[geos-commits] [SCM] GEOS branch main updated. 927e1df7e5f4202c64d986bb8ee858d53e5b71eb
Sat Mar 7 19:18:12 PST 2026
the project "GEOS".
The branch, main has been updated
       via  927e1df7e5f4202c64d986bb8ee858d53e5b71eb (commit)
      from  483b30722a47761b87592f8f910b7e0a073b0f69 (commit)
revisions in full, below.
commit 927e1df7e5f4202c64d986bb8ee858d53e5b71eb
Author: Daniel Baston <dbaston at gmail.com>
Date:   Sat Mar 7 21:54:42 2026 -0500
    C API: Add some comments/tests on Z/M handling
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index 800d3f473..95a5e2600 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -4711,8 +4711,11 @@ GEOSCoverageClean(
-* Returns minimum rectangular polygon or point that contains the geometry,
+* Returns minimum 2D rectangular polygon or point that contains the geometry,
 * or an empty point for empty inputs.
+* Z and M values in the input coordinates are ignored.
 * \param g The geometry to calculate an envelope for
 * \return A newly allocated polygonal envelope or point. NULL on exception.
 * Caller is responsible for freeing with GEOSGeom_destroy().
@@ -4728,6 +4731,8 @@ extern GEOSGeometry GEOS_DLL *GEOSEnvelope(const GEOSGeometry* g);
 * - the boundary of a linestring is the end points
 * - the boundary of a point is the point
+* Z and M values in the input coordinates are preserved.
 * \param g The input geometry
 * \return A newly allocated geometry of the boundary. NULL on exception.
@@ -4736,8 +4741,12 @@ extern GEOSGeometry GEOS_DLL *GEOSEnvelope(const GEOSGeometry* g);
 extern GEOSGeometry GEOS_DLL *GEOSBoundary(const GEOSGeometry* g);
-* Returns convex hull of a geometry. The smallest convex Geometry
+* Returns the convex hull of a geometry. The smallest convex Geometry
 * that contains all the points in the input Geometry
+* Z values in the input coordinates will be preserved.
+* M values in the input coordinates will not be preserved.
 * \return A newly allocated geometry of the convex hull. NULL on exception.
@@ -4754,6 +4763,9 @@ extern GEOSGeometry GEOS_DLL *GEOSConvexHull(const GEOSGeometry* g);
 * Frequently used to convert a multi-point into a polygonal area.
 * that contains all the points in the input Geometry.
 * A set of points has a sequence of hulls of increasing concaveness,
 * determined by a numeric target parameter.
 * The concave hull is constructed by removing the longest outer edges
@@ -4789,6 +4801,9 @@ extern GEOSGeometry GEOS_DLL *GEOSConcaveHull(
@@ -5368,6 +5383,8 @@ extern GEOSGeometry GEOS_DLL *GEOSSimplify(
 * that are co-linear within the tolerance distance.
 * Returns a valid output geometry, checking for collapses, ring-intersections, etc
 * and attempting to avoid. More computationally expensive than GEOSSimplify()
+* Z values on the retained coordinates will be preserved.
+* M values will not be preserved.
 * \param tolerance The tolerance to apply. Larger tolerance leads to simpler output.
 * \return The simplified geometry
@@ -5384,6 +5401,10 @@ extern GEOSGeometry GEOS_DLL *GEOSTopologyPreserveSimplify(
 * Return all distinct vertices of input geometry as a MultiPoint.
 * Note that only 2 dimensions of the vertices are considered when
 * testing for equality.
 * \return The distinct points
diff --git a/tests/unit/capi/GEOSConcaveHullTest.cpp b/tests/unit/capi/GEOSConcaveHullTest.cpp
index 5411db1d0..2984418ed 100644
--- a/tests/unit/capi/GEOSConcaveHullTest.cpp
+++ b/tests/unit/capi/GEOSConcaveHullTest.cpp
@@ -61,4 +61,15 @@ void object::test<3>()
     ensure(result_ == nullptr);
+template<>
+template<>
+void object::test<4>()
+    input_ = fromWKT("MULTIPOINT ZM (0 0 1 2, 1 0 3 4, 1 1 5 6, 1 8 11 4, 0.5 0.5 -4 -7)");
+    result_ = GEOSConcaveHull(input_, 0, 0);
+    printf("%s", toWKT(result_).c_str());
 } // namespace tut
diff --git a/tests/unit/capi/GEOSEnvelopeTest.cpp b/tests/unit/capi/GEOSEnvelopeTest.cpp
index 99b603103..68f9317bf 100644
--- a/tests/unit/capi/GEOSEnvelopeTest.cpp
+++ b/tests/unit/capi/GEOSEnvelopeTest.cpp
@@ -17,7 +17,7 @@ struct test_geosenvelope_data : public capitest::utility
         input_ = fromWKT(wktIn);
         result_ = GEOSEnvelope(input_);
         expected_ = fromWKT(wktExp);
-        ensure_geometry_equals(result_, expected_, 0);
+        ensure_geometry_equals_identical(result_, expected_);
@@ -68,5 +68,41 @@ void object::test<4>()
         "POINT EMPTY");
+template<>
+template<>
+void object::test<5>()
+    set_test_name("POINT ZM");
+    checkEnvelope(
+        "POINT ZM (1 2 3 4)",
+             "POINT (1 2)"
+template<>
+template<>
+void object::test<6>()
+    set_test_name("LINESTRING ZM");
+    checkEnvelope(
+        "LINESTRING ZM (0 0 3 4, 5 0 7 8)",
+        "POLYGON ((0 0, 5 0, 5 0, 0 0, 0 0))" // collapsed polygon
+template<>
+template<>
+void object::test<7>()
+    set_test_name("POLYGON ZM");
+    checkEnvelope(
+        "POLYGON ZM ((0 0 1 2, 1 0 3 4, 1 1 5 6, 0 0 1 2))",
+        "POLYGON ((0 0, 1 0, 1 1, 0 1, 0 0))" // collapsed polygon
 } // namespace tut
diff --git a/tests/unit/capi/GEOSGeom_extractUniquePointsTest.cpp b/tests/unit/capi/GEOSGeom_extractUniquePointsTest.cpp
index 95ca4e05e..2ed116462 100644
--- a/tests/unit/capi/GEOSGeom_extractUniquePointsTest.cpp
+++ b/tests/unit/capi/GEOSGeom_extractUniquePointsTest.cpp
@@ -72,6 +72,20 @@ void object::test<4>() {
     ensure_geometry_equals(result_, "MULTIPOINT ((0 0), (1 1), (2 0))");
+template <>
+template <>
+void object::test<5>() {
+    input_ = fromWKT("MULTIPOINT ZM (0 4 7 8, 0 4 11 12, 3 5 6 2)");
+    ensure(input_);
+    result_ = GEOSGeom_extractUniquePoints(input_);
+    ensure(result_);
+    expected_ = fromWKT("MULTIPOINT Z (0 4 7, 3 5 6)");
+    ensure(expected_);
+    ensure_geometry_equals(expected_, result_);
 } // namespace tut
diff --git a/tests/unit/capi/GEOSSimplifyTest.cpp b/tests/unit/capi/GEOSSimplifyTest.cpp
index 1de11740b..3fe73e4a3 100644
--- a/tests/unit/capi/GEOSSimplifyTest.cpp
+++ b/tests/unit/capi/GEOSSimplifyTest.cpp
@@ -50,5 +50,21 @@ void object::test<2>()
+template<>
+template<>
+void object::test<3>()
+    input_ = fromWKT("LINESTRING ZM (0 0 5 8, 1 1 6 2, 2 0 7 9)");
+    ensure(input_);
+    result_ = GEOSSimplify(input_, 2);
+    ensure(result_);
+    expected_ = fromWKT("LINESTRING ZM (0 0 5 8, 2 0 7 9)");
 } // namespace tut
diff --git a/tests/unit/capi/GEOSTopologyPreserveSimplifyTest.cpp b/tests/unit/capi/GEOSTopologyPreserveSimplifyTest.cpp
index 1f6bdcb33..a6ada22d1 100644
--- a/tests/unit/capi/GEOSTopologyPreserveSimplifyTest.cpp
+++ b/tests/unit/capi/GEOSTopologyPreserveSimplifyTest.cpp
@@ -58,5 +58,21 @@ void object::test<3>()
     ensure("curved geometry not supported", result_ == nullptr);
+template<>
+template<>
+    ensure(input_);
+    result_ = GEOSTopologyPreserveSimplify(input_, 2);
+    ensure(result_);
+    expected_ = fromWKT("LINESTRING Z (0 0 5, 2 0 7)");
 } // namespace tut
Summary of changes:
 capi/geos_c.h.in                                   | 25 ++++++++++++--
 tests/unit/capi/GEOSConcaveHullTest.cpp            | 11 +++++++
 tests/unit/capi/GEOSEnvelopeTest.cpp               | 38 +++++++++++++++++++++-
 .../unit/capi/GEOSGeom_extractUniquePointsTest.cpp | 14 ++++++++
 tests/unit/capi/GEOSSimplifyTest.cpp               | 16 +++++++++
 .../unit/capi/GEOSTopologyPreserveSimplifyTest.cpp | 16 +++++++++
 6 files changed, 117 insertions(+), 3 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
