[geos-commits] [SCM] GEOS branch main updated. a1ade8d631190782a6032f2105f4727ead0fb5f3
Sun Mar 8 17:43:54 PDT 2026
the project "GEOS".
The branch, main has been updated
       via  a1ade8d631190782a6032f2105f4727ead0fb5f3 (commit)
      from  927e1df7e5f4202c64d986bb8ee858d53e5b71eb (commit)
revisions in full, below.
commit a1ade8d631190782a6032f2105f4727ead0fb5f3
Author: Daniel Baston <dbaston at gmail.com>
Date:   Sun Mar 8 19:57:22 2026 -0400
     C API: Add more comments/tests on Z/M handling
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index 95a5e2600..21a85501f 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -5034,7 +5034,7 @@ extern GEOSGeometry GEOS_DLL *GEOSMinimumWidth(const GEOSGeometry* g);
-* Returns a point that is inside the boundary of a polygonal geometry.
+* Returns a 2D point that is inside the boundary of a polygonal geometry.
 * \param g The input geometry
 * \return A point that is inside the input
 * Caller is responsible for freeing with GEOSGeom_destroy().
@@ -5045,7 +5045,7 @@ extern GEOSGeometry GEOS_DLL *GEOSMinimumWidth(const GEOSGeometry* g);
 extern GEOSGeometry GEOS_DLL *GEOSPointOnSurface(const GEOSGeometry* g);
-* Returns a point at the center of mass of the input.
+* Returns a 2D point at the center of mass of the input.
 * \return A point at the center of mass of the input
@@ -5056,7 +5056,7 @@ extern GEOSGeometry GEOS_DLL *GEOSPointOnSurface(const GEOSGeometry* g);
 extern GEOSGeometry GEOS_DLL *GEOSGetCentroid(const GEOSGeometry* g);
-* Returns a geometry which represents the "minimum bounding circle",
+* Returns a 2D geometry which represents the "minimum bounding circle",
 * the smallest circle that contains the input.
 * \param[in] g The input geometry
 * \param[out] radius Pointer will be filled with output radius.
@@ -5075,6 +5075,9 @@ extern GEOSGeometry GEOS_DLL *GEOSMinimumBoundingCircle(
 * Return a Delaunay triangulation of the vertices of the given geometry.
+* Z values from the input points will be propagated to the generated polygons.
+* M values from the input points will be ignored.
 * \param g the input geometry whose vertices will be used as "sites"
 * \param tolerance optional snapping tolerance to use for improved robustness
 * \param onlyEdges if non-zero will return a MultiLineString, otherwise it will
@@ -5095,6 +5098,9 @@ extern GEOSGeometry GEOS_DLL * GEOSDelaunayTriangulation(
 * given polygon(s).
 * For non-polygonal inputs, returns an empty geometry collection.
 * \param g the input geometry whose rings will be used as input
 * \return A newly allocated geometry. NULL on exception.
@@ -5116,7 +5122,8 @@ enum GEOSVoronoiFlags
-* Returns the Voronoi polygons or edges of the vertices of the given geometry.
+* Returns the 2D Voronoi polygons or edges computed from the vertices
+* of the given geometry.
 * \param g the input geometry whose vertices will be used as sites.
 * \param tolerance snapping tolerance to use for improved robustness. A
@@ -5152,6 +5159,10 @@ extern GEOSGeometry GEOS_DLL * GEOSVoronoiDiagram(
 * For linear inputs, returns a new geometry in which no lines cross
 * each other, and all touching occurs at end points.
+* Z and M values of input coordinates will be preserved.
+* Z and M values at constructed points will be interpolated.
 * \return The noded geometry or NULL on exception
@@ -5165,9 +5176,11 @@ extern GEOSGeometry GEOS_DLL *GEOSNode(const GEOSGeometry* g);
 * Polygonizes a set of Geometries which contain linework that
 * represents the edges of a planar graph.
-* All types of Geometry are accepted as input; the constituent
+* All non-curved types of Geometry are accepted as input; the constituent
 * linework is extracted as the edges to be polygonized.
+* Z and M values from the input linework will be preserved.
 * The edges must be correctly noded; that is, they must only meet
 * at their endpoints and not overlap anywhere. If your edges are not
 * already noded, run them through GEOSUnaryUnion() first.
@@ -5195,7 +5208,7 @@ extern GEOSGeometry GEOS_DLL *GEOSNode(const GEOSGeometry* g);
 * that the input lines form a valid polygonal geometry (which may
 * include holes or nested polygons).
-* \param geoms Array of linear geometries to polygons. Caller retains ownersihp of both array container and objects.
+* \param geoms Array of linear geometries to polygons. Caller retains ownership of both array container and objects.
 * \param ngeoms Size of the geoms array.
 * \return The polygonal output geometry.
@@ -5212,7 +5225,7 @@ extern GEOSGeometry GEOS_DLL *GEOSPolygonize(
 * but returns a result which is a valid polygonal geometry.
 * The result will not contain any edge-adjacent elements.
@@ -5287,7 +5300,8 @@ extern GEOSGeometry GEOS_DLL *GEOSBuildArea(const GEOSGeometry* g);
 * Densifies a geometry using a given distance tolerance.
 * Additional vertices will be added to every line segment
 * that is greater this tolerance; these vertices will
-* evenly subdivide that segment.
+* evenly subdivide that segment. Z and M values of added
+* vertices will be interpolated.
 * Only linear components of input geometry are densified.
 * \param g The geometry to densify
 * \param tolerance the distance tolerance to densify
@@ -5304,7 +5318,11 @@ extern GEOSGeometry GEOS_DLL *GEOSDensify(
 * Merges a set of LineStrings,
 * joining them at nodes which have cardinality 2.
 * Lines may have their direction reversed.
+* Z and M values from the input will be preserved. If the Z and M
+* values differ at the points where two lines are joined, the values
+* from one of the points will be selected.
 * \param g The input linework
 * \return The merged linework.
@@ -5318,7 +5336,11 @@ extern GEOSGeometry GEOS_DLL *GEOSLineMerge(const GEOSGeometry* g);
 * and where the lines have the same direction.
 * This means that lines do not have their direction reversed.
@@ -5331,6 +5353,10 @@ extern GEOSGeometry GEOS_DLL *GEOSLineMergeDirected(const GEOSGeometry* g);
  *  Computes the line which is the section of the input LineString starting and
  *  ending at the given length fractions.
+ *  Z values will be interpolated from the input.
+ *  M values from the input will be ignored.
  *  \param g The input LineString
  *  \param start_fraction start fraction (0-1) along the length of g
  *  \param end_fraction end fraction (0-1) along the length of g
@@ -5347,7 +5373,8 @@ extern GEOSGeometry GEOS_DLL *GEOSLineSubstring(
 * For geometries with coordinate sequences, reverses the order
 * of the sequences. Converts CCW rings to CW. Reverses direction
-* of LineStrings.
+* of LineStrings. Z and M values of the input coordinates are
+* preserved.
 * \return The reversed geometry
diff --git a/tests/unit/capi/GEOSConstrainedDelaunayTriangulationTest.cpp b/tests/unit/capi/GEOSConstrainedDelaunayTriangulationTest.cpp
index cee6d9019..51362108f 100644
--- a/tests/unit/capi/GEOSConstrainedDelaunayTriangulationTest.cpp
+++ b/tests/unit/capi/GEOSConstrainedDelaunayTriangulationTest.cpp
@@ -79,6 +79,21 @@ void object::test<4>()
     ensure("curved geometry not supported", result_ == nullptr);
+template<>
+template<>
+void object::test<5>()
+    set_test_name("POLYGON ZM input");
+    input_ = fromWKT("POLYGON ZM ((0 0 4 3, 1 7 9 8, 6 2 6 2, 0 0 4 4))");
+    ensure(input_);
+    result_ = GEOSConstrainedDelaunayTriangulation(input_);
+    ensure(result_);
+    ensure(GEOSHasZ(result_));
+    ensure(!GEOSHasM(result_));
 } // namespace tut
diff --git a/tests/unit/capi/GEOSDelaunayTriangulationTest.cpp b/tests/unit/capi/GEOSDelaunayTriangulationTest.cpp
index d685ae25b..f0f2ab077 100644
--- a/tests/unit/capi/GEOSDelaunayTriangulationTest.cpp
+++ b/tests/unit/capi/GEOSDelaunayTriangulationTest.cpp
@@ -134,5 +134,21 @@ void object::test<7>()
+template<>
+template<>
+void object::test<8>()
+    set_test_name("MULTIPOINT ZM input");
+    input_ = fromWKT("MULTIPOINT ZM (0 0 4 3, 1 7 9 8, 6 2 6 2)");
+    ensure(input_);
+    result_ = GEOSDelaunayTriangulation(input_, 0, 0);
+    ensure(result_);
 } // namespace tut
diff --git a/tests/unit/capi/GEOSGetCentroidTest.cpp b/tests/unit/capi/GEOSGetCentroidTest.cpp
index e0fc823fe..2e9b17b5c 100644
--- a/tests/unit/capi/GEOSGetCentroidTest.cpp
+++ b/tests/unit/capi/GEOSGetCentroidTest.cpp
@@ -145,5 +145,22 @@ void object::test<6>()
+template<>
+template<>
+void object::test<7>()
+    set_test_name("Z/M dimensions ignored");
+    input_ = fromWKT("LINESTRING ZM (0 0 4 3, 2 6 9 1)");
+    ensure(input_);
+    result_ = GEOSGetCentroid(input_);
+    ensure(result_);
+    expected_ = fromWKT("POINT (1 3)");
+    ensure(expected_);
+    ensure_geometry_equals_identical(result_, expected_);
 } // namespace tut
diff --git a/tests/unit/capi/GEOSLineMergeDirectedTest.cpp b/tests/unit/capi/GEOSLineMergeDirectedTest.cpp
index 1e145abc6..91a2e5072 100644
--- a/tests/unit/capi/GEOSLineMergeDirectedTest.cpp
+++ b/tests/unit/capi/GEOSLineMergeDirectedTest.cpp
@@ -70,5 +70,24 @@ void object::test<3>()
     ensure("curved geometries not supported", result_ == nullptr);
+template<>
+template<>
+void object::test<4>()
+    set_test_name("MULTILINESTRING ZM input");
+    input_ = fromWKT("MULTILINESTRING ZM ((0 0 4 5, 2 8 4 3), (2 8 8 6, 10 10 9 3))");
+    ensure(input_);
+    result_ = GEOSLineMergeDirected(input_);
+    ensure(result_);
+    expected_ = fromWKT("LINESTRING ZM (0 0 4 5, 2 8 4 3, 10 10 9 3)");
 } // namesplace tut
diff --git a/tests/unit/capi/GEOSLineMergeTest.cpp b/tests/unit/capi/GEOSLineMergeTest.cpp
index 48817c074..ba728b82c 100644
--- a/tests/unit/capi/GEOSLineMergeTest.cpp
+++ b/tests/unit/capi/GEOSLineMergeTest.cpp
@@ -53,5 +53,23 @@ void object::test<2>()
+template<>
+template<>
+void object::test<3>()
+    ensure(input_);
+    result_ = GEOSLineMerge(input_);
+    ensure(result_);
 } // namespace tut
diff --git a/tests/unit/capi/GEOSLineSubstringTest.cpp b/tests/unit/capi/GEOSLineSubstringTest.cpp
index 8135a75d5..9dbc7896b 100644
--- a/tests/unit/capi/GEOSLineSubstringTest.cpp
+++ b/tests/unit/capi/GEOSLineSubstringTest.cpp
@@ -85,22 +85,13 @@ template<>
-    input_ = GEOSGeomFromWKT("LINESTRINGZ (0 0 0, 2 2 5)");
+    set_test_name("Z dimension is interpolated, M dimension is dropped");
+    input_ = GEOSGeomFromWKT("LINESTRING ZM (0 0 0 0, 2 2 5 10)");
     result_ = GEOSLineSubstring(input_, 0, 0.5);
-    expected_ = GEOSGeomFromWKT("LINESTRING (0 0 0, 1 1 2.5)");
+    expected_ = GEOSGeomFromWKT("LINESTRING Z (0 0 0, 1 1 2.5)");
-    ensure_geometry_equals(result_, expected_);
-    // check 3rd dimension that isgnored by ensure_geometry_equals
-    ensure(GEOSHasZ(result_));
-    auto seq = GEOSGeom_getCoordSeq(expected_);
-    double z0, z1;
-    GEOSCoordSeq_getZ(seq, 0, &z0);
-    GEOSCoordSeq_getZ(seq, 1, &z1);
-    ensure_equals(z0, 0);
-    ensure_equals(z1, 2.5);
 // reversed fractions give a reversed substring
diff --git a/tests/unit/capi/GEOSPointOnSurfaceTest.cpp b/tests/unit/capi/GEOSPointOnSurfaceTest.cpp
index 0118234fa..de1ab2d3c 100644
--- a/tests/unit/capi/GEOSPointOnSurfaceTest.cpp
+++ b/tests/unit/capi/GEOSPointOnSurfaceTest.cpp
@@ -231,5 +231,20 @@ void object::test<10>
+template<>
+template<>
+void object::test<11>()
+    set_test_name("Z/M values ignored");
+    input_ = fromWKT("POLYGON ZM ((0 0 4 2, 10 0 8 4, 10 10 12 6, 0 10 8 1, 0 0 4 2))");
+    ensure(input_);
+    result_ = GEOSPointOnSurface(input_);
+    ensure(result_);
+    ensure(!GEOSHasZ(result_));
 } // namespace tut
diff --git a/tests/unit/capi/GEOSPolygonizeTest.cpp b/tests/unit/capi/GEOSPolygonizeTest.cpp
index 8ed9325bd..145743ccc 100644
--- a/tests/unit/capi/GEOSPolygonizeTest.cpp
+++ b/tests/unit/capi/GEOSPolygonizeTest.cpp
@@ -5,6 +5,8 @@
 // geos
 #include <geos_c.h>
+#include <array>
 #include "capi_test_utils.h"
 namespace tut {
@@ -205,5 +207,28 @@ void object::test<7>
+template<>
+template<>
+    set_test_name("LINESTRING ZM inputs");
+    geom1_ = fromWKT("LINESTRING ZM (0 0 5 4, 2 0 6 5, 2 2 7 6)");
+    geom2_ = fromWKT("LINESTRING ZM (2 2 7 6, 0 0 5 4)");
+    ensure(geom1_);
+    ensure(geom2_);
+    std::array<GEOSGeometry*, 2> geoms = {geom1_, geom2_};
+    result_ = GEOSPolygonize(geoms.data(), geoms.size());
+    ensure(result_);
+    expected_ = fromWKT("GEOMETRYCOLLECTION ZM (POLYGON ZM ((2 2 7 6, 2 0 6 5, 0 0 5 4, 2 2 7 6)))");
 } // namespace tut
diff --git a/tests/unit/capi/GEOSReverseTest.cpp b/tests/unit/capi/GEOSReverseTest.cpp
index cb8895d26..f2e618ee1 100644
--- a/tests/unit/capi/GEOSReverseTest.cpp
+++ b/tests/unit/capi/GEOSReverseTest.cpp
@@ -13,6 +13,22 @@ namespace tut {
 // Common data used in test cases.
 struct test_capigeosreverse : public capitest::utility {
+    void
+    testReverse(const std::string& wkt_input,
+                const std::string& wkt_output)
+        GEOSGeometry* input = GEOSGeomFromWKT(wkt_input.c_str());
+        GEOSGeometry* expected_result = GEOSGeomFromWKT(wkt_output.c_str());
+        GEOSGeometry* result = GEOSReverse(input);
+        ensure(result != nullptr);
+        ensure_geometry_equals_identical(result, expected_result);
+        GEOSGeom_destroy(input);
+        GEOSGeom_destroy(expected_result);
+        GEOSGeom_destroy(result);
 typedef test_group<test_capigeosreverse> group;
@@ -20,21 +36,6 @@ typedef group::object object;
 group test_capigeosreverse_group("capi::GEOSReverse");
-void
-testReverse(const std::string& wkt_input,
-            const std::string& wkt_output)
-    GEOSGeometry* input = GEOSGeomFromWKT(wkt_input.c_str());
-    GEOSGeometry* expected_result = GEOSGeomFromWKT(wkt_output.c_str());
-    GEOSGeometry* result = GEOSReverse(input);
-    ensure(result != nullptr);
-    ensure_equals(1, GEOSEqualsExact(result, expected_result, 0.0));
-    GEOSGeom_destroy(input);
-    GEOSGeom_destroy(expected_result);
-    GEOSGeom_destroy(result);
 // Test Cases
@@ -127,4 +128,13 @@ void object::test<9>()
                 "CIRCULARSTRING (2 0, 1 1, 0 0)");
+template<>
+template<>
+void object::test<10>()
+    testReverse("POINT ZM (1 2 3 4)", "POINT ZM (1 2 3 4)");
+    testReverse("LINESTRING ZM (1 2 3 4, 5 6 7 8)", "LINESTRING ZM (5 6 7 8, 1 2 3 4)");
+    testReverse("POLYGON ZM ((1 2 3 4, 5 6 7 8, 9 10 11 12, 1 2 3 4))", "POLYGON ZM ((1 2 3 4, 9 10 11 12, 5 6 7 8, 1 2 3 4))");
 } // namespace tut
Summary of changes:
 capi/geos_c.h.in                                   | 49 +++++++++++++++++-----
 .../GEOSConstrainedDelaunayTriangulationTest.cpp   | 15 +++++++
 tests/unit/capi/GEOSDelaunayTriangulationTest.cpp  | 16 +++++++
 tests/unit/capi/GEOSGetCentroidTest.cpp            | 17 ++++++++
 tests/unit/capi/GEOSLineMergeDirectedTest.cpp      | 19 +++++++++
 tests/unit/capi/GEOSLineMergeTest.cpp              | 18 ++++++++
 tests/unit/capi/GEOSLineSubstringTest.cpp          | 19 +++------
 tests/unit/capi/GEOSPointOnSurfaceTest.cpp         | 15 +++++++
 tests/unit/capi/GEOSPolygonizeTest.cpp             | 25 +++++++++++
 tests/unit/capi/GEOSReverseTest.cpp                | 40 +++++++++++-------
 10 files changed, 193 insertions(+), 40 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
