[geos-commits] [SCM] GEOS branch main updated. 9f2be966553f6b81b69b1d2ec7aaf2b6bc3b79ac
Sat Mar 7 10:32:23 PST 2026
the project "GEOS".
The branch, main has been updated
       via  9f2be966553f6b81b69b1d2ec7aaf2b6bc3b79ac (commit)
      from  0f150b39c332b89db633e88c83a7e27dc3b13c1b (commit)
revisions in full, below.
commit 9f2be966553f6b81b69b1d2ec7aaf2b6bc3b79ac
Author: Daniel Baston <dbaston at gmail.com>
Date:   Sat Mar 7 13:31:57 2026 -0500
    GEOSInterpolate: Interpolate M value (#1390)
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index 8c85598e4..800d3f473 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -3874,10 +3874,13 @@ extern double GEOS_DLL GEOSProject(const GEOSGeometry* line,
                                    const GEOSGeometry* point);
-* Measuring from start of line, return point that is distance
-* the start. Line parameter must be a LineString.
-* The returned point is not guaranteed to intersect the line due to limitations
-* of floating point calculations.
+* Return the point that is the specified 2D distance along a LineString from the start.
+* If applicable, the Z value of the returned point will be interpolated from the input line.
+* Since GEOS 3.15, the M value will also be interpolated.
+* If the input is not a LineString, NULL will be returned.
 * \param line linear target of projection
 * \param d distance from start of line to created point
 * \return The point \ref GEOSGeometry that is distance from the start of line.
@@ -3901,8 +3904,14 @@ extern double GEOS_DLL GEOSProjectNormalized(const GEOSGeometry* line,
-* Measuring from start of line, return point that is a proportion
+* Measuring from start of a LineString, return the point at the specified
+* fraction of the total length.
 * \param proportion The proportion from the start of line to created point
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index e082f799c..78a96a612 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -4291,11 +4291,21 @@ extern "C" {
         return execute(extHandle, [&]() {
             GEOSContextHandleInternal_t* handle = reinterpret_cast<GEOSContextHandleInternal_t*>(extHandle);
+            const GeometryFactory* gf = handle->geomFactory;
             geos::linearref::LengthIndexedLine lil(g);
-            geos::geom::Coordinate coord = lil.extractPoint(d);
-            const GeometryFactory* gf = handle->geomFactory;
-            auto point = coord.isNull() ? gf->createPoint(g->getCoordinateDimension()) : gf->createPoint(coord);
+            CoordinateXYZM coord = lil.extractPoint(d);
+            std::unique_ptr<Point> point;
+            if (coord.isNull()) {
+                point = gf->createPoint(g->hasZ(), g->hasM());
+            } else {
+                auto seq = std::make_unique<CoordinateSequence>(1, g->hasZ(), g->hasM());
+                seq->setAt(coord, 0);
+                point = gf->createPoint(std::move(seq));
             point->setSRID(g->getSRID());
             return point.release();
diff --git a/include/geos/linearref/LengthIndexedLine.h b/include/geos/linearref/LengthIndexedLine.h
index 42af91e58..7f5c51075 100644
--- a/include/geos/linearref/LengthIndexedLine.h
+++ b/include/geos/linearref/LengthIndexedLine.h
@@ -64,14 +64,13 @@ public:
      * If the index is out of range the first or last point on the
      * line will be returned.
-     * The Z-ordinate of the computed point will be interpolated from
-     * the Z-ordinates of the line segment containing it, if they exist.
+     * The Z and M ordinates of the computed point will be interpolated from
+     * the Z and M ordinates of the line segment containing it, if they exist.
      * @param index the index of the desired point
      * @return the Coordinate at the given index
-    geom::Coordinate extractPoint(double index) const;
+    geom::CoordinateXYZM extractPoint(double index) const;
      * \brief
diff --git a/include/geos/linearref/LinearLocation.h b/include/geos/linearref/LinearLocation.h
index bbce2b020..623204587 100644
--- a/include/geos/linearref/LinearLocation.h
+++ b/include/geos/linearref/LinearLocation.h
@@ -84,6 +84,8 @@ public:
     static geom::Coordinate pointAlongSegmentByFraction(const geom::Coordinate& p0, const geom::Coordinate& p1,
             double frac);
+    static geom::CoordinateXYZM pointAlongSegmentByFraction(const geom::CoordinateXYZM& p0, const geom::CoordinateXYZM& p1,
+            double frac);
     /** \brief
@@ -161,7 +163,7 @@ public:
      * @param linearGeom the linear geometry referenced by this location
      * @return the Coordinate at the location
-    geom::Coordinate getCoordinate(const geom::Geometry* linearGeom) const;
+    geom::CoordinateXYZM getCoordinate(const geom::Geometry* linearGeom) const;
     /** \brief
      * Gets a [LineSegment](@ref geom::LineSegment) representing the segment of the
diff --git a/src/linearref/LengthIndexedLine.cpp b/src/linearref/LengthIndexedLine.cpp
index 5522eb32c..d25c02168 100644
--- a/src/linearref/LengthIndexedLine.cpp
+++ b/src/linearref/LengthIndexedLine.cpp
@@ -36,11 +36,11 @@ namespace linearref { // geos.linearref
 LengthIndexedLine::LengthIndexedLine(const Geometry* p_linearGeom) :
     linearGeom(p_linearGeom) {}
-Coordinate
+CoordinateXYZM
 LengthIndexedLine::extractPoint(double index) const
     LinearLocation loc = LengthLocationMap::getLocation(linearGeom, index);
-    Coordinate coord = loc.getCoordinate(linearGeom);
+    CoordinateXYZM coord = loc.getCoordinate(linearGeom);
     return coord;
diff --git a/src/linearref/LinearLocation.cpp b/src/linearref/LinearLocation.cpp
index 5eabfab9c..09bbb1c32 100644
--- a/src/linearref/LinearLocation.cpp
+++ b/src/linearref/LinearLocation.cpp
@@ -59,6 +59,25 @@ LinearLocation::pointAlongSegmentByFraction(const Coordinate& p0, const Coordina
     return Coordinate(x, y, z);
+CoordinateXYZM
+LinearLocation::pointAlongSegmentByFraction(const CoordinateXYZM& p0, const CoordinateXYZM& p1, double frac)
+    if(frac <= 0.0) {
+        return p0;
+    if(frac >= 1.0) {
+        return p1;
+    double x = (p1.x - p0.x) * frac + p0.x;
+    double y = (p1.y - p0.y) * frac + p0.y;
+    // interpolate Z/M values. If either is NaN, result will be NaN as well.
+    double z = (p1.z - p0.z) * frac + p0.z;
+    double m = (p1.m - p0.m) * frac + p0.m;
+    return CoordinateXYZM(x, y, z, m);
 /* public */
 LinearLocation::LinearLocation(std::size_t p_segmentIndex,
                                double p_segmentFraction)
@@ -201,21 +220,27 @@ LinearLocation::isVertex() const
 /* public */
-Coordinate
+CoordinateXYZM
 LinearLocation::getCoordinate(const Geometry* linearGeom) const
     if(linearGeom->isEmpty()) {
-        return Coordinate::getNull();
+        return CoordinateXYZM::getNull();
     const LineString* lineComp = dynamic_cast<const LineString*>(linearGeom->getGeometryN(componentIndex));
     if(! lineComp) {
         throw util::IllegalArgumentException("LinearLocation::getCoordinate only works with LineString geometries");
-    Coordinate p0 = lineComp->getCoordinateN(segmentIndex);
-    if(segmentIndex >= lineComp->getNumPoints() - 1) {
+    const CoordinateSequence* pts = lineComp->getCoordinatesRO();
+    CoordinateXYZM p0;
+    pts->getAt(segmentIndex, p0);
+    if (segmentIndex >= pts->size() - 1) {
         return p0;
-    Coordinate p1 = lineComp->getCoordinateN(segmentIndex + 1);
+    CoordinateXYZM p1;
+    pts->getAt(segmentIndex + 1, p1);
     return pointAlongSegmentByFraction(p0, p1, segmentFraction);
diff --git a/tests/unit/capi/GEOSInterpolateTest.cpp b/tests/unit/capi/GEOSInterpolateTest.cpp
index 44992617f..5cfeec787 100644
--- a/tests/unit/capi/GEOSInterpolateTest.cpp
+++ b/tests/unit/capi/GEOSInterpolateTest.cpp
@@ -3,11 +3,6 @@
 #include <tut/tut.hpp>
 // geos
 #include <geos_c.h>
-// std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
-#include <cmath>
 #include "capi_test_utils.h"
@@ -57,7 +52,7 @@ void object::test<3>
     result_ = GEOSInterpolate(geom1_, 0.5);
     expected_ = GEOSGeomFromWKT("POINT (0.5 0)");
-    ensure_geometry_equals(result_, expected_);
+    ensure_geometry_equals_identical(result_, expected_);
 template<>
@@ -69,7 +64,7 @@ void object::test<4>
     result_ = GEOSInterpolateNormalized(geom1_, 0.5);
     expected_ = GEOSGeomFromWKT("POINT (5 0)");
 // ensure NaN argument does not crash
@@ -82,4 +77,75 @@ void object::test<5>
     result_ = GEOSInterpolate(geom1_, std::numeric_limits<double>::quiet_NaN());
+template<>
+template<>
+void object::test<6>
+    set_test_name("Z/M interpolated");
+    geom1_ = fromWKT("LINESTRING ZM (0 0 6 8, 10 0 12 16)");
+    result_ = GEOSInterpolate(geom1_, 5);
+    expected_ = fromWKT("POINT ZM (5 0 9 12)");
+template<>
+template<>
+void object::test<7>
+    set_test_name("Empty LINESTRING M");
+    geom1_ = fromWKT("LINESTRING M EMPTY");
+    expected_ = fromWKT("POINT M EMPTY");
+template<>
+template<>
+void object::test<8>
+    set_test_name("Empty LINESTRING Z");
+    geom1_ = fromWKT("LINESTRING Z EMPTY");
+    expected_ = fromWKT("POINT Z EMPTY");
+template<>
+template<>
+void object::test<9>
+    set_test_name("Empty LINESTRING ZM");
+    geom1_ = fromWKT("LINESTRING ZM EMPTY");
+    expected_ = fromWKT("POINT ZM EMPTY");
+template<>
+template<>
+void object::test<10>
+    set_test_name("Non-LineString input");
+    input_ = fromWKT("POLYGON ((0 0, 0 1, 1 1, 1 0, 0 0))");
+    ensure(input_);
+    result_ = GEOSInterpolate(input_, 5);
+    ensure(result_ == nullptr);
 } // namespace tut
Summary of changes:
 capi/geos_c.h.in                           | 21 +++++---
 capi/geos_ts_c.cpp                         | 16 ++++--
 include/geos/linearref/LengthIndexedLine.h |  7 ++-
 include/geos/linearref/LinearLocation.h    |  4 +-
 src/linearref/LengthIndexedLine.cpp        |  4 +-
 src/linearref/LinearLocation.cpp           | 35 +++++++++++--
 tests/unit/capi/GEOSInterpolateTest.cpp    | 80 +++++++++++++++++++++++++++---
 7 files changed, 139 insertions(+), 28 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
