[geos-commits] [SCM] GEOS branch main updated. 0028dd486e18abb779d3c1d1dfeb1a3f34e4af5c
git at osgeo.org
git at osgeo.org
Mon May 4 12:11:41 PDT 2026
the project "GEOS".
The branch, main has been updated
via 0028dd486e18abb779d3c1d1dfeb1a3f34e4af5c (commit)
from 7ce71942d882ca8ed301181d03d4b31177c340d0 (commit)
revisions in full, below.
commit 0028dd486e18abb779d3c1d1dfeb1a3f34e4af5c
Author: Daniel Baston <dbaston at gmail.com>
Date: Mon May 4 15:11:19 2026 -0400
GeometrySplitter: Support splitting CompoundCurve and CircularString at point (#1433)
diff --git a/include/geos/algorithm/CircularArcs.h b/include/geos/algorithm/CircularArcs.h
index d8793d561..a32a197cb 100644
--- a/include/geos/algorithm/CircularArcs.h
+++ b/include/geos/algorithm/CircularArcs.h
@@ -16,11 +16,17 @@
#include <geos/export.h>
#include <geos/geom/Coordinate.h>
-#include <geos/geom/Envelope.h>
#include <array>
#include <optional>
+namespace geos {
+namespace geom {
+class CoordinateSequence;
+class Envelope;
namespace geos {
namespace algorithm {
@@ -46,6 +52,19 @@ public:
/// Return the point defined by a circle center, radius, and angle
static geom::CoordinateXY createPoint(const geom::CoordinateXY& center, double radius, double theta);
+ /** Interpolate Z/M values for a point added to an arc.
+ * @param seq CoordinateSequence containing the arc points
+ * @param i0 Index of the first point in the arc
+ * @param center The center point of the circle defining the arc
+ * @param isCCW Whether the arc is counterclockwise
+ * @param pt The point to interpolate Z/M values for
+ * @param z The interpolated Z value
+ * @param m The interpolated M value
+ static void interpolateZM(const geom::CoordinateSequence &seq, size_t i0, const geom::CoordinateXY ¢er, bool isCCW, geom::CoordinateXY &pt, double
+ &z, double &m);
/** Determines whether and where a circle intersects a line segment.
diff --git a/include/geos/geom/SimpleCurve.h b/include/geos/geom/SimpleCurve.h
index da24b0125..777ff27a7 100644
--- a/include/geos/geom/SimpleCurve.h
+++ b/include/geos/geom/SimpleCurve.h
@@ -101,6 +101,8 @@ public:
bool isEmpty() const override;
+ std::unique_ptr<SimpleCurve> clone() const;
std::unique_ptr<SimpleCurve> reverse() const;
protected:
diff --git a/include/geos/operation/split/GeometrySplitter.h b/include/geos/operation/split/GeometrySplitter.h
index 7511940a8..08ee641c9 100644
--- a/include/geos/operation/split/GeometrySplitter.h
+++ b/include/geos/operation/split/GeometrySplitter.h
@@ -18,8 +18,8 @@
#include <memory>
namespace geos::geom {
+class Curve;
class Geometry;
-class LineString;
class Point;
@@ -51,12 +51,14 @@ private:
splitPolygonalWithEdge(const geom::Geometry& geom, const geom::Geometry& edge);
static std::unique_ptr<geom::Geometry>
- splitLineWithPoint(const geom::LineString& g, const geom::Point& point);
+ splitCurveWithPoint(const geom::Curve& g, const geom::Point& point);
splitAtPoints(const geom::Geometry& geom, const geom::Geometry& splitPoints);
class SplitWithPointTransformer;
+ static constexpr double POINT_TO_LINE_TOLERANCE = 1e-10;
diff --git a/include/geos/operation/split/SplitGeometryAtVertex.h b/include/geos/operation/split/SplitGeometryAtVertex.h
deleted file mode 100644
index 37c331cb9..000000000
--- a/include/geos/operation/split/SplitGeometryAtVertex.h
+++ /dev/null
@@ -1,48 +0,0 @@
- * GEOS - Geometry Engine Open Source
- * http://geos.osgeo.org
- * Copyright (C) 2026 ISciences, LLC
- * This is free software; you can redistribute and/or modify it under
- * the terms of the GNU Lesser General Public Licence as published
- * by the Free Software Foundation.
- * See the COPYING file for more information.
-#pragma once
-#include <geos/export.h>
-#include <memory>
-#include <utility>
-// Forward declarations
-namespace geos::geom {
-class CircularString;
-class CoordinateXY;
-class LineString;
-class SimpleCurve;
-namespace geos::operation::split {
-class GEOS_DLL SplitGeometryAtVertex {
-public:
- static std::pair<std::unique_ptr<geom::SimpleCurve>, std::unique_ptr<geom::SimpleCurve>>
- splitSimpleCurveAtVertex(const geom::SimpleCurve& sc, std::size_t i);
- static std::pair<std::unique_ptr<geom::LineString>, std::unique_ptr<geom::LineString>>
- splitLineStringAtVertex(const geom::LineString& ls, std::size_t i);
- static std::pair<std::unique_ptr<geom::CircularString>, std::unique_ptr<geom::CircularString>>
- splitCircularStringAtVertex(const geom::CircularString& cs, std::size_t i);
- splitLineStringAtPoint(const geom::LineString& ls, std::size_t i, const geom::CoordinateXY& pt);
diff --git a/include/geos/operation/split/SplitLinealAtPoint.h b/include/geos/operation/split/SplitLinealAtPoint.h
new file mode 100644
index 000000000..a5e1be445
--- /dev/null
+++ b/include/geos/operation/split/SplitLinealAtPoint.h
@@ -0,0 +1,90 @@
+ * GEOS - Geometry Engine Open Source
+ * http://geos.osgeo.org
+ * Copyright (C) 2026 ISciences, LLC
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+#pragma once
+#include <geos/export.h>
+#include <memory>
+#include <utility>
+// Forward declarations
+namespace geos::geom {
+class CircularString;
+class CompoundCurve;
+class CoordinateXY;
+class Curve;
+class LineString;
+class SimpleCurve;
+namespace geos::operation::split {
+class GEOS_DLL SplitLinealAtPoint {
+public:
+ /** Split a curve into two sections at a specified vertex.
+ * If the vertex is the first or last vertex of the geometry, one of the returned
+ * geometries will be empty.
+ * If the input geometry is a CircularString, the vertex must be an endpoint of an arc.
+ * @param sc the curve to split
+ * @param i the index of the vertex to split at.
+ * @return a pair of split geometries.
+ static std::pair<std::unique_ptr<geom::SimpleCurve>, std::unique_ptr<geom::SimpleCurve>>
+ splitSimpleCurveAtVertex(const geom::SimpleCurve& sc, std::size_t i);
+ /** Split a SimpleCurve into two sections at an arbitrary point.
+ * @param i the index of the vertex of the section (segment or arc) that contains pt
+ * @param pt the splitting point
+ splitSimpleCurveAtPoint(const geom::SimpleCurve &sc, std::size_t i, const geom::CoordinateXY &pt);
+ /** Split a CompoundCurve into two sections at an arbitrary point.
+ * @param i the component that contains the splitting vertex
+ * @param j the index of the vertex of the section (segment or arc) that contains pt
+ static std::pair<std::unique_ptr<geom::Curve>, std::unique_ptr<geom::Curve>>
+ splitCompoundCurveAtPoint(const geom::CompoundCurve &sc, std::size_t i, std::size_t j, const geom::CoordinateXY &pt);
+ /** Split a CircularString into two sections at an arbitrary point. */
+ static std::pair<std::unique_ptr<geom::CircularString>, std::unique_ptr<geom::CircularString>>
+ splitCircularStringAtPoint(const geom::CircularString &ls, std::size_t i, const geom::CoordinateXY &pt);
+ /** Split CircularString into two sections at vertex i.
+ * The vertex must be an endpoint of an arc. */
+ splitCircularStringAtVertex(const geom::CircularString &cs, std::size_t i);
+ /** Split a LineString into two sections at an arbitrary point. */
+ static std::pair<std::unique_ptr<geom::LineString>, std::unique_ptr<geom::LineString>>
+ splitLineStringAtPoint(const geom::LineString &ls, std::size_t i, const geom::CoordinateXY &pt);
+ /** Split LineString into two sections at vertex i */
+ splitLineStringAtVertex(const geom::LineString &ls, std::size_t i);
diff --git a/include/geos/util/Assert.h b/include/geos/util/Assert.h
index 275de021e..06acf1bb5 100644
--- a/include/geos/util/Assert.h
+++ b/include/geos/util/Assert.h
@@ -39,6 +39,13 @@ public:
isTrue(assertion, std::string());
+ template<typename T>
+ static void
+ isNotNull(const T& ptr, const std::string& message)
+ isTrue(ptr != nullptr, message);
static void equals(const geom::CoordinateXY& expectedValue,
const geom::CoordinateXY& actualValue,
diff --git a/src/algorithm/CircularArcIntersector.cpp b/src/algorithm/CircularArcIntersector.cpp
index 31a6eea7c..b5e6adcc3 100644
--- a/src/algorithm/CircularArcIntersector.cpp
+++ b/src/algorithm/CircularArcIntersector.cpp
@@ -25,109 +25,6 @@ using geos::geom::CircularArc;
namespace geos::algorithm {
-static double
-interpolateValue(double a1, double a2, double frac)
- frac = std::clamp(frac, 0.0, 1.0);
- if (std::isnan(a1)) {
- return a2;
- if (std::isnan(a2)) {
- return a1;
- return a1 + frac * (a2 - a1);
-static void
-interpolateZM(const CircularArc& arc, const CoordinateXY& pt, double& z, double& m)
- using geom::Ordinate;
- const CoordinateSequence& seq = *arc.getCoordinateSequence();
- std::size_t i0 = arc.getCoordinatePosition();
- // Read Z, M from control point
- double z1, m1;
- seq.applyAt(i0 + 1, [&z1, &m1](const auto& arcPt) {
- z1 = arcPt.template get<Ordinate::Z>();
- m1 = arcPt.template get<Ordinate::M>();
- // Test point = control point?
- // Take Z, M from the control point
- if (arc.p1().equals2D(pt)) {
- z = z1;
- m = m1;
- return;
- // Read Z, M from start point
- double z0, m0;
- seq.applyAt(i0, [&z0, &m0](const auto& arcPt) {
- z0 = arcPt.template get<Ordinate::Z>();
- m0 = arcPt.template get<Ordinate::M>();
- // Test point = start point?
- // Take Z, M from the start point
- if (arc.p0().equals2D(pt)) {
- z = z0;
- m = m0;
- return;
- // Read Z, M from end point
- double z2, m2;
- seq.applyAt(i0 + 2, [&z2, &m2](const auto& arcPt) {
- z2 = arcPt.template get<Ordinate::Z>();
- m2 = arcPt.template get<Ordinate::M>();
- // Test point = end point?
- // Take Z, M from the end point
- if (arc.p2().equals2D(pt)) {
- z = z2;
- m = m2;
- return;
- double theta0 = arc.theta0();
- const double theta1 = arc.theta1();
- double theta2 = arc.theta2();
- const double theta = CircularArcs::getAngle(pt, arc.getCenter());
- if (!arc.isCCW()) {
- std::swap(theta0, theta2);
- std::swap(z0, z2);
- std::swap(m0, m2);
- if (std::isnan(z1)) {
- // Interpolate between p0 / p2
- const double frac = Angle::fractionCCW(theta, theta0, theta2);
- z = interpolateValue(z0, z2, frac);
- } else if (Angle::isWithinCCW(theta, theta0, theta1)) {
- // Interpolate between p0 / p1
- const double frac = Angle::fractionCCW(theta, theta0, theta1);
- z = interpolateValue(z0, z1, frac);
- } else {
- // Interpolate between p1 / p2
- const double frac = Angle::fractionCCW(theta, theta1, theta2);
- z = interpolateValue(z1, z2, frac);
- if (std::isnan(m1)) {
- m = interpolateValue(m0, m2, frac);
- m = interpolateValue(m0, m1, frac);
- } else {
- m = interpolateValue(m1, m2, frac);
// Interpolate the Z/M values of a point lying on the provided line segment
static void
@@ -155,8 +52,8 @@ interpolateZM(const CircularArc& arc0, const CircularArc& arc1, geom::Coordinate
double z0, m0;
double z1, m1;
- interpolateZM(arc0, pt, z0, m0);
- interpolateZM(arc1, pt, z1, m1);
+ CircularArcs::interpolateZM(*arc0.getCoordinateSequence(), arc0.getCoordinatePosition(), arc0.getCenter(), arc0.isCCW(), pt, z0, m0);
+ CircularArcs::interpolateZM(*arc1.getCoordinateSequence(), arc1.getCoordinatePosition(), arc1.getCenter(), arc1.isCCW(), pt, z1, m1);
if (std::isnan(pt.z)) {
pt.z = Interpolate::getOrAverage(z0, z1);
@@ -179,7 +76,7 @@ interpolateZM(const CircularArc& arc0,
double z0, m0;
double z1, m1;
interpolateSegmentZM(seq, ind0, ind1, pt, z1, m1);
@@ -191,7 +88,6 @@ interpolateZM(const CircularArc& arc0,
bool
CircularArcIntersector::hasIntersection(const geom::CoordinateXY &p) const {
switch (nPt) {
diff --git a/src/algorithm/CircularArcs.cpp b/src/algorithm/CircularArcs.cpp
index ee28c96c4..eeb779e2b 100644
--- a/src/algorithm/CircularArcs.cpp
+++ b/src/algorithm/CircularArcs.cpp
@@ -20,6 +20,7 @@
#include <geos/geom/Quadrant.h>
#include <geos/math/DD.h>
+using geos::geom::CoordinateSequence;
using geos::geom::CoordinateXY;
using geos::geom::Envelope;
using geos::geom::LineSegment;
@@ -75,6 +76,112 @@ CircularArcs::createPoint(const CoordinateXY& center, double radius, double thet
return { center.x + radius* std::cos(theta), center.y + radius* std::sin(theta) };
+static double
+interpolateValue(double a1, double a2, double frac)
+ frac = std::clamp(frac, 0.0, 1.0);
+ if (std::isnan(a1)) {
+ return a2;
+ if (std::isnan(a2)) {
+ return a1;
+ return a1 + frac * (a2 - a1);
+void
+CircularArcs::interpolateZM(const CoordinateSequence& seq, std::size_t i0,
+ const CoordinateXY ¢er, bool isCCW,
+ CoordinateXY &pt, double &z, double &m)
+ using geom::Ordinate;
+ const CoordinateXY& p0 = seq.getAt<CoordinateXY>(i0);
+ const CoordinateXY& p1 = seq.getAt<CoordinateXY>(i0 + 1);
+ const CoordinateXY& p2 = seq.getAt<CoordinateXY>(i0 + 2);
+ // Read Z, M from control point
+ double z1, m1;
+ seq.applyAt(i0 + 1, [&z1, &m1](const auto& arcPt) {
+ z1 = arcPt.template get<Ordinate::Z>();
+ m1 = arcPt.template get<Ordinate::M>();
+ // Test point = control point?
+ // Take Z, M from the control point
+ if (p1.equals2D(pt)) {
+ z = z1;
+ m = m1;
+ return;
+ // Read Z, M from start point
+ double z0, m0;
+ seq.applyAt(i0, [&z0, &m0](const auto& arcPt) {
+ z0 = arcPt.template get<Ordinate::Z>();
+ m0 = arcPt.template get<Ordinate::M>();
+ // Test point = start point?
+ // Take Z, M from the start point
+ if (p0.equals2D(pt)) {
+ z = z0;
+ m = m0;
+ return;
+ // Read Z, M from end point
+ double z2, m2;
+ seq.applyAt(i0 + 2, [&z2, &m2](const auto& arcPt) {
+ z2 = arcPt.template get<Ordinate::Z>();
+ m2 = arcPt.template get<Ordinate::M>();
+ // Test point = end point?
+ // Take Z, M from the end point
+ if (p2.equals2D(pt)) {
+ z = z2;
+ m = m2;
+ return;
+ double theta0 = getAngle(p0, center);
+ const double theta1 = getAngle(p1, center);
+ double theta2 = getAngle(p2, center);
+ const double theta = getAngle(pt, center);
+ if (!isCCW) {
+ std::swap(theta0, theta2);
+ std::swap(z0, z2);
+ std::swap(m0, m2);
+ if (std::isnan(z1)) {
+ // Interpolate between p0 / p2
+ const double frac = Angle::fractionCCW(theta, theta0, theta2);
+ z = interpolateValue(z0, z2, frac);
+ } else if (Angle::isWithinCCW(theta, theta0, theta1)) {
+ // Interpolate between p0 / p1
+ const double frac = Angle::fractionCCW(theta, theta0, theta1);
+ z = interpolateValue(z0, z1, frac);
+ } else {
+ // Interpolate between p1 / p2
+ const double frac = Angle::fractionCCW(theta, theta1, theta2);
+ z = interpolateValue(z1, z2, frac);
+ if (std::isnan(m1)) {
+ m = interpolateValue(m0, m2, frac);
+ m = interpolateValue(m0, m1, frac);
+ } else {
+ m = interpolateValue(m1, m2, frac);
CoordinateXY getCenterImpl(const CoordinateXY& p0, const CoordinateXY& p1, const CoordinateXY& p2)
diff --git a/src/geom/CircularArc.cpp b/src/geom/CircularArc.cpp
index 7dfcbbf34..dd5a56d85 100644
--- a/src/geom/CircularArc.cpp
+++ b/src/geom/CircularArc.cpp
@@ -14,6 +14,7 @@
#include <geos/algorithm/CircularArcs.h>
#include <geos/geom/CircularArc.h>
+#include <geos/geom/Envelope.h>
#include <geos/triangulate/quadedge/TrianglePredicate.h>
#include <sstream>
diff --git a/src/geom/CompoundCurve.cpp b/src/geom/CompoundCurve.cpp
index 70916aa9c..26f8d450f 100644
--- a/src/geom/CompoundCurve.cpp
+++ b/src/geom/CompoundCurve.cpp
@@ -20,7 +20,7 @@
#include <geos/geom/CircularString.h>
#include <geos/geom/GeometryFactory.h>
#include <geos/operation/BoundaryOp.h>
-#include <geos/operation/split/SplitGeometryAtVertex.h>
+#include <geos/operation/split/SplitLinealAtPoint.h>
#include <geos/util.h>
namespace geos {
@@ -379,7 +379,7 @@ CompoundCurve::normalizeClosed()
} else if (minInd == curves[minCurve]->getNumPoints() - 1) {
finalCurve = std::move(curves[minCurve]);
} else {
- auto split = operation::split::SplitGeometryAtVertex::splitSimpleCurveAtVertex(*curves[minCurve], minInd);
+ auto split = operation::split::SplitLinealAtPoint::splitSimpleCurveAtVertex(*curves[minCurve], minInd);
newCurves.push_back(std::move(split.second));
finalCurve = std::move(split.first);
diff --git a/src/geom/SimpleCurve.cpp b/src/geom/SimpleCurve.cpp
index 40fbf460b..14ff8e39a 100644
--- a/src/geom/SimpleCurve.cpp
+++ b/src/geom/SimpleCurve.cpp
@@ -330,6 +330,12 @@ SimpleCurve::isEmpty() const
return points->isEmpty();
+std::unique_ptr<SimpleCurve>
+SimpleCurve::clone() const
+ return std::unique_ptr<SimpleCurve>(static_cast<SimpleCurve*>(cloneImpl()));
SimpleCurve::reverse() const
diff --git a/src/noding/NodableArcString.cpp b/src/noding/NodableArcString.cpp
index 488293ac3..d16acafd5 100644
--- a/src/noding/NodableArcString.cpp
+++ b/src/noding/NodableArcString.cpp
@@ -15,6 +15,8 @@
#include <geos/noding/NodableArcString.h>
#include <geos/algorithm/Angle.h>
+#include <algorithm>
using geos::geom::CoordinateXYZM;
diff --git a/src/operation/split/GeometrySplitter.cpp b/src/operation/split/GeometrySplitter.cpp
index 41cac82ce..a795d9f4f 100644
--- a/src/operation/split/GeometrySplitter.cpp
+++ b/src/operation/split/GeometrySplitter.cpp
@@ -15,6 +15,7 @@
#include <geos/operation/split/GeometrySplitter.h>
+#include <geos/geom/CompoundCurve.h>
#include <geos/geom/Geometry.h>
#include <geos/geom/GeometryCollection.h>
@@ -31,11 +32,13 @@
#include <geos/operation/distance/DistanceOp.h>
#include <geos/operation/distance/GeometryLocation.h>
#include <geos/operation/polygonize/Polygonizer.h>
#include <geos/shape/random/RandomPointsBuilder.h>
+#include <geos/util/Assert.h>
using geos::geom::CircularString;
+using geos::geom::CompoundCurve;
using geos::geom::Curve;
using geos::geom::CurvePolygon;
using geos::geom::Geometry;
@@ -45,6 +48,7 @@ using geos::geom::LineString;
using geos::geom::MultiLineString;
using geos::geom::MultiPoint;
using geos::geom::Polygon;
+using geos::geom::SimpleCurve;
using geos::geom::prep::PreparedGeometryFactory;
using geos::geom::util::GeometryCombiner;
using geos::geom::util::GeometryTransformer;
@@ -59,20 +63,27 @@ using geos::shape::random::RandomPointsBuilder;
-class GeometrySplitter::SplitWithPointTransformer : public geom::util::GeometryTransformer {
+class GeometrySplitter::SplitWithPointTransformer : public GeometryTransformer {
public:
- SplitWithPointTransformer(const Point& pt) : m_pt(pt) {}
+ explicit SplitWithPointTransformer(const Point& pt) : m_pt(pt) {}
+protected:
+ std::unique_ptr<Geometry>
+ transformCircularString(const CircularString* geom, const Geometry* /*parent*/) override
+ return splitCurveWithPoint(*geom, m_pt);
- transformCircularString(const CircularString*, const Geometry* /*parent*/) override
+ transformCompoundCurve(const CompoundCurve* geom, const Geometry* /*parent*/) override
- throw geos::util::UnsupportedOperationException("Splitting a CircularString with a point is not supported.");
transformLineString(const LineString* geom, const Geometry* /*parent*/) override
- return GeometrySplitter::splitLineWithPoint(*geom, m_pt);
@@ -210,11 +221,10 @@ GeometrySplitter::split(const Geometry &geom, const Geometry &splitGeom)
return splitLinealWithEdge(*toSplit, splitGeom);
-std::unique_ptr<Geometry>
-GeometrySplitter::splitLineWithPoint(const geom::LineString& g, const Point& point)
- constexpr double tolerance = 1e-10;
+std::unique_ptr<Geometry>
+GeometrySplitter::splitCurveWithPoint(const Curve& g, const Point& point)
if (g.isEmpty()) {
std::vector<std::unique_ptr<Geometry>> geoms;
geoms.push_back(g.clone());
@@ -223,7 +233,7 @@ GeometrySplitter::splitLineWithPoint(const geom::LineString& g, const Point& poi
DistanceOp distance(g, point);
- if (distance.distance() > tolerance) {
+ if (distance.distance() > POINT_TO_LINE_TOLERANCE) {
return g.getFactory()->createGeometryCollection(std::move(geoms));
@@ -231,22 +241,26 @@ GeometrySplitter::splitLineWithPoint(const geom::LineString& g, const Point& poi
const auto& nearestLoc = distance.nearestLocations()[0];
- const auto* seq = detail::down_cast<const LineString*>(nearestLoc.getGeometryComponent())->getCoordinatesRO();
+ std::pair<std::unique_ptr<Curve>, std::unique_ptr<Curve>> split;
+ if (g.getGeometryTypeId() == geom::GEOS_COMPOUNDCURVE) {
+ const CompoundCurve& cc = static_cast<const CompoundCurve&>(g);
- const CoordinateXY& p0 = seq->getAt<CoordinateXY>(nearestLoc.getSegmentIndex());
- const CoordinateXY& p1 = seq->getAt<CoordinateXY>(nearestLoc.getSegmentIndex() + 1);
+ for (std::size_t i = 0 ; i < cc.getNumCurves(); i++) {
+ const auto* sc = cc.getCurveN(i);
- std::pair<std::unique_ptr<LineString>, std::unique_ptr<LineString>> split;
- if (nearestLoc.getCoordinate().equals2D(p0)) {
- // no need to add a new point
- split = SplitGeometryAtVertex::splitLineStringAtVertex(static_cast<const LineString&>(g), nearestLoc.getSegmentIndex());
- } else if (nearestLoc.getCoordinate().equals2D(p1)) {
- split = SplitGeometryAtVertex::splitLineStringAtVertex(static_cast<const LineString&>(g), nearestLoc.getSegmentIndex() + 1);
+ if (sc == nearestLoc.getGeometryComponent()) {
+ split = SplitLinealAtPoint::splitCompoundCurveAtPoint(cc, i, nearestLoc.getSegmentIndex(), nearestLoc.getCoordinate());
+ break;
} else {
- split = SplitGeometryAtVertex::splitLineStringAtPoint(static_cast<const LineString&>(g), nearestLoc.getSegmentIndex(), nearestLoc.getCoordinate());
+ const SimpleCurve& sc = static_cast<const SimpleCurve&>(g);
+ split = SplitLinealAtPoint::splitSimpleCurveAtPoint(sc, nearestLoc.getSegmentIndex(), nearestLoc.getCoordinate());
+ util::Assert::isNotNull(split.first, "Split result first curve should not be null");
+ util::Assert::isNotNull(split.second, "Split result second curve should not be null");
if (!split.first->isEmpty()) {
geoms.push_back(std::move(split.first));
diff --git a/src/operation/split/SplitGeometryAtVertex.cpp b/src/operation/split/SplitGeometryAtVertex.cpp
index 512e6f009..000000000
--- a/src/operation/split/SplitGeometryAtVertex.cpp
+++ /dev/null
@@ -1,123 +0,0 @@
-#include <geos/algorithm/Interpolate.h>
-#include <geos/geom/LineString.h>
-#include <geos/geom/CircularString.h>
-#include <geos/geom/GeometryFactory.h>
-#include <geos/util/UnsupportedOperationException.h>
-using geos::geom::CoordinateSequence;
-using geos::geom::CoordinateXY;
-using geos::geom::CoordinateXYZM;
-using geos::geom::CircularString;
-using geos::geom::LineString;
-using geos::geom::SimpleCurve;
-using geos::geom::GeometryTypeId;
-std::pair<std::unique_ptr<LineString>, std::unique_ptr<LineString>>
-SplitGeometryAtVertex::splitLineStringAtPoint(const LineString& ls, std::size_t i, const CoordinateXY& pt)
- const auto& gf = *ls.getFactory();
- const CoordinateSequence& pts = *ls.getCoordinatesRO();
- if (i + 1 >= pts.size()) {
- throw util::IllegalArgumentException("Cannot split LineString at point beyond end");
- auto pts1 = std::make_shared<CoordinateSequence>(0, pts.hasZ(), pts.hasM());
- auto pts2 = std::make_shared<CoordinateSequence>(0, pts.hasZ(), pts.hasM());
- CoordinateXYZM ptZM(pt);
- if (pts.hasZ() || pts.hasM()) {
- CoordinateXYZM prev;
- CoordinateXYZM next;
- pts.getAt(i, prev);
- pts.getAt(i + 1, next);
- ptZM.z = algorithm::Interpolate::zGetOrInterpolate(pt, prev, next);
- ptZM.m = algorithm::Interpolate::mGetOrInterpolate(pt, prev, next);
- pts1->add(pts, 0, i);
- pts1->add(ptZM);
- if (i < pts.size() - 1) {
- pts2->add(ptZM);
- pts2->add(pts, i + 1, pts.size() - 1);
- return { gf.createLineString(pts1), gf.createLineString(pts2) };
-SplitGeometryAtVertex::splitLineStringAtVertex(const LineString& ls, std::size_t i)
- if (i > 0) {
- pts2->add(pts, i, pts.size() - 1);
-std::pair<std::unique_ptr<CircularString>, std::unique_ptr<CircularString>>
- SplitGeometryAtVertex::splitCircularStringAtVertex(const CircularString& cs, std::size_t i)
- const auto& gf = *cs.getFactory();
- const CoordinateSequence& pts = *cs.getCoordinatesRO();
- if (i % 2) {
- throw util::IllegalArgumentException("Cannot split CircularString at arc control point");
- if (i > 0) {
- return { gf.createCircularString(pts1), gf.createCircularString(pts2) };
-std::pair<std::unique_ptr<SimpleCurve>, std::unique_ptr<SimpleCurve>>
- SplitGeometryAtVertex::splitSimpleCurveAtVertex(const SimpleCurve& sc, std::size_t i)
- if (sc.getGeometryTypeId() == GeometryTypeId::GEOS_CIRCULARSTRING) {
- return splitCircularStringAtVertex(static_cast<const CircularString&>(sc), i);
- if (sc.getGeometryTypeId() == GeometryTypeId::GEOS_LINESTRING || sc.getGeometryTypeId() == GeometryTypeId::GEOS_LINEARRING) {
- return splitLineStringAtVertex(static_cast<const LineString&>(sc), i);
- throw util::UnsupportedOperationException("Unhandled type in SplitGeometryAtVertex::splitAtVertex");
\ No newline at end of file
diff --git a/src/operation/split/SplitLinealAtPoint.cpp b/src/operation/split/SplitLinealAtPoint.cpp
index 000000000..a3e230af7
--- /dev/null
+++ b/src/operation/split/SplitLinealAtPoint.cpp
@@ -0,0 +1,252 @@
+#include <geos/algorithm/CircularArcs.h>
+#include <geos/algorithm/Interpolate.h>
+#include <geos/geom/LineString.h>
+#include <geos/geom/CircularString.h>
+#include <geos/geom/GeometryFactory.h>
+#include <geos/util/UnsupportedOperationException.h>
+using geos::algorithm::CircularArcs;
+using geos::geom::CircularArc;
+using geos::geom::CircularString;
+using geos::geom::CoordinateXY;
+using geos::geom::CoordinateXYZM;
+using geos::geom::Curve;
+using geos::geom::Geometry;
+using geos::geom::GeometryTypeId;
+using geos::geom::LineString;
+std::pair<std::unique_ptr<LineString>, std::unique_ptr<LineString>>
+SplitLinealAtPoint::splitLineStringAtPoint(const LineString& ls, std::size_t i, const CoordinateXY& pt)
+ const auto& gf = *ls.getFactory();
+ const CoordinateSequence& pts = *ls.getCoordinatesRO();
+ if (pt.equals2D(pts.getAt<CoordinateXY>(i))) {
+ return splitLineStringAtVertex(ls, i);
+ if (i + 1 >= pts.size()) {
+ throw util::IllegalArgumentException("Cannot split LineString at point beyond end");
+ if (pt.equals2D(pts.getAt<CoordinateXY>(i + 1))) {
+ return splitLineStringAtVertex(ls, i + 1);
+ auto pts1 = std::make_shared<CoordinateSequence>(0, pts.hasZ(), pts.hasM());
+ auto pts2 = std::make_shared<CoordinateSequence>(0, pts.hasZ(), pts.hasM());
+ CoordinateXYZM ptZM(pt);
+ if (pts.hasZ() || pts.hasM()) {
+ CoordinateXYZM prev;
+ CoordinateXYZM next;
+ pts.getAt(i, prev);
+ pts.getAt(i + 1, next);
+ ptZM.z = algorithm::Interpolate::zGetOrInterpolate(pt, prev, next);
+ ptZM.m = algorithm::Interpolate::mGetOrInterpolate(pt, prev, next);
+ pts1->add(pts, 0, i);
+ pts1->add(ptZM);
+ if (i < pts.size() - 1) {
+ pts2->add(ptZM);
+ pts2->add(pts, i + 1, pts.size() - 1);
+ return { gf.createLineString(pts1), gf.createLineString(pts2) };
+std::pair<std::unique_ptr<CircularString>, std::unique_ptr<CircularString>>
+SplitLinealAtPoint::splitCircularStringAtPoint(const CircularString& cs, std::size_t i, const CoordinateXY& pt)
+ const auto& gf = *cs.getFactory();
+ const CoordinateSequence& pts = *cs.getCoordinatesRO();
+ if (i % 2) {
+ throw util::IllegalArgumentException("Section index must be the start of an arc");
+ return splitCircularStringAtVertex(cs, i);
+ if (i + 2 >= pts.size()) {
+ throw util::IllegalArgumentException("Cannot split CircularString at arc beyond end");
+ const CircularArc arc(pts, i);
+ if (pt.equals2D(arc.p2())) {
+ return splitCircularStringAtVertex(cs, i + 2);
+ CoordinateXYZM splitPointZM(pt);
+ CircularArcs::interpolateZM(pts, i, arc.getCenter(), arc.isCCW(), splitPointZM, splitPointZM.z, splitPointZM.m);
+ CoordinateXYZM sec0Midpoint(CircularArcs::getMidpoint(pts.getAt<CoordinateXY>(i), splitPointZM, arc.getCenter(), arc.getRadius(), arc.isCCW()));
+ CircularArcs::interpolateZM(pts, i, arc.getCenter(), arc.isCCW(), sec0Midpoint, sec0Midpoint.z, sec0Midpoint.m);
+ pts1->add(sec0Midpoint);
+ pts1->add(splitPointZM);
+ CoordinateXYZM sec1Midpoint(CircularArcs::getMidpoint(splitPointZM, pts.getAt<CoordinateXY>(i + 2), arc.getCenter(), arc.getRadius(), arc.isCCW()));
+ CircularArcs::interpolateZM(pts, i, arc.getCenter(), arc.isCCW(), sec1Midpoint, sec1Midpoint.z, sec1Midpoint.m);
+ pts2->add(splitPointZM);
+ pts2->add(sec1Midpoint);
+ pts2->add(pts, i + 2, pts.size() - 1);
+ return { gf.createCircularString(pts1), gf.createCircularString(pts2) };
+SplitLinealAtPoint::splitLineStringAtVertex(const LineString& ls, std::size_t i)
+ if (i > 0) {
+ pts2->add(pts, i, pts.size() - 1);
+ SplitLinealAtPoint::splitCircularStringAtVertex(const CircularString& cs, std::size_t i)
+ if (i % 2) {
+ throw util::IllegalArgumentException("Cannot split CircularString at arc control point");
+ if (i > 0) {
+std::pair<std::unique_ptr<SimpleCurve>, std::unique_ptr<SimpleCurve>>
+ SplitLinealAtPoint::splitSimpleCurveAtVertex(const SimpleCurve& sc, std::size_t i)
+ if (sc.getGeometryTypeId() == GeometryTypeId::GEOS_CIRCULARSTRING) {
+ return splitCircularStringAtVertex(static_cast<const CircularString&>(sc), i);
+ if (sc.getGeometryTypeId() == GeometryTypeId::GEOS_LINESTRING || sc.getGeometryTypeId() == GeometryTypeId::GEOS_LINEARRING) {
+ return splitLineStringAtVertex(static_cast<const LineString&>(sc), i);
+ throw util::UnsupportedOperationException("Unhandled type in SplitLinealAtPoint::splitAtVertex");
+SplitLinealAtPoint::splitSimpleCurveAtPoint(const SimpleCurve& sc, std::size_t i, const CoordinateXY& pt)
+ return splitCircularStringAtPoint(static_cast<const CircularString&>(sc), i, pt);
+ return splitLineStringAtPoint(static_cast<const LineString&>(sc), i, pt);
+template<typename T>
+void removeEmptyGeometries(T& geoms) {
+ geoms.erase(std::remove_if(geoms.begin(), geoms.end(), [](const auto& curve) { return curve->isEmpty(); }), geoms.end());
+static std::unique_ptr<Curve>
+makeCurve(const geom::GeometryFactory& gfact, std::vector<std::unique_ptr<SimpleCurve>> curves)
+ if (curves.size() == 1) {
+ return std::move(curves[0]);
+ removeEmptyGeometries(curves);
+ return gfact.createCompoundCurve(std::move(curves));
+std::pair<std::unique_ptr<Curve>, std::unique_ptr<Curve>>
+SplitLinealAtPoint::splitCompoundCurveAtPoint(const CompoundCurve& cc, std::size_t component, std::size_t section, const CoordinateXY& pt)
+ const auto& gfact = *cc.getFactory();
+ std::vector<std::unique_ptr<SimpleCurve>> firstCurves;
+ std::vector<std::unique_ptr<SimpleCurve>> secondCurves;
+ for (std::size_t i = 0; i < cc.getNumCurves(); i++) {
+ if (i < component) {
+ firstCurves.push_back(sc->clone());
+ } else if (i == component) {
+ auto split = splitSimpleCurveAtPoint(*sc, section, pt);
+ firstCurves.push_back(std::move(split.first));
+ secondCurves.push_back(std::move(split.second));
+ } else {
+ secondCurves.push_back(sc->clone());
+ std::pair<std::unique_ptr<Curve>, std::unique_ptr<Curve>> result;
+ result.first = makeCurve(gfact, std::move(firstCurves));
+ result.second = makeCurve(gfact, std::move(secondCurves));
+ return result;
diff --git a/tests/unit/operation/split/GeometrySplitterTest.cpp b/tests/unit/operation/split/GeometrySplitterTest.cpp
index 15a53d964..988644c10 100644
--- a/tests/unit/operation/split/GeometrySplitterTest.cpp
+++ b/tests/unit/operation/split/GeometrySplitterTest.cpp
@@ -606,13 +606,11 @@ void object::test<49>()
-#if 0
template<>
template<>
void object::test<50>()
set_test_name("split CircularString with point");
- // not implemented yet: need curve support in DistanceOp
testSplit("CIRCULARSTRING (-5 0, -4 3, 4 3)",
"POINT (0 5)",
@@ -624,18 +622,27 @@ template<>
void object::test<51>()
set_test_name("split CompoundCurve with point on curve");
testSplit("COMPOUNDCURVE(CIRCULARSTRING (-5 0, -4 3, 4 3), (4 3, 0 0))",
"POINT (0 5)",
- "GEOMETRYCOLLECTION (CIRCULARSTRING (-5 0, -3.5355339059327373 3.5355339059327378, 0 5), CIRCULARSTRING (0 5, 2.2360679774997902 4.47213595499958, 4 3))");
+ "GEOMETRYCOLLECTION (CIRCULARSTRING (-5 0, -3.5355339059327373 3.5355339059327378, 0 5), COMPOUNDCURVE(CIRCULARSTRING (0 5, 2.2360679774997902 4.47213595499958, 4 3), (4 3, 0 0)))");
+template<>
+template<>
+void object::test<52>()
+ set_test_name("split CompoundCurve with point on line");
+ testSplit("COMPOUNDCURVE(CIRCULARSTRING (-5 0, -4 3, 4 3), (4 3, 0 0))",
+ "POINT (2 1.5)",
+ "GEOMETRYCOLLECTION (COMPOUNDCURVE( CIRCULARSTRING (-5 0, -4 3, 4 3), (4 3, 2 1.5)), LINESTRING (2 1.5, 0 0))");
-#endif
#if 0
template<>
template<>
-void object::test<52>()
+void object::test<53>()
set_test_name("nearly-collapsed Polygon (QGIS test #1)");
// void TestQgsGeometry::splitGeometry()
@@ -651,7 +658,7 @@ void object::test<52>()
template<>
template<>
-void object::test<53>()
+void object::test<54>()
set_test_name("Z values of split edge are not used in interpolation; QGIS test #2");
// See https://github.com/qgis/QGIS/issues/33489
@@ -663,7 +670,7 @@ void object::test<53>()
template<>
template<>
-void object::test<54>()
+void object::test<55>()
set_test_name("split CompoundCurve at an existing vertex; QGIS test #3");
@@ -674,7 +681,7 @@ void object::test<54>()
template<>
template<>
-void object::test<55>()
+void object::test<56>()
set_test_name("Split self-intersecting LineString at points; adaptation of QGIS test #4");
@@ -687,7 +694,7 @@ void object::test<55>()
#if 0
template<>
template<>
-void object::test<56>()
+void object::test<57>()
set_test_name("do not split on self-intersections; QGIS test #4");
@@ -705,7 +712,7 @@ void object::test<56>()
template<>
template<>
-void object::test<57>()
+void object::test<58>()
set_test_name("do not split on self-intersections; QGIS test #5");
@@ -717,7 +724,7 @@ void object::test<57>()
template<>
template<>
-void object::test<58>()
+void object::test<59>()
set_test_name("split LineString Z on existing vertex; QGIS test #6");
@@ -729,7 +736,7 @@ void object::test<58>()
template<>
template<>
-void object::test<59>()
+void object::test<60>()
// Should not crash - https://github.com/qgis/QGIS/issues/50948
testSplit("LINESTRING ( -63294.10966012725839391 -79156.27234554117603693, -63290.25259721937618451 -79162.78533450335089583, -63290.25259721936890855 -79162.78533450335089583)",
@@ -739,7 +746,7 @@ void object::test<59>()
template<>
template<>
-void object::test<60>()
+void object::test<61>()
// Should not split the first part - https://github.com/qgis/QGIS/issues/54155
testSplit("MULTILINESTRING((0 1, 1 0), (0 2, 2 0))",
@@ -749,7 +756,7 @@ void object::test<60>()
template<>
template<>
-void object::test<61>()
+void object::test<62>()
set_test_name("cannot split Polygon with point");
@@ -761,7 +768,7 @@ void object::test<61>()
template<>
template<>
-void object::test<62>()
+void object::test<63>()
set_test_name("cannot split CurvePolygon with point");
@@ -771,4 +778,37 @@ void object::test<62>()
ensure_THROW(GeometrySplitter::split(*geom, *splitGeom), geos::util::IllegalArgumentException);
+template<>
+template<>
+void object::test<64>()
+ set_test_name("split LineString with disjoint point");
+ testSplit("LINESTRING (0 0, 10 0)",
+ "POINT (5 1)",
+ "GEOMETRYCOLLECTION (LINESTRING (0 0, 10 0))");
+template<>
+template<>
+void object::test<65>()
+ set_test_name("split LineString with empty point");
+ "POINT EMPTY",
+template<>
+template<>
+void object::test<66>()
+ set_test_name("split LineString with invalid point");
+ "POINT (6 NaN)",
diff --git a/tests/unit/operation/split/SplitGeometryAtVertexTest.cpp b/tests/unit/operation/split/SplitGeometryAtVertexTest.cpp
index 59af695d2..000000000
--- a/tests/unit/operation/split/SplitGeometryAtVertexTest.cpp
+++ /dev/null
@@ -1,139 +0,0 @@
-#include <tut/tut.hpp>
-#include <tut/tut_macros.hpp>
-#include <utility.h>
-#include <geos/io/WKTReader.h>
-using geos::operation::split::SplitGeometryAtVertex;
-namespace tut {
-struct test_splitgeometryatvertex_data {
- const geos::io::WKTReader reader_;
-typedef test_group<test_splitgeometryatvertex_data, 255> group;
-typedef group::object object;
-group test_splitgeometryatvertextest_group("geos::operation::split::SplitGeometryAtVertex");
-template<>
-template<>
-void object::test<1>()
- set_test_name("Split LineString ZM at vertex");
- auto input = reader_.read<LineString>("LINESTRING ZM (0 3 2 3, 5 8 3 4, 2 2 4 5, 6 1 5 6)");
- auto splitAtStart = SplitGeometryAtVertex::splitSimpleCurveAtVertex(*input, 0);
- ensure(splitAtStart.first->isEmpty());
- ensure(splitAtStart.first->hasZ());
- ensure(splitAtStart.first->hasM());
- ensure(splitAtStart.second->equalsIdentical(input.get()));
- auto splitAtEnd = SplitGeometryAtVertex::splitSimpleCurveAtVertex(*input, input->getNumPoints() - 1);
- ensure(splitAtEnd.first->equalsIdentical(input.get()));
- ensure(splitAtEnd.second->isEmpty());
- ensure(splitAtEnd.second->hasZ());
- ensure(splitAtEnd.second->hasM());
- auto splitInMiddle = SplitGeometryAtVertex::splitSimpleCurveAtVertex(*input, 2);
- auto expectedFirst = reader_.read("LINESTRING ZM (0 3 2 3, 5 8 3 4, 2 2 4 5)");
- auto expectedSecond = reader_.read("LINESTRING ZM (2 2 4 5, 6 1 5 6)");
- ensure(splitInMiddle.first->equalsIdentical(expectedFirst.get()));
- ensure(splitInMiddle.second->equalsIdentical(expectedSecond.get()));
-template<>
-template<>
-void object::test<2>()
- set_test_name("Split CircularString ZM at vertex");
- auto input = reader_.read<CircularString>("CIRCULARSTRING ZM (-5 0 1 2, 0 5 2 3, 5 0 3 4, 10 -5 4 5, 15 0 5 6)");
- auto expectedFirst = reader_.read("CIRCULARSTRING ZM (-5 0 1 2, 0 5 2 3, 5 0 3 4)");
- auto expectedSecond = reader_.read("CIRCULARSTRING ZM (5 0 3 4, 10 -5 4 5, 15 0 5 6)");
- ensure_THROW(SplitGeometryAtVertex::splitSimpleCurveAtVertex(*input, 1), geos::util::IllegalArgumentException);
-template<>
-template<>
-void object::test<3>()
- set_test_name("Split LineString ZM at new point");
- CoordinateXY pt{2, 3};
- ensure_THROW(SplitGeometryAtVertex::splitLineStringAtPoint(*input, 3, pt), geos::util::IllegalArgumentException);
- // Split first segment
- auto [first, second] = SplitGeometryAtVertex::splitLineStringAtPoint(*input, 0, pt);
- auto expectedFirst = reader_.read("LINESTRING ZM (0 3 2 3, 2 3 2.282842712474619 3.282842712474619)");
- auto expectedSecond = reader_.read("LINESTRING ZM (2 3 2.282842712474619 3.282842712474619, 5 8 3 4, 2 2 4 5, 6 1 5 6)");
- ensure_equals_exact_geometry_xyzm(first.get(), expectedFirst.get(), 0.0);
- ensure_equals_exact_geometry_xyzm(second.get(), expectedSecond.get(), 0.0);
- // Split second segment
- auto [first, second] = SplitGeometryAtVertex::splitLineStringAtPoint(*input, 1, pt);
- auto expectedFirst = reader_.read("LINESTRING ZM (0 3 2 3, 5 8 3 4, 2 3 3.8692269873603533 4.869226987360353)");
- auto expectedSecond = reader_.read("LINESTRING ZM (2 3 3.8692269873603533 4.869226987360353, 2 2 4 5, 6 1 5 6)");
diff --git a/tests/unit/operation/split/SplitLinealAtPointTest.cpp b/tests/unit/operation/split/SplitLinealAtPointTest.cpp
index 000000000..8bf29cff7
--- /dev/null
+++ b/tests/unit/operation/split/SplitLinealAtPointTest.cpp
@@ -0,0 +1,243 @@
+#include <tut/tut.hpp>
+#include <tut/tut_macros.hpp>
+#include <utility.h>
+#include <geos/io/WKTReader.h>
+using geos::operation::split::SplitLinealAtPoint;
+namespace tut {
+struct test_splitlinealatpoint_data {
+ const geos::io::WKTReader reader_;
+typedef test_group<test_splitlinealatpoint_data, 255> group;
+typedef group::object object;
+group test_splitlinealatpointtest_group("geos::operation::split::SplitLinealAtPoint");
+template<>
+template<>
+void object::test<1>()
+ set_test_name("Split LineString ZM at vertex");
+ auto input = reader_.read<LineString>("LINESTRING ZM (0 3 2 3, 5 8 3 4, 2 2 4 5, 6 1 5 6)");
+ auto splitAtStart = SplitLinealAtPoint::splitSimpleCurveAtVertex(*input, 0);
+ ensure(splitAtStart.first->isEmpty());
+ ensure(splitAtStart.first->hasZ());
+ ensure(splitAtStart.first->hasM());
+ ensure(splitAtStart.second->equalsIdentical(input.get()));
+ auto splitAtEnd = SplitLinealAtPoint::splitSimpleCurveAtVertex(*input, input->getNumPoints() - 1);
+ ensure(splitAtEnd.first->equalsIdentical(input.get()));
+ ensure(splitAtEnd.second->isEmpty());
+ ensure(splitAtEnd.second->hasZ());
+ ensure(splitAtEnd.second->hasM());
+ auto splitInMiddle = SplitLinealAtPoint::splitSimpleCurveAtVertex(*input, 2);
+ auto expectedFirst = reader_.read("LINESTRING ZM (0 3 2 3, 5 8 3 4, 2 2 4 5)");
+ auto expectedSecond = reader_.read("LINESTRING ZM (2 2 4 5, 6 1 5 6)");
+ ensure(splitInMiddle.first->equalsIdentical(expectedFirst.get()));
+ ensure(splitInMiddle.second->equalsIdentical(expectedSecond.get()));
+template<>
+template<>
+void object::test<2>()
+ set_test_name("Split CircularString ZM at vertex");
+ auto input = reader_.read<CircularString>("CIRCULARSTRING ZM (-5 0 1 2, 0 5 2 3, 5 0 3 4, 10 -5 4 5, 15 0 5 6)");
+ auto expectedFirst = reader_.read("CIRCULARSTRING ZM (-5 0 1 2, 0 5 2 3, 5 0 3 4)");
+ auto expectedSecond = reader_.read("CIRCULARSTRING ZM (5 0 3 4, 10 -5 4 5, 15 0 5 6)");
+ ensure_THROW(SplitLinealAtPoint::splitSimpleCurveAtVertex(*input, 1), geos::util::IllegalArgumentException);
+template<>
+template<>
+void object::test<3>()
+ set_test_name("Split LineString ZM at new point");
+ CoordinateXY pt{2, 3};
+ ensure_THROW(SplitLinealAtPoint::splitLineStringAtPoint(*input, 3, pt), geos::util::IllegalArgumentException);
+ // Split first segment
+ auto [first, second] = SplitLinealAtPoint::splitLineStringAtPoint(*input, 0, pt);
+ auto expectedFirst = reader_.read("LINESTRING ZM (0 3 2 3, 2 3 2.282842712474619 3.282842712474619)");
+ auto expectedSecond = reader_.read("LINESTRING ZM (2 3 2.282842712474619 3.282842712474619, 5 8 3 4, 2 2 4 5, 6 1 5 6)");
+ ensure_equals_exact_geometry_xyzm(first.get(), expectedFirst.get(), 0.0);
+ ensure_equals_exact_geometry_xyzm(second.get(), expectedSecond.get(), 0.0);
+ // Split second segment
+ auto [first, second] = SplitLinealAtPoint::splitLineStringAtPoint(*input, 1, pt);
+ auto expectedFirst = reader_.read("LINESTRING ZM (0 3 2 3, 5 8 3 4, 2 3 3.8692269873603533 4.869226987360353)");
+ auto expectedSecond = reader_.read("LINESTRING ZM (2 3 3.8692269873603533 4.869226987360353, 2 2 4 5, 6 1 5 6)");
+template<>
+template<>
+void object::test<4>()
+ set_test_name("Split CompoundCurve ZM at existing vertices");
+ auto input = reader_.read<geos::geom::CompoundCurve>("COMPOUNDCURVE ZM(CIRCULARSTRING ZM(2 8 1 2, 4 7 3 4, 1 9 5 6, 3 15 7 8, 8 16 9 10), (8 16 9 10, 8 10 11 12, 6 14 13 14, 4 12 15 16), CIRCULARSTRING (4 12 15 16, 4 10 17 18, 2 8 19 20))");
+ // Split at first point
+ auto [first, second] = SplitLinealAtPoint::splitCompoundCurveAtPoint(*input, 0, 0, CoordinateXY{2, 8});
+ ensure(first->isEmpty());
+ ensure(second->equalsIdentical(input.get()));
+ // Split at intermediate point of first curve
+ auto [first, second] = SplitLinealAtPoint::splitCompoundCurveAtPoint(*input, 0, 2, CoordinateXY{1, 9});
+ auto expectedFirst = reader_.read("CIRCULARSTRING ZM (2 8 1 2, 4 7 3 4, 1 9 5 6)");
+ auto expectedSecond = reader_.read("COMPOUNDCURVE ZM (CIRCULARSTRING ZM(1 9 5 6, 3 15 7 8, 8 16 9 10), (8 16 9 10, 8 10 11 12, 6 14 13 14, 4 12 15 16), CIRCULARSTRING (4 12 15 16, 4 10 17 18, 2 8 19 20))");
+ // Split at last point of first curve
+ auto [first, second] = SplitLinealAtPoint::splitCompoundCurveAtPoint(*input, 0, 2, CoordinateXY{8, 16});
+ ensure(first->equalsIdentical(input->getCurveN(0)));
+ auto expectedSecond = reader_.read("COMPOUNDCURVE ZM ((8 16 9 10, 8 10 11 12, 6 14 13 14, 4 12 15 16), CIRCULARSTRING (4 12 15 16, 4 10 17 18, 2 8 19 20))");
+ // Split at first point of second curve
+ auto [first, second] = SplitLinealAtPoint::splitCompoundCurveAtPoint(*input, 1, 0, CoordinateXY{8, 16});
+ // Split at intermate point of second curve
+ auto [first, second] = SplitLinealAtPoint::splitCompoundCurveAtPoint(*input, 1, 1, CoordinateXY{6, 14});
+ auto expectedFirst = reader_.read("COMPOUNDCURVE ZM (CIRCULARSTRING ZM(2 8 1 2, 4 7 3 4, 1 9 5 6, 3 15 7 8, 8 16 9 10), (8 16 9 10, 8 10 11 12, 6 14 13 14))");
+ auto expectedSecond = reader_.read("COMPOUNDCURVE ((6 14 13 14, 4 12 15 16), CIRCULARSTRING (4 12 15 16, 4 10 17 18, 2 8 19 20))");
+ // Split at last point of second curve
+ auto [first, second] = SplitLinealAtPoint::splitCompoundCurveAtPoint(*input, 1, 3, CoordinateXY{4, 12});
+ auto expectedFirst = reader_.read("COMPOUNDCURVE (CIRCULARSTRING(2 8 1 2, 4 7 3 4, 1 9 5 6, 3 15 7 8, 8 16 9 10), (8 16 9 10, 8 10 11 12, 6 14 13 14, 4 12 15 16))");
+ ensure(second->equalsIdentical(input->getCurveN(2)));
+ // Split at first point of third curve
+ auto [first, second] = SplitLinealAtPoint::splitCompoundCurveAtPoint(*input, 2, 0, CoordinateXY{4, 12});
+ // Split at last point of third curve
+ auto [first, second] = SplitLinealAtPoint::splitCompoundCurveAtPoint(*input, 2, 2, CoordinateXY{2, 8});
+ ensure(first->equalsIdentical(input.get()));
+ ensure(second->isEmpty());
+template<>
+template<>
+void object::test<5>()
+ set_test_name("Split CompoundCurve ZM at new point");
+ auto [first, second] = SplitLinealAtPoint::splitCompoundCurveAtPoint(*input, 0, 2, CoordinateXY{5, 16});
+ auto expectedFirst = reader_.read("CIRCULARSTRING ZM (2 8 1 2, 4 7 3 4, 1 9 5 6, 1.5502525316941682 13.328427124746192 6.33570524800221 7.33570524800221, 5 16 7.851489605544531 8.851489605544531)");
+ auto expectedSecond = reader_.read("COMPOUNDCURVE ZM (CIRCULARSTRING ZM (5 16 7.851489605544531 8.851489605544531, 6.5 16.20087712549569 8.425744802772266 9.425744802772266, 8 16 9 10), (8 16 9 10, 8 10 11 12, 6 14 13 14, 4 12 15 16), CIRCULARSTRING ZM (4 12 15 16, 4 10 17 18, 2 8 19 20)) ");
Summary of changes:
include/geos/algorithm/CircularArcs.h | 21 +-
include/geos/geom/SimpleCurve.h | 2 +
include/geos/operation/split/GeometrySplitter.h | 6 +-
.../geos/operation/split/SplitGeometryAtVertex.h | 48 ----
include/geos/operation/split/SplitLinealAtPoint.h | 90 ++++++++
include/geos/util/Assert.h | 7 +
src/algorithm/CircularArcIntersector.cpp | 110 +--------
src/algorithm/CircularArcs.cpp | 107 +++++++++
src/geom/CircularArc.cpp | 1 +
src/geom/CompoundCurve.cpp | 4 +-
src/geom/SimpleCurve.cpp | 6 +
src/noding/NodableArcString.cpp | 2 +
src/operation/split/GeometrySplitter.cpp | 56 +++--
src/operation/split/SplitGeometryAtVertex.cpp | 123 ----------
src/operation/split/SplitLinealAtPoint.cpp | 252 +++++++++++++++++++++
.../unit/operation/split/GeometrySplitterTest.cpp | 72 ++++--
.../operation/split/SplitGeometryAtVertexTest.cpp | 139 ------------
.../operation/split/SplitLinealAtPointTest.cpp | 243 ++++++++++++++++++++
18 files changed, 830 insertions(+), 459 deletions(-)
delete mode 100644 include/geos/operation/split/SplitGeometryAtVertex.h
create mode 100644 include/geos/operation/split/SplitLinealAtPoint.h
delete mode 100644 src/operation/split/SplitGeometryAtVertex.cpp
create mode 100644 src/operation/split/SplitLinealAtPoint.cpp
delete mode 100644 tests/unit/operation/split/SplitGeometryAtVertexTest.cpp
create mode 100644 tests/unit/operation/split/SplitLinealAtPointTest.cpp
hooks/post-receive
More information about the geos-commits
