[geos-commits] [SCM] GEOS branch 3.13 updated. 938dcf7d376144e8cdcde79a424feabff94ea413
Sun Mar 22 17:30:17 PDT 2026
the project "GEOS".
The branch, 3.13 has been updated
       via  938dcf7d376144e8cdcde79a424feabff94ea413 (commit)
      from  2bf492cf2c9915663f08f3fc7e7e7b3aef45f6d6 (commit)
revisions in full, below.
commit 938dcf7d376144e8cdcde79a424feabff94ea413
Author: Mike Taves <mwtoews at gmail.com>
Date:   Mon Mar 23 13:08:33 2026 +1300
    CI: update various GitHub Actions
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index deea2b503..7d88e428b 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -149,10 +149,10 @@ jobs:
         echo "$(python3 -m site --user-base)/bin" >> $GITHUB_PATH
     - name: 'Check Out'
-      uses: actions/checkout at v4
+      uses: actions/checkout at v6
     - name: Retrieve build cache
-      uses: actions/cache/restore at v4
+      uses: actions/cache/restore at v5
       with:
         path: .ccache
@@ -181,7 +181,7 @@ jobs:
         ccache --show-stats
     - name: Save build cache
-      uses: actions/cache/save at v4
+      uses: actions/cache/save at v5
       with:
         path: .ccache
         key: ${{ steps.restore-cache.outputs.cache-primary-key }}
@@ -203,7 +203,7 @@ jobs:
     - name: 'Upload Valgrind Log'
       if: failure()
-      uses: actions/upload-artifact at v4
+      uses: actions/upload-artifact at v7
       with:
         path: build/Testing/Temporary/MemoryChecker.**.log
@@ -229,7 +229,7 @@ jobs:
     steps:
     - name: 'Check Out'
     - name: 'Setup'
       uses: msys2/setup-msys2 at v2
@@ -244,7 +244,7 @@ jobs:
       with:
         path: .ccache
         key: windows-mingw-${{ matrix.build_type}}-${{ github.ref_name }}-${{ github.run_id }}
@@ -266,7 +266,7 @@ jobs:
         ccache --show-stats --verbose
       with:
         path: .ccache
@@ -280,7 +280,7 @@ jobs:
     runs-on: windows-2022
     steps:
     - name: 'Check Out'
     # ccache not supported for this generator and/or Debug
@@ -321,11 +321,11 @@ jobs:
     steps:
     - name: 'Check Out'
       with:
         path: .ccache
         key: msvc-ninja-${{ matrix.ci.os }}-${{ matrix.ci.cxxstd }}-${{ matrix.ci.arch }}-${{ github.ref_name }}-${{ github.run_id }}
@@ -360,7 +360,7 @@ jobs:
       with:
         path: .ccache
@@ -401,11 +401,11 @@ jobs:
         clang++ --version
     - name: 'Check Out'
       with:
         path: .ccache
         key: ${{ runner.os }}-${{ matrix.xcode }}-${{ matrix.build_type}}-${{ matrix.cxxstd }}-${{ github.ref_name }}-${{ github.run_id }}
@@ -426,7 +426,7 @@ jobs:
         ccache --show-stats
       with:
         path: .ccache
@@ -435,7 +435,6 @@ jobs:
       working-directory: ./build
       run: ctest -V --output-on-failure -C ${{ matrix.build_type }}
   code-quality:
     name: Code quality checks
     runs-on: ubuntu-latest
@@ -448,7 +447,7 @@ jobs:
         python3 -m pip install --disable-pip-version-check --user codespell
     - name: 'Check Out'
     - name: 'cppcheck'
       run: ./tools/cppcheck.sh
@@ -472,7 +471,7 @@ jobs:
     - name: 'Check Out'
       with:
         path: geos
diff --git a/.github/workflows/codeql.yml b/.github/workflows/codeql.yml
index 556a2143e..a99e32536 100644
--- a/.github/workflows/codeql.yml
+++ b/.github/workflows/codeql.yml
@@ -37,11 +37,11 @@ jobs:
     steps:
     - name: Checkout repository
     # Initializes the CodeQL tools for scanning.
     - name: Initialize CodeQL
-      uses: github/codeql-action/init at v3
+      uses: github/codeql-action/init at v4
       with:
         languages: ${{ matrix.language }}
         # If you wish to specify custom queries, you can do so here or in a config file.
@@ -64,6 +64,6 @@ jobs:
           make -j$(nproc)
     - name: Perform CodeQL Analysis
-      uses: github/codeql-action/analyze at v3
+      uses: github/codeql-action/analyze at v4
       with:
         category: "/language:${{matrix.language}}"
diff --git a/.github/workflows/container.yml b/.github/workflows/container.yml
index 0505fd9e1..4bace6fd6 100644
--- a/.github/workflows/container.yml
+++ b/.github/workflows/container.yml
@@ -23,13 +23,13 @@ jobs:
     steps:
     - name: 'Check Out'
     - name: Set up Docker Buildx
-      uses: docker/setup-buildx-action at v2
+      uses: docker/setup-buildx-action at v4
     - name: Login to GitHub Container Registry
-      uses: docker/login-action at v2
+      uses: docker/login-action at v4
       with:
         registry: ghcr.io
         username: ${{ github.repository_owner }}
@@ -40,7 +40,7 @@ jobs:
         cp tools/ci/geosop/Dockerfile .
     - name: Build and Push
-      uses: docker/build-push-action at v4
+      uses: docker/build-push-action at v7
       with:
         context: .
         # platforms: linux/amd64,linux/arm64
diff --git a/.github/workflows/release.yml b/.github/workflows/release.yml
index a268cef6a..845d021a7 100644
--- a/.github/workflows/release.yml
+++ b/.github/workflows/release.yml
@@ -33,7 +33,7 @@ jobs:
         sudo -E apt-get -yq --no-install-suggests --no-install-recommends install make doxygen
     - name: 'Check Out'
     - name: Get tag
@@ -68,7 +68,7 @@ jobs:
     - name: Create Release
       if: ${{ steps.tag.outputs.tag == steps.version.outputs.geosversion }}
-      uses: softprops/action-gh-release at v1
+      uses: softprops/action-gh-release at v2
       with:
         body_path: ${{ steps.notes.outputs.geosnotes }}
         name: Release ${{ steps.version.outputs.geosversion }}
diff --git a/.github/workflows/web.yml b/.github/workflows/web.yml
index 4bcc1306c..c059e4210 100644
--- a/.github/workflows/web.yml
+++ b/.github/workflows/web.yml
@@ -27,11 +27,11 @@ jobs:
     - name: 'Check Out 📗'
     - name: 'Hugo Build 🛠'
       # ...or replace 'master' with a full version tag, such as: v0.64.1
-      uses: jakejarvis/hugo-build-action at v0.88.1
+      uses: jakejarvis/hugo-build-action at v0.111.3
       with:
         args: --source web --destination public --verbose
@@ -51,7 +51,7 @@ jobs:
         cp -ra build.cmake/doxygen/doxygen_docs/html/* public_html/doxygen
     - name: 'Deploy 🚀'
-      uses: JamesIves/github-pages-deploy-action at v4.4.1
+      uses: JamesIves/github-pages-deploy-action at v4
       with:
         branch: gh-pages           # The branch the action should deploy to.
         folder: public_html    # The folder the action should deploy.
Summary of changes:
 .github/workflows/ci.yml        | 33 ++++++++++++++++-----------------
 .github/workflows/codeql.yml    |  6 +++---
 .github/workflows/container.yml |  8 ++++----
 .github/workflows/release.yml   |  4 ++--
 .github/workflows/web.yml       |  6 +++---
 5 files changed, 28 insertions(+), 29 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
