[geos-commits] [SCM] GEOS branch main updated. efa5d0ff93d7a49a135b3ad9816247f01efe9b47
git at osgeo.org
git at osgeo.org
Mon Mar 30 06:26:24 PDT 2026
the project "GEOS".
The branch, main has been updated
via efa5d0ff93d7a49a135b3ad9816247f01efe9b47 (commit)
from ab9c66697bbbead12c8519c8b2e331394ae99c33 (commit)
revisions in full, below.
commit efa5d0ff93d7a49a135b3ad9816247f01efe9b47
Author: Even Rouault <even.rouault at spatialys.com>
Date: Mon Mar 30 15:25:52 2026 +0200
Doc of GEOSConcaveHullOfPolygons(): document isTight and isHolesAllowed… (#1415)
* Doc of GEOSConcaveHullOfPolygons(): document isTight and isHolesAllowed in the order where they are expected by the function
This will avoid confusion such as https://github.com/qgis/QGIS/pull/65596/changes#diff-ef1a3cc494a81e934d927d5e020f4bfe3acc1caddf7707d215db1981deaf8808R1955
inverting the order w.r.t GEOS
* Update capi/geos_c.h.in
Co-authored-by: Andrea Giudiceandrea <andreaerdna at libero.it>
Co-authored-by: Dan Baston <dbaston at gmail.com>
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index 4637c5ab4..1116b0024 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -3359,9 +3359,9 @@ extern char GEOS_DLL GEOSHasM(const GEOSGeometry* g);
* A closed geometry is either:
* - a non-empty LineString, CircularString, or CompoundCurve whose
* start and end points having the same XY values; or
-* - a non-empty MultiLineString or MultiCurve whose elements are
+* - a non-empty MultiLineString or MultiCurve whose elements are
* all closed.
* Z and M values are not considered.
* \param g The geometry to test
@@ -3635,7 +3635,7 @@ extern GEOSGeometry GEOS_DLL *GEOSMinimumClearanceLine(const GEOSGeometry* g);
* result in an invalid geometry being returned. Be sure
* to check and repair validity.
-* Z and M coordinate values are preserved but are not considered when
+* Z and M coordinate values are preserved but are not considered when
* determining if a point is repeated.
* \return A geometry with all points within the tolerance of each other removed.
@@ -4387,7 +4387,7 @@ extern void GEOS_DLL GEOSClusterInfo_destroy(GEOSClusterInfo* clusters);
* Buffer a geometry.
* The coordinates of the constructed geometry will not have Z or M values.
* \param g The input geometry to be buffered.
* \param width The distance by which to expand the geometry (or contract)
* if the value is negative.
@@ -4501,7 +4501,7 @@ extern GEOSGeometry GEOS_DLL *GEOSBufferWithParams(
* Generate a buffer using the provided style parameters.
* \param g The geometry to buffer
* \param width Width of the buffer
* \param quadsegs Number of segments per quadrant
@@ -4918,8 +4918,8 @@ extern GEOSGeometry GEOS_DLL *GEOSConcaveHullByLength(
* This normalizes the Maximum Edge Length to be scale-free.
* A value of 1 produces the convex hull; a value of 0 produces
* the original polygons.
+* \param isTight does the hull follow the outer boundaries of the input polygons?
* \param isHolesAllowed is the concave hull allowed to contain holes?
-* \param isTight does the hull follow the outer boundaries of the input polygons.
* \return A newly allocated geometry of the concave hull. NULL on exception.
* Caller is responsible for freeing with GEOSGeom_destroy().
@@ -5184,7 +5184,7 @@ enum GEOSVoronoiFlags
-* Returns the 2D Voronoi polygons or edges computed from the vertices
+* Returns the 2D Voronoi polygons or edges computed from the vertices
* of the given geometry.
* \param g the input geometry whose vertices will be used as sites.
Summary of changes:
capi/geos_c.h.in | 14 +++++++-------
1 file changed, 7 insertions(+), 7 deletions(-)
hooks/post-receive
More information about the geos-commits
