[geos-commits] [SCM] GEOS branch 3.12 updated. 19857cafbc79e8e9d35154ff1b709ab5d61e14ae
git at osgeo.org
git at osgeo.org
Sun Mar 22 17:51:35 PDT 2026
the project "GEOS".
The branch, 3.12 has been updated
via 19857cafbc79e8e9d35154ff1b709ab5d61e14ae (commit)
from 3802326b4d063a41550d9fe411d891cdd52e68bc (commit)
revisions in full, below.
commit 19857cafbc79e8e9d35154ff1b709ab5d61e14ae
Author: Mike Taves <mwtoews at gmail.com>
Date: Mon Mar 23 13:47:26 2026 +1300
CI: update various GitHub Actions
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index 4408f33a7..5c4b961e3 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -148,10 +148,10 @@ jobs:
echo "$(python3 -m site --user-base)/bin" >> $GITHUB_PATH
- name: 'Check Out'
- uses: actions/checkout at v4
+ uses: actions/checkout at v6
- name: Retrieve build cache
- uses: actions/cache/restore at v4
+ uses: actions/cache/restore at v5
with:
path: .ccache
@@ -179,7 +179,7 @@ jobs:
ccache -s
- name: Save build cache
- uses: actions/cache/save at v4
+ uses: actions/cache/save at v5
with:
path: .ccache
key: ${{ steps.restore-cache.outputs.cache-primary-key }}
@@ -204,7 +204,7 @@ jobs:
- name: 'Upload Valgrind Log'
if: failure()
- uses: actions/upload-artifact at v4
+ uses: actions/upload-artifact at v7
with:
path: build.cmake/Testing/Temporary/MemoryChecker.**.log
@@ -229,7 +229,7 @@ jobs:
steps:
- name: 'Check Out'
- name: 'Setup'
uses: msys2/setup-msys2 at v2
@@ -239,7 +239,7 @@ jobs:
with:
path: .ccache
key: windows-mingw-${{ matrix.build_type}}-${{ github.ref_name }}-${{ github.run_id }}
@@ -258,7 +258,7 @@ jobs:
cmake --build . -j 2
with:
path: .ccache
@@ -284,14 +284,14 @@ jobs:
runs-on: ${{ matrix.ci.os }}
steps:
- name: 'Check Out'
- name: 'Setup'
run: choco install ccache
with:
path: .ccache
key: windows-msvc-${{ matrix.build_type}}-${{ github.ref_name }}-${{ github.run_id }}
@@ -306,7 +306,7 @@ jobs:
cmake --build . --config ${{ matrix.ci.build_type }} -j 2
with:
path: .ccache
@@ -348,11 +348,11 @@ jobs:
clang++ --version
- name: 'Check Out'
with:
path: .ccache
key: ${{ runner.os }}-${{ matrix.xcode }}-${{ matrix.build_type}}-${{ matrix.cxxstd }}-${{ github.ref_name }}-${{ github.run_id }}
@@ -373,7 +373,7 @@ jobs:
ccache --show-stats
with:
path: .ccache
@@ -383,7 +383,6 @@ jobs:
cd build
ctest -V --output-on-failure -C ${{ matrix.build_type }}
code-quality:
name: Code quality checks
runs-on: ubuntu-latest
@@ -395,7 +394,7 @@ jobs:
sudo -E apt-get -yq --no-install-suggests --no-install-recommends install cppcheck
- name: 'Check Out'
- name: 'cppcheck'
run: |
diff --git a/.github/workflows/container.yml b/.github/workflows/container.yml
index 0505fd9e1..4bace6fd6 100644
--- a/.github/workflows/container.yml
+++ b/.github/workflows/container.yml
@@ -23,13 +23,13 @@ jobs:
steps:
- name: 'Check Out'
- name: Set up Docker Buildx
- uses: docker/setup-buildx-action at v2
+ uses: docker/setup-buildx-action at v4
- name: Login to GitHub Container Registry
- uses: docker/login-action at v2
+ uses: docker/login-action at v4
with:
registry: ghcr.io
username: ${{ github.repository_owner }}
@@ -40,7 +40,7 @@ jobs:
cp tools/ci/geosop/Dockerfile .
- name: Build and Push
- uses: docker/build-push-action at v4
+ uses: docker/build-push-action at v7
with:
context: .
# platforms: linux/amd64,linux/arm64
diff --git a/.github/workflows/release.yml b/.github/workflows/release.yml
index 0cd89dd4e..afdb1878a 100644
--- a/.github/workflows/release.yml
+++ b/.github/workflows/release.yml
@@ -33,7 +33,7 @@ jobs:
sudo -E apt-get -yq --no-install-suggests --no-install-recommends install make doxygen
- name: 'Check Out'
- name: Get tag
@@ -68,7 +68,7 @@ jobs:
- name: Create Release
if: ${{ steps.tag.outputs.tag == steps.version.outputs.geosversion }}
- uses: softprops/action-gh-release at v1
+ uses: softprops/action-gh-release at v2
with:
body_path: ${{ steps.notes.outputs.geosnotes }}
name: Release ${{ steps.version.outputs.geosversion }}
diff --git a/.github/workflows/web.yml b/.github/workflows/web.yml
index 4bcc1306c..c059e4210 100644
--- a/.github/workflows/web.yml
+++ b/.github/workflows/web.yml
@@ -27,11 +27,11 @@ jobs:
- name: 'Check Out 📗'
- name: 'Hugo Build 🛠'
# ...or replace 'master' with a full version tag, such as: v0.64.1
- uses: jakejarvis/hugo-build-action at v0.88.1
+ uses: jakejarvis/hugo-build-action at v0.111.3
with:
args: --source web --destination public --verbose
@@ -51,7 +51,7 @@ jobs:
cp -ra build.cmake/doxygen/doxygen_docs/html/* public_html/doxygen
- name: 'Deploy 🚀'
- uses: JamesIves/github-pages-deploy-action at v4.4.1
+ uses: JamesIves/github-pages-deploy-action at v4
with:
branch: gh-pages # The branch the action should deploy to.
folder: public_html # The folder the action should deploy.
Summary of changes:
.github/workflows/ci.yml | 29 ++++++++++++++---------------
.github/workflows/container.yml | 8 ++++----
.github/workflows/release.yml | 4 ++--
.github/workflows/web.yml | 6 +++---
4 files changed, 23 insertions(+), 24 deletions(-)
hooks/post-receive
More information about the geos-commits
