9 +++++++++
src/operation/split/GeometrySplitter.cpp | 20 +++++++++++---------
tests/unit/operation/split/GeometrySplitterTest.cpp | 14 ++++++++++++++
4 files changed, 35 insertions(+), 9 deletions(-)
hooks/post-receive
More information about the geos-commits
