[geos-commits] [SCM] GEOS branch main updated. 0f150b39c332b89db633e88c83a7e27dc3b13c1b
git at osgeo.org
git at osgeo.org
Sat Mar 7 05:50:47 PST 2026
the project "GEOS".
The branch, main has been updated
via 0f150b39c332b89db633e88c83a7e27dc3b13c1b (commit)
from 99494637e83a22284fadb24e527c3eedb1250e1b (commit)
revisions in full, below.
commit 0f150b39c332b89db633e88c83a7e27dc3b13c1b
Author: Daniel Baston <dbaston at gmail.com>
Date: Sat Mar 7 08:50:24 2026 -0500
C API: Add some comments/tests on Z/M handling (#1389)
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index b31a4290a..8c85598e4 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -3290,7 +3290,8 @@ extern char GEOS_DLL GEOSisEmpty(const GEOSGeometry* g);
* Tests whether the input geometry is a ring. Rings are
* linestrings, without self-intersections,
-* with start and end point being identical.
+* with start and end point having the same XY values.
+* Z and M values are not considered.
* \param g The geometry to test
* \return 1 on true, 0 on false, 2 on exception
* \since 2.2
@@ -3317,7 +3318,8 @@ extern char GEOS_DLL GEOSHasM(const GEOSGeometry* g);
* Tests whether the input geometry is closed.
* A closed geometry is a linestring or multilinestring
-* with the start and end points being the same.
+* with the start and end points having the same XY values.
* \since 3.3
@@ -3363,6 +3365,8 @@ extern void GEOS_DLL GEOSGeom_setUserData(GEOSGeometry* g, void* userData);
* - Polygon shell rings are oriented CW, and holes CCW
* - Collection elements are sorted by their first coordinate
+* Coordinate Z and M values are not modified during normalization.
* Use before calling \ref GEOSEqualsExact to avoid false "not equal" results.
* \param g Input geometry
* \return 0 on success or -1 on exception
@@ -3373,6 +3377,7 @@ extern int GEOS_DLL GEOSNormalize(GEOSGeometry* g);
* Enforce a ring orientation on all polygonal elements in the input geometry.
* Non-polygonal geometries will not be modified.
+* Coordinate Z and M values are not modified.
* \param exteriorCW if 1, exterior rings will be clockwise and interior rings
@@ -3395,6 +3400,7 @@ and geometric quality.
* Tests whether the input geometry is "simple". Mostly relevant for
* linestrings. A "simple" linestring has no self-intersections.
* \since 2.2
@@ -3428,6 +3434,8 @@ extern char GEOS_DLL GEOSisSimpleDetail(
* contained within exterior rings.
* - Multi-polygon components may not touch or overlap.
* \see geos::operation::valid::isValidOp
@@ -3560,7 +3568,7 @@ extern int GEOS_DLL GEOSMakeValidParams_setKeepCollapsed(
extern int GEOS_DLL GEOSMinimumClearance(const GEOSGeometry* g, double* d);
-* Returns a LineString whose endpoints define the minimum clearance of a geometry.
+* Returns a 2D LineString whose endpoints define the minimum clearance of a geometry.
* If the geometry has no minimum clearance, an empty LineString will be returned.
* \param g the input geometry
@@ -3581,6 +3589,9 @@ extern GEOSGeometry GEOS_DLL *GEOSMinimumClearanceLine(const GEOSGeometry* g);
* result in an invalid geometry being returned. Be sure
* to check and repair validity.
+* Z and M coordinate values are preserved but are not considered when
+* determining if a point is repeated.
* \return A geometry with all points within the tolerance of each other removed.
* \param g The geometry to filter
* \param tolerance Remove all points within this distance of each other. Use 0.0 to remove only exactly repeated points.
@@ -3614,6 +3625,7 @@ extern int GEOS_DLL GEOSArea(
* Calculate the length of a geometry.
+* Length is calculated in the XY plane; Z and M values are ignored.
* \param[in] g Input geometry
* \param[out] length Pointer to be filled in with length result
* \return 1 on success, 0 on exception.
@@ -3626,6 +3638,7 @@ extern int GEOS_DLL GEOSLength(
* Calculate the length of a LineString.
* Only works for LineString inputs, returns exception otherwise.
@@ -3647,6 +3660,8 @@ extern int GEOS_DLL GEOSGeomGetLength(
* Calculate the distance between two geometries.
+* Distance is calculated in the XY plane; Z and M values are ignored.
* \param[in] g1 Input geometry
* \param[in] g2 Input geometry
* \param[out] dist Pointer to be filled in with distance result. Positive
@@ -3662,6 +3677,8 @@ extern int GEOS_DLL GEOSDistance(
* Test whether the distance between two geometries is
* within the given dist.
* \param g1 Input geometry
* \param g2 Input geometry
* \param dist The max distance
@@ -3695,6 +3712,7 @@ extern int GEOS_DLL GEOSDistanceIndexed(
* The closest points of the two geometries.
* The first point comes from g1 geometry and the second point comes from g2.
+* Returned points will not have Z or M values.
@@ -4301,6 +4319,8 @@ extern void GEOS_DLL GEOSClusterInfo_destroy(GEOSClusterInfo* clusters);
* Buffer a geometry.
+* The coordinates of the constructed geometry will not have Z or M values.
* \param g The input geometry to be buffered.
* \param width The distance by which to expand the geometry (or contract)
* if the value is negative.
@@ -4413,6 +4433,8 @@ extern GEOSGeometry GEOS_DLL *GEOSBufferWithParams(
* Generate a buffer using the provided style parameters.
* \param g The geometry to buffer
* \param width Width of the buffer
* \param quadsegs Number of segments per quadrant
@@ -4434,7 +4456,8 @@ extern GEOSGeometry GEOS_DLL *GEOSBufferWithStyle(
* Generates offset curve line(s) for a geometry.
-* Handles all geometry types as input.
+* Handles all non-curved geometry types as input.
* - For a LineString the result is a LineString.
* - For a Point the result is an empty LineString.
diff --git a/tests/unit/capi/GEOSBufferTest.cpp b/tests/unit/capi/GEOSBufferTest.cpp
index 702cc8dff..f8a555bf3 100644
--- a/tests/unit/capi/GEOSBufferTest.cpp
+++ b/tests/unit/capi/GEOSBufferTest.cpp
@@ -472,4 +472,19 @@ void object::test<26>()
ensure(result_ == nullptr);
+template<>
+template<>
+void object::test<27>()
+ set_test_name("buffer of XYZM geometry is XY");
+ input_ = fromWKT("POINT ZM (1 2 3 4)");
+ ensure(input_ != nullptr);
+ result_ = GEOSBuffer(input_, 1, 8);
+ ensure(result_ != nullptr);
+ ensure(!GEOSHasZ(result_));
+ ensure(!GEOSHasM(result_));
} // namespace tut
diff --git a/tests/unit/capi/GEOSDistanceTest.cpp b/tests/unit/capi/GEOSDistanceTest.cpp
index 152aade8b..42a895a62 100644
--- a/tests/unit/capi/GEOSDistanceTest.cpp
+++ b/tests/unit/capi/GEOSDistanceTest.cpp
@@ -182,5 +182,22 @@ void object::test<6>()
ensure_equals("curved geometry not supported", ret, 0);
+template<>
+template<>
+void object::test<7>()
+ set_test_name("distance calculated in 2D only");
+ geom1_ = fromWKT("POINT ZM (0 0 1 2)");
+ geom2_ = fromWKT("POINT ZM (3 4 7 9)");
+ ensure(geom1_);
+ ensure(geom2_);
+ double dist;
+ ensure_equals(GEOSDistance(geom1_, geom2_, &dist), 1);
+ ensure_equals(dist, 5.0);
} // namespace tut
diff --git a/tests/unit/capi/GEOSDistanceWithinTest.cpp b/tests/unit/capi/GEOSDistanceWithinTest.cpp
index e64c14b63..074c1b59b 100644
--- a/tests/unit/capi/GEOSDistanceWithinTest.cpp
+++ b/tests/unit/capi/GEOSDistanceWithinTest.cpp
@@ -422,6 +422,20 @@ void object::test<32>()
ensure_equals("curved geometry not supported", ret, 2);
+template<>
+template<>
+void object::test<33>()
+ ensure(geom1_);
+ ensure(geom2_);
+ ensure_equals(GEOSDistanceWithin(geom1_, geom2_, 5.0000001), 1);
} // namespace tut
diff --git a/tests/unit/capi/GEOSLengthTest.cpp b/tests/unit/capi/GEOSLengthTest.cpp
index 7be71de71..5e89a0ede 100644
--- a/tests/unit/capi/GEOSLengthTest.cpp
+++ b/tests/unit/capi/GEOSLengthTest.cpp
@@ -72,5 +72,21 @@ void object::test<4>()
ensure_equals(length, geos::MATH_PI);
+template<>
+template<>
+void object::test<5>()
+ set_test_name("length calculated in 2D only");
+ input_ = fromWKT("LINESTRING (0 0 0 0, 1 0 7 9)");
+ double length = -1;
+ int ret = GEOSLength(input_, &length);
+ ensure_equals(ret, 1);
+ ensure_equals(length, 1);
} // namespace tut
diff --git a/tests/unit/capi/GEOSLineStringTest.cpp b/tests/unit/capi/GEOSLineStringTest.cpp
index ca795de60..4beae5439 100644
--- a/tests/unit/capi/GEOSLineStringTest.cpp
+++ b/tests/unit/capi/GEOSLineStringTest.cpp
@@ -168,4 +168,20 @@ void object::test<5>
ensure(length > 0.0);
+template<>
+template<>
+void object::test<6>
+ int ret = GEOSGeomGetLength(input_, &length);
} // namespace tut
diff --git a/tests/unit/capi/GEOSMakeValidTest.cpp b/tests/unit/capi/GEOSMakeValidTest.cpp
index c6531d5b8..0cad2e552 100644
--- a/tests/unit/capi/GEOSMakeValidTest.cpp
+++ b/tests/unit/capi/GEOSMakeValidTest.cpp
@@ -102,4 +102,31 @@ void object::test<5>()
ensure("curved geometry not supported", result_ == nullptr);
+template<>
+template<>
+void object::test<6>()
+ set_test_name("Z/M values preserved for valid input");
+ input_ = fromWKT("POLYGON ZM ((0 0 1 2, 1 0 2 3, 1 1 3 4, 0 0 1 2))");
+ ensure(input_);
+ result_ = GEOSMakeValid(input_);
+ ensure_geometry_equals_identical(result_, input_);
+template<>
+template<>
+ set_test_name("Z/M values are preserved/interpolated for self-intersecting input");
+ input_ = fromWKT("POLYGON ZM ((0 0 1 2, 1 0 2 3, 0 1 3 4, 1 1 4 5, 0 0 1 2))");
+ ensure(input_);
+ expected_ = fromWKT("MULTIPOLYGON ZM (((0 0 1 2, 0.5 0.5 2.5 3.5, 1 0 2 3, 0 0 1 2)), ((1 1 4 5, 0.5 0.5 2.5 3.5, 0 1 3 4, 1 1 4 5)))");
+ ensure_geometry_equals_identical(result_, expected_);
} // namespace tut
diff --git a/tests/unit/capi/GEOSMinimumClearanceTest.cpp b/tests/unit/capi/GEOSMinimumClearanceTest.cpp
index 064763986..49fca2637 100644
--- a/tests/unit/capi/GEOSMinimumClearanceTest.cpp
+++ b/tests/unit/capi/GEOSMinimumClearanceTest.cpp
@@ -126,4 +126,21 @@ void object::test<6>
ensure_equals(GEOSMinimumClearance(input_, &d), 2);
+template<>
+template<>
+ set_test_name("2D LineString returned for 4D inputs");
+ input_ = fromWKT("POLYGON ZM ((0 0 1 2, 2 0 2 3, 2 1 3 4, 1 0.1 4 5, 0 1 5 6, 0 0 1 2))");
+ result_ = GEOSMinimumClearanceLine(input_);
+ expected_ = fromWKT("LINESTRING (1 0.1, 1 0)");
+ ensure_geometry_equals(result_, expected_);
} // namespace tut
diff --git a/tests/unit/capi/GEOSNearestPointsTest.cpp b/tests/unit/capi/GEOSNearestPointsTest.cpp
index c1caa1887..fb7581751 100644
--- a/tests/unit/capi/GEOSNearestPointsTest.cpp
+++ b/tests/unit/capi/GEOSNearestPointsTest.cpp
@@ -139,5 +139,25 @@ void object::test<6>
+template<>
+template<>
+ set_test_name("2D points returned for 4D inputs");
+ ensure(geom1_);
+ ensure(geom2_);
+ GEOSCoordSequence* coords = GEOSNearestPoints(geom1_, geom2_);
+ ensure(coords);
+ ensure(!GEOSCoordSeq_hasM(coords));
+ ensure(!GEOSCoordSeq_hasZ(coords));
+ GEOSCoordSeq_destroy(coords);
} // namespace tut
diff --git a/tests/unit/capi/GEOSOffsetCurveTest.cpp b/tests/unit/capi/GEOSOffsetCurveTest.cpp
index a979155b8..242d18853 100644
--- a/tests/unit/capi/GEOSOffsetCurveTest.cpp
+++ b/tests/unit/capi/GEOSOffsetCurveTest.cpp
@@ -270,5 +270,24 @@ void object::test<13>()
ensure("curved geometries not supported", result_ == nullptr);
+template<>
+template<>
+void object::test<14>()
+ set_test_name("offset of XYZM geometry is XY");
+ input_ = fromWKT("LINESTRING ZM (0 0 3 5, 10 0 7 8)");
+ ensure(input_);
+ result_ = GEOSOffsetCurve(input_, 2, 0, GEOSBUF_JOIN_ROUND, 2);
+ ensure(result_);
+ expected_ = fromWKT("LINESTRING (0 2, 10 2)");
} // namespace tut
diff --git a/tests/unit/capi/GEOSOrientPolygonsTest.cpp b/tests/unit/capi/GEOSOrientPolygonsTest.cpp
index a82955911..10cbcdbe8 100644
--- a/tests/unit/capi/GEOSOrientPolygonsTest.cpp
+++ b/tests/unit/capi/GEOSOrientPolygonsTest.cpp
@@ -95,5 +95,20 @@ void object::test<6>()
ensure_equals("curved geometries not supported", ret, -1);
+template<>
+template<>
+ set_test_name("Z/M values preserved");
+ geom1_ = GEOSGeomFromWKT("POLYGON ZM ((0 0 5 7, 10 0 6 8, 10 10 7 9, 0 10 8 10, 0 0 5 7), (1 1 1 3, 2 1 2 4, 2 2 3 5, 1 2 4 6, 1 1 1 3))");
+ ensure_equals(GEOSOrientPolygons(geom1_, 0), 0);
+ ensure_equals(toWKT(geom1_), "POLYGON ZM ((0 0 5 7, 10 0 6 8, 10 10 7 9, 0 10 8 10, 0 0 5 7), (1 1 1 3, 1 2 4 6, 2 2 3 5, 2 1 2 4, 1 1 1 3))");
+ ensure_equals(GEOSOrientPolygons(geom1_, 1), 0);
+ ensure_equals(toWKT(geom1_), "POLYGON ZM ((0 0 5 7, 0 10 8 10, 10 10 7 9, 10 0 6 8, 0 0 5 7), (1 1 1 3, 2 1 2 4, 2 2 3 5, 1 2 4 6, 1 1 1 3))");
} // namespace tut
diff --git a/tests/unit/capi/GEOSRemoveRepeatedPointsTest.cpp b/tests/unit/capi/GEOSRemoveRepeatedPointsTest.cpp
index c1a53bb32..2ce17f6a1 100644
--- a/tests/unit/capi/GEOSRemoveRepeatedPointsTest.cpp
+++ b/tests/unit/capi/GEOSRemoveRepeatedPointsTest.cpp
@@ -60,4 +60,19 @@ void object::test<3>()
+template<>
+template<>
+void object::test<4>()
+ set_test_name("Z/M values not considered");
+ input_ = fromWKT("LINESTRING ZM (0 0 0 0, 1 3 5 6, 1 3 6 7, 2 6 7 4)");
+ ensure(input_);
+ expected_ = fromWKT("LINESTRING ZM (0 0 0 0, 1 3 5 6, 2 6 7 4)");
+ result_ = GEOSRemoveRepeatedPoints(input_, 0);
} // namespace tut
Summary of changes:
capi/geos_c.h.in | 31 +++++++++++++++++++++---
tests/unit/capi/GEOSBufferTest.cpp | 15 ++++++++++++
tests/unit/capi/GEOSDistanceTest.cpp | 17 +++++++++++++
tests/unit/capi/GEOSDistanceWithinTest.cpp | 14 +++++++++++
tests/unit/capi/GEOSLengthTest.cpp | 16 ++++++++++++
tests/unit/capi/GEOSLineStringTest.cpp | 16 ++++++++++++
tests/unit/capi/GEOSMakeValidTest.cpp | 27 +++++++++++++++++++++
tests/unit/capi/GEOSMinimumClearanceTest.cpp | 17 +++++++++++++
tests/unit/capi/GEOSNearestPointsTest.cpp | 20 +++++++++++++++
tests/unit/capi/GEOSOffsetCurveTest.cpp | 19 +++++++++++++++
tests/unit/capi/GEOSOrientPolygonsTest.cpp | 15 ++++++++++++
tests/unit/capi/GEOSRemoveRepeatedPointsTest.cpp | 15 ++++++++++++
12 files changed, 218 insertions(+), 4 deletions(-)
hooks/post-receive
More information about the geos-commits
