[geos-commits] [SCM] GEOS branch main updated. cf859843556dd76e9597c588543915b7aa7d7bc4
Mon May 4 14:32:21 PDT 2026
the project "GEOS".
The branch, main has been updated
       via  cf859843556dd76e9597c588543915b7aa7d7bc4 (commit)
      from  0028dd486e18abb779d3c1d1dfeb1a3f34e4af5c (commit)
revisions in full, below.
commit cf859843556dd76e9597c588543915b7aa7d7bc4
Author: MUGUNDAN <mugunthan.selvanayagam at multicorewareinc.com>
Date:   Mon May 4 17:31:58 2026 -0400
    Fix GEOS benchmarking on Windows (#1429)
    * Fix GEOS benchmarking on Windows
    * Add instructions for benchmarking Geos library
diff --git a/benchmarks/README.md b/benchmarks/README.md
index 65eb4b4f9..760815be6 100644
--- a/benchmarks/README.md
+++ b/benchmarks/README.md
@@ -1,10 +1,64 @@
-## Benchmarks
+## Building
-A variety of programs to execute various kinds of tests,
-including benchmarks, stability and robustness tests.
+Building the benchmark tests must be enabled using:
-### Building
+```bash
+cmake -DBUILD_BENCHMARKS=ON ..
-Building the benchmark tests must be enabled using
+Geos uses Google Benchmarks for validating performance of Geos library. It can be built using the following ways:
-    cmake -DBUILD_BENCHMARKS=ON ..
+### Linux
+Install via package manager:
+```bash
+# Debian/Ubuntu
+sudo apt install libbenchmark-dev
+# Fedora
+sudo dnf install google-benchmark-devel
+Then build:
+```bash
+mkdir build && cd build
+make -j$(nproc)
+### Windows (MSYS2)
+Install Google Benchmark via pacman:
+```bash
+# MINGW64
+pacman -S mingw-w64-x86_64-benchmark
+# UCRT64
+pacman -S mingw-w64-ucrt-x86_64-benchmark
+# CLANG64
+pacman -S mingw-w64-clang-x86_64-benchmark
+# CLANGARM64
+pacman -S mingw-w64-clang-aarch64-benchmark
+Then build:
+```bash
+cmake -G "MinGW Makefiles" -DBUILD_BENCHMARKS=ON ..
+mingw32-make -j$(nproc)
+### Windows (MSVC / vcpkg)
+```bash
+vcpkg install benchmark:x64-windows
+cmake -DBUILD_BENCHMARKS=ON -DCMAKE_TOOLCHAIN_FILE=$VCPKG_ROOT/scripts/buildsystems/vcpkg.cmake ..
+cmake --build . --config Release
diff --git a/benchmarks/algorithm/CMakeLists.txt b/benchmarks/algorithm/CMakeLists.txt
index 3b8f867a5..6e8382307 100644
--- a/benchmarks/algorithm/CMakeLists.txt
+++ b/benchmarks/algorithm/CMakeLists.txt
@@ -29,7 +29,7 @@ if (benchmark_FOUND)
             $<BUILD_INTERFACE:${PROJECT_SOURCE_DIR}/include>
             $<BUILD_INTERFACE:${PROJECT_BINARY_DIR}/include>)
     target_link_libraries(perf_orientation PRIVATE
-            benchmark::benchmark geos_cxx_flags)
+            benchmark::benchmark geos)
     add_executable(perf_line_intersector LineIntersectorPerfTest.cpp)
     target_include_directories(perf_line_intersector PUBLIC
diff --git a/benchmarks/algorithm/OrientationIndexStressTest.cpp b/benchmarks/algorithm/OrientationIndexStressTest.cpp
index 24e19677f..c4c6f7246 100644
--- a/benchmarks/algorithm/OrientationIndexStressTest.cpp
+++ b/benchmarks/algorithm/OrientationIndexStressTest.cpp
@@ -43,6 +43,11 @@ Two kinds of test generators are provided:
 #include <iomanip>
+// MSVC does not provide POSIX random(), Use rand() for compatibility
+#ifdef _MSC_VER
+#define random rand
+#endif
 using namespace geos::algorithm;
 using namespace geos::geom;
 using namespace geos::io;
diff --git a/include/geos/index/intervalrtree/IntervalRTreeLeafNode.h b/include/geos/index/intervalrtree/IntervalRTreeLeafNode.h
index b0c3692a9..5dee32cc6 100644
--- a/include/geos/index/intervalrtree/IntervalRTreeLeafNode.h
+++ b/include/geos/index/intervalrtree/IntervalRTreeLeafNode.h
@@ -15,6 +15,7 @@
 #pragma once
+#include <geos/export.h>
 #include <geos/index/intervalrtree/IntervalRTreeNode.h> // inherited
@@ -30,7 +31,7 @@ namespace geos {
 namespace index {
 namespace intervalrtree {
-class IntervalRTreeLeafNode : public IntervalRTreeNode {
+class GEOS_DLL IntervalRTreeLeafNode : public IntervalRTreeNode {
 private:
     /// externally owned
     void* item;
diff --git a/include/geos/index/intervalrtree/SortedPackedIntervalRTree.h b/include/geos/index/intervalrtree/SortedPackedIntervalRTree.h
index ec472613e..b97623023 100644
--- a/include/geos/index/intervalrtree/SortedPackedIntervalRTree.h
+++ b/include/geos/index/intervalrtree/SortedPackedIntervalRTree.h
@@ -15,6 +15,7 @@
 #pragma once
 #include <geos/index/intervalrtree/IntervalRTreeBranchNode.h>
 #include <geos/index/intervalrtree/IntervalRTreeLeafNode.h>
@@ -48,7 +49,7 @@ namespace intervalrtree {
  * @author Martin Davis
-class SortedPackedIntervalRTree {
+class GEOS_DLL SortedPackedIntervalRTree {
 private:
     std::vector<IntervalRTreeLeafNode> leaves;
     std::vector<IntervalRTreeBranchNode> branches;
Summary of changes:
 benchmarks/README.md                               | 66 ++++++++++++++++++++--
 benchmarks/algorithm/CMakeLists.txt                |  2 +-
 .../algorithm/OrientationIndexStressTest.cpp       |  5 ++
 .../index/intervalrtree/IntervalRTreeLeafNode.h    |  3 +-
 .../intervalrtree/SortedPackedIntervalRTree.h      |  3 +-
 5 files changed, 70 insertions(+), 9 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
