[geos-commits] [SCM] GEOS branch 3.14 updated. a2e484ca26a8c2a896452f0d8247c4b83e08f4e2
git at osgeo.org
git at osgeo.org
Sun Mar 22 17:05:08 PDT 2026
the project "GEOS".
The branch, 3.14 has been updated
via a2e484ca26a8c2a896452f0d8247c4b83e08f4e2 (commit)
from 2b48c043c11a15beb8d2e0ca4efe004be171bd42 (commit)
revisions in full, below.
commit a2e484ca26a8c2a896452f0d8247c4b83e08f4e2
Author: Mike Taves <mwtoews at gmail.com>
Date: Mon Mar 23 13:04:29 2026 +1300
CI: update various GitHub Actions
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index c1741a25f..735dbddbc 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -189,10 +189,10 @@ jobs:
echo "$(python3 -m site --user-base)/bin" >> $GITHUB_PATH
- name: 'Check Out'
- uses: actions/checkout at v4
+ uses: actions/checkout at v6
- name: Retrieve build cache
- uses: actions/cache/restore at v4
+ uses: actions/cache/restore at v5
with:
path: .ccache
@@ -221,7 +221,7 @@ jobs:
ccache --show-stats
- name: Save build cache
- uses: actions/cache/save at v4
+ uses: actions/cache/save at v5
with:
path: .ccache
key: ${{ steps.restore-cache.outputs.cache-primary-key }}
@@ -243,7 +243,7 @@ jobs:
- name: 'Upload Valgrind Log'
if: failure()
- uses: actions/upload-artifact at v4
+ uses: actions/upload-artifact at v7
with:
path: build/Testing/Temporary/MemoryChecker.**.log
@@ -276,7 +276,7 @@ jobs:
steps:
- name: 'Check Out'
- name: 'Setup'
uses: msys2/setup-msys2 at v2
@@ -291,7 +291,7 @@ jobs:
with:
path: .ccache
key: windows-mingw-${{ matrix.build_type}}-${{ github.ref_name }}-${{ github.run_id }}
@@ -313,7 +313,7 @@ jobs:
ccache --show-stats --verbose
with:
path: .ccache
@@ -327,7 +327,7 @@ jobs:
runs-on: windows-2022
steps:
- name: 'Check Out'
# ccache not supported for this generator and/or Debug
@@ -367,11 +367,11 @@ jobs:
steps:
- name: 'Check Out'
with:
path: .ccache
key: msvc-ninja-${{ matrix.ci.os }}-${{ matrix.ci.cxxstd }}-${{ matrix.ci.arch }}-${{ github.ref_name }}-${{ github.run_id }}
@@ -406,7 +406,7 @@ jobs:
with:
path: .ccache
@@ -447,11 +447,11 @@ jobs:
clang++ --version
- name: 'Check Out'
with:
path: .ccache
key: ${{ runner.os }}-${{ matrix.xcode }}-${{ matrix.build_type}}-${{ matrix.cxxstd }}-${{ github.ref_name }}-${{ github.run_id }}
@@ -472,7 +472,7 @@ jobs:
ccache --show-stats
with:
path: .ccache
@@ -492,10 +492,10 @@ jobs:
sudo -E apt-get autopurge -y needrestart
sudo -E apt-get -yq --no-install-suggests --no-install-recommends install make cmake emscripten ccache
- - uses: actions/checkout at v5
+ - uses: actions/checkout at v6
with:
path: .ccache
@@ -516,7 +516,7 @@ jobs:
ccache --show-stats
with:
path: .ccache
@@ -537,7 +537,7 @@ jobs:
python3 -m pip install --disable-pip-version-check --user codespell
- name: 'Check Out'
- name: 'cppcheck'
run: ./tools/cppcheck.sh
@@ -561,7 +561,7 @@ jobs:
- name: 'Check Out'
with:
path: geos
diff --git a/.github/workflows/codeql.yml b/.github/workflows/codeql.yml
index 556a2143e..a99e32536 100644
--- a/.github/workflows/codeql.yml
+++ b/.github/workflows/codeql.yml
@@ -37,11 +37,11 @@ jobs:
steps:
- name: Checkout repository
# Initializes the CodeQL tools for scanning.
- name: Initialize CodeQL
- uses: github/codeql-action/init at v3
+ uses: github/codeql-action/init at v4
with:
languages: ${{ matrix.language }}
# If you wish to specify custom queries, you can do so here or in a config file.
@@ -64,6 +64,6 @@ jobs:
make -j$(nproc)
- name: Perform CodeQL Analysis
- uses: github/codeql-action/analyze at v3
+ uses: github/codeql-action/analyze at v4
with:
category: "/language:${{matrix.language}}"
diff --git a/.github/workflows/container.yml b/.github/workflows/container.yml
index 0505fd9e1..4bace6fd6 100644
--- a/.github/workflows/container.yml
+++ b/.github/workflows/container.yml
@@ -23,13 +23,13 @@ jobs:
steps:
- name: 'Check Out'
- name: Set up Docker Buildx
- uses: docker/setup-buildx-action at v2
+ uses: docker/setup-buildx-action at v4
- name: Login to GitHub Container Registry
- uses: docker/login-action at v2
+ uses: docker/login-action at v4
with:
registry: ghcr.io
username: ${{ github.repository_owner }}
@@ -40,7 +40,7 @@ jobs:
cp tools/ci/geosop/Dockerfile .
- name: Build and Push
- uses: docker/build-push-action at v4
+ uses: docker/build-push-action at v7
with:
context: .
# platforms: linux/amd64,linux/arm64
diff --git a/.github/workflows/release.yml b/.github/workflows/release.yml
index 0cd89dd4e..afdb1878a 100644
--- a/.github/workflows/release.yml
+++ b/.github/workflows/release.yml
@@ -33,7 +33,7 @@ jobs:
sudo -E apt-get -yq --no-install-suggests --no-install-recommends install make doxygen
- name: 'Check Out'
- name: Get tag
@@ -68,7 +68,7 @@ jobs:
- name: Create Release
if: ${{ steps.tag.outputs.tag == steps.version.outputs.geosversion }}
- uses: softprops/action-gh-release at v1
+ uses: softprops/action-gh-release at v2
with:
body_path: ${{ steps.notes.outputs.geosnotes }}
name: Release ${{ steps.version.outputs.geosversion }}
diff --git a/.github/workflows/web.yml b/.github/workflows/web.yml
index 7a14b534c..c059e4210 100644
--- a/.github/workflows/web.yml
+++ b/.github/workflows/web.yml
@@ -27,7 +27,7 @@ jobs:
- name: 'Check Out 📗'
- name: 'Hugo Build 🛠'
# ...or replace 'master' with a full version tag, such as: v0.64.1
@@ -51,7 +51,7 @@ jobs:
cp -ra build.cmake/doxygen/doxygen_docs/html/* public_html/doxygen
- name: 'Deploy 🚀'
- uses: JamesIves/github-pages-deploy-action at v4.4.1
+ uses: JamesIves/github-pages-deploy-action at v4
with:
branch: gh-pages # The branch the action should deploy to.
folder: public_html # The folder the action should deploy.
Summary of changes:
.github/workflows/ci.yml | 38 +++++++++++++++++++-------------------
.github/workflows/codeql.yml | 6 +++---
.github/workflows/container.yml | 8 ++++----
.github/workflows/release.yml | 4 ++--
.github/workflows/web.yml | 4 ++--
5 files changed, 30 insertions(+), 30 deletions(-)
hooks/post-receive
More information about the geos-commits
