[geos-commits] [SCM] GEOS branch main updated. 637142a36e34062f32fd2c94f7e37d2c8259becb
Mon Mar 9 05:51:38 PDT 2026
the project "GEOS".
The branch, main has been updated
       via  637142a36e34062f32fd2c94f7e37d2c8259becb (commit)
      from  a1ade8d631190782a6032f2105f4727ead0fb5f3 (commit)
revisions in full, below.
commit 637142a36e34062f32fd2c94f7e37d2c8259becb
Author: Daniel Baston <dbaston at gmail.com>
Date:   Mon Mar 9 08:51:17 2026 -0400
    CurvePolygon: throw construction exception on non-closed ring (#1393)
diff --git a/include/geos/geom/Surface.h b/include/geos/geom/Surface.h
index d2dcb384e..35e0d9cf1 100644
--- a/include/geos/geom/Surface.h
+++ b/include/geos/geom/Surface.h
@@ -109,6 +109,8 @@ protected:
     void geometryChangedAction() override {}
+    void validateConstruction() const;
diff --git a/include/geos/geom/SurfaceImpl.h b/include/geos/geom/SurfaceImpl.h
index 60da401ef..fc66a1a87 100644
--- a/include/geos/geom/SurfaceImpl.h
+++ b/include/geos/geom/SurfaceImpl.h
@@ -70,6 +70,8 @@ protected:
         if (shell == nullptr) {
             shell.reset(static_cast<RingType*>(createEmptyRing(newFactory).release()));
+        validateConstruction();
     SurfaceImpl(std::unique_ptr<RingType>&& newShell,
@@ -83,12 +85,7 @@ protected:
-        if(shell->isEmpty() && hasNonEmptyElements(&holes)) {
-            throw geos::util::IllegalArgumentException("shell is empty but holes are not");
-        if (hasNullElements(&holes)) {
-            throw geos::util::IllegalArgumentException("holes must not contain null elements");
 public:
diff --git a/src/geom/Surface.cpp b/src/geom/Surface.cpp
index 34bb5c601..9a5d66277 100644
--- a/src/geom/Surface.cpp
+++ b/src/geom/Surface.cpp
@@ -282,5 +282,30 @@ Surface::isEmpty() const
     return getExteriorRing()->isEmpty();
+void
+Surface::validateConstruction() const
+    const bool shellIsEmpty = getExteriorRing()->isEmpty();
+    if (!shellIsEmpty && !getExteriorRing()->isClosed()) {
+        throw util::IllegalArgumentException("Exterior ring is not closed");
+    for (std::size_t i = 0 ; i < getNumInteriorRing(); i++) {
+        const Curve* hole = getInteriorRingN(i);
+        if (hole == nullptr) {
+            throw util::IllegalArgumentException("holes must not contain null elements");
+        if (shellIsEmpty && !hole->isEmpty()) {
+            throw util::IllegalArgumentException("shell is empty but holes are not");
+        if (!hole->isClosed()) {
+            throw util::IllegalArgumentException("Hole is not closed");
diff --git a/tests/unit/capi/GEOSisValidDetailTest.cpp b/tests/unit/capi/GEOSisValidDetailTest.cpp
index 4c0c12e9e..a4f8e3a38 100644
--- a/tests/unit/capi/GEOSisValidDetailTest.cpp
+++ b/tests/unit/capi/GEOSisValidDetailTest.cpp
@@ -144,7 +144,7 @@ template<>
 template<>
 void object::test<7>()
-    input_ = fromWKT("CURVEPOLYGON (COMPOUNDCURVE( CIRCULARSTRING (0 0, 1 1, 2 0), (2 0, 1 1)))");
+    input_ = fromWKT("CURVEPOLYGON (COMPOUNDCURVE( CIRCULARSTRING (0 0, 1 1, 2 0), (2 0, 0 0)))");
     ensure(input_ != nullptr);
     char ret = GEOSisValidDetail(input_, 0, nullptr, nullptr);
diff --git a/tests/unit/capi/GEOSisValidReasonTest.cpp b/tests/unit/capi/GEOSisValidReasonTest.cpp
index fbd988e59..e3146c443 100644
--- a/tests/unit/capi/GEOSisValidReasonTest.cpp
+++ b/tests/unit/capi/GEOSisValidReasonTest.cpp
@@ -61,7 +61,7 @@ template<>
 template<>
     char* reason = GEOSisValidReason(input_);
diff --git a/tests/unit/capi/GEOSisValidTest.cpp b/tests/unit/capi/GEOSisValidTest.cpp
index a71fc5150..046a53feb 100644
--- a/tests/unit/capi/GEOSisValidTest.cpp
+++ b/tests/unit/capi/GEOSisValidTest.cpp
@@ -68,7 +68,7 @@ template<>
 template<>
 void object::test<5>()
     char ret = GEOSisValid(input_);
diff --git a/tests/unit/geom/CurvePolygonTest.cpp b/tests/unit/geom/CurvePolygonTest.cpp
index 774a8bb32..ebddf3328 100644
--- a/tests/unit/geom/CurvePolygonTest.cpp
+++ b/tests/unit/geom/CurvePolygonTest.cpp
@@ -198,4 +198,41 @@ void object::test<4>()
     ensure_equals("cpRev->getArea()", cpRev->getArea(), 9.8185835, 1e-6);
+template<>
+template<>
+void object::test<5>()
+    set_test_name("construction error on non-closed ring");
+    auto seq = std::make_unique<geos::geom::CoordinateSequence>(3);
+    seq->setAt(CoordinateXY{0, 0}, 0);
+    seq->setAt(CoordinateXY{1, 1}, 1);
+    seq->setAt(CoordinateXY{2, 0}, 2);
+    auto cs = factory_->createCircularString(std::move(seq));
+    seq = std::make_unique<geos::geom::CoordinateSequence>(2);
+    seq->setAt(CoordinateXY{2, 0}, 0);
+    seq->setAt(CoordinateXY{1, 0}, 1);
+    auto ls = factory_->createLineString(std::move(seq));
+    std::vector<std::unique_ptr<geos::geom::SimpleCurve>> curves;
+    curves.push_back(std::move(cs));
+    curves.push_back(std::move(ls));
+    auto cc = factory_->createCompoundCurve(std::move(curves));
+    // shell is non-closed
+    ensure_THROW(factory_->createCurvePolygon(std::move(cc)), geos::util::IllegalArgumentException);
+    geos::geom::Envelope shellEnv(-100, 100, -100, 100);
+    auto shell = static_cast<const geos::geom::Polygon*>(factory_->toGeometry(&shellEnv).get())->getExteriorRing()->clone();
+    std::vector<std::unique_ptr<geos::geom::Curve>> holes;
+    holes.push_back(std::move(cc));
+    // hole is non-cloesd
+    ensure_THROW(factory_->createCurvePolygon(std::move(shell), std::move(holes)), geos::util::IllegalArgumentException);
Summary of changes:
 include/geos/geom/Surface.h               |  2 ++
 include/geos/geom/SurfaceImpl.h           |  9 +++-----
 src/geom/Surface.cpp                      | 25 +++++++++++++++++++++
 tests/unit/capi/GEOSisValidDetailTest.cpp |  2 +-
 tests/unit/capi/GEOSisValidReasonTest.cpp |  2 +-
 tests/unit/capi/GEOSisValidTest.cpp       |  2 +-
 tests/unit/geom/CurvePolygonTest.cpp      | 37 +++++++++++++++++++++++++++++++
 7 files changed, 70 insertions(+), 9 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
