[geos-commits] [SCM] GEOS branch main updated. 43b00bd6babaab57b3c48c0699e9e0f2e36e04db
Fri Mar 20 14:35:57 PDT 2026
the project "GEOS".
The branch, main has been updated
       via  43b00bd6babaab57b3c48c0699e9e0f2e36e04db (commit)
       via  68129fd3360a0c5b6ccbd058a058a0db6b7f076a (commit)
      from  1c6865422740045de3521cae0622a15ec470f4d2 (commit)
revisions in full, below.
commit 43b00bd6babaab57b3c48c0699e9e0f2e36e04db
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri Mar 20 14:22:01 2026 -0700
    Use func(void) in CAPI func definition sites too,
    in following clang warning defined modern
    practice, references #1404
diff --git a/capi/geos_c.cpp b/capi/geos_c.cpp
index 9a832a64b..e74070e3e 100644
--- a/capi/geos_c.cpp
+++ b/capi/geos_c.cpp
@@ -122,7 +122,7 @@ extern "C" {
     void
-    finishGEOS()
+    finishGEOS(void)
         if(handle != NULL) {
             finishGEOS_r(handle);
@@ -137,13 +137,13 @@ extern "C" {
     void
-    GEOS_interruptRequest()
+    GEOS_interruptRequest(void)
         geos::util::Interrupt::request();
     void
-    GEOS_interruptCancel()
+    GEOS_interruptCancel(void)
         geos::util::Interrupt::cancel();
@@ -1011,7 +1011,7 @@ extern "C" {
     GEOSMakeValidParams*
-    GEOSMakeValidParams_create()
+    GEOSMakeValidParams_create(void)
         return GEOSMakeValidParams_create_r(handle);
@@ -1047,7 +1047,7 @@ extern "C" {
     GEOSCoverageCleanParams*
-    GEOSCoverageCleanParams_create()
+    GEOSCoverageCleanParams_create(void)
         return GEOSCoverageCleanParams_create_r(handle);
@@ -1169,7 +1169,7 @@ extern "C" {
     int
-    GEOS_getWKBOutputDims()
+    GEOS_getWKBOutputDims(void)
         return GEOS_getWKBOutputDims_r(handle);
@@ -1181,7 +1181,7 @@ extern "C" {
     int
-    GEOS_getWKBByteOrder()
+    GEOS_getWKBByteOrder(void)
         return GEOS_getWKBByteOrder_r(handle);
@@ -1478,7 +1478,7 @@ extern "C" {
     /* WKT Reader */
     WKTReader*
-    GEOSWKTReader_create()
+    GEOSWKTReader_create(void)
         return GEOSWKTReader_create_r(handle);
@@ -1503,7 +1503,7 @@ extern "C" {
     /* WKT Writer */
     WKTWriter*
-    GEOSWKTWriter_create()
+    GEOSWKTWriter_create(void)
         return GEOSWKTWriter_create_r(handle);
@@ -1552,7 +1552,7 @@ extern "C" {
     /* WKB Reader */
     WKBReader*
-    GEOSWKBReader_create()
+    GEOSWKBReader_create(void)
         return GEOSWKBReader_create_r(handle);
@@ -1583,7 +1583,7 @@ extern "C" {
     /* WKB Writer */
     WKBWriter*
-    GEOSWKBWriter_create()
+    GEOSWKBWriter_create(void)
         return GEOSWKBWriter_create_r(handle);
@@ -1664,7 +1664,7 @@ extern "C" {
     /* GeoJSON Reader */
     GeoJSONReader*
-    GEOSGeoJSONReader_create()
+    GEOSGeoJSONReader_create(void)
         return GEOSGeoJSONReader_create_r(handle);
@@ -1683,7 +1683,7 @@ extern "C" {
     /* GeoJSON Writer */
     GeoJSONWriter*
-    GEOSGeoJSONWriter_create()
+    GEOSGeoJSONWriter_create(void)
         return GEOSGeoJSONWriter_create_r(handle);
@@ -1939,37 +1939,37 @@ extern "C" {
     geos::geom::Geometry*
-    GEOSGeom_createEmptyPoint()
+    GEOSGeom_createEmptyPoint(void)
         return GEOSGeom_createEmptyPoint_r(handle);
-    GEOSGeom_createEmptyLineString()
+    GEOSGeom_createEmptyLineString(void)
         return GEOSGeom_createEmptyLineString_r(handle);
-    GEOSGeom_createEmptyPolygon()
+    GEOSGeom_createEmptyPolygon(void)
         return GEOSGeom_createEmptyPolygon_r(handle);
-    GEOSGeom_createEmptyCircularString()
+    GEOSGeom_createEmptyCircularString(void)
         return GEOSGeom_createEmptyCircularString_r(handle);
-    GEOSGeom_createEmptyCompoundCurve()
+    GEOSGeom_createEmptyCompoundCurve(void)
         return GEOSGeom_createEmptyCompoundCurve_r(handle);
-    GEOSGeom_createEmptyCurvePolygon()
+    GEOSGeom_createEmptyCurvePolygon(void)
         return GEOSGeom_createEmptyCurvePolygon_r(handle);
@@ -2001,7 +2001,7 @@ extern "C" {
     GEOSBufferParams*
-    GEOSBufferParams_create()
+    GEOSBufferParams_create(void)
         return GEOSBufferParams_create_r(handle);
commit 68129fd3360a0c5b6ccbd058a058a0db6b7f076a
Date:   Fri Mar 20 13:24:17 2026 -0700
    Remove use of () in C prototypes with no parameters in favour
    of using func(void), quiets clang warnings in newer clang.
    References #1404
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index 630f1763f..635bfff64 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -2834,7 +2834,7 @@ extern GEOSGeometry GEOS_DLL *GEOSGeom_createCircularString(GEOSCoordSequence* s
 * Caller is responsible for freeing with GEOSGeom_destroy().
 * \since 3.13
-extern GEOSGeometry GEOS_DLL *GEOSGeom_createEmptyCircularString();
+extern GEOSGeometry GEOS_DLL *GEOSGeom_createEmptyCircularString(void);
 * Creates a CompoundCurve geometry.
@@ -2853,7 +2853,7 @@ extern GEOSGeometry GEOS_DLL *GEOSGeom_createCompoundCurve(GEOSGeometry** curves
 * \since 3.13
-extern GEOSGeometry GEOS_DLL *GEOSGeom_createEmptyCompoundCurve();
+extern GEOSGeometry GEOS_DLL *GEOSGeom_createEmptyCompoundCurve(void);
 * Creates a CurvePolygon geometry from ring geometries.
@@ -2879,7 +2879,7 @@ extern GEOSGeometry GEOS_DLL *GEOSGeom_createCurvePolygon(
 * \since 3.13
-extern GEOSGeometry GEOS_DLL *GEOSGeom_createEmptyCurvePolygon();
+extern GEOSGeometry GEOS_DLL *GEOSGeom_createEmptyCurvePolygon(void);
 * Create a geometry collection.
@@ -4638,7 +4638,7 @@ extern GEOSGeometry GEOS_DLL * GEOSCoverageSimplifyVW(
 * \since 3.14
 extern GEOSCoverageCleanParams GEOS_DLL *
-GEOSCoverageCleanParams_create();
+GEOSCoverageCleanParams_create(void);
 * Destroy a GEOSCoverageCleanParams and free all associated memory.
Summary of changes:
 capi/geos_c.cpp  | 40 ++++++++++++++++++++--------------------
 capi/geos_c.h.in |  8 ++++----
 2 files changed, 24 insertions(+), 24 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
