[geos-commits] [SCM] GEOS branch main updated. 1c6865422740045de3521cae0622a15ec470f4d2
Fri Mar 20 12:42:15 PDT 2026
the project "GEOS".
The branch, main has been updated
       via  1c6865422740045de3521cae0622a15ec470f4d2 (commit)
      from  09463aeb954524fb11318e1d9934e37b563ddf4b (commit)
revisions in full, below.
commit 1c6865422740045de3521cae0622a15ec470f4d2
Author: Daniel Baston <dbaston at gmail.com>
Date:   Tue Dec 23 10:49:36 2025 -0500
    CircularArc: make center and radius calculation orientation-independent
diff --git a/include/geos/geom/CircularArc.h b/include/geos/geom/CircularArc.h
index 067e5ba39..de75334fc 100644
--- a/include/geos/geom/CircularArc.h
+++ b/include/geos/geom/CircularArc.h
@@ -86,7 +86,11 @@ public:
     /// Return the center point of the circle associated with this arc
     const CoordinateXY& getCenter() const {
         if (!m_center_known) {
-            m_center = algorithm::CircularArcs::getCenter(p0(), p1(), p2());
+            if (isCCW()) {
+                m_center = algorithm::CircularArcs::getCenter(p0(), p1(), p2());
+            } else {
+                m_center = algorithm::CircularArcs::getCenter(p2(), p1(), p0());
             m_center_known = true;
@@ -121,7 +125,11 @@ public:
     /// Return the radius of the circle associated with this arc
     double getRadius() const {
         if (!m_radius_known) {
-            m_radius = getCenter().distance(p0());
+            if (isCCW()) {
+                m_radius = getCenter().distance(p0());
+            } else {
+                m_radius = getCenter().distance(p2());
             m_radius_known = true;
diff --git a/tests/unit/geom/CircularArcTest.cpp b/tests/unit/geom/CircularArcTest.cpp
index d09c9ae5b..67df5734a 100644
--- a/tests/unit/geom/CircularArcTest.cpp
+++ b/tests/unit/geom/CircularArcTest.cpp
@@ -1,11 +1,15 @@
 #include <tut/tut.hpp>
+#include <geos/algorithm/Orientation.h>
 #include <geos/geom/Coordinate.h>
 #include <geos/geom/CircularArc.h>
 #include <geos/constants.h>
 using geos::geom::CoordinateXY;
+using geos::geom::CoordinateXYZM;
 using geos::geom::CircularArc;
+using geos::geom::CoordinateSequence;
 using geos::MATH_PI;
 namespace tut {
@@ -31,6 +35,9 @@ struct test_circulararc_data {
         auto rev = CircularArc::create(p2, p1, p0);
         ensure_equals(p2.toString() + " / " + p1.toString() + " / " + p0.toString(), rev.getLength(), expected, eps);
 using group = test_group<test_circulararc_data>;
@@ -123,4 +130,22 @@ void object::test<5>()
     CircularArc::create(CoordinateXY{-5, 0}, {0, 5}, {5, 0}).containsPointOnCircle({5, 0});
+template<>
+template<>
+void object::test<6>() {
+    set_test_name("getRadius and getCenter are order-independent");
+    using XY = CoordinateXY;
+    CircularArc arc1 = CircularArc::create(XY{71.96, -65.54}, XY{22.2, -18.52}, XY{20, 50});
+    double r1 = arc1.getRadius();
+    CoordinateXY c1 = arc1.getCenter();
+    CircularArc arc2 = CircularArc::create(XY{20, 50}, XY{22.2, -18.52}, XY{71.96, -65.54});
+    double r2 = arc1.getRadius();
+    CoordinateXY c2 = arc1.getCenter();
+    ensure_equals(r1, r2);
+    ensure_equals(c1, c2);
Summary of changes:
 include/geos/geom/CircularArc.h     | 12 ++++++++++--
 tests/unit/geom/CircularArcTest.cpp | 25 +++++++++++++++++++++++++
 2 files changed, 35 insertions(+), 2 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
