[geos-commits] [SCM] GEOS branch main updated. 7ce71942d882ca8ed301181d03d4b31177c340d0
git at osgeo.org
git at osgeo.org
Mon May 4 05:43:29 PDT 2026
the project "GEOS".
The branch, main has been updated
via 7ce71942d882ca8ed301181d03d4b31177c340d0 (commit)
via b06377c2680f9ab4cef6f9d4bcaf0301e9e1bf59 (commit)
from 5ae8f7c6499b41e650e389a1c9eb2a81025b252c (commit)
revisions in full, below.
commit 7ce71942d882ca8ed301181d03d4b31177c340d0
Author: Daniel Baston <dbaston at gmail.com>
Date: Fri May 1 16:41:22 2026 -0400
DistanceToPoint: Set dllexport
diff --git a/include/geos/algorithm/distance/DistanceToPoint.h b/include/geos/algorithm/distance/DistanceToPoint.h
index 108b85506..10f280ade 100644
--- a/include/geos/algorithm/distance/DistanceToPoint.h
+++ b/include/geos/algorithm/distance/DistanceToPoint.h
@@ -18,6 +18,7 @@
#pragma once
+#include <geos/export.h>
#include <geos/geom/LineSegment.h> // for composition
namespace geos {
@@ -43,7 +44,7 @@ namespace distance { // geos::algorithm::distance
* Also computes two points which are separated by the distance.
-class DistanceToPoint {
+class GEOS_DLL DistanceToPoint {
public:
DistanceToPoint() {}
commit b06377c2680f9ab4cef6f9d4bcaf0301e9e1bf59
Date: Fri May 1 16:32:44 2026 -0400
Avoid -Warray-bounds warning on gcc 16
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index 5568b7731..a1be8e65b 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -1885,6 +1885,10 @@ extern "C" {
GEOSGridIntersectionFractions_r(GEOSContextHandle_t extHandle, const Geometry* g, double xmin, double ymin,
double xmax, double ymax, unsigned nx, unsigned ny, float* buf)
+#ifdef __GNUC__
+#pragma GCC diagnostic push
+#pragma GCC diagnostic ignored "-Warray-bounds"
+#endif
return execute(extHandle, 0, [&]() {
Envelope env(xmin, xmax, ymin, ymax);
double dx = env.getWidth() / static_cast<double>(nx);
@@ -1900,6 +1904,9 @@ extern "C" {
return 1;
+#ifdef __GNUC__
+#pragma GCC diagnostic pop
+#endif
Geometry*
Summary of changes:
capi/geos_ts_c.cpp | 7 +++++++
include/geos/algorithm/distance/DistanceToPoint.h | 3 ++-
2 files changed, 9 insertions(+), 1 deletion(-)
hooks/post-receive
More information about the geos-commits
