[geos-commits] [SCM] GEOS branch 3.11 updated. b3e1169efeb6eb02f9f442bb66226f24d346b83a
Sun Mar 22 18:09:46 PDT 2026
the project "GEOS".
The branch, 3.11 has been updated
       via  b3e1169efeb6eb02f9f442bb66226f24d346b83a (commit)
      from  63930d5392860983292b421b258cbbba530191ac (commit)
revisions in full, below.
commit b3e1169efeb6eb02f9f442bb66226f24d346b83a
Author: Mike Taves <mwtoews at gmail.com>
Date:   Mon Mar 23 14:02:42 2026 +1300
    CI: update various GitHub Actions
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index b02fca152..4e71e5006 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -89,7 +89,7 @@ jobs:
         echo "$(python3 -m site --user-base)/bin" >> $GITHUB_PATH
     - name: 'Check Out'
-      uses: actions/checkout at v4
+      uses: actions/checkout at v6
     - name: 'Build'
       env:
@@ -124,7 +124,7 @@ jobs:
     - name: 'Upload Valgrind Log'
       if: failure()
-      uses: actions/upload-artifact at v4
+      uses: actions/upload-artifact at v7
       with:
         path: build.cmake/Testing/Temporary/MemoryChecker.**.log
@@ -145,7 +145,7 @@ jobs:
         shell: msys2 {0}
     steps:
     - name: 'Check Out'
     - name: 'Setup'
       uses: msys2/setup-msys2 at v2
@@ -174,7 +174,7 @@ jobs:
         shell: msys2 {0}
     steps:
     - name: 'Check Out'
     - name: 'Setup'
@@ -200,7 +200,7 @@ jobs:
     runs-on: windows-2022
     steps:
     - name: 'Check Out'
     - name: 'Build'
       run: |
@@ -220,7 +220,7 @@ jobs:
     runs-on: windows-2025
     steps:
     - name: 'Check Out'
     - name: 'Build'
       run: |
diff --git a/.github/workflows/container.yml b/.github/workflows/container.yml
index 9c894ff9d..4908fc127 100644
--- a/.github/workflows/container.yml
+++ b/.github/workflows/container.yml
@@ -22,13 +22,13 @@ jobs:
     steps:
     - name: 'Check Out'
     - name: Set up Docker Buildx
-      uses: docker/setup-buildx-action at v2
+      uses: docker/setup-buildx-action at v4
     - name: Login to GitHub Container Registry
-      uses: docker/login-action at v2
+      uses: docker/login-action at v4
       with:
         registry: ghcr.io
         username: ${{ github.repository_owner }}
@@ -40,7 +40,7 @@ jobs:
     - name: Build and Push
       if: ${{ github.repository == 'libgeos/geos' }} }}
-      uses: docker/build-push-action at v4
+      uses: docker/build-push-action at v7
       with:
         context: .
         # platforms: linux/amd64,linux/arm64
diff --git a/.github/workflows/release.yml b/.github/workflows/release.yml
index 0cd89dd4e..afdb1878a 100644
--- a/.github/workflows/release.yml
+++ b/.github/workflows/release.yml
@@ -33,7 +33,7 @@ jobs:
         sudo -E apt-get -yq --no-install-suggests --no-install-recommends install make doxygen
     - name: 'Check Out'
     - name: Get tag
@@ -68,7 +68,7 @@ jobs:
     - name: Create Release
       if: ${{ steps.tag.outputs.tag == steps.version.outputs.geosversion }}
-      uses: softprops/action-gh-release at v1
+      uses: softprops/action-gh-release at v2
       with:
         body_path: ${{ steps.notes.outputs.geosnotes }}
         name: Release ${{ steps.version.outputs.geosversion }}
diff --git a/.github/workflows/web.yml b/.github/workflows/web.yml
index 85cc3d6b9..fe92f164d 100644
--- a/.github/workflows/web.yml
+++ b/.github/workflows/web.yml
@@ -26,11 +26,11 @@ jobs:
     - name: 'Check Out 📗'
     - name: 'Hugo Build 🛠'
       # ...or replace 'master' with a full version tag, such as: v0.64.1
-      uses: jakejarvis/hugo-build-action at v0.88.1
+      uses: jakejarvis/hugo-build-action at v0.111.3
       with:
         args: --source web --destination public --verbose
@@ -50,7 +50,7 @@ jobs:
         cp -ra build.cmake/doxygen/doxygen_docs/html/* public_html/doxygen
     - name: 'Deploy 🚀'
-      uses: JamesIves/github-pages-deploy-action at 4.1.5
+      uses: JamesIves/github-pages-deploy-action at v4
       with:
         branch: gh-pages           # The branch the action should deploy to.
         folder: public_html    # The folder the action should depl y.
Summary of changes:
 .github/workflows/ci.yml        | 12 ++++++------
 .github/workflows/container.yml |  8 ++++----
 .github/workflows/release.yml   |  4 ++--
 .github/workflows/web.yml       |  6 +++---
 4 files changed, 15 insertions(+), 15 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
