[geos-commits] [SCM] GEOS branch main updated. 09463aeb954524fb11318e1d9934e37b563ddf4b
git at osgeo.org
git at osgeo.org
Fri Mar 20 12:41:15 PDT 2026
the project "GEOS".
The branch, main has been updated
via 09463aeb954524fb11318e1d9934e37b563ddf4b (commit)
via a4fd2b4bd05a868fb19791cb9dcb0135857a5797 (commit)
from f1c154d67d6f0a71e76b7ced2f014d74b4f64b19 (commit)
revisions in full, below.
commit 09463aeb954524fb11318e1d9934e37b563ddf4b
Author: Daniel Baston <dbaston at gmail.com>
Date: Mon Mar 9 18:16:58 2026 -0400
geos_unit: handle (Curve)Polygons in ensure_equals_exact_geometry
diff --git a/tests/unit/utility.h b/tests/unit/utility.h
index bdd50cfcc..21825988b 100644
--- a/tests/unit/utility.h
+++ b/tests/unit/utility.h
@@ -540,17 +540,19 @@ template <typename T> inline void ensure_equals_exact_geometry(const T *lhs_in,
template <>
inline void
ensure_equals_exact_geometry(const geos::geom::Geometry *lhs_in,
- const geos::geom::Geometry *rhs_in,
- double tolerance)
+ const geos::geom::Geometry *rhs_in,
+ double tolerance)
assert(nullptr != lhs_in);
assert(nullptr != rhs_in);
using geos::geom::CoordinateSequence;
+ using geos::geom::Curve;
using geos::geom::GeometryCollection;
using geos::geom::Point;
using geos::geom::Polygon;
using geos::geom::SimpleCurve;
+ using geos::geom::Surface;
ensure_equals("type id do not match",
lhs_in->getGeometryTypeId(), rhs_in->getGeometryTypeId());
@@ -563,6 +565,23 @@ ensure_equals_exact_geometry(const geos::geom::Geometry *lhs_in,
const SimpleCurve *gln2 = static_cast<const SimpleCurve *>(rhs_in);
return ensure_equals_dims( gln1->getCoordinatesRO(), gln2->getCoordinatesRO(), 2, tolerance);
+ else if (const Surface* gply1 = dynamic_cast<const Surface*>(lhs_in)) {
+ const Surface* gply2 = static_cast<const Surface*>(rhs_in);
+ const Geometry* extRing1 = gply1->getExteriorRing();
+ const Geometry* extRing2 = gply2->getExteriorRing();
+ ensure_equals_exact_geometry(extRing1, extRing2, tolerance);
+ ensure_equals("number of holes does not match",
+ gply1->getNumInteriorRing(),
+ gply2->getNumInteriorRing());
+ for (std::size_t i = 0; i < gply1->getNumInteriorRing(); i++) {
+ ensure_equals_exact_geometry(static_cast<const Geometry*>(gply1->getInteriorRingN(i)),
+ static_cast<const Geometry*>(gply2->getInteriorRingN(i)),
+ tolerance);
else if (const GeometryCollection* gc1 = dynamic_cast<const GeometryCollection *>(lhs_in)) {
const GeometryCollection *gc2 = static_cast<const GeometryCollection *>(rhs_in);
for (unsigned int i = 0; i < gc1->getNumGeometries(); i++) {
commit a4fd2b4bd05a868fb19791cb9dcb0135857a5797
Date: Fri Jan 30 13:30:14 2026 -0500
geos_unit: use specified tolerance for Z/M in ensure_equals_exact_geometry_xyzm
index 7736d6de6..bdd50cfcc 100644
@@ -177,13 +177,13 @@ ensure_equals_xyzm(geos::geom::CoordinateXYZM const& actual,
-inline void ensure_same(const char* msg, double a, double b)
+inline void ensure_same(const char* msg, double a, double b, double tol = std::numeric_limits<double>::epsilon())
if (std::isnan(a) && std::isnan(b)) {
return;
- ensure_equals(msg, a, b);
+ ensure_equals(msg, a, b, tol);
inline void ensure_same(double a, double b)
@@ -431,8 +431,8 @@ ensure_equals_exact_xyzm(const geos::geom::CoordinateSequence* seq1,
seq2->getAt(i, c2);
ensure("xy not in tolerance", c1.distance(c2) <= tol);
- ensure_same(("index " + std::to_string(i) + "/" + std::to_string(seq1->getSize() - 1) + " z not same").c_str(), c1.z, c2.z);
- ensure_same(("index " + std::to_string(i) + "/" + std::to_string(seq1->getSize() - 1) + " m not same").c_str(), c1.m, c2.m);
+ ensure_same(("index " + std::to_string(i) + "/" + std::to_string(seq1->getSize() - 1) + " z not same").c_str(), c1.z, c2.z, tol);
+ ensure_same(("index " + std::to_string(i) + "/" + std::to_string(seq1->getSize() - 1) + " m not same").c_str(), c1.m, c2.m, tol);
Summary of changes:
tests/unit/utility.h | 31 +++++++++++++++++++++++++------
1 file changed, 25 insertions(+), 6 deletions(-)
hooks/post-receive
More information about the geos-commits
