[geos-commits] [SCM] GEOS branch main updated. 2841a0dc9c1931f4ca78701476c87b8cd3f41b58
git at osgeo.org
git at osgeo.org
Tue Mar 31 09:27:38 PDT 2026
the project "GEOS".
The branch, main has been updated
via 2841a0dc9c1931f4ca78701476c87b8cd3f41b58 (commit)
via 38c0f66df4b3c029add23d701cacd72cf08044e5 (commit)
from efa5d0ff93d7a49a135b3ad9816247f01efe9b47 (commit)
revisions in full, below.
commit 2841a0dc9c1931f4ca78701476c87b8cd3f41b58
Author: Daniel Baston <dbaston at gmail.com>
Date: Fri Mar 27 11:31:31 2026 -0400
geos_unit: avoid checking isValid / isSimple on curves
diff --git a/tests/unit/utility.h b/tests/unit/utility.h
index a9003be56..a4f522831 100644
--- a/tests/unit/utility.h
+++ b/tests/unit/utility.h
@@ -227,18 +227,20 @@ ensure_equals_geometry(T const* lhs_in, T const* rhs_in, double tolerance = 0.0)
lhs->normalize();
rhs->normalize();
- ensure_equals("is-valid do not match",
- lhs->isValid(), rhs->isValid());
+ if (!lhs->hasCurvedComponents() && !rhs->hasCurvedComponents()) {
+ if(!isInstanceOf<GeometryCollection>(lhs.get()) &&
+ !isInstanceOf<GeometryCollection>(rhs.get())) {
+ ensure_equals("is-simple do not match",
+ lhs->isSimple(), rhs->isSimple());
+ ensure_equals("is-valid do not match",
+ lhs->isValid(), rhs->isValid());
ensure_equals("is-empty do not match",
lhs->isEmpty(), rhs->isEmpty());
- if(!isInstanceOf<GeometryCollection>(lhs.get()) &&
- !isInstanceOf<GeometryCollection>(rhs.get())) {
- ensure_equals("is-simple do not match",
- lhs->isSimple(), rhs->isSimple());
ensure_equals("type do not match",
lhs->getGeometryType(), rhs->getGeometryType());
commit 38c0f66df4b3c029add23d701cacd72cf08044e5
Date: Fri Mar 27 11:30:58 2026 -0400
Surface: add clone()
diff --git a/include/geos/geom/Surface.h b/include/geos/geom/Surface.h
index 35e0d9cf1..d2e401f36 100644
--- a/include/geos/geom/Surface.h
+++ b/include/geos/geom/Surface.h
@@ -49,6 +49,8 @@ public:
void apply_rw(const CoordinateFilter* filter) override;
+ std::unique_ptr<Surface> clone() const;
std::unique_ptr<Geometry> convexHull() const override;
bool
diff --git a/src/geom/Surface.cpp b/src/geom/Surface.cpp
index 9a5d66277..37a41386b 100644
--- a/src/geom/Surface.cpp
+++ b/src/geom/Surface.cpp
@@ -101,6 +101,12 @@ Surface::apply_rw(GeometryFilter* filter)
filter->filter_rw(this);
+std::unique_ptr<Surface>
+Surface::clone() const
+ return std::unique_ptr<Surface>(detail::down_cast<Surface*>(cloneImpl()));
int
Surface::compareToSameClass(const Geometry* g) const
Summary of changes:
include/geos/geom/Surface.h | 2 ++
src/geom/Surface.cpp | 6 ++++++
tests/unit/utility.h | 18 ++++++++++--------
3 files changed, 18 insertions(+), 8 deletions(-)
hooks/post-receive
More information about the geos-commits
